CXM-11-27-80-36-AB00-F2-3
    LUMINUS(朗明纳斯)
    LEDCOB
CXM-11-27-80-36-AB00-F2-3 数据手册
Sensus™ LED Series Product Datasheet Generation 3 Sensus™ LED Series Pure White Targeted COB Arrays Below the Black Body Locus (BBBL) Features: • Matching the human perception of “Pure white” light Table of Contents Technology Overview. . . . . . 2 • Designed to provide the look and feel of ceramic metal halide lights • Wide product range from 1,000lm to over 10,000lm • 3000K and 3500K, 80 and 90CRI standard Test Specifications . . . . . . . . . 2 • Highly saturated color rendering version in 3000K and 3500K Chromaticity Bins. . . . . . . . . . 3 • 3 SDCM color binning accuracy Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 Product Typical Flux Range. 5 Operating Characteristics . . 9 • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Package thermal conductivity more than the industry average • Environmentally friendly: RoHS and REACH compliant • UL Recognized, File # E465703 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . 13 Spectra. . . . . . . . . . . . . . . . . . . 21 Mechanical Dimensions. . . 22 Packaging Information. . . . 23 Handing notes. . . . . . . . . . . . 31 Applications • Retail Shop Lighting • Halogen replacement LED lamps • Spotlights/Track Lights • Hospitality Lighting • CMH replacement LED lamps • Architectural and Specialty 1 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Sensus LED™ Series Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The Sensus LED series has been specially design for retail shop lighting where enhanced red coloring is a preferred lighting standard. The selection covers a wide lumen range from less than 500lm to over 10,000lm, and is focused on the major market color and CRI of 3000K and both 80 and 90 CRI. These breakthroughs allow illumination engineers and designers to develop beautifully lit spaces without sacrificing efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM-80 test data and TM-21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2 SDCM. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve ANSI C78.377-2008 0.45 3-SDCM Sensus 3-SDCM Xtreme Sensus 3000K 0.43 3500K 0.41 CIEy Black Body Locus 0.39 0.37 0.35 0.33 0.37 0.38 0.39 0.40 0.41 0.42 0.43 0.44 0.45 0.46 0.47 CIEx Sensus™ LED White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Description Standard Xtreme Standard Xtreme *Note: CCT 3000K 3500K Center Point 3-step Bin CIEx CIEy θ (°) 0.4252 0.3877 53.6 0.4210 0.3720 53.2 0.4067 0.3845 54 0.3980 0.3660 54 Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved a b 0.00834 0.00408 0.00927 0.00414 Sensus™ LED Series Product Datasheet Product Ordering and Shipping Part Number Nomenclature All Sensus LED products are packaged and labeled with part numbers as outlined in the table on page 5. Luminus will include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM XX 30 80 36 QQPP FG W Product Family Light Emitting Surface Diameter1 Color Temperature2 Color Rendering Index (CRI)3 Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CIM/ CLM/ CXM: Chip on Board XX: LES Diameter (mm) Approximate CCT XX Volts Also 54V in some cases AA32 (Basic package) Lumens See page 3 for bins Note 1 : XX nomenclature corresponds to the following: 9 = 9.6 mm 11 = 11.6 mm 14 = 14.3 mm 18 = 17.5 mm 22 = 22 mm 27 = 26.5mm Note 2: CT Nomenclature corresponds to the following 30 is 3000K 35 is 3500K Note 3: XX Color Rendering nomenclature corresponds to the following 80 = 80 CRI 90 = 90 CRI Note 4: AA32 is the Standard Sensus and a standard substrate size AA34 is the Xtreme