CXM-11-30-80-36-AA02-F2-2
    LUMINUS(朗明纳斯)
CXM-11-30-80-36-AA02-F2-2 数据手册
Sensus™ LED Series Product Datasheet Preliminary Sensus™ LED Series Pure White Targeted COB Arrays Below the Black Body Locus (BBL) Preliminary Data Sheet Features: • Matching the human perception of “Pure white” light Table of Contents Technology Overview. . . . . . 2 Test Specifications . . . . . . . . . 2 • Designed to provide the look and feel of ceramic metal halide lights • Wide product range from 300lm to over 7,500lm • 3000K, 80 CRI standard • 2-step and 3-step MacAdam Ellipse color binning accuracy Chromaticity Bins. . . . . . . . . . 3 • Excellent optical uniformity and color over angle consistency Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • Exceptional long term color stability Product Typical Flux Range. 5 • Environmentally friendly: RoHS and REACh compliant Operating Characteristics . . 7 • Superior thermal conductivity for uniform heat spreading • UL Recognized, File # E465703 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . 12 Spectra. . . . . . . . . . . . . . . . . . . 19 Mechanical Dimensions. . . 20 Packaging Information. . . . 20 Handling Notes. . . . . . . . . . . 28 Applications • Retail Shop Lighting • Halogen replacement LED lamps • Spotlights/Track Lights • Hospitality Lighting • CMH replacement LED lamps • Architectural and Specialty 1 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus LED™ Series Product Datasheet Preliminary Technology Overview Luminus XNova™ Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The Sensus LED series has been specially design for retail shop ligthing where enhanced red coloring is a preferred lighting standard. The selection covers a wide lumen range from less than 300lm to over 3,000lm, and is focused on the major market color and CRI of 3000K and 80 CRI. These innovative breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the XNova™ COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM-80 test data and TM-21 lifetime results that certify lumen maintenance at 35,000 hours or more, XNova™ COB LEDs are ready for the toughest challenges. UL Recognized Compliance XNova COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding XNova™ COB LED Test Specifications Every XNova™ LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each XNova COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature XNova™ COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Preliminary Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.4600 ANSI C78.377-2008 3-SDCM 2-SDCM A and B Bin Separator 0.4400 3000K CIEy 0.4200 Black Body Locus A 0.4000 0.3800 B 0.3600 0.3400 0.3200 0.3800 0.4000 0.4200 0.4400 0.4600 0.4800 0.5000 CIEx Sensus™ LED White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. 3-step Bin 2-step Bin Center Point CCT CIEx CIEy θ (°) a b θ (°) a b 3000K 0.4285 0.3933 53.6 0.00556 0.00272 53.1 0.00834 0.00408 The chromaticity range is sorted into two sections, “A” and “B” for delivered product. The position for the separator line dividing the bins is described in the following table by a line connecting points at CIEx and CIEy coordinates that lie on the 2-step and 3-step ellipse. 2-step Bin Separator *Note: 3-step Bin Position CIEx CIEy CIEx CIEy Right Side 0.4274 0.3863 0.4285 0.3856 Left Side 0.4229 0.3892 0.4218 0.3899 Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Preliminary Product Ordering and Shipping Part Number Nomenclature All Sensus LED products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. Luminus will include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM Sensus™ LED Series XX 36 XX 30 Product Family Light Emitting Surface Diameter1 Color Temperature Color Rendering Index (CRI)3 CXM: Chip on Board XX: LES Diameter (mm) Approximate 3000K CRI QQPP FG W Voltage (typical) Package Configurator Flux Bin Chromaticity Bin Volts AA02 (Basic package) Lumens See page 4 for bins Note 1 : XX nomenclature corresponds to the following: 6 = 6.3mm 7 = 7.5mm 9 = 9mm 14 = 13.5mm 18 = 17.5mm 22 = 22mm Note2: AA02 is a standard package configurator AC02 is an alternative substrate