REVISION BG
DO NOT
SCALE FROM
THIS PRINT
NOTES:
ESW-1XX-XX-X-X-XX-XX
1. C REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM CONTACT PUSHOUT FORCE: 0.5 LB.
3. MAXIMUM ALLOWABLE BOW .003[0.08] IN/IN AFTER ASSEMBLY.
4. FOR A 1 POSITION SINGLE ROW ALL SPACERS ARE TO BE LBS-S.
5. NOTE DELETED.
6. SINGLE ROW, 33 POS PART TO USE 31 POS AND 2 POS SPACERS.
7. MAXIMUM CUT FLASH: .015.
8. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING
EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM
CONTACT STYLE
SOLDER TAIL
STANDARD INSERTION USE C-8-X-X
LOW INSERTION USE C-17-X-X
(SEE TABLE 1)
C
LEAD STYLE SPECIFICATION
(SEE TABLE 1)
.095 2.41 REF
SUB-SSB-32
(SEE NOTE 4)
C
LBS-36-S
"D"±.010[0.25]
CONTACT
"B"±.010[0.25]
C
01
2 MAX SWAY
(EITHER DIRECTION)
36
2 MAX SWAY
(EITHER DIRECTION)
.031 0.79 x .016[0.41] REF
+.005[0.13]
(NO OF POS x .100[2.54]) -.015[0.38]
PLATING SPECIFICATION
-G: 20µ" SELECTIVE GOLD IN CONTACT AREA,
3µ" SELECTIVE GOLD ON TAIL.
-T: MATTE TIN ON ENTIRE PIN.
(STANDARD INSERTION FORCE ONLY)
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
-H: 30µ" SELECTIVE GOLD IN CONTACT AREA,
-F: 3µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
-E: 50µ" SELECTIVE GOLD IN CONTACT AREA,
-L: 10µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL.
SSW-XX-X
"C" REF
LOCKING LEAD OPTION
-LL (SEE FIG 4, SHT 2)
(N/A ON 1 OR 2
POSITION SINGLE ROW)
ROW SPECIFICATION
-S: SINGLE (USE SSW-50-S)
-D: DOUBLE (USE SSW-50-D)
BODY LENGTH SPEC
POSITIONS 01 THRU 36 (SEE FIG 1)
(SEE NOTE 4 FOR ONE POSITION
SINGLE ROW)
(FOR 33 POS, SEE NOTE 6)
(NO OF POS x .100[2.54]+.020[.51]) .010[0.25]
.100 2.54 REF
POLARIZING OPTION
INDICATES POS
(SEE FIG 3, SHT 2)
+.005[0.13]
72
(NO OF POS x .100[2.54]+ .009[0.23]) -.015[0.38]
(ONLY FOR SUB-SSB-32)
.195 4.95
REF
.100 2.54 REF
FIG 1
01
ESW-1XX-XX-X-S SHOWN
DSB-XX
ESW-XX-D
FIG 2
ESW-1XX-XX-X-D SHOWN
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0020 [.051]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SSW: LCP, UL 94 VO, COLOR: BLACK
SSB, ESS, DSB: PBT, UL 94 V0, COLOR: BLACK
LBS: HTN, UL 94 V0, COLOR: BLACK
CONTACT: PHOS BRONZE
F:\DWG\MISC\MKTG\ESW-1XX-XX-X-X-XX-XX-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
DWG. NO.
ESW STRIP ASM.
BY: JORDAN
07/16/1985
SHEET 1 OF 2
REVISION BG
.272 6.91 REF
PK-06-N
72
PK-06-N
02
.04 0.9
+.005
+0.13
0.00
.008 - .000 0.20
01
36
71
01
FIG 3
POLARIZATION LOCATION
INSERT PK-06-N INTO SPECIFIED POS AND BREAK OFF TAB
(ESW-1XX-XX-X-X-02 SHOWN)
(SAME AS FIG 1, DIFFERENT AS SHOWN)
"B"±.010[0.25]
(TYP)
FIG 5
FIG 4
IN PROCESS 'A'
(LEAD STYLES -13, -14, -23, -24, -33, -34,
-44, -38, -39, -48, -49, -58, -59, -69)
LOCKING LEAD OPTION
LOCATED ON OR ABOUT THE CENTERLINE
(N/A IN 1 OR 2 POSITION SINGLE ROW)
"C" REF
"D"±.010[0.27]
"B" + "E"
"B"±.010[0.27]
STEP 1
STEP 2
STEPS:
1. MACHINE FILL SSW-50-D TO 36 POS.
2. MOUNT ESW-36-D.
3. ROTO CUT TO POS. (SEE FIG 1)
FIG 7
TUBE VIEWS
NOTE:
FOR -12 & -37 LEAD STYLES, TUBE PACKAGE -05 THRU -36
POSITIONS ONLY
FOR -13, -23, -33, -38, -48 & -58 LEAD STYLES, TUBE PACKAGE
-08 THRU -36 POSITIONS ONLY.
FOR -14, -24, -34, -39, -44, -49, -59, & -69 LEAD STYLES TUBE
PACKAGE -05 THRU -36 POSITIONS ONLY.
PROPRIETARY NOTE
FIG 6
IN PROCESS 'B'
(LEAD STYLES -12 & -37)
SHEET SCALE: 3:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
ESW STRIP ASM.
BY: JORDAN
07/16/1985
SHEET 2 OF 2
