Bridgelux® V6 Array
Product Data Sheet DS40
BXRE-27x0400 | 30x0400 | 35x0400 | 40x0400 | 50x0400
V Series
Introduction
The V Series LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package.
These Chip-on-Board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility
not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost
directional luminaires and replacement lamps for commercial and residential applications.
The V6 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility
and energy efficiencies.
Lighting system designs incorporating these LED Arrays deliver comparable performance to 7-13 Watt compact
fluorescent and 25 - 50 Watt incandescent and halogen based luminaires, delivering increased system level efficacy and
longer service life. Typical applications include, but are not limited to, replacement lamps, task, accent, spot, track, down
light, wide area, security, and wall pack.
Features
Efficacy of 130 lm/W typical
Compact high flux density light source
Uniform high quality illumination
Minimum 70, 80 and 90 CRI options
Streamlined thermal path
Energy Star / ANSI compliant color binning structure
with 3SDCM and 4SDCM options
Benefits
More energy efficient than incandescent, halogen and
Low voltage DC operation
Instant light with unlimited dimming
Clean white light without pixilation
High quality true color reproduction
Significantly reduced thermal resistance and
increased operating temperatures
fluorescent lamps
Enhanced optical control
Uniform consistent white light
Lower operating costs
Easy to use with daylight and motion detectors to
enable increased energy savings
Reduced maintenance costs
Environmentally friendly, no disposal issue
Contents
Product Feature Map
2
Product Nomenclature
2
Product Selection Guide
3
Performance at Commonly Used Drive Currents
4
Electrical Characteristics
7
Absolute Maximum Ratings
8
Performance Curves
9
Typical Radiation Pattern
13
Typical Color Spectrum
14
Mechanical Dimensions
15
Color Binning Information
16
Packaging and Labeling
17
Design Resources
19
Precautions
19
Disclaimers
19
About Bridgelux
Product Feature Map
Bridgelux arrays are fully engineered devices that provide
consistent thermal and optical performance on an
engineered mechanical platform. The V Series arrays are
the most compact chip-on-board devices across all of
Bridgelux’s LED Array products. The arrays incorporate
several features to simplify design integration and assembly.
Polarity symbols
Fully engineered substrate
for consistent thermal, mechanical
and optical properties
Solder pads
White ring around LES
Yellow phosphor Light
Emitting Surface (LES)
Case Temperature (Tc) measurement point
Note: Part number and lot codes are scribed on back of array
The part number designation for Bridgelux V Series LED arrays is explained as follows:
1 2 3 4
5 6
8 9 10 11
12
13 14
BXRE
30 E 0400
7
A
23
Product Family
Color Control Bin Options
23 = 3 SDCM
24 = 4 SDCM
Product Family
27 = 2700K
30 = 3000K
40 = 4000K
50 = 5000K
Array Configuration
Minimum CRI
C = 70 CRI
E = 80 CRI
G = 90 CRI
Flux Indicator
0400 = 400lm
2
The following product configurations are available:
Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25ºC)
Part Number
Nominal CCT1
(K)
CRI2
Nominal Drive
Current3
(mA)
Typical Pulsed
Flux4,5,6
Tc = 25ºC
(lm)
Minimum
Pulsed Flux6,7
Tc = 25ºC
(lm)
Typical Vf
(V)
Typical
Power (W)
Typical
Efficacy
(lm/W)
BXRE-27E0400-A-2x
BXRE-27E0400-B-2x
BXRE-27G0400-A-2x
BXRE-27G0400-B-2x
BXRE-30E0400-A-2x
BXRE-30E0400-B-2x
BXRE-30G0400-A-2x
BXRE-30G0400-B-2x
BXRE-35E0400-A-2x
BXRE-35E0400-B-2x
BXRE-35G0400-A-2x
BXRE-35G0400-B-2x
BXRE-40E0400-A-2x
BXRE-40E0400-B-2x
BXRE-50C0400-A-24
BXRE-50C0400-B-24
BXRE-50E0400-A-24
BXRE-50E0400-B-24
