LTPL-M08218ZS27-T0
LTPL-M08218ZS27-T0
    LITE-ON(光宝)
    SMD
    LED COB CCT 2700K 80CRI 24W SMD
LTPL-M08218ZS27-T0 数据手册
LIGHT LED M08 CoB Product Series 1. Description The LiteON CoB Product series is a revolutionary, energy efficient and ultra-compact new light source, combining the lifetime and reliability advantages of Light Emitting Diodes with the brightness of conventional lighting. It gives you total design freedom and unmatched brightness, creating a new opportunities for solid state lighting to displace conventional lighting technologies. 1.1 Features        Compact high flux density light source Uniform high quality illumination Streamlined thermal path MacAdam compliant binning structure More energy efficient than incandescent, halogen and fluorescent lamps Instant light with unlimited dimming RoHS compliant and Pb free 1.2 Benefits Features       Enhanced optical control Clean white light without pixilation Uniform consistent white light Significantly reduced thermal resistance and increased operating temperatures Lower operating costs Reduced maintenance costs 1.3 Naming Rule 1/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 1.4 Product List Color Bin PN Series CCT Lumen Bin CRI 3SDCM 5SDCM ANSI -8%~+8% -15%~+15% LTPL-M08206ZS27-T0 6 2700K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08206ZS30-T0 6 3000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08206ZS40-T0 6 4000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08210ZS27-T0 10 2700K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08210ZS30-T0 10 3000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08210ZS40-T0 10 4000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08218ZS27-T0 18 2700K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08218ZS30-T0 18 3000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08218ZS40-T0 18 4000K 80 ☆ ☆ ☆ ☆ ☆ LTPL-M08206QS30-T0 6 3000K 90 ☆ ☆ ☆ ☆ ☆ LTPL-M08210QS30-T0 10 3000K 90 ☆ ☆ ☆ ☆ ☆ LTPL-M08218QS30-T0 18 3000K 90 ☆ ☆ ☆ ☆ ☆ 2/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 2. Outline Dimensions 2.1 Form Factor of M082 series CoB Notes 1. All dimensions are in millimeters. 2. Tolerance is ±0.3mm unless otherwise noted. 2.2 Internal Equivalent Circuit 06 Series Product 10 Series Product 18 Series Product Notes 1. LED of equivalent circuit means all series/parallel in CoB package. 3/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 3. Absolute Maximum Ratings at Ta=25°C Parameter Power Dissipation Forward Current Symbol Rating 6 8 10 16 18 24 6 200 10 400 18 600 PO IF Junction Temperature Thermal Resistance, Junction-Case Product Series Tj Rth, J-C Unit W mA 125 6 2.04 10 1.2 18 0.9 °C °C/W Operating Temperature Range Topr -40 to 85 °C Storage Temperature Range Tstg -40 to 100 °C Notes 1. 2. 3. 4. The pulse mode condition is 1/10 duty cycle with 100 msec. pulse width. Forbid to be operated at reverse voltage condition. The unit of Rth is °C/W electrical. The M08 CoB is recommended soldering temperature under 350degC and could not over 3.5sec. 4/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 4. Electro-Optical Characteristics 4.1 Typical Performance Dominant Product CRI Current VF (V) Flux(lm) VF (V) Flux(lm) Eff.(lm/W) Eff.(lm/W) CCT Series min. (mA) @25°C @25°C @85°C @85°C @25°C @85°C 6 80 120 37.0 596 35.8 531 134 124 10 80 240 37.0 1121 35.8 998 126 116 18 80 360 37.0 1720 35.8 1531 129 119 6 80 120 37.0 621 35.8 553 140 129 10 80 240 37.0 1168 35.8 1040 132 121 18 80 360 37.0 1792 35.8 1595 135 124 6 80 120 37.0 658 35.8 586 148 136 10 80 240 37.0 1238 35.8 1102 139 128 18 80 360 37.0 1900 35.8 1691 143 131 6 90 120 37.0 515 35.8 459 116 107 10 90 240 37.0 969 35.8 863 109 100 18 90 360 37.0 1487 35.8 1324 112 103 2700K 3000K 4000K 3000K Notes 1. 2. 3. 4. All of VF value are typical, the real bin range please refer page 16 ” VF Binning Parameter”. All of flux value are typical, the real bin range please refer page 13 ”Flux Binning Parameter”. Tolerance of flux is ±7%, tolerance of CCX/CCY is ±0.007, tolerance of CRI is ±2, and tolerance of VF is ±3%. Typical viewing angle is 120deg. 5/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 4.2 Forward Current vs. Lumen Voltage  06 Series Product Lumen (lm) Current VF CRI 80 CRI 90 (mA) (V) 2700K 3000K 4000K 3000K 60 34.5 323 337 357 280 70 34.9 371 387 410 321 80 35.3 419 436 462 362 90 35.7 466 485 514 403 100 36.1 507 529 560 439 110 36.6 554 577 611 479 120 37.0 596 621 658 515 130 37.4 636 663 702 550 140 37.8 677 705 747 585 150 38.2 714 744 788 617 160 38.7 757 788 836 654 170 39.1 793 826 875 686 180 39.5 829 863 915 716 200 40.3 912 950 1007 789 6/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series  