LIGHT LED
M03 CoB Product Series
1. Description
The LiteON CoB Product series is a revolutionary, energy efficient and ultra-compact new light source, combining the
lifetime and reliability advantages of Light Emitting Diodes with the brightness of conventional lighting. It gives you total
design freedom and unmatched brightness, creating a new opportunities for solid state lighting to displace conventional
lighting technologies.
1.1 Features
Compact high flux density light source
Uniform high quality illumination
Streamlined thermal path
MacAdam compliant binning structure
More energy efficient than incandescent, halogen
and fluorescent lamps
Instant light with unlimited dimming
RoHS compliant and Pb free
1.2 Benefits Features
Enhanced optical control
Clean white light without pixilation
Uniform consistent white light
Significantly reduced thermal resistance and
increased operating temperatures
Lower operating costs
Reduced maintenance costs
ESD rating is 8KV in HBM
1.3 Naming Rule
1/21
Part No. : M03 CoB Product Series
BNS-OD-FC002/A4
LIGHT LED
1.4 Product List
Part Number
Product
CCT
Color Bin
CRI
Series
Lumen Bin
3SDCM
5SDCM
ANSI
-8%~+8%
-15%~+15%
LTPL-M03614ZS27-T0
14
2700K
80
LTPL-M03614ZS30-T0
14
3000K
80
LTPL-M03614ZS40-T0
14
4000K
80
LTPL-M03622ZS27-T0
22
2700K
80
LTPL-M03622ZS30-T0
22
3000K
80
LTPL-M03622ZS40-T0
22
4000K
80
2/21
BNS-OD-FC002/A4
LIGHT LED
2. Outline Dimensions
2.1 Form Factor of M036 series CoB
Notes
1. All dimensions are in millimeters.
2. Tolerance is ±0.3mm unless otherwise noted.
3. LED of equivalent circuit means all series/parallel in CoB package.
2.2 Internal Equivalent Circuit
14 Series Product
22 Series Product
3/21
BNS-OD-FC002/A4
LIGHT LED
3. Absolute Maximum Ratings at Ta=25°C
Parameter
Power Dissipation
Forward Current
Symbol
Product Series
Rating
Code 4
PO
14
16
22
24
14
400
22
600
W
IF
Junction Temperature
Thermal Resistance, Junction-Case
Unit
mA
Tj
Rth, J-C
125
14
1.7
22
1.2
°C
°C/W
Operating Temperature Range
Topr
-40 to 85
°C
Storage Temperature Range
Tstg
-40 to 100
°C
Breakdown Voltage(DC)
VB
2.25
KV
Electrostatic Discharge
ESD
8
KV
Notes
1.
2.
3.
4.
5.
The pulse mode condition is 1/10 duty cycle with 100 msec pulse width.
Forbid to be operated at reverse voltage condition.
ESD spec is reference to AEC-Q101-001 HBM.
The unit of Rth is °C/W electrical.
The M03 CoB is recommended soldering temperature under 350degC and could not over 3.5sec.
4/21
BNS-OD-FC002/A4
LIGHT LED
4. Electro-Optical Characteristics
4.1 Typical Performance
14 Series Product
Dominant
Product
Current
VF (V)
Flux(lm)
VF (V)
Flux(lm)
Eff.(lm/W)
Eff.(lm/W)
CCT
Series
(mA)
@25°C
@25°C
@85°C
@85°C
@25°C
@85°C
2700K
14
350
38.5
1546
37.7
1391
115
105
3000K
14
350
38.5
1610
37.7
1448
119
110
4000K
14
350
38.5
1707
37.7
1535
127
116
22 Series Product
Dominant
Product
Current
VF (V)
Flux(lm)
VF (V)
Flux(lm)
Eff.(lm/W)
Eff.(lm/W)
CCT
Series
(mA)
@25°C
@25°C
@85°C
@85°C
@25°C
@85°C
2700K
22
500
38.3
2284
37.5
2055
119
110
3000K
22
500
38.3
2360
37.5
2123
123
113
4000K
22
500
38.3
2500
37.5
2249
131
120
Notes
1.