Sensus and a standard substrate size AC32 and XD22 is the Standard Sensus and alternative substrate size AC34 is the Xtreme Sensus and an alternative substrate size Color Temperature, CRI and R9 Values Color Temperatures 3000K, 3500K Note: XX Value CRI R9 80 >80 >0 90 >90 >50 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Sensus™ LED Series Part Numbers The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) LES Diamenter (mm) Typ. Current (mA) 3 SDCM (25ºC) 665 620 715 CXM-6-30-80-36-AA32-F4-3 560 525 605 CXM-6-30-90-36-AA32-F4-3 685 635 735 CXM-6-35-80-36-AA32-F4-3 570 530 615 665 620 715 560 525 605 CXM-6-30-90-36-AC32-F4-3 685 635 735 CXM-6-35-80-36-AC32-F4-3 570 530 615 CXM-6-35-90-36-AC32-F4-3 665 620 715 CXM-6-30-80-18-AA32-F4-3 560 525 605 685 635 735 570 530 615 CXM-6-35-90-18-AA32-F4-3 860 800 925 CIM-9-30-80-36-AC32-F4-3 720 670 780 885 820 955 735 685 795 CIM-9-35-90-36-AC32-F4-3 1,155 1,075 1,245 CLM-9-30-80-36-AA32-F4-3 970 905 1,050 CLM-9-30-90-36-AA32-F4-3 1,190 1,105 1,285 CLM-9-35-80-36-AA32-F4-3 990 920 1,070 1,155 1,075 1,245 970 905 1,050 CLM-9-30-90-36-AC32-F4-3 1,190 1,105 1,285 CLM-9-35-80-36-AC32-F4-3 990 920 1,070 CLM-9-35-90-36-AC32-F4-3 *Note: 6.3 6.3 9.6 9.6 Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 150 300 180 240 CXM-6-35-90-36-AA32-F4-3 CXM-6-30-80-36-AC32-F4-3 CXM-6-30-90-18-AA32-F4-3 CXM-6-35-80-18-AA32-F4-3 CIM-9-30-90-36-AC32-F4-3 CIM-9-35-80-36-AC32-F4-3 CLM-9-35-90-36-AA32-F4-3 CLM-9-30-80-36-AC32-F4-3 Sensus™ LED Series Product Datasheet Sensus™ LED Series Part Numbers The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) LES Diamenter (mm) Typ. Current (mA) 3 SDCM (25ºC) 1,690 1,570 1,860 CXM-9-30-80-36-AC32-F4-3 1,425 1,325 1,565 1,745 1,620 1,915 1,450 1,350 1,595 CXM-9-35-90-36-AC32-F4-3 1,605 1,490 1,735 CHM-9-30-80-36-XD22-F4-3 1,350 1,255 1,455 1,655 1,540 1,780 1,380 1,285 1,485 CHM-9-35-90-36-XD22-F4-3 2,165 1,990 2,315 CXM-11-30-80-36-AA32-F4-3 1,820 1,675 1,950 CXM-11-30-90-36-AA32-F4-3 2,230 2,050 2,385 CXM-11-35-80-36-AA32-F4-3 1,860 1,710 1,985 2,165 1,990 2,315 1,820 1,675 1,950 CXM-11-30-90-36-AC32-F4-3 2,230 2,050 2,385 CXM-11-35-80-36-AC32-F4-3 1,860 1,710 1,985 CXM-11-35-90-36-AC32-F4-3 2,215 2,055 2,390 CIM-14-30-80-36-AC32-F4-3 1,860 1,735 2,010 2,280 2,125 2,460 1,900 1,765 2,050 CIM-14-35-90-36-AC32-F4-3 2,415 2,235 2,590 CLM-14-30-80-36-AA32-F4-3 2,030 1,875 2,180 CLM-14-30-90-36-AA32-F4-3 2,480 2,300 2,670 CLM-14-35-80-36-AA32-F4-3 2,065 1,915 2,225 2,415 2,235 2,590 2,030 1,875 2,180 CLM-14-30-90-36-AC32-F4-3 2,480 2,300 2,670 CLM-14-35-80-36-AC32-F4-3 2,065 1,915 2,225 CLM-14-35-90-36-AC32-F4-3 9.6 9.6 11.6 14.3 14.3 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 360 360 450 450 500 CXM-9-30-90-36-AC32-F4-3 CXM-9-35-80-36-AC32-F4-3 CHM-9-30-90-36-XD22-F4-3 CHM-9-35-80-36-XD22-F4-3 CXM-11-35-90-36-AA32-F4-3 CXM-11-30-80-36-AC32-F4-3 CIM-14-30-90-36-AC32-F4-3 CIM-14-35-80-36-AC32-F4-3 CLM-14-35-90-36-AA32-F4-3 CLM-14-30-80-36-AC32-F4-3 Sensus™ LED Series Product Datasheet Sensus™ LED Series Part Numbers The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) LES Diamenter (mm) Typ. Current (mA) 3 SDCM (25ºC) 3,420 3,120 3,620 CXM-14-30-80-36-AA32-F4-3 2,880 2,620 3,050 CXM-14-30-90-36-AA32-F4-3 3,525 3,210 3,730 CXM-14-35-80-36-AA32-F4-3 2,935 2,675 3,105 3,420 3,120 3,620 2,880 2,620 3,050 CXM-14-30-90-36-AC32-F4-3 3,525 3,210 3,730 CXM-14-35-80-36-AC32-F4-3 2,935 2,675 3,105 CXM-14-35-90-36-AC32-F4-3 4,375 4,070 4,725 CXM-18-30-80-36-AA32-F4-3 3,680 3,420 3,975 4,505 4,190 4,865 3,750 3,490 4,055 CXM-18-35-90-36-AA32-F4-3 5465 5085 5895 