BXRE-30G0400-A-23
BXRE-30G0400-A-23
    BRIDGELUX(普瑞)
    BXRE-30G0400-A-23
BXRE-30G0400-A-23 数据手册
Bridgelux® V6 Array Product Data Sheet DS40 BXRE-27x0400 | 30x0400 | 35x0400 | 40x0400 | 50x0400 V Series Introduction The V Series LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These Chip-on-Board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V6 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED Arrays deliver comparable performance to 7-13 Watt compact fluorescent and 25 - 50 Watt incandescent and halogen based luminaires, delivering increased system level efficacy and longer service life. Typical applications include, but are not limited to, replacement lamps, task, accent, spot, track, down light, wide area, security, and wall pack. Features • • • • • • Efficacy of 130 lm/W typical Compact high flux density light source Uniform high quality illumination Minimum 70, 80 and 90 CRI options • • • • Streamlined thermal path Energy Star / ANSI compliant color binning structure with 3SDCM and 4SDCM options • Benefits More energy efficient than incandescent, halogen and Low voltage DC operation Instant light with unlimited dimming Clean white light without pixilation High quality true color reproduction Significantly reduced thermal resistance and increased operating temperatures • • • fluorescent lamps • • Enhanced optical control Uniform consistent white light Lower operating costs Easy to use with daylight and motion detectors to enable increased energy savings • • Reduced maintenance costs Environmentally friendly, no disposal issue Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 4 Electrical Characteristics 7 Absolute Maximum Ratings 8 Performance Curves 9 Typical Radiation Pattern 13 Typical Color Spectrum 14 Mechanical Dimensions 15 Color Binning Information 16 Packaging and Labeling 17 Design Resources 19 Precautions 19 Disclaimers 19 About Bridgelux 20 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Polarity symbols Fully engineered substrate for consistent thermal, mechanical and optical properties Solder pads White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) measurement point Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 8 9 10 11 12 13 14 BXRE 30 E 0400 7 A 23 Product Family Color Control Bin Options 23 = 3 SDCM 24 = 4 SDCM Product Family 27 = 2700K 30 = 3000K 40 = 4000K 50 = 5000K Array Configuration Minimum CRI C = 70 CRI E = 80 CRI G = 90 CRI Flux Indicator 0400 = 400lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25ºC) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-27E0400-A-2x BXRE-27E0400-B-2x BXRE-27G0400-A-2x BXRE-27G0400-B-2x BXRE-30E0400-A-2x BXRE-30E0400-B-2x BXRE-30G0400-A-2x BXRE-30G0400-B-2x BXRE-35E0400-A-2x BXRE-35E0400-B-2x BXRE-35G0400-A-2x BXRE-35G0400-B-2x BXRE-40E0400-A-2x BXRE-40E0400-B-2x BXRE-50C0400-A-24 BXRE-50C0400-B-24 BXRE-50E0400-A-24 BXRE-50E0400-B-24 2700 2700 2700 2700 3000 3000 3000 3000 3500 3500 3500 3500 4000 4000 5000 5000 5000 5000 80 80 90 90 80 80 90 90 80 80 90 90 80 80 70 70 80 80 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 381 381 320 320 400 400 334 334 403 403 344 344 426 426 439 439 416 416 362 362 283 283 372 372 309 309 371 371 310 310 411 411 403 403 400 400 18.0 9.0 18.0 9.0 18.0 9.0 18.0 9.0 18.0 9.0 18.0 9.0 18.0 9.0 18.0 9.0 18.0 9.0 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 121 121 102 102 127 127 106 106 128 128 109 109 135 135 139 139 132 132 Table 2: Selection Guide, Stabalized DC Performance (Tc = 85ºC) 8,9 Part Number Nominal CCT1 (K) BXRE-27E0400-A-2x BXRE-27E0400-B-2x BXRE-27G0400-A-2x BXRE-27G0400-B-2x BXRE-30E0400-A-2x BXRE-30E0400-B-2x BXRE-30G0400-A-2x BXRE-30G0400-B-2x BXRE-35E0400-A-2x BXRE-35E0400-B-2x BXRE-35G0400-A-2x BXRE-35G0400-B-2x BXRE-40E0400-A-2x BXRE-40E0400-B-2x BXRE-50C0400-A-24 BXRE-50C0400-B-24 BXRE-50E0400-A-24 BXRE-50E0400-B-24 2700 2700 2700 2700 3000 3000 3000 3000 3500 3500 3500 3500 4000 4000 5000 5000 5000 5000 CRI Nominal Drive Current3 (mA) Typical DC Flux Tc = 85ºC (lm) Minimum DC Flux10 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 80 80 90 90 80 80 90 90 80 80 90 90 80 80 70 70 80 80 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 175 350 337 337 283 283 354 354 295 295 356 356 304 304 380 380 381 381 361 361 320 320 250 250 329 329 273 273 328 328 274 274 367 367 349 349 347 347 17.6 8.8 17.6 8.8 17.6 8.8 17.6 8.8 17.6 8.8 17.6 8.8 17.6 8.8 17.6 8.8 17.6 8.8 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 3.1 110 110 92 92 115 115 96 96 116 116 99 99 124 124 124 124 118 118 2 Notes for Tables 1 & 2: 1.Nominal CCT as defined by ANSI C78.377-2011. 