2.
3.
4.
All of VF value are typical, the real bin range please refer page 14 ” VF Binning Parameter”.
All of flux value are typical, the real bin range please refer page 13 ”Flux Binning Parameter”.
Tolerance of flux is ±7%, tolerance of CCX/CCY is ±0.007, tolerance of CRI is ±2, and tolerance of VF is ±3%.
Typical viewing angle is 120deg.
5/21
BNS-OD-FC002/A4
LIGHT LED
4.2 Forward Current vs. Lumen and Voltage
14 Series Product
Flux (lm)
Current (mA)
VF (V)
2700K
3000K
4000K
CRI>80
CRI>80
CRI>80
50
33.0
355
374
390
75
33.5
457
475
506
100
33.9
553
586
613
125
34.4
657
687
732
150
34.9
766
794
847
175
35.3
857
899
955
200
35.8
962
991
1067
225
36.3
1073
1103
1168
250
36.7
1172
1221
1293
275
37.2
1271
1303
1398
300
37.6
1347
1415
1516
325
38.1
1457
1504
1589
350
38.5
1546
1610
1707
375
38.9
1642
1687
1786
400
39.3
1711
1782
1893
6/21
BNS-OD-FC002/A4
LIGHT LED
22 Series Product
Flux (lm)
Current (mA)
VF (V)
2700K
3000K
4000K
CRI>80
CRI>80
CRI>80
250
35.2
1248
1311
1381
275
35.6
1369
1423
1490
300
35.9
1483
1538
1610
325
36.2
1530
1629
1704
350
36.5
1676
1748
1853
375
36.8
1772
1867
1953
400
37.1
1872
1977
2087
425
37.4
1980
2086
2185
450
37.7
2096
2190
2289
475
38
2161
2267
2398
500
38.3
2284
2360
2500
525
38.6
2378
2473
2594
550
38.9
2448
2550
2703
575
39.1
2555
2661
2801
600
39.4
2627
2742
2877
7/21
BNS-OD-FC002/A4
LIGHT LED
4.3 Relative Spectral Power Distribution at Typical Current
3000K
25degC
85degC
4.4 Radiation Characteristics
0°
100%
90%
30°
Relative Intensity (%)
80%
70%
60%
60°
50%
40%
30%
20%
10%
0%
90°
60
30°
0°
50
8/21
100
BNS-OD-FC002/A4
LIGHT LED
4.5 Forward Current vs. Forward Voltage
9/21
BNS-OD-FC002/A4
LIGHT LED
4.6 Forward Voltage vs. Junction Temperature
10/21
BNS-OD-FC002/A4
LIGHT LED
4.7 Relative Intensity vs. Junction Temperature
Relative Intensity vs. Case Temperature
11/21
BNS-OD-FC002/A4
LIGHT LED
4.8 Forward Current Degrading Curve
12/21
BNS-OD-FC002/A4
LIGHT LED
5. CoB Binning Definition
Example of M03 Series Product Bin (2700K 14 series)
Flux Binning Parameter (25degC)
Lumen (lm)
Lumen CODE List of M03 Series Product
Parameter
Code
Unit
2700K
Lumen
CCT
I
1345
Bin
Range
J
1455
IJ
1345~1455
K
1570
JL
1455~1695
L
1695
LM
1695~1830
M
1830
Lumen Range
Luminous
N
lm
1975
Bin Code
Flux
O
2130
P
2300
Q
2485
R
2680
S
2890
Main Bin
I
J
-15%~-8%
L
-8%~+8%
M
+8%~+15%
Full Bins
14 Series Lumen Bin
Lumen (lm)
2700K
3000K
