CHM-11-40-95-36-XH00-F2-3 数据手册
CHM-11 Product Datasheet
CHM-11-XH00 LED
High Density White
COB Array
Features:
• High lumen output, density
Table of Contents
• Over 3,450 lumens, @ 3000K, 80 CRI, 85ºC
• Over 4,000 lumens per square centimeter of Light Emitting Surface (LES)
Technology Overview. . . . . . 2
Test Specifications . . . . . . . . . 2
• CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K
• CRI Ra 80 or 90 min. in all colors (except 6500K)
Chromaticity Bins. . . . . . . . . . 3
• R9 up to 90 min. CRI 98 typical in 2700K, 3000K, 3500K and 4000K
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
• 3 SDCM color binning accuracy
Part Numbers. . . . . . . . . . . . . . 5
• Exceptional long term color stability
Operating Characteristics . . 6
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7
• Excellent optical emission uniformity and color over angle consistency
• Package thermal conductivity more than twice the industry average
• Environmentally friendly: RoHS and REACH compliant
Spectra. . . . . . . . . . . . . . . . . . . . 8
Mechanical Dimensions. . . . 9
Packaging Information. . . . . 9
Handling Notes. . . . . . . . . . . 10
Applications
• Spotlights/Track Lights
• Architectural and Specialty
• Downlights
• Street Lighting
• Shop Lighting
• Parking Lot and Area Lighting
• Hospitality Lighting
• Tunnel Lighting
1
PDS-002624 Rev 03
© 2016 Luminus Devices, Inc. - All Rights Reserved
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The selection covers a wide lumen range from less than 400lm to over 25,000lm, all major color temperatures and can
deliver color rendering greater than 95 at 2700K and 3000K and R9 greater than 90. These breakthroughs allow illumination engineers
and designers to develop beautifully lit spaces without sacrificing efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM80 test data and TM21 lifetime results that certify
lumen maintenance at 35,000 hours or more, Luminus COB
LEDs are ready for the toughest challenges.
UL Recognized Compliance
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACH & RoHS Compliance
All LED products manufactured by Luminus are REACH and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application. For
the most demanding application, Luminus is one of only a few
companies that can provide a 2-step ellipse bin. These tightly
controlled, small distribution bins provide customers
predictable, repeatable colors.
Testing Temperature
Luminus COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002624 Rev 03
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.46
0.46
ANSI
C78.377-2008
ANSI
C78.377-2008
2-step Ellipse
3-step Ellipse
3-step Ellipse
5-step
Ellipse
5-step Ellipse
0.44
0.44
2700K
2700K
3000K
3000K
3500K
3500K
0.42
0.42
Black
Body
Black Body
4000K
4000K
CIE y
CIE y
0.4
0.4
5000K
5000K
0.38
0.38
0.36
0.36
6500K
6500K
0.34
0.34
0.32
0.32
0.3
0.3
0.3
0.3
0.32
0.32
0.34
0.34
0.36
0.36
0.38
0.38
0.4
0.4
0.42
0.42
0.44
0.44
0.46
0.46
0.48
0.48
0.5
0.5
CIE
CIE xx
CHM-11 White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
Center Point
*Note:
5-step Bin
3-step Bin
Angle
CCT
CIEx
CIEy
θ (°)
a
b
a
b
2700K
0.4578
0.4101
53.7
0.0081
0.0042
0.0135
0.007
3000K
0.4338
0.403
53.2
0.00834
0.00408
0.0139
0.0068
3500K
0.4073
0.3917
54
0.00927
0.00414
0.01545
0.0069
4000K
0.3818
0.3797
53.7
0.00939
0.00402
0.01565
0.0067
5000K
0.3447
0.3553
59.6
0.00822
0.00354
0.0137
0.0059
6500K
0.3123
0.3282
58.57
0.00669
0.00285
0.01115
0.00475
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002624 Rev 03
Product Ordering and Shipping Part Number Nomenclature
All CHM-11 products are packaged and labeled with part numbers as outlined in the table on page 5. When shipped, each package will
contain only a single flux and chromaticity bin. The part number designation is as follows:
CHM
CHM-11
XX
11
NN
36
QQPP
FG
W
Product Family
Light Emitting
Surface Diameter
Color
Temperature
Color Rendering Index (CRI)
Voltage
(typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
CHM: Chip on
Board, High
Density, Multidie
11: LES
Diameter (mm)
Color
See Note 1
below
CRI
Volts
XH00
Lumens
See page 3 for
bins
Note 1: NN nomenclature corresponds to the following:
27 = 2700K
30 = 3000K
35 = 3500K
40 = 4000K
50 = 5000K
65 = 6500K
Color Temperature, CRI and R9 Values
Color Temperatures
XX Value
CRI
R9
2700K, 3000K, 3500K, 4000K, 5000K, 6500K
80
>80
>0
90
>90
>50
95
>95
2700K, 3000K
3500K,
Note:
>90
>75
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002624 Rev 03
CHM-11-XH00 Part Numbers
The following tables describe products with typical flux and minimum flux measured at 960mA and specified at Tj = 85ºC. The values at
25ºC are calculated and shown for reference only.
Output Flux (lm)
CCT
3000K
3500K
4000K
5000K
6500K
*Note:
Ordering Part Number
CRI (min.)
3-step MacAdam Ellipse
Typ.