2.CRI Values are minimums. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. 3.Drive current is referred to as nominal drive current. 4.Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5.Typical performance values are provided as a reference only and are not a guarantee of performance. 6.Bridgelux maintains a ±7% tolerance on flux measurements. 7.Minimum flux values at the nominal test current are guaranteed by 100% test. 8.Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9.Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 10. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number BXRE-27E0400-A-2x BXRE-27E0400-B-2x BXRE-27G0400-A-2x BXRE-27G0400-B-2x BXRE-30E0400-A-2x BXRE-30E0400-B-2x CRI 80 80 90 90 80 80 Drive Current1 (mA) Typical Vf Tc =25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 18.0 3.2 381 337 121 250 18.6 4.7 521 461 112 350 19.4 6.8 689 609 101 175 8.6 1.5 203 180 135 350 9.0 3.2 381 337 121 500 9.3 4.7 516 457 111 700 9.7 6.8 668 591 98 175 18.0 3.2 320 283 102 250 18.6 4.7 437 387 94 350 19.4 6.8 578 512 85 175 8.6 1.5 170 151 113 350 9.0 3.2 320 283 102 500 9.3 4.7 434 384 93 700 9.7 6.8 561 496 83 175 18.0 3.2 400 354 127 250 18.6 4.7 547 483 118 350 19.4 6.8 723 639 106 175 8.6 1.5 213 188 142 350 9.0 3.2 400 354 127 500 9.3 4.7 542 479 117 700 9.7 6.8 701 620 103 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 4 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRE-30G0400-A-2x BXRE-30G0400-B-2x BXRE-35E0400-A-2x BXRE-35E0400-B-2x BXRE-35G0400-A-2x BXRE-35G0400-B-2x CRI 90 90 80 80 90 90 Drive Current1 (mA) Typical Vf Tc =25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 18.0 3.2 334 295 106 250 18.6 4.7 456 404 98 350 19.4 6.8 604 534 89 175 8.6 1.5 178 157 118 350 9.0 3.2 334 295 106 500 9.3 4.7 453 400 97 700 9.7 6.8 586 518 86 175 18.0 3.2 403 356 128 250 18.6 4.7 551 487 118 350 19.4 6.8 728 644 107 175 8.6 1.5 215 190 143 350 9.0 3.2 403 356 128 500 9.3 4.7 546 483 117 700 9.7 6.8 707 625 104 175 18.0 3.2 344 304 109 250 18.6 4.7 470 416 101 350 19.4 6.8 622 550 92 175 8.6 1.5 183 162 122 350 9.0 3.2 344 304 109 500 9.3 4.7 466 412 100 700 9.7 6.8 603 533 89 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRE-40E0400-A-2x BXRE-40E0400-B-2x BXRE-50C0400-A-24 BXRE-50C0400-B-24 BXRE-50E0400-A-24 BXRE-50E0400-B-24 CRI 80 80 70 70 80 80 Drive Current1 (mA) Typical Vf Tc =25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 175 18.0 3.2 426 380 135 250 18.6 4.7 582 519 125 350 19.4 6.8 770 687 113 175 8.6 1.5 227 203 151 350 9.0 3.2 426 380 135 500 9.3 4.7 577 515 124 700 9.7 6.8 747 667 110 175 18.0 3.2 439 381 139 250 18.6 4.7 600 520 129 350 19.4 6.8 794 688 117 175 8.6 1.5 234 203 155 350 9.0 3.2 439 381 139 500 9.3 4.7 595 516 128 700 9.7 6.8 770 667 113 175 18.0 3.2 416 361 132 250 18.6 4.7 568 493 122 350 19.4 6.8 752 652 111 175 8.6 1.5 222 192 147 350 9.0 3.2 416 361 132 500 9.3 4.7 564 489 121 700 9.7 6.8 729 632 107 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 6 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3 Part Number BXRE-xxx0400-A-2x BXRE-xxx0400-B-2x Drive Current (mA) Typical Coefficient of Forward Voltage4 ΔVf/ΔT (mV/ºC) Typical Thermal Resistance Junction to Case5,6 R j-c (C/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 1.25 16.1 19.8 -7 1.72 17.2 21.3 9.7 -4 1.25 8.0 10.0 10.5 -4 1.72 8.6 10.8 Minimum Typical Maximum 175 16.7 18.0 19.3 -7 350 17.8 19.4 20.8 350 8.3 9.0 700 8.9 9.8 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 7 Absolute Maximum Ratings Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150ºC Storage Temperature -40♪ºC to +105ºC Operating Case Temperature1 (Tc) 105ºC Soldering Temperature2 350ºC or lower for a maximum of 10 seconds BXRE-xxx0400-A-2x BXRE-xxx0400-B-2x Maximum Drive Current3,4,5 350 mA 700 mA Maximum Peak Pulsed Drive Current6 500 mA 1000 mA Maximum Reverse Voltage7 -30 V -15 V Notes for Table 5: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN41: Assembly Considerations for Bridgelux V Series LED Arrays. 3. DC Forward Current for LM-80 is the maximum drive current for which LM-80 data is currently available. 4. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these arrays. Contact your Bridgelux sales representatives for LM-80 report. 5. Arrays may be driven at higher currents however lumen maintenance may be reduced. 6. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 7. