CLM-9-35-95-36-AC30-F4-3
    LUMINUS(朗明纳斯)
CLM-9-35-95-36-AC30-F4-3 数据手册
CLM-9 Product Datasheet Generation 3 CLM-9 COB Arrays White LED Features: • High lumen output and efficacy typical Table of Contents • Over 1,215 lm, 150 LPW @ 3000K, 80CRI, Tj = 85ºC Technology Overview. . . . . . 2 • Over 1,380 lm, 170 LPW @ 5000K, 70CRI, Tj = 85ºC Test Specifications . . . . . . . . . 2 • CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K • 80 or 90 CRI min. up to 95 min. in warm white Chromaticity Bins. . . . . . . . . . 3 • 3 SDCM color binning accuracy Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • Excellent optical emission uniformity and color over angle consistency Part Numbers. . . . . . . . . . . . . . 5 Operating Characteristics . . 9 • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading • Environmentally friendly: RoHS and REACH compliant • UL recognized, file # E465703 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . 10 Spectra. . . . . . . . . . . . . . . . . . . 12 Mechanical Dimensions. . . 13 Packaging Information. . . . 14 Handling Notes. . . . . . . . . . . 15 Applications • Spotlights/Track Lights • Architectural and Specialty • Downlights • Street Lighting • Shop Lighting • Parking Lot and Area Lighting • Hospitality Lighting • Tunnel Lighting 1 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACH & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale datasheet specifications to real world situations. 2 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 2700K 0.44 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CLM-9 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. CCT Center Point Angle 3-step Bin 5-step Bin CIEx CIEy θ (°) a b 2700K 0.4578 0.4101 53.7 0.0081 0.0042 3000K 0.4338 0.403 53.2 0.00834 0.00408 3500K 0.4073 0.3917 54 0.00927 0.00414 4000K 0.3818 0.3797 53.7 0.00939 0.00402 5000K 0.3447 0.3553 59.6 0.00822 6500K 0.3123 0.3282 58.57 0.00669 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved a b 0.00354 0.0137 0.0059 0.00285 0.01115 0.00475 CLM-9 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CLM-9 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. Luminus may include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CLM 9 NN XX 36 QQPP FG W Product Family Light Emitting Surface Diameter Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CLM: Chip on Board, Multi-die 9.6: LES Diameter (mm) Color See Note 1 below CRI See Table Below Volts AC30 See Note 2 below Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Note 2: AC is standard package configurator AA is an alternative Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI *R9 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 95 >95 2700K, 3000K 3500K, 4000K, 5000K Note: >85 >75 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. *R9 values have a tolerance of +/- 5% 4 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet CLM-9 Part Numbers - AC30 36V The following tables describe products with typical flux and minimum flux measured at 240mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 3000K 3500K 4000K CRI (min.) 3-step MacAdam Ellipse Typ. 1,150 1,070 1,240 80 CLM-9-27-80-36-AC30-F4-3 950 880 1,025 90 CLM-9-27-90-36-AC30-F4-3 905 845 980 95 