CHM-14-30-90-36-AC00-F2-3
    LUMINUS(朗明纳斯)
CHM-14-30-90-36-AC00-F2-3 数据手册
CHM-14 Product Datasheet CHM-14 COB Arrays White LED Features: Table of Contents • High lumen output and efficacy typical • Over 3,050 lm, 121 LPW @ 3000K, 25ºC Technology Overview. . . . . . 2 • Over 3,500 lm, 138 LPW @ 5000K, 25ºC Test Specifications . . . . . . . . . 2 • Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K Chromaticity Bins. . . . . . . . . . 3 • 80 or 90 CRI min. up to 95 min. with high R9 in warm white Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 Part Numbers (AA00). . . . . . . 5 • 3 SDCM color binning accuracy • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading Part Numbers (AC00). . . . . . . 6 • Environmentally friendly: RoHS and REACh compliant Operating Characteristics . . 7 • Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8 Spectra. . . . . . . . . . . . . . . . . . . . 9 Mechanical Dimensions. . . 10 Packaging Information. . . . 11 Handling Notes. . . . . . . . . . . 12 Applications • Spotlights/Track Lights • Architectural and Specialty • Downlights • Street Lighting • Shop Lighting • Parking Lot and Area Lighting • Hospitality Lighting • Tunnel Lighting 1 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 0.46 ANSI C78.377-2008 ANSI C78.377-2008 2-step Ellipse 3-step Ellipse 3-step Ellipse 5-step Ellipse 2700K 2700K 5-step Ellipse 0.44 0.44 3000K 3000K 3500K 3500K 0.42 0.42 Black BlackBody Body 4000K 4000K 5000K 5000K CIE y CIE y 0.4 0.4 0.38 0.38 0.36 0.36 6500K 6500K 0.34 0.34 0.32 0.32 0.3 0.3 0.3 0.3 0.32 0.34 0.32 0.34 0.36 0.38 0.36 0.38 0.4 0.42 0.4 0.44 0.42 CIE x 0.46 0.44 0.48 0.46 0.48 0.5 0.5 CIE x CHM-14 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point *Note: 5-step Bin 3-step Bin Angle CCT CIEx CIEy θ (°) a b a b 2700K 0.4578 0.4101 53.7 0.0081 0.0042 0.0135 0.007 3000K 0.4338 0.403 53.2 0.00834 0.00408 0.0139 0.0068 3500K 0.4073 0.3917 54 0.00927 0.00414 0.01545 0.0069 4000K 0.3818 0.3797 53.7 0.00939 0.00402 0.01565 0.0067 5000K 0.3447 0.3553 59.6 0.00822 0.00354 0.0137 0.0059 6500K 0.3123 0.3282 58.57 0.00669 0.00285 0.01115 0.00475 Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CHM-14 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CHM-14 CHM 14 NN Product Family Light Emitting Surface Diameter CHM: Chip on Board, High Density, Multidie 13.5: LES Diameter (mm) XX 36 QQPP FG W Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin Color See Note 1 below CRI Volts See Note 2 Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Note 2: AA00 is a standard-package configurator AC00 is an alternative substrate size Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI R9 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 95 >95 2700K, 3000K 3500K Note: >90 >80 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet CHM-14 Part Numbers (AA00) The following tables describe products with typical flux and minimum flux measured at 720mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 2700K 3000K 3500K 4000K Reference Ordering Part Number CRI (min.) 3-step MacAdam Ellipse Typ. Typ. (85ºC) Min. (85ºC) (calculated) 2,655 2,520 2,920 80 CHM-14-27-80-36-AA00-F2-3 2,070 1,965 2,280 90 CHM-14-27-90-36-AA00-F2-3 1,950 1,850 2,145 95 CHM-14-27-95-36-AA00-F2-3 2,800 2,660 3,080 80 CHM-14-30-80-36-AA00-F2-3 2,385 2,265 2,625 90 CHM-14-30-90-36-AA00-F2-3 2,205 2,095 2,430 95 CHM-14-30-95-36-AA00-F2-3 2,900 2,755 3,190 80 CHM-14-35-80-36-AA00-F2-3 2,470 2,345 2,715 90 CHM-14-35-90-36-AA00-F2-3 2,280 2,170 2,515 95 CHM-14-35-95-36-AA00-F2-3 3,000 2,850 3,300 80 CHM-14-40-80-36-AA00-F2-3 2,550 2,430 2,810 90 CHM-14-40-90-36-AA00-F2-3 Color Rendering Index Part Number Output Flux (lm) (25ºC) Reference Typ. Typ. (85ºC) Min. (85ºC) (calculated) 5000K 3,070 2,920 6500K 3,060 2,905 CCT Color Rendering Index CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 3,380 80 CHM-14-50-80-36-AA00-F2-5 CHM-14-50-80-36-AA00-F2-3 3,365 80 CHM-14-65-80-36-AA00-F2-5 CHM-14-65-80-36-AA00-F2-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet CHM-14 Part Numbers (AC00) The following tables describe products with typical