SFH11-PBPC-D04-ST-BK
    SULLINS
    CONNHEADER.100"8POS
SFH11-PBPC-D04-ST-BK 数据手册
Headers .100” [2.54 mm] Contact Centers, Female Headers, Straight/Right Angle - SFH11 Series Mates with SBH11 series (See opposite page) SPECIFICATIONS • Centered Polarizing Key Optional • Operating Temperature: -40°C to +105°C • Processing Temperature: 230°C Max. for 60 seconds, (260°C Max. for 10 seconds) • UL Flammability Rating: 94V-0 • Contact Resistance: 20 milli Ohms Max. • Current Rating: 3 Amps • Dielectric Withstanding: 1000 VAC • Insulation Resistance: 5000 Megohms Min. PART NUMBER OPTIONS SFH11 - P P P C - D 10 - ST - BK - M181 SERIES SFH11 = Female Header, .100” [2.54 mm] Contact Centers by .100” [2.54 mm] Row Spacing INSULATOR MATERIAL P = PBT N = NYLON CONTACT MATERIAL P = Phosphor Bronze B = Brass MODIFICATION (Omit for Standard) M181 = Without Centered Polarizing Key COLOR BK = Black TERMINATION TYPE (Opposite Page) ST = Straight RA = Right Angle CONTACT FINISH - RoHS Compliant P = Gold Flash Overall E = .000100” Pure Tin, Matte, Overall NUMBER OF CONTACT POSITIONS 03 thru 08,10,12, 13, 15,17, 20, 25, 30, 32 Headers NUMBER OF ROWS D = Dual Row CONTACT CENTERS C = .100” [2.54 mm] DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com Dimensions in [ ] are in millimeters, all others are in inches. .276[7.00] .236[6.00] .100[2.54] .126[3.20] .016[0.40] .100[2.54] .039[1.00] .100[2.54] STRAIGHT (ST) Example P/N: SFH11-PPPC-D20-ST-BK -M181 Modification (No Centered Polarizing Key) Centered Polarizing Key Optional, Requires -M181 Modification to Remove .335 [8.50] .276[7.00] .236[6.00] .398[10.10] .100[2.54] .106[2.70] .016[0.40] .024[0.60] -M181 Modification (No Centered Polarizing Key) RIGHT ANGLE (RA) Example P/N: SFH11-PPPC-D20-RA-BK www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 119
- 物料型号:SFH11系列,具体型号为SFH11-PPPC-D10-ST-BK和SFH11-PPPC-D20-RA-BK。 - 器件简介:这些是2.54mm接触中心的女性连接器,具有可选的中心极化键。 - 引脚分配:文档中未明确提供引脚分配图,但提到了不同行数和接触位置的选项。 - 参数特性: - 操作温度范围:-40°C至+105°C - 加工温度:最高230°C持续60秒,或最高260°C持续10秒 - UL阻燃等级:94V-0 - 接触电阻:最大20毫欧姆 - 电流额定值:3安培 - 介质耐压:1000V交流电 - 绝缘电阻:最小5000兆欧姆 - 功能详解:文档中未提供详细的功能解释,但提到了中心极化键的可选性,以及如何通过-M181修改去除它。 - 应用信息:适用于需要2.54mm间距连接器的应用,文档建议访问www.sullinscorp.com或联系技术支持以获取更多信息。 - 封装信息:提供了直插式(ST)和直角型(RA)两种封装选项,以及尺寸信息。
SFH11-PBPC-D04-ST-BK 价格&库存
很抱歉,暂时无法提供与“SFH11-PBPC-D04-ST-BK”相匹配的价格&库存,您可以联系我们找货
