SFM230-NPPN-S02-SD-BK
    SULLINS
    CONNHEADER.079"2POS
SFM230-NPPN-S02-SD-BK 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2399 INITIAL RELEASE 07/20/2011 GC F F .020 0.50 PIN 1 E E .157 [4.00] SFM230-NPPN-S_ _-SC-BK (STANDARD) A .157 [4.00] PIN 1 D .020 0.50 .039 [1.00] (NOT REQ'D FOR USE AS TOP ENTRY) PIN 1 RECOMMENDED PCB LAYOUT SFM230-NPPN-S_ _-SC-BK (OPPOSITE BEND, APPLICABLE ON EVEN PIN COUNTS) C C .037 0.95 REF B .091 2.30 .079 [2.00] .091 2.30 .079 [2.00] .118 [3.00] A 8 7 6 .004 [0.10] .008 0.20 .079 [2.00] .031 0.80 NOTES: 1. INSULATOR MATERIAL: NYLON 6T, UL 94V-0, BLACK. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: .000030" ~ .000050"NICKEL UNDERPLATE, GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMPS PER CONTACT. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 500 V AC. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. PROCESSING TEMP.: 230° C FOR 60 SECONDS MAX. (260° C FOR 10 SECONDS) (INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME.) 10. FOR TOP/BOTTOM ENTRY. 11. CONSULT FACTORY FOR THE MATE IF BEING USED AS BOTTOM ENTRY. .055 1.40 .079 [2.00] SFM230-NPPN-S_ _-SD-BK A D .157 [4.00] .031 0.80 B .157 [4.00] .055 1.40 .039 [1.00] B (NOT REQ'D FOR USE AS TOP ENTRY) .157 [4.00] .157 [4.00] PIN 1 A RECOMMENDED PCB LAYOUT SFM230-NPPN-S_ _-SD-BK DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .012 [0.30] .XXX= .008 [0.20] .XXXX= .0040 [0.100] RoHS COMPLIANT 5 4 INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 07/20/11 GC THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER FEMALE, .079 CC, T/B ENTRY PART NUMBER SIZE C 54453 SCALE: 4:1 2 SFM230-NPPN-S_ _-S_-BK, CAGE CODE DWG. NO. 11814 SHEET 1 OF 1 1 REV A FILE NAME: 11814, SFM230-NPPN-S_ _-S_-BK A
SFM230-NPPN-S02-SD-BK 价格&库存
很抱歉,暂时无法提供与“SFM230-NPPN-S02-SD-BK”相匹配的价格&库存,您可以联系我们找货