2700
2700
2700
2700
3000
3000
3000
3000
3500
3500
3500
3500
4000
4000
5000
5000
5000
5000
80
80
90
90
80
80
90
90
80
80
90
90
80
80
70
70
80
80
175
350
175
350
175
350
175
350
175
350
175
350
175
350
175
350
175
350
381
381
320
320
400
400
334
334
403
403
344
344
426
426
439
439
416
416
362
362
283
283
372
372
309
309
371
371
310
310
411
411
403
403
400
400
18.0
9.0
18.0
9.0
18.0
9.0
18.0
9.0
18.0
9.0
18.0
9.0
18.0
9.0
18.0
9.0
18.0
9.0
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
3.2
121
121
102
102
127
127
106
106
128
128
109
109
135
135
139
139
132
132
Table 2: Selection Guide, Stabalized DC Performance (Tc = 85ºC) 8,9
Part Number
Nominal CCT1
(K)
BXRE-27E0400-A-2x
BXRE-27E0400-B-2x
BXRE-27G0400-A-2x
BXRE-27G0400-B-2x
BXRE-30E0400-A-2x
BXRE-30E0400-B-2x
BXRE-30G0400-A-2x
BXRE-30G0400-B-2x
BXRE-35E0400-A-2x
BXRE-35E0400-B-2x
BXRE-35G0400-A-2x
BXRE-35G0400-B-2x
BXRE-40E0400-A-2x
BXRE-40E0400-B-2x
BXRE-50C0400-A-24
BXRE-50C0400-B-24
BXRE-50E0400-A-24
BXRE-50E0400-B-24
2700
2700
2700
2700
3000
3000
3000
3000
3500
3500
3500
3500
4000
4000
5000
5000
5000
5000
CRI
Nominal Drive
Current3
(mA)
Typical DC
Flux
Tc = 85ºC
(lm)
Minimum DC
Flux10
Tc = 85ºC
(lm)
Typical Vf
(V)
Typical
Power (W)
Typical
Efficacy
(lm/W)
80
80
90
90
80
80
90
90
80
80
90
90
80
80
70
70
80
80
175
350
175
350
175
350
175
350
175
350
175
350
175
350
175
350
175
350
337
337
283
283
354
354
295
295
356
356
304
304
380
380
381
381
361
361
320
320
250
250
329
329
273
273
328
328
274
274
367
367
349
349
347
347
17.6
8.8
17.6
8.8
17.6
8.8
17.6
8.8
17.6
8.8
17.6
8.8
17.6
8.8
17.6
8.8
17.6
8.8
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
3.1
110
110
92
92
115
115
96
96
116
116
99
99
124
124
124
124
118
118
2
Notes for Tables 1 & 2:
1.Nominal CCT as defined by ANSI C78.377-2011.
2.CRI Values are minimums. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50.
3.Drive current is referred to as nominal drive current.
4.Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C.
5.Typical performance values are provided as a reference only and are not a guarantee of performance.
6.Bridgelux maintains a ±7% tolerance on flux measurements.
7.Minimum flux values at the nominal test current are guaranteed by 100% test.
8.Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance.
9.Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material
and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or
the exposed environment to which the product is subjected.
10. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected.
3
V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also
be driven at other drive currents dependent on specific application design requirements. The performance at any drive
current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current
characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 3.
Table 3: Product Performance at Commonly Used Drive Currents
Part Number
BXRE-27E0400-A-2x
BXRE-27E0400-B-2x
BXRE-27G0400-A-2x
BXRE-27G0400-B-2x
BXRE-30E0400-A-2x
BXRE-30E0400-B-2x
CRI
80
80
90
90
80
80
Drive
Current1
(mA)
Typical Vf
Tc =25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
175
18.0
3.2
381
337
121
250
18.6
4.7
521
461
112
350
19.4
6.8
689
609
101
175
8.6
1.5
203
180
135
350
9.0
3.2
381
337
121
500
9.3
4.7
516
457
111
700
9.7
6.8
668
591
98
175
18.0
3.2
320
283
102
250
18.6
4.7
437
387
94
350
19.4
6.8
578
512
85
175
8.6
1.5
170
151
113
350
9.0
3.2
320
283
102
500
9.3
4.7
434
384
93
700
9.7
6.8
561
496
83
175
18.0
3.2
400
354
127
250
18.6
4.7
547
483
118
350
19.4
6.8
723
639
106
175
8.6
1.5
213
188
142
350
9.0
3.2
400
354
127
500
9.3
4.7
542
479
117
700
9.7
6.8
701
620
103
Notes for Table 3:
1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance.
