NJU7261 Series
C-MOS STEP-UP SWITCHING REGULATOR
PRELIMINARY
■ GENERAL DESCRIPTION
The NJU7261 series is a C-MOS step-up switching regulator
which contains accurate voltage reference, error amplifier, CR
oscillator, control circuit, switching transistor, diode and resistor.
The stand-by function is effective for low power consumption.
The regulation voltage is fixed by internal circuits and the following
line-up of different output voltages version are available.
This series is suitable for portable equipment's or battery operated
items because of its small packaged outline, low operating voltage
and current.
■ PACKAGE OUTLINE
■ FEATURES
• Low Operating Voltage
• Low Operating Current
• Low Stand-by Current
• High Precision Output Voltage
• Wide Operating Voltage Range
• Stand-by Function
• CR Oscillator On-chip
• Diode On-chip
• Package Outline
• C-MOS Technology
■ PIN CONFIGULATION
NJU7261UX
(1.0V min.)
(5.0µA typ. / VOUT = 3.0V)
(0.2µA max. / VOUT = 3.0V)
(±3% max.)
SOT89-5
■ LINE-UP
■ EQUIVALENT CIRCUIT
Output Voltage (V)
Line-Up
3.0
NJU7261U30
3.3
NJU7261U33
4.5
NJU7261U45
5.0
NJU7261U50
■ TERMINAL DESCRIPTION
No.
Term. Name
I/O
1
CONT
I
2
GND
POWER
3
STB
I
4
VIN
POWER
5
VOUT
O
Ver.2003-07-18
FUNCTION
External Inductor Connect Terminal
Power Source (GND)
Strobe Terminal : "H" or OPEN···Normal Operation (step-up)
" L"
···Standp-By Operation
Power Source (+)
Step-up Output Terminal
-1-
NJU7261 Series
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
(Ta = 25ºC)
SYMBOL
Input Voltage
RATINGS
UNIT
VIN
10
V
CONT Input Voltage
VCONT
GND-0.3 ≤ VCONT ≤ 10
V
Strobe Input Voltage
VSTB
GND-0.3 ≤ VSTB ≤ VIN
V
Output Voltage
VOUT
GND-0.3 ≤ VOUT ≤ 10
V
Power Dissipation
PD
300
mW
Operating Temperature Range
Topr
-25 to + 75
ºC
Storage Temperature Range
Tstg
-40 to +125
ºC
Note1) When a coil used. This IC of VCONT possible over the absolute maximum ratings. Consequently please conduct
enough to test.
Note2) The CONT input voltage (VCONT) should be inspected at the real application circuit, as some kinds of coils make
the CONT input voltage exceed the Absolute Maximum Rating of the VCONT.
■ ELECTRICAL CHARACTERISTICS
+3.0V Version
PARAMETER
SYMBOL
(Ta = 25°C)
CONDITION
NORM
MIN.
TYP.
MAX.
UNIT
MEASUREMENT
CIRCUIT
Input Voltage
VIN
5.0
V
1
Start Voltage
VSTART
NO LOAD
1.0
V
1
Oscillator Freq.
fOSC
VIN = 1.5V
50
kHz
2
Output Voltage
VOUT
VIN = 1.5V, IOUT = 20mA
2.91
3.0
3.09
V
1
30
100
mV
1
Input Stability
∆VOUT1
VIN = 1.5V to 2.0V
IOUT = 20mA
Load Stability
∆VOUT2
VIN = 1.5V
IOUT = 10µA to 25mA
30
100
mV
1
ISS
VIN = VSTB = 1.5V, NO LOAD
5.0
10
µA
3
Stand-by Current
IQ
VIN = 1.5V
VSTB = 0V, NO LOAD
0.2
µA
4
Switching Current
ISI
VDS = 0.2V
250
mA
Operating Current
STB Terminal
Input Voltage
STB Terminal
Input Current
-2-
H level
VSTBH
VIN = 1.5V
1.0
V
5
L level
VSTBL
VIN = 1.5V
0.4
V
5
H level
L level
ISTBH1
VIN = 1.5V, VSTB = 1.0V
15
30
µA
6
ISTBH2
VIN = 1.5V, VSTB = 1.5V
0.1
µA
6
ISTBL1
VIN = 1.5V, VSTB = 0.4V
15
30
µA
6
ISTBL2
VIN = 1.5V, VSTB = 0V
0.1
µA
6
Ver.2003-07-18
NJU7261 Series
+3.3V Version
PARAMETER
(Ta = 25°C)
SYMBOL
CONDITION
Input Voltage
VIN
Start Voltage
VSTART
NO LOAD
Oscillator Freq.
fOSC
VIN = 1.5V
Output Voltage
VOUT
NORM
UNIT
MEASUREMENT
CIRCUIT
MIN.
TYP.
MAX.