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 8 Performance Curves Figure 1: Drive Current vs. Voltage (Tj = Tc = 25ºC) - BXRE-xxx0400-A-2x 350 300 Current (mA) 250 200 150 100 Typical Vf Minimum Vf 50 0 Maximum Vf 14 15 16 17 18 19 20 21 22 Forward Voltage (V) Figure 2: Drive Current vs. Voltage (Tj = Tc = 25ºC) - BXRE-xxx0400-B-2x 700 600 Current (mA) 500 400 300 200 Typical Vf Minimum Vf 100 0 Maximum Vf 7 8 9 10 11 Forward Voltage (V) 9 Performance Curves Figure 3: Typical Relative Luminous Flux vs. Current - BXRE-xxx0400-A-2x 180% 160% Relative Flux 140% 120% 100% 80% 60% 40% 20% 0% 0 50 100 150 200 250 300 350 Current (mA) Figure 4: Typical Relative Luminous Flux vs. Current - BXRE-xxx0400-B-2x 180% 160% Relative Flux 140% 120% 100% 80% 60% 40% 20% 0% 0 100 200 300 400 500 600 700 Current (mA) 10 Performance Curves Figure 5: Typical DC Flux vs. Case Temperature 105% Warm White Neutral White Relative Flux 100% Cool White 95% 90% 85% 80% 0 25 50 75 100 Case Temperature (°C) Figure 6: Typical DC ccx Shift vs. Case Temperature 0.000 0 25 50 75 100 ccx Shift -0.005 Warm White -0.010 Neutral White Cool White -0.015 Case Temperature (°C) Notes for Figure 5-6: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 11 Performance Curves Figure 7: Typical DC ccy Shift vs. Case Temperature 0.000 0 25 50 75 100 ccy Shift -0.005 Warm White -0.010 Neutral White Cool White -0.015 Case Temperature (°C) Notes for Figure 7: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 12 Typical Radiation Pattern Figure 8: Typical Spatial Radiation Pattern Notes for Figure 8: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle form the centerline where Iv is ½ of the peak value. Figure 9: Typical Polar Radiation Pattern 13 Typical Color Spectrum Figure 10: Typical Color Spectrum Notes for Figure 10: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 14 Mechanical Dimensions Figure 11: Drawing for V6 Arrays Notes for Figure 11: 1. Solder pads are labeled “+” and “-“to denote positive and negative polarity, respectively. 2. It is not necessary to provide electrical connections to both sets of solder pads. Either set may be used depending on application specific design requirements. 3. Drawings are not to scale. 4. Drawing dimensions are in millimeters. 5. Unless otherwise specified, tolerances are ± 0.10mm. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.2 mm 7. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN40 and AN41 for product handling, mounting and heat sink recommendations. 15 Color Binning Information Figure 12: Graph of Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 6: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 23 (3SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 13: Graph of Cool White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K ANSI Bin (for reference only) (4745K - 5311K) 24 (4SDCM) (4801K - 5282K) Center Point (x,y) (0.3447, 0.3553) 16 Packaging and Labeling Figure 14: Drawing for V6 Packaging Tray Notes for Figure 14: 1. Dimensions are in millimeters 2. Tolerances: X.X = ± 0.25, X.XX = ± 0.13, X°0’ = ±0°30’ 3. Trays are stackable without interference and will not stick together during unstacking operation 17 Packaging and Labeling Figure 15: V Series Packaging and Labeling Notes for Figure 15: 1. Each tray holds 60 COB arrays, 10 trays are stacked and one empty tray placed on top to cover the top tray. 2. Stacked trays are to contain only 1 part number and be vacuum sealed in an anti-static bag and placed in its own individual box. 3. Each bag and box is to be labeled as shown above. Figure 16: Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number Internal Bridgelux use only. 18 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For a list of of resources under development, visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN41 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. V Series LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed under pulsed conditions at the nominal drive current. 19 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux WeChat ID: BridgeluxInChina 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8410 www.bridgelux.com © 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and V Series are registered trademarks of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux V6 Array Series Product Data Sheet DS40 Rev. F (06/2016) 20
BXRE-30G0400-A-23 价格&库存
很抱歉,暂时无法提供与“BXRE-30G0400-A-23”相匹配的价格&库存,您可以联系我们找货
BXRE-30G0400-A-23
    • 1+29.67840
    • 200+11.84760
    • 600+11.44800
    • 1200+11.25360