2. Bridgelux maintains a ± 7% tolerance on flux measurements.
3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance.
4
Table 3: Product Performance at Commonly Used Drive Currents (Continued)
Part Number
BXRE-30G0400-A-2x
BXRE-30G0400-B-2x
BXRE-35E0400-A-2x
BXRE-35E0400-B-2x
BXRE-35G0400-A-2x
BXRE-35G0400-B-2x
CRI
90
90
80
80
90
90
Drive
Current1
(mA)
Typical Vf
Tc =25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
175
18.0
3.2
334
295
106
250
18.6
4.7
456
404
98
350
19.4
6.8
604
534
89
175
8.6
1.5
178
157
118
350
9.0
3.2
334
295
106
500
9.3
4.7
453
400
97
700
9.7
6.8
586
518
86
175
18.0
3.2
403
356
128
250
18.6
4.7
551
487
118
350
19.4
6.8
728
644
107
175
8.6
1.5
215
190
143
350
9.0
3.2
403
356
128
500
9.3
4.7
546
483
117
700
9.7
6.8
707
625
104
175
18.0
3.2
344
304
109
250
18.6
4.7
470
416
101
350
19.4
6.8
622
550
92
175
8.6
1.5
183
162
122
350
9.0
3.2
344
304
109
500
9.3
4.7
466
412
100
700
9.7
6.8
603
533
89
Notes for Table 3:
5
Part Number
BXRE-40E0400-A-2x
BXRE-40E0400-B-2x
BXRE-50C0400-A-24
BXRE-50C0400-B-24
BXRE-50E0400-A-24
BXRE-50E0400-B-24
CRI
80
80
70
70
80
80
Drive
Current1
(mA)
Typical Vf
Tc =25ºC
(V)
Typical
Power
Tc = 25ºC
(W)
Typical
Flux2
Tc = 25ºC
(lm)
Typical
Flux3
Tc = 85ºC
(lm)
Typical
Efficacy
Tc = 25ºC
(lm/W)
175
18.0
3.2
426
380
135
250
18.6
4.7
582
519
125
350
19.4
6.8
770
687
113
175
8.6
1.5
227
203
151
350
9.0
3.2
426
380
135
500
9.3
4.7
577
515
124
700
9.7
6.8
747
667
110
175
18.0
3.2
439
381
139
250
18.6
4.7
600
520
129
350
19.4
6.8
794
688
117
175
8.6
1.5
234
203
155
350
9.0
3.2
439
381
139
500
9.3
4.7
595
516
128
700
9.7
6.8
770
667
113
175
18.0
3.2
416
361
132
250
18.6
4.7
568
493
122
350
19.4
6.8
752
652
111
175
8.6
1.5
222
192
147
350
9.0
3.2
416
361
132
500
9.3
4.7
564
489
121
700
9.7
6.8
729
632
107
Notes for Table 3:
6
Table 4: Electrical Characteristics
Forward Voltage
Pulsed, Tc = 25ºC (V) 1, 2, 3
Part Number
BXRE-xxx0400-A-2x
BXRE-xxx0400-B-2x
Drive Current
(mA)
Typical
Coefficient
of Forward
Voltage4
ΔVf/ΔT
(mV/ºC)
Typical
Thermal
Resistance
Junction
to Case5,6
R j-c (C/W)
Driver Selection
Voltages7
(V)
Vf Min.
Hot
Tc = 105ºC
(V)
Vf Max.
Cold
Tc = -40ºC
(V)
1.25
16.1
19.8
-7
1.72
17.2
21.3
9.7
-4
1.25
8.0
10.0
10.5
-4
1.72
8.6
10.8
Minimum
Typical
Maximum
175
16.7
18.0
19.3
-7
350
17.8
19.4
20.8
350
8.3
9.0
700
8.9
9.8
Notes for Table 4:
1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms.
2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance.
3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements.
4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current.
5. Thermal resistance values are based from test data of a 3000K 80 CRI product.
6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power.
The thermal interface material used during testing is not included in the thermal resistance value.
7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid
in driver design and selection over the operating range of the product.
