CHM-14 Product Datasheet
CHM-14 COB Arrays
White LED
Features:
Table of Contents
• High lumen output and efficacy typical
• Over 3,050 lm, 121 LPW @ 3000K, 25ºC
Technology Overview. . . . . . 2
• Over 3,500 lm, 138 LPW @ 5000K, 25ºC
Test Specifications . . . . . . . . . 2
• Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K
Chromaticity Bins. . . . . . . . . . 3
• 80 or 90 CRI min. up to 95 min. with high R9 in warm white
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
Part Numbers (AA00). . . . . . . 5
• 3 SDCM color binning accuracy
• Excellent optical emission uniformity and color over angle consistency
• Exceptional long term color stability
• Superior thermal conductivity for uniform heat spreading
Part Numbers (AC00). . . . . . . 6
• Environmentally friendly: RoHS and REACh compliant
Operating Characteristics . . 7
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8
Spectra. . . . . . . . . . . . . . . . . . . . 9
Mechanical Dimensions. . . 10
Packaging Information. . . . 11
Handling Notes. . . . . . . . . . . 12
Applications
• Spotlights/Track Lights
• Architectural and Specialty
• Downlights
• Street Lighting
• Shop Lighting
• Parking Lot and Area Lighting
• Hospitality Lighting
• Tunnel Lighting
1
PDS-002448 Rev 05
© 2016 Luminus Devices, Inc. - All Rights Reserved
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can
deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and
designers to develop lighting solutions with maximum efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM80 test data and TM21 lifetime results that certify
lumen maintenance at 35,000 hours or more, Luminus COB
LEDs are ready for the toughest challenges.
UL Recognized Compliance
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACh & RoHS Compliance
All LED products manufactured by Luminus are REACh and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application. For
the most demanding application, Luminus is one of only a few
companies that can provide a 2-step ellipse bin. These tightly
controlled, small distribution bins provide customers
predictable, repeatable colors.
Testing Temperature
Luminus COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002448 Rev 05
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.46
0.46
ANSI
C78.377-2008
ANSI
C78.377-2008
2-step
Ellipse
3-step Ellipse
3-step Ellipse
5-step Ellipse
2700K
2700K
5-step Ellipse
0.44
0.44
3000K
3000K
3500K
3500K
0.42
0.42
Black
BlackBody
Body
4000K
4000K
5000K
5000K
CIE y
CIE y
0.4
0.4
0.38
0.38
0.36
0.36
6500K
6500K
0.34
0.34
0.32
0.32
0.3
0.3
0.3
0.3
0.32
0.34
0.32
0.34
0.36
0.38
0.36
0.38
0.4
0.42
0.4
0.44
0.42
CIE x
0.46
0.44
0.48
0.46
0.48
0.5
0.5
CIE x
CHM-14 White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
Center Point
*Note:
5-step Bin
3-step Bin
Angle
CCT
CIEx
CIEy
θ (°)
a
b
a
b
2700K
0.4578
0.4101
53.7
0.0081
0.0042
0.0135
0.007
3000K
0.4338
0.403
53.2
0.00834
0.00408
0.0139
0.0068
3500K
0.4073
0.3917
54
0.00927
0.00414
0.01545
0.0069
4000K
0.3818
0.3797
53.7
0.00939
0.00402
0.01565
0.0067
5000K
0.3447
0.3553
59.6
0.00822
0.00354
0.0137
0.0059
6500K
0.3123
0.3282
58.57
0.00669
0.00285
0.01115
0.00475
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002448 Rev 05
Product Ordering and Shipping Part Number Nomenclature
All CHM-14 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. When shipped, each
package will contain only a single flux and chromaticity bin. The part number designation is as follows:
CHM-14
CHM
14
NN
Product Family
Light Emitting
Surface Diameter
CHM: Chip on
Board, High
Density, Multidie
13.5: LES
Diameter (mm)
XX
36
QQPP
FG
W
Color
Temperature
Color Rendering Index (CRI)
Voltage
(typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
Color
See Note 1
below
CRI
Volts
See Note 2
Lumens
See page 3 for
bins
Note 1: NN nomenclature corresponds to the following:
27 = 2700K
30 = 3000K
35 = 3500K
40 = 4000K
50 = 5000K
65 = 6500K
Note 2: AA00 is a standard-package configurator
AC00 is an alternative substrate size
Color Temperature, CRI and R9 Values
Color Temperatures
XX Value
CRI
R9
4000K, 5000K, 6500K
70
>70
2700K, 3000K, 3500K, 4000K, 5000K, 6500K
80
>80
>0
90
>90
>50
95
>95
2700K, 3000K
3500K
Note:
>90
>80
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002448 Rev 05
CHM-14 Part Numbers (AA00)
The following tables describe products with typical flux and minimum flux measured at 720mA and specified at Tj = 85ºC. The values at
25ºC are calculated and shown for reference only.
Output Flux
(lm)
CCT
2700K
3000K
3500K
4000K
Reference
Ordering Part Number
CRI (min.)