10 Series Product Lumen (lm) Current VF CRI 80 CRI 90 (mA) (V) 2700K 3000K 4000K 3000K 120 34.5 608 634 672 526 140 34.9 698 727 771 603 160 35.3 790 822 872 683 180 35.7 877 913 968 758 200 36.1 956 996 1056 827 220 36.6 1040 1084 1149 900 240 37.0 1121 1168 1238 969 260 37.4 1204 1254 1330 1041 280 37.8 1266 1318 1397 1094 300 38.2 1347 1403 1487 1164 320 38.7 1415 1474 1562 1223 340 39.1 1490 1552 1645 1288 360 39.5 1567 1633 1731 1355 400 40.3 1727 1799 1907 1493 7/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series  18 Series Product Lumen (lm) Current VF CRI 80 CRI 90 (mA) (V) 2700K 3000K 4000K 3000K 150 34.0 800 833 883 691 180 34.5 943 983 1042 816 210 34.9 1089 1134 1202 941 240 35.3 1229 1280 1357 1062 270 35.7 1366 1423 1508 1181 300 36.1 1482 1544 1637 1282 360 37.0 1720 1792 1900 1487 390 37.4 1853 1931 2046 1602 420 37.8 1961 2043 2166 1696 450 38.2 2065 2151 2280 1785 480 38.7 2193 2284 2421 1896 510 39.1 2288 2383 2526 1978 540 39.5 2373 2472 2620 2051 600 40.3 2563 2670 2830 2216 8/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 4.3 Relative Spectral Power Distribution at Typical Current 4.4 Radiation Characteristics 0° 100% 90% 30° Relative Intensity (%) 80% 70% 60% 60° 50% 40% 30% 20% 10% 0% 90° 60 30° 0° 50 9/19 100 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 4.5 Forward Current vs. Forward Voltage 4.6 Forward Current Degrading Curve 10/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 4.7 Relative Intensity vs. Case Temperature 4.8 Forward Voltage vs. Case Temperature 11/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 5. CoB Binning Definition  Example of M08 Series Product Bin (2700K 06 series)  Flux Binning Parameter (25degC) Lumen CODE List of M08 Series Product Parameter Code Unit Lumen (lm) 2700K Lumen CCT C 495 Bin Range D 535 DE 535~580 E 580 EG 580~675 F 625 GH 675~730 G 675 H 730 I 790 J 850 K 920 L 990 Lumen Range Bin Code Luminous lm Flux M 1070 N 1155 O 1245 P 1345 Q 1455 R 1570 S 1695 T 1830 U 1975 V 2130 Main Bin C D -15%~-8% F -8%~+8% G +8%~+15% Full Bins 12/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series  06 Series Lumen Bin Lumen (lm) CRI 80 2700K CRI 90 3000K 4000K 3000K Bin Range Bin Range Bin Range Bin Range DE 535~580 DE 535~580 EF 580~625 BC 460~495 EG 580~675 EG 580~675 FH 625~730 CE 495~580 GH 675~730 GH 675~730 HI 730~790 EF 580~625  10 Series Lumen Bin Lumen (lm) CRI 80 2700K CRI 90 3000K 4000K 3000K Bin Range Bin Range Bin Range Bin Range LM 990~1070 LM 990~1070 MN 1070~1155 JK 850~920 MO 1070~1245 MO 1070~1245 NP 1155~1345 KM 920~1070 OP 1245~1345 OP 1245~1345 PQ 1345~1455 MN 1070~1155  18 Series Lumen Bin Lumen (lm) CRI 80 2700K CRI 90 3000K 4000K 3000K Bin Range Bin Range Bin Range Bin Range QR 1455~1570 RS 1570~1695 RS 1570~1695 OP 1245~1345 RT 1570~1830 SU 1695~1975 SU 1695~1975 PR 1345~1570 TU 1830~1975 UV 1975~2130 UV 1975~2130 RS 1570~1695 13/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series  Example of LiteOn CoB MacAdam Ellipse Color Definition (EX: 2700K) Solid line in red/blue/black is 3SDCM/5SDCM/ANSI at 25degC. D3 It is shipping Spec. of LiteOn. D2 D1 Dotted line in light gray is 3SDCM/5SDCM/ANSI at 85degC and the CCX/CCY center follows ANSI. CIE Center Point 25degC (LiteOn Spec.) 85degC (ANSI) Hot/Cold Factor CCT CCX CCY CCX CCY CCX CCY 2700 0.4611 0.4137 0.4578 0.4101 -0.0033 -0.0036 3000 0.4381 0.4077 0.4338 0.4030 -0.0043 -0.0047 4000 0.3869 0.3860 0.3818 0.3797 -0.0051 -0.0063 Notes 1. 2. 3. 4. LiteOn tester and shipping spec follow the color bin with 25degC CCX/CCY center. The Hot/Cold factor means the CCX/CCY shift from 25degC to 85degC. The Hot/Cold shift is measured by LiteOn CAS 140B instrument system. 2 2 0.5 The ellipse equation expression: SDCM = (g11*(x-x0) + 2*g12*(x-x0)*(y-y0) + g22*(y-y0) ) 14/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series  M08 2700K  M08 3000K 15/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series  M08 4000K  Forward Voltage Binning Parameter (25degC) Parameter Bin Symbol Min Max Unit Condition Forward Voltage V1 VF 33 42.0 V IF =Typical Current Note: 1. Full Rank on Label. ( Example: V1/EG/D1 ) Forward Voltage Rank Luminous Flux Rank Color Rank V1 EG D1 16/19 Part No. : M08 CoB Product Series BNS-OD-FC002/A4 LIGHT LED M08 CoB Product Series 6. Reliability Test Plan No Test item Condition Duration Result 1 High Temperature Operating Life Tc=85°C, IF=Typical Current 1K hours Pass 2 Wet High Temperature Operating 60°C/90%RH, IF=Typical Current(DC) 1K hours Pass Life 30 min ON/OFF Thermal Shock -40°C to 125°C, 15minutes dwell,
LTPL-M08218ZS27-T0 价格&库存
很抱歉,暂时无法提供与“LTPL-M08218ZS27-T0”相匹配的价格&库存,您可以联系我们找货