7
Table 5: Maximum Ratings
Parameter
Maximum Rating
LED Junction Temperature (Tj)
150ºC
Storage Temperature
-40♪ºC to +105ºC
Operating Case Temperature1 (Tc)
105ºC
Soldering Temperature2
350ºC or lower for a maximum of 10 seconds
BXRE-xxx0400-A-2x
BXRE-xxx0400-B-2x
Maximum Drive Current3,4,5
350 mA
700 mA
Maximum Peak Pulsed Drive Current6
500 mA
1000 mA
Maximum Reverse Voltage7
-30 V
-15 V
Notes for Table 5:
1. For IEC 62717 requirement, please consult your Bridgelux sales representative.
2. Refer to Bridgelux Application Note AN41: Assembly Considerations for Bridgelux V Series LED Arrays.
3. DC Forward Current for LM-80 is the maximum drive current for which LM-80 data is currently available.
4. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing
as included in the applicable LM-80 test report for these arrays. Contact your Bridgelux sales representatives for LM-80 report.
5. Arrays may be driven at higher currents however lumen maintenance may be reduced.
6. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed
current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures.
7. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating
provided for reference only.
8
Performance Curves
Figure 1: Drive Current vs. Voltage (Tj = Tc = 25ºC) - BXRE-xxx0400-A-2x
350
300
Current (mA)
250
200
150
100
Typical Vf
Minimum Vf
50
Maximum Vf
14
15
16
17
18
19
22
Forward Voltage (V)
Figure 2: Drive Current vs. Voltage (Tj = Tc = 25ºC) - BXRE-xxx0400-B-2x
700
600
Current (mA)
500
400
300
200
Typical Vf
Minimum Vf
100
Maximum Vf
7
8
9
10
11
Forward Voltage (V)
9
Performance Curves
Figure 3: Typical Relative Luminous Flux vs. Current - BXRE-xxx0400-A-2x
180%
160%
Relative Flux
140%
120%
100%
80%
60%
40%
20%
0%
100
150
200
250
300
350
Current (mA)
Figure 4: Typical Relative Luminous Flux vs. Current - BXRE-xxx0400-B-2x
180%
160%
Relative Flux
140%
120%
100%
80%
60%
40%
20%
0%
200
300
400
500
600
700
Current (mA)
10
Performance Curves
Figure 5: Typical DC Flux vs. Case Temperature
105%
Warm White
Neutral White
Relative Flux
100%
Cool White
95%
90%
85%
80%
50
75
100
Case Temperature (°C)
Figure 6: Typical DC ccx Shift vs. Case Temperature
0.000
50
75
100
ccx Shift
-0.005
Warm White
-0.010
Neutral White
Cool White
-0.015
Notes for Figure 5-6:
1. Characteristics shown for warm white based on 3000K and 80 CRI.
2. Characteristics shown for neutral white based on 4000K and 80 CRI.
3. Characteristics shown for cool white based on 5000K and 70 CRI.
4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information.
11
Performance Curves
Figure 7: Typical DC ccy Shift vs. Case Temperature
0.000
50
75
100
ccy Shift
-0.005
Warm White
-0.010
Neutral White
Cool White
-0.015
Notes for Figure 7:
12
Figure 8: Typical Spatial Radiation Pattern
Notes for Figure 8:
1. Typical viewing angle is 120⁰.
2. The viewing angle is defined as the off axis angle form the centerline where Iv is ½ of the peak value.
Figure 9: Typical Polar Radiation Pattern
13
Figure 10: Typical Color Spectrum
Notes for Figure 10:
14
Figure 11: Drawing for V6 Arrays
Notes for Figure 11:
1. Solder pads are labeled “+” and “-“to denote positive and negative polarity, respectively.
2. It is not necessary to provide electrical connections to both sets of solder pads. Either set may be used depending on application
specific design requirements.
3. Drawings are not to scale.
4. Drawing dimensions are in millimeters.
5. Unless otherwise specified, tolerances are ± 0.10mm.
6. The optical center of the LED Array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is
centered on the mechanical center of the array to a tolerance of ± 0.2 mm
7. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN40 and AN41 for
product handling, mounting and heat sink recommendations.
