CXM-11-50-70-36-AA30-F4-5
    LUMINUS(朗明纳斯)
    冷白色 5000K CRI:70
CXM-11-50-70-36-AA30-F4-5 数据手册
CXM-11 Gen 3 Product Datasheet Preliminary Generation 3 CXM-11 LED White COB Arrays Features: • High lumen output and efficacy typical Table of Contents • Over 2,280 lm, 150 LPW @ 3000K, 80CRI, Tj = 85ºC Technology Overview . . . . . .2 • Over 2,595 lm, 171 LPW @ 5000K, 70CRI, Tj = 85ºC Test Specifications . . . . . . . . .2 • CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K • 80 or 90 CRI min. up to 95 min. in warm white Chromaticity Bins . . . . . . . . . .3 • 3 SDCM color binning accuracy Product Ordering & Shipping Part Numbers . . . . . . . . . . . . . .4 • Excellent optical emission uniformity and color over angle consistency Part Numbers . . . . . . . . . . . . . 5 Operating Characteristics . .7 • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading • Environmentally friendly: RoHS and REACH compliant • Optical and Electrical Characteristics . . . . . . . . . . . . . . . . . . . . . . .8 Spectra . . . . . . . . . . . . . . . . . . . .9 Mechanical Dimensions . . 10 Packaging Information . . . 11 Handling Notes . . . . . . . . . . 12 Applications • Spotlights/Track Lights • Architectural and Specialty • Downlights • Street Lighting • Shop Lighting • Parking Lot and Area Lighting • Hospitality Lighting • Tunnel Lighting 1 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-11 Gen 3 Product Datasheet Preliminary Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACH & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-11 Gen 3 Product Datasheet Preliminary Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 0.44 3200K 2700K 3000K 3500K 0.42 4000K 0.4 Black Body CIE y 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CXM-11 Gen 3 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. CCT Center Point Angle 3-step Bin 5-step Bin CIEx CIEy θ (°) a b 2700K 0.4578 0.4101 53.7 0.0081 0.0042 3000K 0.4338 0.403 53.2 0.00834 0.00408 3200K 0.4232 0.3991 53.2 0.0108 0.0056 3500K 0.4073 0.3917 54 0.00927 0.00414 4000K 0.3818 0.3797 53.7 0.00939 0.00402 5000K 0.3447 0.3553 59.6 0.00822 6500K 0.3123 0.3282 58.57 0.00669 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved a b 0.00354 0.0137 0.0059 0.00285 0.01115 0.00475 CXM-11 Gen 3 Product Datasheet Preliminary Product Ordering and Shipping Part Number Nomenclature All CXM-11 products are packaged and labeled with part numbers as outlined in the table on pages 5. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 11 NN Product Family Light Emitting Surface Diameter CXM: Chip on Board, Multi-die 11.7: LES Diameter (mm) XX 36 QQPP FG W Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin Color See Note 1 below CRI Volts AC30 Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Note 2: AC is standard package configurator AA is an alternative Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI R9 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K,, 5000K 90 >90 >50 95 >95 2700K, 3000K, 3200K 3500K, 4000K, 5000K Note: >85 >75 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-11 Gen 3 Product Datasheet Preliminary