CLM-22-30-80-36-AC32-F4-3 4595 4275 4955 5625 5230 6065 4690 4360 5060 CLM-22-35-90-36-AC32-F4-3 7,870 7,320 8,505 CXM-22-30-80-54-AC32-F4-3 6,620 6,155 7,150 8,105 7,540 8,755 6,750 6,280 7,290 CXM-22-35-90-54-AC32-F4-3 11,780 10,955 12,720 CXM-27-30-80-54-AB32-F4-3 9,910 9,215 10,700 12,130 11,280 13,100 10,110 9,400 10,915 14.3 17.5 22 22 26.5 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 7 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 720 900 1,100 1,100 1,600 CXM-14-35-90-36-AA32-F4-3 CXM-14-30-80-36-AC32-F4-3 CXM-18-30-90-36-AA32-F4-3 CXM-18-35-80-36-AA32-F4-3 CLM-22-30-90-36-AC32-F4-3 CLM-22-35-80-36-AC32-F4-3 CXM-22-30-90-54-AC32-F4-3 CXM-22-35-80-54-AC32-F4-3 CXM-27-30-90-54-AB32-F4-3 CXM-27-35-80-54-AB32-F4-3 CXM-27-35-90-54-AB32-F4-3 Sensus™ LED Series Product Datasheet Xtreme Sensus™ LED Series Part Numbers The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) LES Diamenter (mm) Typ. Current (mA) 9.6 180 9.6 360 3 SDCM (25ºC) 620 580 670 635 590 685 1,235 1,150 1,240 1,260 1,170 1,260 1,580 1,470 1,585 1,615 1,500 1,620 1,580 1,470 1,585 1,615 1,500 1,620 1,605 1,495 1,735 1,640 1,520 1,765 1,640 1,520 1,765 1,670 1,555 1,800 1,640 1,520 1,765 1,670 1,555 1,800 CLM-14-35-90-36-AA34-F4-3 2,520 2,345 2,530 CXM-14-30-90-36-AC34-F4-3 2,570 2,390 2,580 2,520 2,345 2,530 2,570 2,390 2,580 3,575 3,325 3,590 3,645 3,390 3,660 3,750 3,490 3,765 3,830 3,565 3,845 11.6 14.3 CXM-9-35-90-36-AC34-F4-3 450 CXM-11-35-90-36-AC34-F4-3 CXM-11-30-90-36-AA34-F4-3 450 CIM-14-30-90-36-AC34-F4-3 CIM-14-35-90-36-AC34-F4-3 CLM-14-30-90-36-AC34-F4-3 14.3 14.3 500 720 CLM-14-35-90-36-AC34-F4-3 CLM-14-30-90-36-AA34-F4-3 CXM-14-35-90-36-AC34-F4-3 CXM-14-30-90-36-AA34-F4-3 CXM-14-35-90-36-AA34-F4-3 17.5 900 22 1100 Luminus maintains a +/- 2% tolerance on CRI measurements. © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-9-30-90-36-AC34-F4-3 CXM-11-35-90-36-AA34-F4-3 Luminus maintains a +/- 6% tolerance on flux measurements. PDS-002832 Rev 11 CIM-9-35-90-36-AC34-F4-3 CXM-11-30-90-36-AC34-F4-3 *Note: 8 CIM-9-30-90-36-AC34-F4-3 CXM-18-30-90-36-AA34-F4-3 CXM-18-35-90-36-AA34-F4-3 CLM-22-30-90-36-AC34-F4-3 CLM-22-35-90-36-AC34-F4-3 Sensus™ LED Series Product Datasheet CXM-6 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Minimum Typical Maximum Unit Forward Current (36V)2 If 150 325 mA 2 Forward Current (18V) If 300 650 mA Forward Voltage (36V)3 Vf 31 34.6 37 V Forward Voltage(18V)3 Vf 15.5 17.3 18.5 V 5.2 11.8 W 105 ºC Power Operating Case Temperature Tc 4 Light Emitting Surface Diameter LES 6.3 mm Thermal Resistance (junction-to-case) Qjc 0.96 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CIM-9 Operating Characteristics1 Optical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum 31.8 Power Operating Case Temperature Typical Maximum Unit 180 360 mA 33.8 35.8 V 6.1 13.2 W 105 ºC Tc 4 Light Emitting Surface Diameter LES 9.6 mm Thermal Resistance (junction-to-case) Qjc 0.9 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CLM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Power Operating Case Temperature4 Minimum 31 Typical Maximum Unit 240 540 mA 33.8 37 V 8.2 20 W 105 ºC Tc Light Emitting Surface Diameter LES 9.6 mm Thermal Resistance (junction-to-case) Qjc 0.65 ºC/W Junction Temperature Tj Viewing Angle 120 9 PDS-002832 Rev 11 140 © 2017 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet CXM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum 31 Power Typical Maximum Unit 360 720 mA 34 37 V 12.2 27 W 100 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 9.6 mm Thermal Resisitance (junction-to-case) Qjc 