CLM-9-27-95-36-AC30-F4-3 1,215 1,130 1,310 80 CLM-9-30-80-36-AC30-F4-3 1,020 950 1,105 90 CLM-9-30-90-36-AC30-F4-3 955 885 1,030 95 CLM-9-30-95-36-AC30-F4-3 1,250 1,165 1,350 80 CLM-9-35-80-36-AC30-F4-3 1,040 970 1,125 90 CLM-9-35-90-36-AC30-F4-3 1,000 925 1,075 95 CLM-9-35-95-36-AC30-F4-3 1,360 1,265 1,470 70 CLM-9-40-70-36-AC30-F4-3 1,270 1,180 1,370 80 CLM-9-40-80-36-AC30-F4-3 1,100 1,025 1,190 90 CLM-9-40-90-36-AC30-F4-3 965 900 1,035 95 CLM-9-40-95-36-AC30-F4-3 Color Rendering Index Part Number CCT (25ºC) Reference Typ. Min.. (85ºC) (calculated) 1,380 1,285 1,275 Typ. (85ºC) 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min.. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 1,495 70 CLM-9-50-70-36-AC30-F4-5 CLM-9-50-70-36-AC30-F4-3 1,185 1,380 80 CLM-9-50-80-36-AC30-F4-5 CLM-9-50-80-36-AC30-F4-3 1,105 1,030 1,195 90 CLM-9-50-90-36-AC30-F4-5 CLM-9-50-90-36-AC30-F4-3 1,020 950 1,100 95 CLM-9-50-95-36-AC30-F4-5 CLM-9-50-95-36-AC30-F4-3 1,385 1,285 1,495 70 CLM-9-65-70-36-AC30-F4-5 CLM-9-65-70-36-AC30-F4-3 1,270 1,180 1,375 80 CLM-9-65-80-36-AC30-F4-5 CLM-9-65-80-36-AC30-F4-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet CLM-9 Part Numbers - AA30 36V The following tables describe products with typical flux and minimum flux measured at 240mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 3000K 3500K 4000K CRI (min.) 3-step MacAdam Ellipse Typ. 1,150 1,070 1,240 80 CLM-9-27-80-36-AA30-F4-3 950 880 1,025 90 CLM-9-27-90-36-AA30-F4-3 905 845 980 95 CLM-9-27-95-36-AA30-F4-3 1,215 1,130 1,310 80 CLM-9-30-80-36-AA30-F4-3 1,020 950 1,105 90 CLM-9-30-90-36-AA30-F4-3 955 885 1,030 95 CLM-9-30-95-36-AA30-F4-3 1,250 1,165 1,350 80 CLM-9-35-80-36-AA30-F4-3 1,040 970 1,125 90 CLM-9-35-90-36-AA30-F4-3 1,000 925 1,075 95 CLM-9-35-95-36-AA30-F4-3 1,360 1,265 1,470 70 CLM-9-40-70-36-AA30-F4-3 1,270 1,180 1,370 80 CLM-9-40-80-36-AA30-F4-3 1,100 1,025 1,190 90 CLM-9-40-90-36-AA30-F4-3 965 900 1,035 95 CLM-9-40-95-36-AA30-F4-3 Color Rendering Index Part Number CCT (25ºC) Reference Typ. Min.. (85ºC) (calculated) 1,380 1,285 1,275 Typ. (85ºC) 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min.. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 1,495 70 CLM-9-50-70-36-AA30-F4-5 CLM-9-50-70-36-AA30-F4-3 1,185 1,380 80 CLM-9-50-80-36-AA30-F4-5 CLM-9-50-80-36-AA30-F4-3 1,105 1,030 1,195 90 CLM-9-50-90-36-AA30-F4-5 CLM-9-50-90-36-AA30-F4-3 1,020 950 1,100 95 CLM-9-50-95-36-AA30-F4-5 CLM-9-50-95-36-AA30-F4-3 1,385 1,285 1,495 70 CLM-9-65-70-36-AA30-F4-5 CLM-9-65-70-36-AA30-F4-3 1,270 1,180 1,375 80 CLM-9-65-80-36-AA30-F4-5 CLM-9-65-80-36-AA30-F4-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet CLM-9 Part Numbers - AC30 18V The following tables describe products with typical flux and minimum flux measured at 240mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 3000K 3500K 4000K CRI (min.) 3-step MacAdam Ellipse Typ. 1,150 1,070 1,240 80 CLM-9-27-80-18-AC30-F4-3 950 880 1,025 90 CLM-9-27-90-18-AC30-F4-3 905 845 980 95 CLM-9-27-95-18-AC30-F4-3 1,215 1,130 1,310 80 CLM-9-30-80-18-AC30-F4-3 1,020 950 1,105 90 CLM-9-30-90-18-AC30-F4-3 955 885 1,030 95 CLM-9-30-95-18-AC30-F4-3 1,250 1,165 1,350 80 CLM-9-35-80-18-AC30-F4-3 1,040 970 1,125 90 CLM-9-35-90-18-AC30-F4-3 1,000 925 1,075 95 CLM-9-35-95-18-AC30-F4-3 1,360 1,265 1,470 70 CLM-9-40-70-18-AC30-F4-3 1,270 1,180 1,370 80 CLM-9-40-80-18-AC30-F4-3 1,100 1,025 1,190 90 CLM-9-40-90-18-AC30-F4-3 965 900 1,035 95 CLM-9-40-95-18-AC30-F4-3 Color Rendering Index Part Number CCT (25ºC) Reference Typ. Min.. (85ºC) (calculated) 1,380 1,285 1,275 Typ. (85ºC) 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min.. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 1,495 70 CLM-9-50-70-18-AC30-F4-5 CLM-9-50-70-18-AC30-F4-3 1,185 1,380 80 CLM-9-50-80-18-AC30-F4-5 CLM-9-50-80-18-AC30-F4-3 1,105 1,030 1,195 90 CLM-9-50-90-18-AC30-F4-5 CLM-9-50-90-18-AC30-F4-3 1,020 950 1,100 95 CLM-9-50-95-18-AC30-F4-5 CLM-9-50-95-18-AC30-F4-3 1,385 1,285 1,495 70 CLM-9-65-70-18-AC30-F4-5 CLM-9-65-70-18-AC30-F4-3 1,270 1,180 1,375 80 CLM-9-65-80-18-AC30-F4-5 CLM-9-65-80-18-AC30-F4-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 7 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet CLM-9 Part Numbers - AA30 18V The following tables describe products with typical flux and minimum flux measured at 240mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 3000K 3500K 4000K CRI (min.) 3-step MacAdam Ellipse Typ. 1,150 1,070 1,240 80 CLM-9-27-80-18-AA30-F4-3 950 880 1,025 90 CLM-9-27-90-18-AA30-F4-3 905 845 980 95 CLM-9-27-95-18-AA30-F4-3 1,215 1,130 1,310 80 CLM-9-30-80-18-AA30-F4-3 1,020 950 1,105 90 CLM-9-30-90-18-AA30-F4-3 955 885 1,030 95 CLM-9-30-95-18-AA30-F4-3 1,250 1,165 1,350 80 CLM-9-35-80-18-AA30-F4-3 1,040 970 1,125 90 CLM-9-35-90-18-AA30-F4-3 1,000 925 1,075 95 CLM-9-35-95-18-AA30-F4-3 1,360 1,265 1,470 70 CLM-9-40-70-18-AA30-F4-3 1,270 1,180 1,370 80 CLM-9-40-80-18-AA30-F4-3 1,100 1,025 1,190 90 CLM-9-40-90-18-AA30-F4-3 965 900 1,035 95 CLM-9-40-95-18-AA30-F4-3 Color Rendering Index Part Number CCT (25ºC) Reference Typ. Min.. (85ºC) (calculated) 1,380 1,285 1,275 Typ. (85ºC) 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min.. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 1,495 70 CLM-9-50-70-18-AA30-F4-5 CLM-9-50-70-18-AA30-F4-3 1,185 1,380 80 CLM-9-50-80-18-AA30-F4-5 CLM-9-50-80-18-AA30-F4-3 1,105 1,030 1,195 90 CLM-9-50-90-18-AA30-F4-5 CLM-9-50-90-18-AA30-F4-3 1,020 950 1,100 95 CLM-9-50-95-18-AA30-F4-5 CLM-9-50-95-18-AA30-F4-3 1,385 1,285 1,495 70 CLM-9-65-70-18-AA30-F4-5 CLM-9-65-70-18-AA30-F4-3 1,270 1,180 1,375 80 CLM-9-65-80-18-AA30-F4-5 CLM-9-65-80-18-AA30-F4-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 8 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet CLM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter - 36V Symbol Forward Current2 If Forward Voltage3 Vf Parameter - 18V Symbol Forward Current Minimum Typical Maximum Unit 240 540 mA 31 33.8 37 V Minimum Typical Maximum Unit 480 1080 mA 2 If Forward Voltage3 Vf 15.5 16.9 18.5 V Symbol Minimum Typical Maximum Unit 8.16 20 W 105 ºC Parameter Power Operating Case Temperature 4 Tc Light Emitting Surface Diameter LES 9.6 mm Thermal Resistance (junction-to-case) Qjc 0.65 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: Device operation not recommended at drive currents less than 10% of the typical value Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 6: All product operating specifications are subject to change without advance notice. 