CXM-11 Gen 3 Part Numbers The following tables describe products with typical flux and minimum flux measured at 450mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Luminus may choose to ship a smaller chromatiticy bin in an order for a larger. Output Flux (lm) CCT 3000K 3500K 4000K 3-step MacAdam Ellipse 1,985 2,305 80 CXM-11-27-80-36-AC30-F4-3 1,780 1,635 1,900 90 CXM-11-27-90-36-AC30-F4-3 1,700 1,565 1,815 95 CXM-11-27-95-36-AC30-F4-3 2,280 2,095 2,435 80 CXM-11-30-80-36-AC30-F4-3 1,915 1,765 2,050 90 CXM-11-30-90-36-AC30-F4-3 1,790 1,645 1,915 95 CXM-11-30-95-36-AC30-F4-3 2,345 2,160 2,510 80 CXM-11-35-80-36-AC30-F4-3 1,955 1,800 2,090 90 CXM-11-35-90-36-AC30-F4-3 1,870 1,720 2,000 95 CXM-11-35-95-36-AC30-F4-3 2,550 2,345 2,725 70 CXM-11-40-70-36-AC30-F4-3 2,380 2,190 2,540 80 CXM-11-40-80-36-AC30-F4-3 2,065 1,900 2,205 90 CXM-11-40-90-36-AC30-F4-3 1,905 1,755 2,035 95 CXM-11-40-95-36-AC30-F4-3 Reference Color Rendering Index Part Number (25ºC) Typ. Min.. (85ºC) (calculated) 2,595 2,385 2,395 Typ. (85ºC) *Note: CRI (min.) Typ. 2,155 CCT 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 2,770 70 CXM-11-50-70-36-AC30-F4-5 CXM-11-50-70-36-AC30-F4-3 2,205 2,560 80 CXM-11-50-80-36-AC30-F4-5 CXM-11-50-80-36-AC30-F4-3 2,075 1,910 2,215 90 CXM-11-50-90-36-AC30-F4-5 CXM-11-50-90-36-AC30-F4-3 2,595 2,390 2,775 70 CXM-11-65-70-36-AC30-F4-5 CXM-11-65-70-36-AC30-F4-3 2,385 2,195 2,550 80 CXM-11-65-80-36-AC30-F4-5 CXM-11-65-80-36-AC30-F4-3 (25ºC) Luminus maintains a +/- 6% tolerance on flux measurements, a +/- 2% tolerance on CRI measurements, and a +/- 5% tolerance of R9 5 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-11 Gen 3 Product Datasheet Preliminary CXM-11 Gen 3 Part Numbers The following tables describe products with typical flux and minimum flux measured at 450mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Luminus may choose to ship a smaller chromatiticy bin in an order for a larger. Output Flux (lm) CCT 3000K 3200K 3500K 4000K 3-step MacAdam Ellipse 1,985 2,305 80 CXM-11-27-80-36-AA30-F4-3 1,780 1,635 1,900 90 CXM-11-27-90-36-AA30-F4-3 1,700 1,565 1,815 95 CXM-11-27-95-36-AA30-F4-3 2,280 2,095 2,435 80 CXM-11-30-80-36-AA30-F4-3 1,915 1,765 2,050 90 CXM-11-30-90-36-AA30-F4-3 1,790 1,645 1,915 95 CXM-11-30-95-36-AA30-F4-3 1,800 1,675 1,980 95 CXM-11-32-95-36-AA30-F4-3 2,345 2,160 2,510 80 CXM-11-35-80-36-AA30-F4-3 1,955 1,800 2,090 90 CXM-11-35-90-36-AA30-F4-3 1,870 1,720 2,000 95 CXM-11-35-95-36-AA30-F4-3 2,550 2,345 2,725 70 CXM-11-40-70-36-AA30-F4-3 2,380 2,190 2,540 80 CXM-11-40-80-36-AA30-F4-3 2,065 1,900 2,205 90 CXM-11-40-90-36-AA30-F4-3 1,905 1,755 2,035 95 CXM-11-40-95-36-AA30-F4-3 Reference Color Rendering Index Part Number (25ºC) Typ. Min.. (85ºC) (calculated) 2,595 2,385 2,395 Typ. (85ºC) *Note: CRI (min.) Typ. 2,155 CCT 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 2,770 70 CXM-11-50-70-36-AA30-F4-5 CXM-11-50-70-36-AA30-F4-3 2,205 2,560 80 CXM-11-50-80-36-AA30-F4-5 CXM-11-50-80-36-AA30-F4-3 2,075 1,910 2,215 90 CXM-11-50-90-36-AA30-F4-5 CXM-11-50-90-36-AA30-F4-3 2,005 1,755 2,035 95 CXM-11-50-95-36-AA30-F4-5 CXM-11-50-95-36-AA30-F4-3 