size Note 3: Shipped product will be delivered with the 2-step or 3-step chromaticity bin divided into section “A” an d section “B” as shown in the chromaticty diagram. While these sub-bins are not availalbe for direct purchse, it is hoped this fine binning can add another design dimension to select customer’s products. The packaged product will have the sub bin shown on the label at the end of the Customer Part Number from page 5 and 6. Color Temperature, CRI and R9 Values Color Temperatures 3000K Note: XX Value CRI R9 80 >80 >0 90 >90 >50 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Preliminary Sensus™ LED Series Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All products are measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromatiticy bin in an order for a larger. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) (25ºC) Typ. Current (mA) 3-step MacAdam Ellipse 2-step MacAdam Ellipse 445 420 495 120 CXM-6-30-80-36-AA02-F2-3 CXM-6-30-80-36-AA02-F2-2 585 555 645 160 CHM-6-30-80-36-AA02-F2-3 CHM-6-30-80-36-AA02-F2-2 615 585 685 160 CXM-7-30-80-36-AA02-F2-3 CXM-7-30-80-36-AA02-F2-2 625 590 695 160 CLM-9-30-80-36-AC02-F2-3 CLM-9-30-80-36-AC02-F2-2 CLM-9-30-80-36-AA02-F2-3 CLM-9-30-80-36-AC02-F2-2 930 885 1,025 CXM-9-30-80-36-AC02-F2-3 CXM-9-30-80-36-AC02-F2-2 CXM-9-30-80-36-AA02-F2-3 CXM-9-30-80-36-AA02-F2-2 CXM-9-30-90-36-AC02-F2-3 CXM-9-30-90-36-AC02-F2-2 CXM-9-30-90-36-AA02-F2-3 CXM-9-30-90-36-AA02-F2-2 CHM-9-30-80-36-AC02-F2-3 CHM-9-30-80-36-AC02-F2-2 CHM-9-30-80-36-AA02-F2-3 CHM-9-30-80-36-AA02-F2-2 CHM-9-30-90-36-AC02-F2-3 CHM-9-30-90-36-AC02-F2-2 CHM-9-30-90-36-AA02-F2-3 CHM-9-30-90-36-AA02-F2-2 CXM-14-30-80-36-AC02-F2-3 CXM-14-30-80-36-AC02-F2-2 CXM-14-30-80-36-AA02-F2-3 CXM-14-30-80-36-AA02-F2-2 CXM-14-30-90-36-AC02-F2-3 CXM-14-30-90-36-AC02-F2-2 CXM-14-30-90-36-AA02-F2-3 CXM-14-30-90-36-AA02-F2-2 CHM-14-30-80-36-AC02-F2-3 CHM-14-30-80-36-AC02-F2-2 CHM-14-30-80-36-AA02-F2-3 CHM-14-30-80-36-AA02-F2-2 CHM-14-30-90-36-AC02-F2-3 CHM-14-30-90-36-AC02-F2-2 CHM-14-30-90-36-AA02-F2-3 CHM-14-30-90-36-AA02-F2-2 240 780 750 870 1,310 1,245 1,455 360 1,110 1,050 1,230 1,930 1,830 2,135 480 1,635 1,550 1,810 2,660 2,525 2,925 720 2,255 2,140 2,475 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Preliminary Sensus™ LED Series Part Numbers (Typical) The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may choose to ship a smaller chromatiticy bin in an order for a larger. Output Flux (lm) Ordering Part Number Typ. Typ. (85ºC) Min. (85ºC) (calculated) (25ºC) Typ. Current (mA) 3-step MacAdam Ellipse 2-step MacAdam Ellipse 3,210 3,050 3,560 800 CXM-18-30-80-36-AA02-F2-3 CXM-18-30-80-36-AA02-F2-2 4,435 4,210 4,875 1,200 CHM-18-30-80-36-AA02-F2-3 CHM-18-30-80-36-AA02-F2-2 5,130 4,870 5,700 1,280 CXM-22-30-80-36-AC02-F2-3 CXM-22-30-80-36-AC02-F2-2 7,090 6,735 7,800 1,920 CHM-22-30-80-36-AC02-F2-3 CHM-22-30-80-36-AC02-F2-2 *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Preliminary CXM-6 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Minimum Typical Maximum 120 240 240 480 480 960 33.5 35 37.5 16.8 17.5 18.8 8.4 8.8 9.4 4.3 9 W 105 ºC Forward Current (36V) 2 Forward Current (18V)2 If Forward Current (9V) 2 Forward Voltage3 Vf Power Unit mA V Operating Case Temperature Tc Light Emitting Surface Diameter LES 6.3 mm Thermal Resisitance (junction-to-case) Qjc 2.33 ºC/W Junction Temperature Tj 4 140 Viewing Angle 120 ºC Degree CXM-7 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Minimum Typical Maximum 160 320 320 640 640 1280 33.5 35 37.5 16.8 17.5 18.8 8.4 8.8 9.4 5.6 13 W 105 ºC Forward Current (36V) 2 Forward Current (18V)2 If Forward Current (9V)2 Forward Voltage3 Vf Power Unit mA V Operating Case Temperature Tc Light Emitting Surface Diameter LES 7.5 mm Thermal Resisitance (junction-to-case) Qjc 1.9 ºC/W Junction Temperature Tj 4 Viewing Angle 120 7 PDS-002349 Rev 07 140 © 2015 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet Preliminary CHM-6 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current (36V) Minimum Typical Maximum 160 320 640 1280 33.5 35 37.5 8.4 8.8 9.4 5.6 13 W 105 ºC 2 If Forward Current (9V)2 