9 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved CLM-9 Product Datasheet CLM-9 Optical & Electrical Characteristics - 36V Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 220% 540 200% 490 180% 440 Forward Current (mA) Relative Luminous Flux 160% 140% 120% 100% 80% 60% 390 340 290 240 190 40% 140 20% 0% 90 140 190 240 290 340 390 Forward Current (mA) 440 490 90 540 Relative Output Flux vs. Junction Temperature 34 35 Forward Voltage (V) 80% 60% 36 34 32 5 15 25 35 45 55 65 75 85 95 105 30 5 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 37 38 100% 0 0 -0.01 -0.01 -0.02 36 40 Forward Voltage (V) Relative Luminous Flux 33 Change in Voltage vs. Junction Temperature 120% 40% 32 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 10 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CLM-9 Product Datasheet CLM-9 Optical & Electrical Characteristics - 18V Forward Current vs. Forward Voltage @ 85ºC 210% 1080 190% 980 170% 880 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 150% 130% 110% 90% 780 680 580 480 70% 380 50% 280 30% 80 180 280 380 480 580 680 780 880 980 180 1080 16 16.5 17 Forward Current (mA) Relative Output Flux vs. Junction Temperature 18.5 Forward Voltage (V) 100% Relative Luminous Flux 19 80% 60% 40% 18 17.5 17 16 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 45 55 65 75 85 95 105 Junction Temperature (℃) Forward Current (mA) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 18.5 16.5 20% 0 0 -0.01 -0.01 -0.02 18 Change in Voltage vs. Junction Temperature 120% 0% 17.5 Forward Voltage (V) 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 11 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CLM-9 Product Datasheet CLM-9 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 12 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CLM-9 Product Datasheet Mechanical Dimensions (AC30) Shipping Container (AC30) 400 pcs per box Each bag is boxed for easier storage/ stacking 80 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 13 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc CLM-9 Product Datasheet Mechanical Dimensions (AA30) Shipping Container (AA30) 300 pcs per box Each bag is boxed for easier storage/ stacking 60 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 14 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc CLM-9 Product Datasheet Datasheet (Part #) Product Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guidelines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 15 PDS-002816 Rev 06 © 2020 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
物料型号:Luminus CLM-9 COB Arrays
器件简介:Luminus的COB LED系列提供高性能照明应用的完整照明解决方案,涵盖从少于400lm到超过10,000lm的广泛流明范围,所有主要色温和超过97的显色指数。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 高流明输出和效率典型值 - 色温范围2700K至6500K - 显色指数(CRI)最小80,暖白色可达到95 - 3 SDCM色度精度 - 出色的光学发射均匀性和颜色角度一致性 - 卓越的长期颜色稳定性 - 优越的热传导性,实现均匀的热扩散 - 符合RoHS和REACH环保标准 - UL认可,文件编号E465703
功能详解: - 可靠性:经过一系列环境和机械应力测试 - 了解Luminus COB LED测试规范:每个LED都经过全面测试以确保满足高质量标准 - 色度分选提供每个订单的颜色一致性 - 测试温度:在LED在灯具中工作时的典型温度下测量
应用信息: - 聚光灯/轨道灯 - 建筑和特殊照明 - 筒灯 - 街道照明 - 商店照明 - 停车场和区域照明 - 酒店照明 - 隧道照明
封装信息: - 提供不同色温和显色指数的多种产品编号 - 产品包装和标签包含部件编号 - 提供18V和36V的产品选项
CLM-9-35-95-36-AC30-F4-3 价格&库存
很抱歉,暂时无法提供与“CLM-9-35-95-36-AC30-F4-3”相匹配的价格&库存,您可以联系我们找货
  • 2400+15.743452400+2.04270