3-step MacAdam Ellipse
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
2,655
2,520
2,920
80
CHM-14-27-80-36-AA00-F2-3
2,070
1,965
2,280
90
CHM-14-27-90-36-AA00-F2-3
1,950
1,850
2,145
95
CHM-14-27-95-36-AA00-F2-3
2,800
2,660
3,080
80
CHM-14-30-80-36-AA00-F2-3
2,385
2,265
2,625
90
CHM-14-30-90-36-AA00-F2-3
2,205
2,095
2,430
95
CHM-14-30-95-36-AA00-F2-3
2,900
2,755
3,190
80
CHM-14-35-80-36-AA00-F2-3
2,470
2,345
2,715
90
CHM-14-35-90-36-AA00-F2-3
2,280
2,170
2,515
95
CHM-14-35-95-36-AA00-F2-3
3,000
2,850
3,300
80
CHM-14-40-80-36-AA00-F2-3
2,550
2,430
2,810
90
CHM-14-40-90-36-AA00-F2-3
Color
Rendering
Index
Part Number
Output Flux
(lm)
(25ºC)
Reference
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
5000K
3,070
2,920
6500K
3,060
2,905
CCT
Color
Rendering
Index
CRI (min.)
5-step MacAdam Ellipse
3,380
80
CHM-14-50-80-36-AA00-F2-5
CHM-14-50-80-36-AA00-F2-3
3,365
80
CHM-14-65-80-36-AA00-F2-5
CHM-14-65-80-36-AA00-F2-3
(25ºC)
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002448 Rev 05
CHM-14 Part Numbers (AC00)
The following tables describe products with typical flux and minimum flux measured at 720mA and specified at 85ºC. The values at 25ºC
are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature.
Output Flux
(lm)
CCT
2700K
3000K
3500K
4000K
5000K
6500K
Color
Rendering
Index
CRI (min.)
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
2,655
2,520
2,920
80
CHM-14-27-80-36-AC00-F2-3
2,070
1,965
2,280
90
CHM-14-27-90-36-AC00-F2-3
1,950
1,850
2,145
95
CHM-14-27-95-36-AC00-F2-3
2,800
2,660
3,080
80
CHM-14-30-80-36-AC00-F2-3
2,385
2,265
2,625
90
CHM-14-30-90-36-AC00-F2-3
2,205
2,095
2,430
95
CHM-14-30-95-36-AC00-F2-3
2,900
2,755
3,190
80
CHM-14-35-80-36-AC00-F2-3
2,470
2,345
2,715
90
CHM-14-35-90-36-AC00-F2-3
3,150
2,995
3,465
70
CHM-14-40-70-36-AC00-F2-3
3,000
2,850
3,300
80
CHM-14-40-80-36-AC00-F2-3
2,550
2,430
2,810
90
CHM-14-40-90-36-AC00-F2-3
Color
Rendering
Index
Part Number
Output Flux
(lm)
CCT
Reference
(25ºC)
Reference
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
3,225
3,064
3,070
CRI (min.)
3,550
70
CHM-14-50-70-36-AC00-F2-5
CHM-14-50-70-36-AC00-F2-3
2,920
3,380
80
CHM-14-50-80-36-AC00-F2-5
CHM-14-50-80-36-AC00-F2-3
3,210
3,050
3,530
70
CHM-14-65-70-36-AC00-F2-5
CHM-14-65-70-36-AC00-F2-3
3,060
2,905
3,365
80
CHM-14-65-80-36-AC00-F2-5
CHM-14-65-80-36-AC00-F2-3
(25ºC)
*Note:
6
PDS-002448 Rev 05
CHM-14 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
32
Power
Operating Case Temperature4
Typical
Maximum
Unit
720
1,440
mA
35
37.5
V
25.2
50
W
105
ºC
Tc
Light Emitting Surface Diameter
LES
Thermal Resistance (junction-to-case)
Qjc
Junction Temperature
Tj
13.5
mm
0.45
Viewing Angle
ºC/W
140
120
ºC
Degree
Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs.
Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not
harm the device but may result in uneven light emission across the LES surface.
Note 5: Luminus retains the right to change any specifications without prior notice. Please refer to the company web site for the latest data sheet revision
Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
7
PDS-002448 Rev 05
CHM-14 Optical & Electrical Characteristics
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
200%
1400
1000
180%
140%
Forward Current (mA)
Relative
Relative Luminous
Luminous Flux
Flux
160%
120%
100%
80%
60%
60%
1200
800
1000
600
800
400
600
40%
40%
200
400
20%
20%
0%
0%
200
250
350 450
450
550
650
650850
750
1050850
950
1250
34
1050 1450
35
36
Relative Output Flux vs. Junction Temperature
39
40
40
100%
38
80%
Forward Voltage (V)
Relative Luminous Flux
38
Change in Voltage vs. Junction Temperature
120%
60%
40%
36
34
32
20%
30
0%
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
55
65
75
85
95
105
Junction Temperature (ºC)
Change in CIEx vs. Junction Temp. (3000K, 80CRI)
Change in CIEy vs. Junction Temp. (3000K, 80CRI)
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
37
Forward Voltage (V)
-0.02
-0.02
5
15
25
35
45
55
65
75
8
PDS-002448 Rev 05
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Typical Spectrum
120.00%
100.00%
Relative Intensity
80.00%
Warm White
60.00%
Neutral White
Cool White
40.00%
3000K-90CRI
3000K-97CRI
20.00%
0.00%
400
450
500
-20.00%
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
9
PDS-002448 Rev 05
40
60
80
Mechanical Dimensions (AA00)
Mechanical Dimensions (AC00)
10
PDS-002448 Rev 05
CHM-14
(Part #) Product
Product Datasheet
Shipping Container
Each bag is boxed for
easier storage/stacking
Trays are sealed in an
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
11
PDS-002448 Rev 05
5 trays are stacked together
with one tray as a cover
CHM-14
Product
Datasheet
(Part
#) Product
Datasheet
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with Luminus COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the Luminus COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
12
PDS-002448 Rev 05
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