5.0
V
1
1.0
V
1
50
kHz
2
3.20
3.30
3.40
V
1
Input Stability
∆VOUT1
VIN = 1.5V to 3.0V
IOUT = 20mA
30
100
mV
1
Load Stability
∆VOUT2
VIN = 1.5V
IOUT = 10µA to 25mA
30
100
mV
1
Operating Current
ISS
5
10
µA
3
Stand-by Current
IQ
VIN = 1.5V
VSTB = 0V, NO LOAD
0.2
µA
4
Switching Current
ISI
VDS = 0.2V
250
mA
STB Terminal
Input Voltage
STB Terminal
Input Current
H level
VSTBH
VIN = 1.5V
1.0
V
5
L level
VSTBL
VIN = 1.5V
0.4
V
5
ISTBH1
15
30
µA
6
ISTBH2
0.1
µA
6
ISTBL1
15
30
µA
6
ISTBL2
0.1
µA
6
H level
L level
+4.5V Version
PARAMETER
(Ta = 25°C)
SYMBOL
CONDITION
Input Voltage
VIN
Start Voltage
VSTART
NO LOAD
Oscillator Freq.
fOSC
VIN = 3.0V
Output Voltage
VOUT
VIN = 3.0V, IOUT = 20mA
NORM
UNIT
MEASUREMENT
CIRCUIT
4.5
V
1
1.0
V
1
MIN.
TYP.
MAX.
50
kHz
2
4.36
4.50
4.64
V
1
Input Stability
∆VOUT1
VIN = 2.0V to 3.0V
IOUT = 20mA
30
100
mV
1
Load Stability
∆VOUT2
VIN = 3.0V
IOUT = 10µA to 25mA
30
100
mV
1
Operating Current
ISS
VIN = VSTB = 3.0V, NO LOAD
5
15
µA
3
Stand-by Current
IQ
VIN = 3.0V
VSTB = 0V, NO LOAD
0.2
µA
4
Switching Current
ISI
VDS = 0.2V
250
mA
STB Terminal
Input Voltage
STB Terminal
Input Current
Ver.2003-07-18
H level
VSTBH
VIN = 3.0V
2.4
V
5
L level
VSTBL
VIN = 3.0V
0.4
V
5
ISTBH1
VIN = 3.0V, VSTB = 2.4V
50
100
µA
6
ISTBH2
VIN = 3.0V, VSTB = 3.0V
0.1
µA
6
ISTBL1
VIN = 3.0V, VSTB = 0.4V
50
100
µA
6
ISTBL2
VIN = 3.0V, VSTB = 0V
0.1
µA
6
H level
L level
-3-
NJU7261 Series
+5.0V Version
PARAMETER
(Ta = 25°C)
SYMBOL
CONDITION
Input Voltage
VIN
Start Voltage
VSTART
NO LOAD
Oscillator Freq.
fOSC
VIN = 3.0V
Output Voltage
VOUT
NORM
UNIT
MEASUREMENT
CIRCUIT
MIN.
TYP.
MAX.
5.0
V
1
1.0
V
1
50
kHz
2
4.85
5.0
5.15
V
1
Input Stability
∆VOUT1
VIN = 2.0V to 3.0V
IOUT = 20mA
30
100
mV
1
Load Stability
∆VOUT2
VIN = 3.0V
IOUT = 10µA to 25mA
30
100
mV
1
Operating Current
ISS
5
15
µA
3
Stand-by Current
IQ
VIN = 3.0V
VSTB = 0V, NO LOAD
0.2
µA
4
Switching Current
ISI
VDS = 0.2V
250
mA
STB Terminal
Input Voltage
STB Terminal
Input Current
-4-
H level
VSTBH
VIN = 3.0V
2.4
V
5
L level
VSTBL
VIN = 3.0V
0.4
V
5
ISTBH1
50
100
µA
6
ISTBH2
0.1
µA
6
ISTBL1
50
100
µA
6
ISTBL2
0.1
µA
6
H level
L level
Ver.2003-07-18
NJU7261 Series
■ MEASUREMENT CIRCUIT 1
(1)
External Diode Type : "D1NS4" provided by SHINDENGEN
(IF = 1A, VF = 0.55V)
(2)
(3)
ISS = I1 + l2 x
VOUT
V2
Under the condition of V2 =VOUT + 1.0V
Ver.2003-07-18
-5-
NJU7261 Series
■ MEASUREMENT CIRCUIT 2
(4)
(5)
(6)
-6-
Ver.2003-07-18
NJU7261 Series
■ APPLICATION CIRCUIT
Ver.2003-07-18
-7-
NJU7261 Series
■ TYPICAL CHARACTERISTIC
Start Voltage vs. Temperature
Internal Oscillator Operation : External D1NS4
Oscillation Frequency vs. Temperature
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-8-
Ver.2003-07-18
很抱歉,暂时无法提供与“NJU7261U50-TE1”相匹配的价格&库存,您可以联系我们找货