Forward Voltage3 Vf Power Unit mA V Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 6.3 mm Thermal Resisitance (junction-to-case) Qjc 1.55 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CLM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Power Minimum 33.5 Typical Maximum Unit 160 350 mA 35 37.5 V 5.6 12 W 105 ºC Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 9.0 mm Thermal Resisitance (junction-to-case) Qjc 1.55 ºC/W Junction Temperature Tj Viewing Angle 120 8 PDS-002349 Rev 07 140 © 2015 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet Preliminary CXM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum Typical Maximum Unit 240 530 mA 35 37.5 V 8.6 21 W 100 ºC 33.5 Power Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 9 mm Thermal Resisitance (junction-to-case) Qjc 1.51 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-9 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum Typical Maximum Unit 360 720 mA 35 37.5 V 12.6 26 W 105 ºC 33.5 Power Operating Case Temperature Tc Light Emitting Surface Diameter LES 9 mm Thermal Resisitance (junction-to-case) Qjc 0.85 ºC/W Junction Temperature Tj 4 140 Viewing Angle 120 ºC Degree CXM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Power Operating Case Temperature Minimum 33.5 Typical Maximum Unit 480 1,000 mA 35 37.5 V 17.3 40 W 105 ºC Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resisitance (junction-to-case) Qjc 0.87 ºC/W Junction Temperature Tj Viewing Angle 120 9 PDS-002349 Rev 07 140 © 2015 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary CHM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum Maximum Unit 720 1,440 mA 35 37.5 V 25.2 50.4 W 105 ºC 33.5 Power Operating Case Temperature Typical Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resisitance (junction-to-case) Qjc 0.46 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CXM-18 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum Typical Maximum Unit 800 1,600 mA 35 37.5 V 29 65 W 105 ºC 33.5 Power Operating Case Temperature Tc 4 Light Emitting Surface Diameter LES 17.5 mm Thermal Resisitance (junction-to-case) Qjc 0.56 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-18 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Power Operating Case Temperature4 Minimum 33.5 Typical Maximum Unit 1,200 2,400 mA 35 37.5 V 42 96 W 105 ºC Tc Light Emitting Surface Diameter LES 17.5 mm Thermal Resisitance (junction-to-case) Qjc 0.30 ºC/W Junction Temperature Tj Viewing Angle 120 10 PDS-002349 Rev 07 140 © 2015 Luminus Devices, Inc. - All Rights Reserved ºC Degree Sensus™ LED Series Product Datasheet Preliminary CXM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum 33.5 Power Operating Case Temperature4 Typical Maximum Unit 1,280 2,560 mA 35 37.5 V 45 90 W 105 ºC Tc Light Emitting Surface Diameter LES 22 mm Thermal Resisitance (junction-to-case) Qjc 0.37 ºC/W Junction Temperature Tj 140 Viewing Angle 120 ºC Degree CHM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum 33.5 Power Operating Case Temperature4 Typical Maximum Unit 1,920 3,840 mA 35 37.5 V 67 90 W 105 ºC Tc Light Emitting Surface Diameter LES 22 mm Thermal Resisitance (junction-to-case) Qjc 0.2 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Operating Characteristics Notes Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Forward voltage range is specified at a typical current drive condition and Tj = 85ºC . Note 4: CXM COB LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Refer to the current vs. case temperature derating curves for further information. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 11 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary CXM-6 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 300 180% Forward Current (mA) Relative Luminous Flux 160% 140% 120% 100% 80% 60% 200 100 40% 20% 0 0% 50 75 100 125 150 175 200 225 32 250 32.5 33 33.5 34 Relative Output Flux vs. Junction Temperature 35 35.5 36 36.5 37 Change in Voltage vs. Junction Temperature 40 120.0% 100.0% 38 Forward Voltage (V) Relative Luminous Flux 34.5 Forward Voltage (V) Forward Current (mA) 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 5 15 25 35 45 55 65 75 85 95 30 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CHM-6 , CXM-7, CLM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 350 200.0% 180.0% 300 Forward Current (mA) Relative Luminous Flux 160.0% 140.0% 120.0% 100.0% 80.0% 60.0% 40.0% 250 200 150 100 20.0% 50 0.0% 50 100 150 200 250 Forward Current (mA) 12 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 300 32 33 34 35 36 37 Forward Voltage (V) 38 39 40 Sensus™ LED Series Product Datasheet Preliminary CHM-6, CXM-7, CLM-9 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 40 1.2 38 Forward Voltage (V) Relative Luminous Flux 1 0.8 0.6 0.4 36 34 32 0.2 0 30 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) CXM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 250.0% 500 450 Forward Current (mA) Relative Luminous Flux 200.0% 150.0% 100.0% 400 350 300 250 200 50.0% 150 0.0% 100 100 150 200 250 300 350 400 450 32 500 33 34 35 Relative Output Flux vs. Junction Temperature 37 38 39 40 Change in Voltage vs. Junction Temperature 40 1.2 1 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) Forward Current (mA) 0.8 0.6 0.4 36 34 32 0.2 30 0 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 13 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Series Product Datasheet Preliminary CHM-9 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200.0% 700 180.0% 600 140.0% Forward Current (mA) Relative Luminous Flux 160.0% 120.0% 100.0% 80.0% 60.0% 40.0% 500 400 300 200 20.0% 100 0.0% 100 200 300 400 500 600 32 700 33 34 35 Relative Output Flux vs. Junction Temperature 37 38 39 40 Change in Voltage vs. Junction Temperature 120.0% 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) Forward Current (mA) 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 45 Junction Temperature (ºC) 55 65 75 85 95 105 Junction Temperature (ºC) CXM-14 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 200% 960 180% 860 160% 760 140% 660 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 120% 100% 80% 60% 40% 560 460 360 260 160 20% 60 0% 250 350 450 550 650 750 Forward Current (mA) 14 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 850 950 -40 33 34 35 36 Forward Voltage (V) 37 38 39 Sensus™ LED Series Product Datasheet Preliminary CXM-14 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 40 120% 38 Forward Voltage (V) Relative Luminous Flux 100% 80% 60% 40% 36 34 32 20% 30 0% 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CHM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 1600 200% 180% 1400 1200 140% Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 1000 800 600 400 40% 200 20% 0 0% 250 450 650 850 1050 34 1250 35 36 Relative Output Flux vs. Junction Temperature 38 39 40 Change in Voltage vs. Junction Temperature 40 120% 100% 38 80% Forward Voltage (V) Relative Luminous Flux 37 Forward Voltage (V) Forward Current (mA) 60% 40% 36 34 32 20% 0% 30 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 15 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary CXM-18 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 250% 1700 1500 Forward Current (mA) Relative Luminous Flux 200% 150% 100% 50% 1300 1100 900 700 0% 600 700 800 900 1000 1100 1200 1300 1400 1500 500 1600 33 34 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 37 38 39 Change in Voltage vs. Junction Temperature 40 120% 100% 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) 80% 60% 40% 36 34 32 20% 30 0% 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) CHM-18 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 180.0% 2800 160.0% Forward Current (mA) Relative Luminous Flux 140.0% 120.0% 100.0% 80.0% 60.0% 40.0% 2300 1800 1300 800 20.0% 300 0.0% 400 600 800 1000 1200 1400 1600 1800 Forward Current (mA) 16 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 2000 2200 33 34 35 36 Forward Voltage (V) 37 38 39 (Part #) Product Sensus™ LED Series Product Datasheet Preliminary CHM-18 Optical & Electrical Characteristics Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120.0% 40 38 Forward Voltage (V) Relative Luminous Flux 100.0% 