CHM-14-40-80-36-AC10-F3-3
    LUMINUS(朗明纳斯)
CHM-14-40-80-36-AC10-F3-3 数据手册
CHM-14 Product Datasheet Preliminary Generation 2 CHM-14 COB Arrays White LED Features: Table of Contents • High lumen output and efficacy typical • Over 3,200 lm, 128 LPW @ 3000K, 85ºC Technology Overview. . . . . . 2 • Over 3,700 lm, 147 LPW @ 5000K, 85ºC Test Specifications . . . . . . . . . 2 • Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K Chromaticity Bins. . . . . . . . . . 3 • 80 or 90 CRI min. up to 95 min. with high R9 in warm white Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 Part Numbers (AA10). . . . . . . 5 • 3 SDCM color binning accuracy • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading Part Numbers (AC10). . . . . . . 6 • Environmentally friendly: RoHS and REACh compliant Operating Characteristics . . 7 • Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8 Spectra. . . . . . . . . . . . . . . . . . . . 9 Mechanical Dimensions. . . 10 Packaging Information. . . . 11 Handling Notes. . . . . . . . . . . 12 Applications • Spotlights/Track Lights • Architectural and Specialty • Downlights • Street Lighting • Shop Lighting • Parking Lot and Area Lighting • Hospitality Lighting • Tunnel Lighting 1 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Technology Overview Preliminary Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACh and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Preliminary Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 2700K 0.44 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CHM-14 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point 5-step Bin 3-step Bin Angle CCT CIEx CIEy θ (°) a b a b 2700K 0.4578 0.4101 53.7 0.0081 0.0042 0.0135 0.007 3000K 0.4338 0.403 53.2 0.00834 0.00408 0.0139 0.0068 3500K 0.4073 0.3917 54 0.00927 0.00414 0.01545 0.0069 4000K 0.3818 0.3797 53.7 0.00939 0.00402 0.01565 0.0067 5000K 0.3447 0.3553 59.6 0.00822 0.00354 0.0137 0.0059 6500K 0.3123 0.3282 58.57 0.00669 0.00285 0.01115 0.00475 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Preliminary Product Ordering and Shipping Part Number Nomenclature All CHM-14 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CHM-14 CHM 14 NN Product Family Light Emitting Surface Diameter CHM: Chip on Board, High Density, Multidie 13.5: LES Diameter (mm) XX 36 QQPP FG W Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin Color See Note 1 below CRI Volts See Note 2 Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Note 2: AA10 is a standard-package configurator AC10 is an alternative substrate size Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI R9 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 95 >95 2700K, 3000K 3500K Note: >85 >80 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Preliminary CHM-14 Part Numbers (AA10) The following tables describe products with typical flux and minimum flux measured at 720mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 2700K 3000K 3500K 4000K Reference Ordering Part Number CRI (min.) 3-step MacAdam Ellipse Typ. Typ. (85ºC) Min. (85ºC) (calculated) 2,980 2,771 3,405 80 CHM-14-27-80-36-AA10-F3-3 2,415 2,245 2,655 90 CHM-14-27-90-36-AA10-F3-3 2,275 2,115 2,500 95 CHM-14-27-95-36-AA10-F3-3 3,150 2,930 3,590 80 CHM-14-30-80-36-AA10-F3-3 2,700 2,511 3,055 90 CHM-14-30-90-36-AA10-F3-3 2,480 2,306 2,830 95 CHM-14-30-95-36-AA10-F3-3 3,280 3,050 3,720 80 CHM-14-35-80-36-AA10-F3-3 2,800 2,604 3,170 90 CHM-14-35-90-36-AA10-F3-3 2,590 2,409 2,925 95 CHM-14-35-95-36-AA10-F3-3 3,330 3,097 3,850 80 CHM-14-40-80-36-AA10-F3-3 2,850 2,651 3,270 90 CHM-14-40-90-36-AA10-F3-3 Color Rendering Index Part Number Output Flux (lm) (25ºC) Reference Typ. Typ. (85ºC) Min. (85ºC) (calculated) 5000K 3,360 3,125 6500K 3,360 3,125 CCT Color Rendering Index CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 3,940 80 CHM-14-50-80-36-AA10-F3-5 CHM-14-50-80-36-AA10-F3-3 3,925 80 CHM-14-65-80-36-AA10-F3-5 CHM-14-65-80-36-AA10-F3-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Preliminary CHM-14 Part Numbers (AC10) The following tables describe products with typical flux and minimum flux measured at 720mA and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature Output Flux (lm) CCT 2700K 3000K 3500K 4000K 5000K 6500K Color Rendering Index Ordering Part Number CRI (min.) 3-step MacAdam Ellipse Typ. Typ. (85ºC) Min. (85ºC) (calculated) 2,980 2,771 3,405 80 CHM-14-27-80-36-AC10-F3-3 2,415 2,245 2,655 90 CHM-14-27-90-36-AC10-F3-3 2,275 2,115 2,500 95 CHM-14-27-95-36-AC10-F3-3 3,150 2,930 3,590 80 CHM-14-30-80-36-AC10-F3-3 2,700 2,511 3,055 90 CHM-14-30-90-36-AC10-F3-3 2,480 2,306 2,830 95 CHM-14-30-95-36-AC10-F3-3 3,280 3,050 3,720 80 CHM-14-35-80-36-AC10-F3-3 2,800 2,604 3,170 90 CHM-14-35-90-36-AC10-F3-3 3,675 3,415 4,045 70 CHM-14-40-70-36-AC10-F3-3 3,330 3,097 3,850 80 CHM-14-40-80-36-AC10-F3-3 2,850 2,651 3,270 90 CHM-14-40-90-36-AC10-F3-3 2,760 2,565 3,035 95 CHM-14-40-95-36-AC10-F3-3 Color Rendering Index Part Number Output Flux (lm) CCT Reference (25ºC) Reference Typ. Typ. (85ºC) Min. (85ºC) (calculated) 3,760 3,495 3,360 CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 4,135 70 CHM-14-50-70-36-AC10-F3-5 CHM-14-50-70-36-AC10-F3-3 3,125 3,940 80 CHM-14-50-80-36-AC10-F3-5 CHM-14-50-80-36-AC10-F3-3 3,745 3,480 4,120 70 CHM-14-65-70-36-AC10-F3-5 CHM-14-65-70-36-AC10-F3-3 3,360 3,125 3,925 80 CHM-14-65-80-36-AC10-F3-5 CHM-14-65-80-36-AC10-F3-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 6 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Preliminary CHM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum 33.5 Power Operating Case Temperature4 Typical Maximum Unit 720 1,440 mA 35.5 37.5 V 25.5 52 W 105 ºC Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resistance (junction-to-case) Qjc 0.45 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs. Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not harm the device but may result in uneven light emission across the LES surface. Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 7 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 Product Datasheet Preliminary CHM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 1400 180% 1200 140% Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 1000 800 600 40% 400 20% 200 0% 250 350 450 550 650 750 850 950 34 1050 35 36 Relative Output Flux vs. Junction Temperature 39 40 40 100% 38 80% Forward Voltage (V) Relative Luminous Flux 38 Change in Voltage vs. Junction Temperature 120% 60% 40% 36 34 32 20% 0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 45 Junction Temperature (ºC) 55 65 75 85 95 105 Junction Temperature (ºC) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 37 Forward Voltage (V) Forward Current (mA) 0 -0.01 0 -0.01 -0.02 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 8 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CHM-14 Product Datasheet Preliminary CHM-14 Optical & Electrical Characteristics Derating Curve 1,600 1,400 1,200 If (mA) 1,000 800 600 400 200 0 0 50 100 Tc Case Temperature (°C) Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 9 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CHM-14 Product Datasheet Preliminary Mechanical Dimensions (AA10) Mechanical Dimensions (AC10) 10 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved CHM-14 (Part #) Product Product Datasheet Preliminary Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 11 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover CHM-14 Product Datasheet (Part #) Product Datasheet Preliminary Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 12 PDS-002762 Rev 02 © 2015 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
物料型号:文档中提到了多种型号,包括CHM-14-27-80-36-AA10-F3-3、CHM-14-27-90-36-AA10-F3-3等,这些型号代表了不同色温、流明输出和色渲染指数(CRI)的LED产品。
器件简介:Luminus的COB(板上芯片)LED系列提供了针对高性能照明应用的完整照明解决方案。这些产品覆盖了从不到400流明到超过10000流明的广泛流明范围,并可提供2700K至6500K的色温以及超过97的色渲染指数。
引脚分配:文档中没有明确提到具体的引脚分配,但提到了COB LED的顶部表面设计有接触垫,这些垫上标有正负极性。
参数特性:文档列出了多个参数,包括正向电流、正向电压、功率、工作温度、发光表面直径、热阻、结温和视角等。
功能详解:Luminus COB LED以其高流明输出、高效率、宽色温范围、高CRI、色彩一致性、长期色彩稳定性、优越的热传导性以及环保特性(符合RoHS和REACh标准)而著称。
应用信息:这些LED适用于聚光灯/轨道灯、建筑和特殊照明、筒灯、街道照明、商店照明、停车场和区域照明、酒店照明和隧道照明等多种应用。
封装信息:文档提供了机械尺寸图和包装信息,说明了产品的物理尺寸和包装方式,例如每个袋子装有5个托盘,每个托盘都密封在防静电袋中。
CHM-14-40-80-36-AC10-F3-3 价格&库存
很抱歉,暂时无法提供与“CHM-14-40-80-36-AC10-F3-3”相匹配的价格&库存,您可以联系我们找货
  • 1125+40.583961125+5.25635
