CHM-9-65-80-36-AC00-F2-5
    LUMINUS(朗明纳斯)
CHM-9-65-80-36-AC00-F2-5 数据手册
CHM-9 Product Datasheet Preliminary CHM-9 COB Arrays White LED Features: Table of Contents • High lumen output and efficacy typical • Over 1,500 lm, 123 LPW @ 3000K, 25ºC Technology Overview. . . . . . 2 • Over 1,650 lm, 135 LPW @ 5000K, 25ºC Test Specifications . . . . . . . . . 2 • CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K Chromaticity Bins. . . . . . . . . . 3 • 80 or 90 CRI min. up to 95 min. in warm white Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 Part Numbers AA00. . . . . . . . 5 • 2-step and 3-step MacAdam Ellipse color binning accuracy • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading Part Numbers AC00 . . . . . . . . 6 • Environmentally friendly: RoHS and REACh compliant Operating Characteristics . . 7 • Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8 Spectra. . . . . . . . . . . . . . . . . . . . 9 Mechanical Dimensions. . . 10 Packaging Information. . . . 11 Handling Notes. . . . . . . . . . . 12 Applications • Spotlights/Track Lights • Architectural and Specialty • Downlights • Street Lighting • Shop Lighting • Parking Lot and Area Lighting • Hospitality Lighting • Tunnel Lighting 1 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Technology Overview Preliminary Luminus XNova™ Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the XNova™ COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, XNova™ COB LEDs are ready for the toughest challenges. UL Recognized Compliance XNova COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding XNova™ COB LED Test Specifications Every XNova™ LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each XNova COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature XNova™ COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Preliminary Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 2-step Ellipse 3-step Ellipse 5-step Ellipse 0.44 2700K 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CHM-9 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point 5-step Bin 3-step Bin 2-step Bin Angle CCT CIEx CIEy θ (°) a b a b a b 2700K 0.4578 0.4101 53.7 0.0054 0.0028 0.0081 0.0042 0.0135 0.007 3000K 0.4338 0.403 53.2 0.00556 0.00272 0.00834 0.00408 0.0139 0.0068 3500K 0.4073 0.3917 54 0.00618 0.00276 0.00927 0.00414 0.01545 0.0069 4000K 0.3818 0.3797 53.7 0.00626 0.00268 0.00939 0.00402 0.01565 0.0067 5000K 0.3447 0.3553 59.6 0.00548 0.00236 0.00822 0.00354 0.0137 0.0059 6500K 0.3123 0.3282 58.57 0.00446 0.0019 0.00669 0.00285 0.01115 0.00475 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Preliminary Product Ordering and Shipping Part Number Nomenclature All CHM-9 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. Luminus may include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CHM 9 NN Product Family Light Emitting Surface Diameter Color Temperature CHM: Chip on Board, High Density, Multidie 9: LES Diameter (mm) Color See Note 1 below CHM-9 XX 36 QQPP FG W Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CRI Volts See Note 2 below Lumens See page 5 and 6 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Note 2: AA00 is a standard -package configurator AC00 is an alternative substrate size Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI R9 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 95 >95 2700K, 3000K 4000K Note: >90 >75 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Preliminary CHM-9 Part Numbers (AA00) The following tables describe products with typical flux and minimum flux measured at 360mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 2700K 3000K 3500K 4000K 5000K 6500K Color Rendering Index Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) 1,305 1,240 1,020 CRI (min.) 3-step MacAdam Ellipse 2-step MacAdam Ellipse 1,450 80 CHM-9-27-80-36-AA00-F2-3 CHM-9-27-80-36-AA00-F2-2 970 1,135 90 CHM-9-27-90-36-AA00-F2-3 CHM-9-27-90-36-AA00-F2-2 965 920 1,070 95 CHM-9-27-95-36-AA00-F2-3 CHM-9-27-95-36-AA00-F2-2 1,380 1,310 1,530 80 CHM-9-30-80-36-AA00-F2-3 CHM-9-30-80-36-AA00-F2-2 1,170 1,110 1,300 90 CHM-9-30-90-36-AA00-F2-3 CHM-9-30-90-36-AA00-F2-2 1,085 1,030 1,205 95 CHM-9-30-95-36-AA00-F2-3 CHM-9-30-95-36-AA00-F2-2 1,420 1,350 1,580 80 CHM-9-35-80-36-AA00-F2-3 CHM-9-35-80-36-AA00-F2-2 1,220 1,160 1,355 90 CHM-9-35-90-36-AA00-F2-3 CHM-9-35-90-36-AA00-F2-2 1,115 1,060 1,230 95 CHM-9-35-95-36-AA00-F2-3 CHM-9-35-95-36-AA00-F2-2 1,480 1,405 1,645 80 CHM-9-40-80-36-AA00-F2-3 CHM-9-40-80-36-AA00-F2-2 1,270 1,205 1,410 90 CHM-9-40-90-36-AA00-F2-3 CHM-9-40-90-36-AA00-F2-2 1,175 1,115 1,295 95 CHM-9-40-95-36-AA00-F2-3 