15
Figure 12: Graph of Warm and Neutral White Test Bins in xy Color Space
Note: Pulsed Test Conditions, Tc = 25°C
Table 6: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT
Bin Code
2700K
3000K
3500K
4000K
ANSI Bin
(for reference only)
(2580K - 2870K)
(2870K - 3220K)
(3220K - 3710K)
(3710K - 4260K)
23 (3SDCM)
(2651K - 2794K)
(2968K - 3136K)
(3369K - 3586K)
(3851K - 4130K)
Center Point (x,y)
(0.4578, 0.4101)
(0.4338, 0.403)
(0.4073, 0.3917)
(0.3818, 0.3797)
Figure 13: Graph of Cool White Test Bins in xy Color Space
Table 7: Cool White xy Bin Coordinates and Associated Typical CCT
Bin Code
5000K
ANSI Bin (for reference only)
(4745K - 5311K)
24 (4SDCM)
(4801K - 5282K)
Center Point (x,y)
(0.3447, 0.3553)
16
Figure 14: Drawing for V6 Packaging Tray
Notes for Figure 14:
1. Dimensions are in millimeters
2. Tolerances: X.X = ± 0.25, X.XX = ± 0.13, X°0’ = ±0°30’
3. Trays are stackable without interference and will not stick together during unstacking operation
17
Figure 15: V Series Packaging and Labeling
Notes for Figure 15:
1. Each tray holds 60 COB arrays, 10 trays are stacked and one empty tray placed on top to cover the top tray.
2. Stacked trays are to contain only 1 part number and be vacuum sealed in an anti-static bag and placed in its own individual box.
3. Each bag and box is to be labeled as shown above.
Figure 16: Product Labeling
Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In
addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux
manufacturing use only. The image below shows which markings are for customer use and which ones are for
Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice,
however these will not impact the form, function or performance of the COB array.
Customer Use- 2D Barcode
Scannable barcode provides
product part number and other
Bridgelux internal production
information.
Customer Use- Product part number
Internal Bridgelux use only.
18
Design Resources
Application Notes
3D CAD Models
Bridgelux has developed a comprehensive set of
application notes and design resources to assist
customers in successfully designing with the V Series
product family of LED array products. For a list of of
resources under development, visit www.bridgelux.com.
Three dimensional CAD models depicting the product
outline of all Bridgelux V Series LED arrays are available
in both IGS and STEP formats. Please contact your
Bridgelux sales representative for assistance.
Optical Source Models
Optical source models and ray set files are available
for all Bridgelux products. For a list of available formats,
Precautions
CAUTION: CHEMICAL EXPOSURE HAZARD
Exposure to some chemicals commonly used in
luminaire manufacturing and assembly can cause
damage to the LED array. Please consult Bridgelux
Application Note AN41 for additional information.
CAUTION: EYE SAFETY
Eye safety classification for the use of Bridgelux
V Series LED arrays is in accordance with IEC specification
EN62471: Photobiological Safety of Lamps and Lamp
Systems. V Series LED arrays are classified as Risk Group
1 (Low Risk) when operated at or below the maximum
drive current. Please use appropriate precautions. It
is important that employees working with LEDs are
trained to use them safely.
CAUTION
CONTACT WITH LIGHT EMITTING SURFACE (LES)
Avoid any contact with the LES. Do not touch the
LES of the LED array or apply stress to the LES
(yellow phosphor resin area). Contact may cause
Optics and reflectors must not be mounted in contact
with the LES (yellow phosphor resin area). Use the
mechanical features of the LED array housing, edges
and/or mounting holes to locate and secure optical
devices as needed.
CAUTION: RISK OF BURN
Do not touch the V Series LED array during operation.
Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated
temperatures such that could burn skin when touched.
Disclaimers
MINOR PRODUCT CHANGE POLICY
STANDARD TEST CONDITIONS
The rigorous qualification testing on products offered by
Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may
occur as Bridgelux continues product optimization.
Unless otherwise stated, array testing is performed under
pulsed conditions at the nominal drive current.
19
About Bridgelux: We Build Light That Transforms
At Bridgelux, we help companies, industries and people experience the power and possibility
of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient,
cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and
financial. And our patented technology drives new platforms for commercial and industrial
luminaires.
For more information about the company, please
visit
bridgelux.com
twitter.com/Bridgelux
facebook.com/Bridgelux
WeChat ID: BridgeluxInChina
101 Portola Avenue
Livermore, CA 94551
Tel (925) 583-8400
Fax (925) 583-8410
www.bridgelux.com
© 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and V Series are
registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners.
Bridgelux V6 Array Series Product Data Sheet DS40 Rev. F (06/2016)