0.5 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum 31 Power Typical Maximum Unit 360 960 mA 34 37 V 12.2 37.4 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 9.6 mm Thermal Resisitance (junction-to-case) Qjc 0.5 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-11 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Power Minimum 31 Typical Maximum Unit 450 1,080 mA 33.8 37 V 15.2 40.5 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 11.6 mm Thermal Resisitance (junction-to-case) Qjc 0.35 ºC/W Junction Temperature Tj Viewing Angle 120 10 PDS-002832 Rev 11 140 © 2017 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CIM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum 31 Power Typical Maximum Unit 450 1,080 mA 34 37 V 15 40 W 105 ºC Operating Case Temperature Tc Light Emitting Surface Diameter LES 14.3 mm Thermal Resisitance (junction-to-case) Qjc 0.32 ºC/W Junction Temperature Tj 4 140 Viewing Angle 120 ºC Degree CLM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Power Minimum 31 Typical Maximum Unit 500 1,260 mA 33.8 37 V 17 47 W 105 ºC Operating Case Temperature Tc Light Emitting Surface Diameter LES 14.3 mm Thermal Resisitance (junction-to-case) Qjc 0.31 ºC/W Junction Temperature Tj 4 Viewing Angle 120 11 PDS-002832 Rev 11 140 © 2017 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum 31 Power Typical Maximum Unit 720 1,440 mA 34 37 V 24.5 54 W 105 ºC Operating Case Temperature Tc Light Emitting Surface Diameter LES 14.3 mm Thermal Resisitance (junction-to-case) Qjc 0.27 ºC/W Junction Temperature Tj 4 140 Viewing Angle 120 ºC Degree CXM-18 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum 31 Power Typical Maximum Unit 900 1,800 mA 34 37 V 30.6 64 W 105 ºC Operating Case Temperature Tc Light Emitting Surface Diameter LES 17.5 mm Thermal Resisitance (junction-to-case) Qjc 0.21 ºC/W Junction Temperature Tj 4 140 Viewing Angle 120 ºC Degree CLM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Power Minimum 31 Typical Maximum Unit 1,100 2,200 mA 33.8 37 V 37.2 82 W 105 ºC Operating Case Temperature Tc Light Emitting Surface Diameter LES 22 mm Thermal Resisitance (junction-to-case) Qjc 0.19 ºC/W Junction Temperature Tj 4 120 Viewing Angle 12 PDS-002832 Rev 11 140 © 2017 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet CXM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum 50 Power Typical Maximum Unit 1,100 2,200 mA 51 55 V 56.1 125 W 105 ºC Operating Case Temperature Tc Light Emitting Surface Diameter LES 22 mm Thermal Resisitance (junction-to-case) Qjc 0.17 ºC/W Junction Temperature Tj 4 140 Viewing Angle 120 ºC Degree CXM-27 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage Vf 3 Minimum 48 Power Typical Maximum Unit 1,600 3,200 mA 51 56 V 82 180 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 26.5 mm Thermal Resisitance (junction-to-case) Qjc 0.15 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Operating Characteristics Notes Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs. Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not harm the device but may result in uneven light emission across the LES surface. Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 13 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-6, 36V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 220% 325 355 180% 200% 305 275 Forward (mA) Forward Current Current (mA) Relative Flux Relative Luminous Luminous Flux 160% 180% 140% 160% 140% 120% 120% 100% 100% 80% 80% 60% 60% 40% 255 225 205 175 155 125 105 40% 20% 20% 0% 55 75 105125 155 175 205 225 255 275305 Forward Current Current(mA) (mA) 55 75 32.5 33 355 325 Relative Output Flux vs. Junction Temperature 3434.5 34.5 35 35 35.5 35.5 36 36 Forward Voltage Voltage(V) (V) 36.5 36.5 3737 37.5 37.5 38 38 40 100% 38 Forward Voltage (V) Relative Luminous Flux 33.534 Change in Voltage vs. Junction Temperature 120% 80% 60% 40% 36 34 32 20% 0% 33 33.5 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CXM-6, 18V Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 650 Forward Current (mA) Relative Luminous Flux 180% 160% 140% 120% 100% 80% 450 350 250 150 60% 40% 550 50 150 250 350 450 Forward Current (mA) 14 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 550 650 50 16 17 Forward Voltage (V) 18 19 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-6, 18V Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 20 120% 19 Forward Voltage (V) Relative Luminous Flux 100% 80% 60% 40% 17 16 20% 0% 18 15 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) Junction Temperature (ºC) 75 85 95 105 CIM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 360 170% Forward Current (mA) Relative Luminous Flux 200% 140% 110% 80% 240 180 120 50% 20% 300 60 120 180 240 300 60 360 31 32 33 Forward Current (mA) 100% 37 Forward Voltage (V) Relative Luminous Flux) 38 80% 60% 35 34 20% 33 32 25 35 45 55 65 75 Junction Temperature (ºC ) 15 PDS-002832 Rev 11 37 36 40% 15 36 Change in Voltage vs. Junction Temperature 120% 5 35 Forward Voltage (V) Relative Output Flux vs. Junction Temperature 0% 34 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC ) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CLM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 220% 540 200% 490 440 160% Forward Current (mA) Relative Luminous Flux 180% 140% 120% 100% 80% 60% 340 290 240 190 40% 140 20% 0% 390 90 140 190 240 290 340 390 Forward Current (mA) 440 490 90 540 Relative Output Flux vs. Junction Temperature 34 35 Forward Voltage (V) 36 37 40 38 Forward Voltage (V) 100% Relative Luminous Flux 33 Change in Voltage vs. Junction Temperature 120% 80% 60% 40% 32 36 34 32 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CXM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 720 200% 180% 620 140% Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 40% 420 320 220 120 20% 0% 520 20 120 220 320 420 Forward Current (mA) 520 16 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 620 720 20 32 33 34 35 Forward Voltage (V) 36 37 38 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-9 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 40 120% 38 Forward Voltage (V) Relative Luminous Flux 100% 80% 60% 40% 36 34 32 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CHM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 260% 960 240% 860 220% 760 180% Forward Current (mA) Relative output flux 200% 160% 140% 120% 100% 80% 60% 560 460 360 260 40% 160 20% 0% 660 60 160 260 360 460 560 660 760 860 60 960 31.0 32.0 33.0 Forward Current (mA) 35.0 36.0 37.0 38.0 39.0 Foreward Voltage (V) Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 40 120% 38 100% Forward Voltage (V) Relative Luminous Flux 34.0 80% 36 34 60% 32 40% 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 17 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 30 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-11 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 1080 1050 200% 250% 990 950 900 850 200% 160% ForwardCurrent Current(mA) (mA) Forward RelativeLuminous LuminousFlux Flux Relative 180% 140% 150% 120% 100% 100% 80% 50% 60% 0% 40%250 180 350 270 360 450 450 550 540 650 630 750 720 