flux and minimum flux measured at 720mA and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Output Flux (lm) CCT 2700K 3000K 3500K 4000K 5000K 6500K Color Rendering Index Ordering Part Number CRI (min.) 3-step MacAdam Ellipse Typ. Typ. (85ºC) Min. (85ºC) (calculated) 2,655 2,520 2,920 80 CHM-14-27-80-36-AC00-F2-3 2,070 1,965 2,280 90 CHM-14-27-90-36-AC00-F2-3 1,950 1,850 2,145 95 CHM-14-27-95-36-AC00-F2-3 2,800 2,660 3,080 80 CHM-14-30-80-36-AC00-F2-3 2,385 2,265 2,625 90 CHM-14-30-90-36-AC00-F2-3 2,205 2,095 2,430 95 CHM-14-30-95-36-AC00-F2-3 2,900 2,755 3,190 80 CHM-14-35-80-36-AC00-F2-3 2,470 2,345 2,715 90 CHM-14-35-90-36-AC00-F2-3 3,150 2,995 3,465 70 CHM-14-40-70-36-AC00-F2-3 3,000 2,850 3,300 80 CHM-14-40-80-36-AC00-F2-3 2,550 2,430 2,810 90 CHM-14-40-90-36-AC00-F2-3 Color Rendering Index Part Number Output Flux (lm) CCT Reference (25ºC) Reference Typ. Typ. (85ºC) Min. (85ºC) (calculated) 3,225 3,064 3,070 CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 3,550 70 CHM-14-50-70-36-AC00-F2-5 CHM-14-50-70-36-AC00-F2-3 2,920 3,380 80 CHM-14-50-80-36-AC00-F2-5 CHM-14-50-80-36-AC00-F2-3 3,210 3,050 3,530 70 CHM-14-65-70-36-AC00-F2-5 CHM-14-65-70-36-AC00-F2-3 3,060 2,905 3,365 80 CHM-14-65-80-36-AC00-F2-5 CHM-14-65-80-36-AC00-F2-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet CHM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum 32 Power Operating Case Temperature4 Typical Maximum Unit 720 1,440 mA 35 37.5 V 25.2 50 W 105 ºC Tc Light Emitting Surface Diameter LES Thermal Resistance (junction-to-case) Qjc Junction Temperature Tj 13.5 mm 0.45 Viewing Angle ºC/W 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs. Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not harm the device but may result in uneven light emission across the LES surface. Note 5: Luminus retains the right to change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 7 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet CHM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 1400 1000 180% 140% Forward Current (mA) Relative Relative Luminous Luminous Flux Flux 160% 120% 100% 80% 60% 60% 1200 800 1000 600 800 400 600 40% 40% 200 400 20% 20% 0% 0% 200 0 250 250 350 450 450 550 650 650850 750 1050850 950 1250 34 1050 1450 35 36 Relative Output Flux vs. Junction Temperature 39 40 40 100% 38 80% Forward Voltage (V) Relative Luminous Flux 38 Change in Voltage vs. Junction Temperature 120% 60% 40% 36 34 32 20% 30 0% 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 45 55 65 75 85 95 105 Junction Temperature (ºC) Junction Temperature (ºC) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 37 Forward Voltage (V) Forward Current (mA) 0 -0.01 0 -0.01 -0.02 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 8 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CHM-14 Product Datasheet CHM-14 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 9 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CHM-14 Product Datasheet Mechanical Dimensions (AA00) Mechanical Dimensions (AC00) 10 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved CHM-14 (Part #) Product Product Datasheet Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 11 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover CHM-14 Product Datasheet (Part #) Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 12 PDS-002448 Rev 05 © 2016 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
物料型号: CHM-14 COB Arrays
器件简介: - 适用于高性能照明应用,提供从少于400lm到超过10,000lm的光通量范围。 - 色温覆盖全范围,CRI(Color Rendering Index,色彩还原指数)可达97,R9可达95。
引脚分配: 文档中未明确列出引脚分配,但提到了COB LED的顶部有用于电气连接的接触垫。
参数特性: - 光通量:2700K至6500K色温下,最高超过3500lm。 - 能效:在3000K色温下,可达121 LPW(流明/瓦)。 - 色容差:3 SDCM(标准偏差的麦克亚当椭圆)。 - 色稳定性:长期色彩稳定性出色。 - 热导性:具有优越的热传导性,以实现均匀的热扩散。
功能详解: - 可靠性:通过了包括机械冲击、振动、温度循环和湿度在内的一系列环境和机械应力测试。 - 合规性:符合UL、REACh和RoHS标准,无有害物质。
应用信息: - 适用于聚光灯、筒灯、商业照明、酒店照明、建筑和特殊照明、街道照明、停车场照明和隧道照明。
封装信息: - 提供了详细的产品订购和发货部件编号,包括标准封装配置器(AA00)和替代基板尺寸(AC00)。 - 描述了产品的光学和电气特性,包括正向电流、正向电压、功率、工作温度、发光面直径、热阻等。
处理注意事项: - 强调了在处理和组装COB LED时需要注意的静电放电(ESD)防护、化学兼容性和热界面材料(TIM)的选择。
CHM-14-30-90-36-AC00-F2-3 价格&库存
很抱歉,暂时无法提供与“CHM-14-30-90-36-AC00-F2-3”相匹配的价格&库存,您可以联系我们找货