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 45 Junction Temperature (ºC) 55 65 75 85 95 105 Junction Temperature (ºC) CXM-22 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200.0% 2800 180.0% 140.0% Forward Current (mA) Relative Luminous Flux 160.0% 120.0% 100.0% 80.0% 60.0% 40.0% 2300 1800 1300 800 20.0% 0.0% 300 400 900 1400 1900 2400 33 34 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 37 38 39 Change in Voltage vs. Junction Temperature 120.0% 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 17 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary CHM-22 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 4000 200.0% 180.0% 3500 140.0% Forward Current (mA) Relative Luminous Flux 160.0% 120.0% 100.0% 80.0% 60.0% 3000 2500 2000 1500 40.0% 1000 20.0% 0.0% 500 500 1000 1500 2000 2500 3000 3500 4000 32 33 34 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 37 38 39 40 Change in Voltage vs. Junction Temperature 120.0% 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 36 Forward Voltage (V) 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 18 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 Sensus™ LED Series Product Datasheet Preliminary Typical Spectrum 120.00% Relative Intensity 100.00% 80.00% 60.00% 40.00% 20.00% 0.00% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Change CIEx vs. Junction Temperature (3000K, 80CRI) Change CIEy vs. Junction Temperature (3000K, 80CRI) 0.02 40 38 Forward Voltage (V) Δ CIEx 0.01 0 -0.01 36 34 32 30 -0.02 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 45 55 65 75 85 95 Junction Temperature (ºC) Junction Temperature (ºC) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 19 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 40 60 80 105 Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary Mechanical Dimensions, CXM-6 Shipping Container, CXM-6 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 20 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Preliminary Mechanical Dimensions, CXM-7 Shipping Container, CXM-7 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 21 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Preliminary Mechanical Dimensions, CXM-9 (AA00) Shipping Container, CXM-9 (AA00) Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 22 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary Mechanical Dimensions, CLM/CXM/CHM-9 (AC00) Shipping Container, CLM/CXM/CHM-9 (AC00) Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 23 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Preliminary Mechanical Dimensions, CXM/CHM-14 (AA00) Mechanical Dimensions CXM/CHM-14(AC00) 24 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Sensus™ LED Series Product Datasheet Preliminary Shipping Container, CXM/CHM-14 (AA00 and AC00) Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 25 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary Mechanical Dimensions, CXM/CHM-18 Shipping Container, CXM/CHM-18 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 26 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Series Product Datasheet Preliminary Mechanical Dimensions, CXM/CHM-22 Shipping Container, CXM/CHM-22 Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 27 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover Sensus™ LED Product Datasheet (PartSeries #) Product Datasheet Preliminary Handling Notes for XNova COBs XNova products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging XNova COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. XNova COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility XNova COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with XNova COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the XNova products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the XNova COB products. Storage: XNova products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling XNova COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 28 PDS-002349 Rev 07 © 2015 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
CXM-11-30-80-36-AA02-F2-2 价格&库存
很抱歉,暂时无法提供与“CXM-11-30-80-36-AA02-F2-2”相匹配的价格&库存,您可以联系我们找货