Forward Current (mA) Forward Current (mA) 810 850 900 950 990 1050 1080 810 750 720 650 630 550 540 450 450 350 360 250 270 150 180 50 90 31 31 Relative Output Flux vs. Junction Temperature 34 34 35 35 36 36 Forward Voltage (V) Forward Voltage (V) 37 37 38 38 40 38 Forward Voltage (V) 100% Relative Luminous Flux 33 33 Change in Voltage vs. Junction Temperature 120% 80% 60% 40% 32 32 36 34 32 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CIM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 1080 250% Forward Current (mA) Relative Luminous Flux 990 200% 150% 100% 900 810 720 630 540 450 360 50% 270 180 0% 90 180 270 360 450 540 630 720 810 Forward Current (mA) 18 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 900 990 1080 90 31 32 33 34 Forward Voltage (V) 35 36 37 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CIM-14 Optical & Electrical Characteristics Change in Voltage vs. Junction Temperature 120% 38 100% 37 Forward Voltage (V) Relative Luminous Flux) Relative Output Flux vs. Junction Temperature 80% 60% 36 35 40% 34 20% 33 0% 32 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC ) Junction Temperature (ºC ) CLM-14 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 220% 275% 1260 1250 250% 195% 1150 225% 1050 1060 170% 200% Forward Forward Current (mA) Relative Luminous Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 175% 145% 150% 120% 125% 95% 100% 75% 70% 50% 950 860 850 750 660 650 550 460 450 350 260 45% 25% 0% 20% 250 350 180 450 300 550 650 750 850 950 540 660 780 900 Forward Current (mA) Forward Current (mA) 420 1050 1020 1150 1140 150 60 32 1250 1260 Relative Output Flux vs. Junction Temperature 32 34 35 33 34 35 Forward Voltage (V) Forward Voltage (V) 36 37 36 37 38 38 40 38 Forward Voltage (V) 100% Relative Luminous Flux 31 Change in Voltage vs. Junction Temperature 120% 80% 60% 40% 33 30 36 34 32 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 19 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 30 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 1440 200% 180% 1240 140% Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 40% 840 640 440 240 20% 0% 1040 240 440 640 840 1040 Forward Current (mA) 1240 40 1440 Relative Output Flux vs. Junction Temperature 32 33 34 35 Forward Voltage (V) 36 37 38 40 100% Relative Luminous Flux 31 Change in Voltage vs. Junction Temperature 120% 38 Forward Voltage (V) 80% 60% 40% 36 34 32 20% 0% 30 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Case Temperature (ºC) CXM-18 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 1800 180% 1600 1400 Forward Current (mA) Relative Luminous Flux 160% 140% 120% 100% 80% 60% 1000 800 600 400 40% 20% 1200 400 600 800 1000 1200 Forward Current (mA) 1400 20 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 1600 1800 200 31 32 33 34 Forward Voltage (V) 35 36 Sensus™ LED Series Product Datasheet CXM-18 Optical & Electrical Characteristics Change in Voltage vs. Junction Temperature 38 100% 36 Forward Voltage (V) Relative Luminous Flux Relative Output Flux vs. JunctionTemperature 120% 80% 60% 40% 34 32 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CLM-22 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 200% 2200 180% 2000 160% 1800 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 140% 120% 100% 80% 1600 1400 1200 1000 800 60% 600 40% 400 20% 400 600 800 1000 1200 1400 1600 Forward Current (mA) 1800 2000 200 2200 Relative Output Flux vs. Junction Temperature 34 35 Forward Voltage (V) 36 37 38 40 38 100% Forward Voltage (V) Relative Luminous Flux 33 Change in Voltage vs. Junction