CHM-9-40-95-36-AA00-F2-2 Output Flux (lm) CCT Reference (25ºC) Reference Typ. Typ. Min.. (calculated) (85ºC) (85ºC) (25ºC) Color Rendering Index Part Number CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 1,500 1,425 1,665 80 CHM-9-50-80-36-AA00-F2-5 CHM-9-50-80-36-AA00-F2-3 1,285 1,223 1,445 90 CHM-9-50-90-36-AA00-F2-5 CHM-9-50-90-36-AA00-F2-3 1,500 1,425 1,665 80 CHM-9-65-80-36-AA00-F2-5 CHM-9-65-80-36-AA00-F2-3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Preliminary CHM-9 Part Numbers (AC00) The following tables describe products with typical flux and minimum flux measured at 360mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 2700K 3000K 3500K 4000K Color Rendering Index Ordering Part Number Typ. Typ. (85ºC) Min.. (85ºC) (calculated) 1,305 1,240 1,020 CRI (min.) 3-step MacAdam Ellipse 2-step MacAdam Ellipse 1,450 80 CHM-9-27-80-36-AC00-F2-3 CHM-9-27-80-36-AC00-F2-2 970 1,135 90 CHM-9-27-90-36-AC00-F2-3 CHM-9-27-90-36-AC00-F2-2 965 920 1,070 95 CHM-9-27-95-36-AC00-F2-3 CHM-9-27-95-36-AC00-F2-2 1,380 1,310 1,530 80 CHM-9-30-80-36-AC00-F2-3 CHM-9-30-80-36-AC00-F2-2 1,170 1,110 1,300 90 CHM-9-30-90-36-AC00-F2-3 CHM-9-30-90-36-AC00-F2-2 1,085 1,030 1,205 95 CHM-9-30-95-36-AC00-F2-3 CHM-9-30-95-36-AC00-F2-2 1,420 1,350 1,580 80 CHM-9-35-80-36-AC00-F2-3 CHM-9-35-80-36-AC00-F2-2 1,220 1,160 1,355 90 CHM-9-35-90-36-AC00-F2-3 CHM-9-35-90-36-AC00-F2-2 1,480 1,405 1,645 80 CHM-9-40-80-36-AC00-F2-3 CHM-9-40-80-36-AC00-F2-2 1,270 1,205 1,410 90 CHM-9-40-90-36-AC00-F2-3 CHM-9-40-90-36-AC00-F2-2 Output Flux (lm) CCT Reference (25ºC) Reference Typ. Typ. Min.. (calculated) (85ºC) (85ºC) (25ºC) Color Rendering Index Part Number CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 5000K 1,500 1,425 1,665 80 CHM-9-50-80-36-AC00-F2-5 CHM-9-50-80-36-AC00-F2-3 6500K 1,500 1,425 1,665 80 CHM-9-65-80-36-AC00-F2-5 CHM-9-65-80-36-AC00-F2-3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Preliminary CHM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum 33.5 Power Operating Case Temperature4 Typical Maximum Unit 360 545 mA 35 37.5 V 12.6 20.4 W 105 ºC Tc Light Emitting Surface Diameter LES 9 mm Thermal Resistance (junction-to-case) Qjc 0.85 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: CHM-9 COB LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Refer to the current vs. case temperature derating curves for further information. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 7 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Preliminary CHM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 550 180% 500 Relative Luminous Flux 160% 450 Forward Current (mA) 140% 120% 100% 80% 60% 400 350 300 250 200 40% 150 20% 100 0% 100 150 200 250 300 350 400 450 32 500 33 34 Relative Output Flux vs. Junction Temperature 37 38 39 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 36 Change in Voltage vs. Junction Temperature 120.0% 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 35 Forward Voltage (V) Forward Current (mA) 0 0 -0.01 -0.01 -0.02 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 8 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CHM-9 Product Datasheet Preliminary CHM-9 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 9 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CHM-9 Product Datasheet Preliminary Mechanical Dimensions (AA00) Mechanical Dimensions (AC00) 10 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-9 Product Datasheet Preliminary Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 11 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover CHM-9 Product Datasheet Datasheet (Part #) Product Preliminary Handling Notes for XNova COBs XNova products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging XNova COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. XNova COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility XNova COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with XNova COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the XNova products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the XNova COB products. Storage: XNova products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling XNova COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions. XNova COB Specifications Changes to specifications can happen with out prior notice. The currently released data sheet will always be posted to the Luminus web site. Please refer to www.luminus. com for more information. 12 PDS-002451 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved
CHM-9-65-80-36-AC00-F2-5 价格&库存
很抱歉,暂时无法提供与“CHM-9-65-80-36-AC00-F2-5”相匹配的价格&库存,您可以联系我们找货