4000K
Bin
Range
Bin
Range
Bin
Range
IJ
1345~1455
IJ
1345~1455
JK
1455~1570
JL
1455~1695
JL
1455~1695
KM
1570~1830
LM
1695~1830
LM
1695~1830
MN
1830~1975
13/21
BNS-OD-FC002/A4
LIGHT LED
22 Series Lumen Bin
Lumen (lm)
2700K
3000K
4000K
Bin
Range
Bin
Range
Bin
Range
NO
1975~2130
NO
1975~2130
OP
2130~2300
OQ
2130~2485
OQ
2130~2485
PR
2300~2680
QR
2485~2680
QR
2485~2680
RS
2680~2890
Forward Voltage Binning Parameter (25decgC)
Parameter
Bin
Symbol
Min
Max
Unit
Condition
Forward Voltage
V1
VF
33.6
42
V
IF=Typical current
Note: Full Rank on Label
Example: V1/DF/D1
Forward Voltage Rank
Luminous Flux Rank
Color Rank
V1
DF
D1
14/21
BNS-OD-FC002/A4
LIGHT LED
Example of LiteOn CoB MacAdam Ellipse Color Definition (Ex: 3000K)
Solid line in red/blue/black is
E3
3SDCM/5SDCM/ANSI at 25degC.
It is shipping Spec. of LiteOn.
E2
E1
Dotted line in light gray is
3SDCM/5SDCM/ANSI at 85degC and
the CCX/CCY center follows ANSI.
follows ANSI C78.377A.
CIE Center Point
25degC (LiteOn Spec.)
85degC (ANSI)
Hot/Cold Factor
CCT
CCX
CCY
CCX
CCY
CCX
CCY
2700
0.4582
0.4150
0.4578
0.4101
-0.0004
-0.0049
3000
0.4352
0.4083
0.4338
0.403
-0.0014
-0.0053
4000
0.3849
0.3856
0.3818
0.3797
-0.0031
-0.0059
Notes
LiteOn tester and shipping spec follow the color bin with 25degC CCX/CCY center.
The Hot/Cold factor means the CCX/CCY shift from 25degC to 85degC.
The Hot/Cold shift is measured by LiteOn CAS 140B instrument system.
2
2 0.5
The ellipse equation expression: SDCM = (g11*(x-x0) + 2*g12*(x-x0)*(y-y0) + g22*(y-y0) )
15/21
BNS-OD-FC002/A4
LIGHT LED
M03 CRI80 2700K
PN: LTPL-M036xxZS27-T0
D3
5-Step at 25degC
D2
ANSI at 25degC
D1
3-Step at 25degC
16/21
BNS-OD-FC002/A4
LIGHT LED
M03 CRI80 3000K
PN: LTPL-M036xxZS30-T0
E3
5-Step at 25degC
ANSI at 25degC
E2
E1
3-Step at 25degC
M03 CRI80 4000K
PN: LTPL-M036xxZS40-T0
G3
5-Step at 25degC
ANSI at 25degC
G2
G1
1
3-Step at 25degC
17/21
BNS-OD-FC002/A4
LIGHT LED
6. Reliability Test Plan
Number
No
Test item
Condition
Duration
Result
of Failed
High Temperature
1
Tc=85°C, IF =Typical Current
1K hours
0/10
Pass
1K hours
0/10
Pass
500 cycles
0/10
Pass
40K cycles
0/10
Pass
Ta=120°C
1K hours
0/10
Pass
Ta=-55°C
1K hours
0/10
Pass
0/10
Pass
0/10
Pass
Operating Life
Wet High
60°C/90%RH, IF =Typical Current(DC)
2
Temperature
30 mins ON/OFF
Operating Life
-40°C to 125°C, 15minutes dwell,
3
Thermal Shock
很抱歉,暂时无法提供与“LTPL-M03622ZS27-T0”相匹配的价格&库存,您可以联系我们找货