Temperature 120% 80% 60% 40% 32 36 34 32 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 21 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 30 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-22 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 200% 2200 180% 2000 160% 1800 140% 1600 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 120% 100% 80% 60% 1400 1200 1000 800 40% 600 20% 400 0% 200 400 600 800 1000 1200 1400 Forward Current (mA) 1600 1800 2000 200 2200 Relative Output Flux vs. Junction Temperature 49 50 51 52 53 Forward Voltage (V) 54 55 56 57 Change in Voltage vs. Junction Temperature 56 120% 100% Forward Voltage (V) Relative Luminous Flux 48 80% 54 52 60% 40% 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 22 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 50 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet CXM-27 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 3200 200% 180% 2800 140% Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 40% 2000 1600 1200 800 20% 0% 2400 400 800 1200 1600 2000 Forward Current (mA) 2400 2800 400 3200 Relative Output Flux vs. Junction Temperature 48 49 50 51 52 53 Forward Voltage (V) 54 55 56 Change in Voltage vs. Junction Temperature 120% 52 100% Forward Voltage (V) Relative Luminous Flux 54 80% 60% 50 48 46 44 42 40% 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 23 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 40 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Series Product Datasheet Optical & Electrical Characteristics Typical Spectrum 120.00% Relative Intensity 100.00% 80.00% 60.00% 40.00% 20.00% 0.00% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Change CIEx vs. Junction Temperature (3000K, 80CRI) Change CIEy vs. Junction Temperature (3000K, 80CRI) 0.02 40 38 Forward Voltage (V) Δ CIEx 0.01 0 -0.01 -0.02 36 34 32 5 15 25 35 45 55 65 75 85 95 30 105 Junction Temperature (ºC) 5 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 24 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved 40 60 80 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions (CXM-6-AA) Mechanical Dimensions (CXM-6-AC) 25 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions (CIM/ CLM/CXM-9 -AC) Shipping Container (CXM-6-AA/ AC & CIM/ CLM/ CXM-9-AC) 400 pcs per box Each bag is boxed for easier storage/ stacking 80 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 26 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc XXXXXX-XX-XX Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions (CLM-9-AA/ CHM-9-XD) Shipping Container (CLM-9-AA/ CHM-9-XD) 300 pcs per box Each bag is boxed for easier storage/ stacking 60 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 27 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc XXXXXX-XX-XX Sensus™ LED Series Product Datasheet Mechanical Dimensions (CXM-11-AC) Mechanical Dimensions (CIM/ CLM/CXM-14-AC) 28 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Mechanical Dimensions (CXM-11-AA) Mechanical Dimensions (CLM/CXM-14-AA) 29 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Shipping Container (CXM-11 & CIM/ CLM/CXM-14) 225 pcs per box Each bag is boxed for easier storage/ stacking 45 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 30 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Mechanical Dimensions (CXM-18) Shipping Container (CXM-18) 180 pcs per box Each bag is boxed for easier storage/ stacking 36 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 31 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc Sensus™ LED Series Product Datasheet Mechanical