(calculated)
3,305
3,135
3,635
80
CHM-11-27-80-36-XH00-F2-3
2,575
2,445
2,830
90
CHM-11-27-90-36-XH00-F2-3
2,420
2,300
2,665
95
CHM-11-27-95-36-XH00-F2-3
3,485
3,305
3,830
80
CHM-11-30-80-36-XH00-F2-3
2,815
2,675
3,100
90
CHM-11-30-90-36-XH00-F2-3
2,700
2,565
2,970
95
CHM-11-30-95-36-XH00-F2-3
3,610
3,425
3,970
80
CHM-11-35-80-36-XH00-F2-3
2,885
2,740
3,175
90
CHM-11-35-90-36-XH00-F2-3
2,705
2,570
2,975
95
CHM-11-35-95-36-XH00-F2-3
3,725
3,540
4,100
80
CHM-11-40-80-36-XH00-F2-3
2,980
2,830
3,280
90
CHM-11-40-90-36-XH00-F2-3
Output Flux
(lm)
CCT
Color Rendering
Index
Min.
(85ºC)
Typ. (85ºC)
2700K
Reference
Reference
(25ºC)
Color
Rendering
Index
Part Number
Typ.
Typ.
(85ºC)
Min.
(85ºC)
(calculated)
3,815
3,625
3,055
3,800
CRI (min.)
5-step MacAdam Ellipse
4,200
80
CHM-11-50-80-36-XH00-F2-5
CHM-11-50-80-36-XH00-F2-3
2,900
3,360
90
CHM-11-50-90-36-XH00-F2-5
CHM-11-50-90-36-XH00-F2-3
3,605
4,180
80
CHM-11-65-80-36-XH00-F2-5
CHM-11-65-80-36-XH00-F2-3
(25ºC)
Luminus maintains a +/- 6% tolerance on flux measurements, a +/- 2% tolerance on CRI measurements, and a +/- 5% tolerance of R9
5
PDS-002624 Rev 03
CHM-11 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
33.5
Power
Operating Case Temperature4
Typical
Maximum
Unit
960
1,440
mA
36
38
V
34.6
51.5
W
105
ºC
Tc
Light Emitting Surface Diameter
LES
11
mm
Thermal Resistance (junction-to-case)
Qjc
0.18
ºC/W
Junction Temperature
Tj
Viewing Angle
140
120
ºC
Degree
Note 1:
Ratings are based on operation at a constant junction temperature of Tj = 85ºC.
Note 2:
To prevent damage refer to operating conditions for maximum operating conditions
Note 3:
Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs.
Note 4:
CHM-11 COB minimum operating current is suggested to be no less than 20% of the typical value. While lower levels will not harm the device, they
may result in uneven lighting across the LES area.
Note 5:
Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
Note 6:
Data sheets are subject to changes without prior notice. Please refer to the Luminus web site for the latest data sheet revisions.
6
PDS-002624 Rev 03
CHM-11 Optical & Electrical Characteristics
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
1200
160%
1100
140%
1000
Forward Current (mA)
Relative Luminous Flux
120%
100%
80%
60%
900
800
700
600
500
40%
400
20%
300
200
0%
250
350
450
550
650
750
850
950
1050
1150
34
1250
34.5
35
35.5
Relative Output Flux vs. Junction Temperature
37
37.5
38
38.5
39
40
100%
38
Forward Voltage (V)
36.5
Change in Voltage vs. Junction Temperature
120%
80%
60%
40%
36
34
32
20%
30
0%
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
55
65
75
85
95
105
Junction Temperature (ºC)
Change in CIEx vs. Junction Temp. (3000K, 80CRI)
Change in CIEy vs. Junction Temp. (3000K, 80CRI)
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
36
Forward Voltage (V)
-0.02
-0.02
5
15
25
35
45
55
65
75
7
PDS-002624 Rev 03
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Typical Spectrum
120.00%
100.00%
Relative Intensity
80.00%
Warm White
60.00%
Neutral White
Cool White
40.00%
3000K-90CRI
3000K-97CRI
20.00%
0.00%
400
450
500
-20.00%
550
600
650
700
750
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
8
PDS-002624 Rev 03
40
60
80
Shipping Container
Each bag is boxed for
easier storage/stacking
Trays are sealed in an
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
9
PDS-002624 Rev 03
5 trays are stacked together
with one tray as a cover
CHM-11
Product
Datasheet
(Part
#) Product
Datasheet
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with Luminus COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the Luminus COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
10
PDS-002624 Rev 03
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Luminus Devices:
CHM-11-50-80-36-XH00-F2-5 CHM-11-40-90-36-XH00-F2-3 CHM-11-65-80-36-XH00-F2-5 CHM-11-40-80-36-XH00F2-3 CHM-11-30-80-36-XH00-F2-3 CHM-11-35-90-36-XH00-F2-3 CHM-11-35-95-36-XH00-F2-3 CHM-11-40-95-36XH00-F2-3 CHM-11-27-90-36-XH00-F2-3 CHM-11-30-95-36-XH00-F2-3 CHM-11-27-80-36-XH00-F2-3 CHM-11-2795-36-XH00-F2-3 CHM-11-30-90-36-XH00-F2-3 CHM-11-50-90-36-XH00-F2-5 CHM-11-35-80-36-XH00-F2-3