2,595 2,390 2,775 70 CXM-11-65-70-36-AA30-F4-5 CXM-11-65-70-36-AA30-F4-3 2,385 2,195 2,550 80 CXM-11-65-80-36-AA30-F4-5 CXM-11-65-80-36-AA30-F4-3 (25ºC) Luminus maintains a +/- 6% tolerance on flux measurements, a +/- 2% tolerance on CRI measurements, and a +/- 5% tolerance of R9 6 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-11 Gen 3 Product Datasheet Preliminary CXM-11 Gen 3 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol Forward Current2 If Forward Voltage3 Vf Minimum 31 Power Operating Case Temperature4 Typical Maximum Unit 450 1,,080 mA 33.8 37 V 15.2 40.5 W 105 ºC Tc Light Emitting Surface Diameter LES 11.7 mm Thermal Resistance (junction-to-case) Qjc 0.35 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: Device operation not recommended at drive currents less than 10% of the typical value Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 6: All product operating specifications are subject to change without advance notice. 7 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-11 Gen 3 Product Datasheet Preliminary CXM-11 Gen 3 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 1080 200% 990 180% Forward Current (mA) Relative Luminous Flux 900 160% 140% 120% 100% 80% 810 720 630 540 450 360 270 60% 180 40% 90 180 270 360 450 540 630 720 810 900 990 1080 31 32 33 Forward Current (mA) Relative Output Flux vs. Junction Temperature 36 37 38 40 38 100% Forward Voltage (V) Relative Luminous Flux 35 Change in Voltage vs. Junction Temperature 120% 80% 60% 36 34 32 40% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 34 Forward Voltage (V) 0 -0.01 0 -0.01 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 8 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CXM-11 Gen 3 Product Datasheet Preliminary CXM-11 Gen 3 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 9 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CXM-11 Gen 3 Product Datasheet Preliminary Mechanical Dimensions (AC30) Mechanical Dimensions (AA30) 10 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-11 Gen 3 Product Datasheet Preliminary Shipping Container 225 pcs per box Each bag is boxed for easier storage/ stacking 45 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 11 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc CXM-11 3 Product Datasheet (PartGen #) Product Datasheet Preliminary Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 12 PDS-002818 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
物料型号:文档中提到了Luminus CXM-11 Gen 3 LED产品系列,具体型号包括CXM-11-27-80-36-AC30-F4-3、CXM-11-30-80-36-AC30-F4-3等,这些型号根据色温、流明输出、色渲染指数(CRI)和色度分选精度有不同的变化。
器件简介:Luminus CXM-11 Gen 3是一系列高性能照明应用的COB LED产品,提供从400lm到超过10,000lm的广泛流明范围,涵盖所有主要色温和超过97的色渲染指数。
引脚分配:文档中没有明确提到引脚分配,但提到了COB LED的顶部表面设计有接触垫,这些接触垫用“+”和“-”极性标记。
参数特性:文档列出了CXM-11 Gen 3 LED的多种参数,包括正向电流、正向电压、功率、工作案例温度、发光表面直径、热阻、结温和视角等。
功能详解:文档详细介绍了Luminus COB LED的技术概览、可靠性、UL认证合规性、REACH和RoHS合规性、测试规格理解、色度分选结构、测试温度等。
应用信息:CXM-11 Gen 3 LED适用于聚光灯/轨道灯、建筑和特殊照明、筒灯、街道照明、商店照明、停车场和区域照明、酒店照明、隧道照明等多种应用。
封装信息:文档提供了机械尺寸、包装信息和处理注意事项,包括产品尺寸、包装方式、防静电措施等。
CXM-11-50-70-36-AA30-F4-5 价格&库存
很抱歉,暂时无法提供与“CXM-11-50-70-36-AA30-F4-5”相匹配的价格&库存,您可以联系我们找货