Dimensions (CLM/CXM-22) Shipping Container (CLM/CXM-22) 100 pcs per box Each bag is boxed for easier storage/ stacking 20 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: (Manufacturer Part Number & Bin Kits) Bar code XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 32 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved (Box ID) Rev XX Bar code (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc XXXXXX-XX-XX Sensus™ LED Series Product Datasheet Mechanical Dimensions (CXM-27) Shipping Container (CXM-27) 100 pcs per box Each bag is boxed for easier storage/ stacking 20 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) Bar code XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 33 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved (Box ID) Rev XX Bar code (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 34 PDS-002832 Rev 11 © 2017 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Luminus Devices: CXM-14-27-80-36-AA00-F2-3 CXM-14-30-95-36-AA00-F2-3 CXM-14-30-80-36-AA00-F2-3 CXM-9-27-80-36-AA00F2-3 CXM-9-30-95-36-AA00-F2-3 CXM-9-30-80-36-AA00-F2-3 CXM-9-27-95-36-AA00-F2-3 CXM-14-27-95-36-AA00F1-3 CXM-14-27-80-36-AA00-F1-3 CXM-14-30-95-36-AA00-F1-3 CXM-9-27-80-36-AA00-F1-3 CXM-9-40-80-36AA00-F1-3 CXM-14-30-80-36-AA00-F1-3 CXM-14-35-80-36-AA00-F1-3 CXM-9-27-90-36-AA00-F1-3 CXM-9-30-9536-AA00-F1-3 CXM-9-35-80-36-AA00-F1-3 CXM-14-50-80-36-AA00-F1-5 CXM-9-30-90-36-AA00-F1-3 CXM-14-3090-36-AA00-F1-3 CXM-9-30-80-36-AA00-F1-3 CXM-14-27-90-36-AA00-F1-3 CXM-9-27-95-36-AA00-F1-3 CXM-1440-80-36-AA00-F1-3 CXM-9-50-80-36-AA00-F1-5 CXM-9-65-90-36-AC00-F2-3 CXM-9-40-90-36-AA00-F2-3 CXM-930-90-36-AC02-F2-3 CXM-9-30-90-36-AC02-F2-2 CXM-9-35-90-36-AA00-F2-2 CXM-9-35-80-36-AC00-F2-3 CXM-965-80-36-AC00-F2-5 CXM-9-35-90-36-AA00-F2-3 CXM-9-30-95-36-AC02-F2-2 CXM-9-30-80-36-AC02-F2-2 CXM-940-80-36-AC00-F2-2 CXM-9-40-90-36-AA00-F2-2 CXM-9-40-90-36-AC00-F2-2 CXM-9-35-90-36-AC00-F2-2 CXM-935-80-36-AC00-F2-2 CXM-9-40-90-36-AC00-F2-3 CXM-9-50-80-36-AC00-F2-5 CXM-9-30-95-36-AC02-F2-3 CXM-935-90-36-AC00-F2-3 CXM-9-50-90-36-AC00-F2-3 CXM-9-30-95-36-AC00-F2-2 CXM-9-27-95-36-AA00-F2-2 CXM-930-90-36-AA00-F2-3 CXM-14-30-90-36-AA00-F2-3 CXM-9-40-80-36-AA00-F2-3 CXM-9-50-80-36-AA00-F2-5 CXM14-40-80-36-AC00-F2-2 CXM-14-27-90-36-AA00-F2-2 CXM-14-40-90-36-AC00-F2-3 CXM-14-35-80-36-AC00-F2-2 CXM-14-30-90-36-AC00-F2-2 CXM-9-35-80-36-AA00-F2-2 CXM-14-30-90-36-AC02-F2-2 CXM-14-50-80-36-AA00-F25 CXM-9-27-90-36-AA00-F2-2 CXM-9-30-80-36-AC00-F2-2 CXM-14-30-95-36-AC02-F2-3 CXM-9-40-80-36-AA00-F22 CXM-14-27-90-36-AA00-F2-3 CXM-14-30-95-36-AC02-F2-2 CXM-9-30-90-36-AC00-F2-2 CXM-14-27-95-36-AA00F2-2 CXM-14-35-80-36-AC00-F2-3 CXM-14-50-80-36-AA00-F2-3 CXM-14-30-80-36-AC02-F2-2 CXM-14-40-80-36AA00-F2-2 CXM-14-40-90-36-AA00-F2-3 CXM-14-35-80-36-AA00-F2-2 CXM-9-30-95-36-AC00-F2-3 CXM-14-40-9036-AC00-F2-2 CXM-9-30-95-36-AA00-F2-2 CXM-14-30-80-36-AA00-F2-2 CXM-14-65-80-36-AC00-F2-3 CXM-9-3580-36-AA00-F2-3 CXM-14-30-90-36-AC02-F2-3 CXM-9-30-80-36-AC00-F2-3 CXM-14-50-80-36-AC00-F2-3 CXM-1450-80-36-AC00-F2-5 CXM-14-30-95-36-AC00-F2-2 CXM-14-35-90-36-AC00-F2-3 CXM-14-65-80-36-AC00-F2-5 CXM-9-30-80-36-AA00-F2-2 CXM-14-40-80-36-AA00-F2-3 CXM-14-30-90-36-AA00-F2-2 CXM-9-30-90-36-AA00-F2-2 CXM-9-27-80-36-AA00-F2-2 CXM-9-50-80-36-AA00-F2-3 CXM-14-30-95-36-AA00-F2-2 CXM-9-27-90-36-AA00-F2-3 CXM-14-30-80-36-AC00-F2-2 CXM-14-35-80-36-AA00-F2-3 CXM-14-35-90-36-AC00-F2-2 CXM-14-27-95-36-AA00F2-3 CXM-14-40-90-36-AA00-F2-2 CXM-14-27-80-36-AA00-F2-2
CXM-11-27-80-36-AB00-F2-3 价格&库存
很抱歉,暂时无法提供与“CXM-11-27-80-36-AB00-F2-3”相匹配的价格&库存,您可以联系我们找货
  • 1125+29.833181125+3.82671
