CXM-14-50-70-36-AC30-F4-5
    LUMINUS(朗明纳斯)
CXM-14-50-70-36-AC30-F4-5 数据手册
CXM-14 Product Datasheet Generation 3 CXM-14 COB Arrays White LED Features: • High lumen output and efficacy typical Table of Contents • Over 3,600 lm, 148 LPW @ 3000K, 80 CRI, Tj = 85ºC Technology Overview. . . . . . 2 • Over 4,095 lm, 168 LPW @ 5000K, 70 CRI, Tj = 85ºC Test Specifications . . . . . . . . . 2 • Complete CCT range 2700K, 3000K, 3500K, 4000K, 5000K and 6500K • 80 or 90 CRI min. up to 95 min. with high R9 in warm white Chromaticity Bins. . . . . . . . . . 3 • 3 SDCM color binning accuracy Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • Excellent optical emission uniformity and color over angle consistency Customer Part Numbers. . . . 5 Operating Characteristics . . 7 • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading • Environmentally friendly: RoHS and REACH compliant • Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 8 Spectra. . . . . . . . . . . . . . . . . . . . 9 Mechanical Dimensions. . . 10 Packaging Information. . . . 11 Handling Notes. . . . . . . . . . . 12 Applications • Spotlights/Track Lights • Architectural and Specialty • Downlights • Street Lighting • Shop Lighting • Parking Lot and Area Lighting • Hospitality Lighting • Tunnel Lighting 1 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-14 Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 20,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACH & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale datasheet specifications to real world situations. 2 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-14 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 0.44 3200K 2700K 3000K 2400K 3500K 0.42 4000K CIE y 0.4 Black Body 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 CIE x 0.42 0.44 0.46 0.48 0.5 CXM-14 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. CCT Center Point Angle 3-step Bin 5-step Bin CIEx CIEy θ (°) a b 2400K 0.4810 0.4140 53.7 0.0081 0.0042 2700K 0.4578 0.4101 53.7 0.0081 0.0042 3000K 0.4338 0.403 53.2 0.00834 0.00408 3200K 0.4232 0.3991 53.2 0.0108 0.0056 3500K 0.4073 0.3917 54 0.00927 0.00414 4000K 0.3818 0.3797 53.7 0.00939 0.00402 5000K 0.3447 0.3553 59.6 0.00822 6500K 0.3123 0.3282 58.57 0.00669 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved a b 0.00354 0.0137 0.0059 0.00285 0.01115 0.00475 CXM-14 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CXM-14 products are packaged and labeled with part numbers as outlined in the table on page 5. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 14 NN XX 36 QQPP FG W Product Family Light Emitting Surface Diameter Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CXM: Chip on Board, High Density, Multidie 14.3: LES Diameter (mm) Color See Note 1 below CRI Volts AC30 See Note 2 below Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Note 2: AC is standard package configurator AA is an alternative Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI R9 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2400K, 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 95 >95 2700K, 3000K, 3200K 3500K, 4000K, 5000K Note: >85 >80 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-14 Product Datasheet CXM-14 Part Numbers (AC30) The following tables describe products with typical flux and minimum flux measured at 720mA and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature Output Flux (lm) CCT 2700K 3000K 3500K 4000K CRI (min.) 3-step MacAdam Ellipse Typ. 2,700 2,510 2,915 90 CXM-14-24-90-36-AC30-F4-3 3,410 3,110 3,610 80 CXM-14-27-80-36-AC30-F4-3 2,810 2,560 2,975 90 CXM-14-27-90-36-AC30-F4-3 2,685 2,450 2,845 95 CXM-14-27-95-36-AC30-F4-3 3,600 3,285 3,810 80 CXM-14-30-80-36-AC30-F4-3 3,030 2,760 3,210 90 CXM-14-30-90-36-AC30-F4-3 2,830 2,580 2,995 95 CXM-14-30-95-36-AC30-F4-3 3,710 3,380 3,925 80 CXM-14-35-80-36-AC30-F4-3 3,090 2,815 3,270 90 CXM-14-35-90-36-AC30-F4-3 2,955 2,695 3,130 95 CXM-14-35-95-36-AC30-F4-3 4,030 3,675 4,265 70 CXM-14-40-70-36-AC30-F4-3 3,755 3,425 3,975 80 CXM-14-40-80-36-AC30-F4-3 3,260 2,970 3,450 90 CXM-14-40-90-36-AC30-F4-3 3,020 2,750 3,190 95 CXM-14-40-95-36-AC30-F4-3 Reference Color Rendering Index Part Number CCT (25ºC) Typ. Min. (85ºC) (calculated) 4,095 3,735 3,785 Typ. (85ºC) 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min. (85ºC) Typ. (85ºC) 2400K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 4,335 70 CXM-14-50-70-36-AC30-F4-5 CXM-14-50-70-36-AC30-F4-3 3,450 4,005 80 CXM-14-50-80-36-AC30-F4-5 CXM-14-50-80-36-AC30-F4-3 3,275 2,985 3,470 90 CXM-14-50-90-36-AC30-F4-5 CXM-14-50-90-36-AC30-F4-3 4,100 3,740 4,340 70 CXM-14-65-70-36-AC30-F4-5 CXM-14-65-70-36-AC30-F4-3 3,770 3,435 3,990 80 CXM-14-65-80-36-AC30-F4-5 CXM-14-65-80-36-AC30-F4-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance for flux measurements. Luminus maintains a +/- 2% tolerance for CRI measurements. 5 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-14 Product Datasheet CXM-14 Part Numbers (AA30) The following tables describe products with typical flux and minimum flux measured at 720mA and specified at 85ºC. The values at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature Output Flux (lm) CCT 3000K 3200K 3500K 4000K CRI (min.) 3-step MacAdam Ellipse Typ. 3,410 3,110 3,610 80 CXM-14-27-80-36-AA30-F4-3 2,810 2,560 2,975 90 CXM-14-27-90-36-AA30-F4-3 2,685 2,450 2,845 95 CXM-14-27-95-36-AA30-F4-3 3,600 3,285 3,810 80 CXM-14-30-80-36-AA30-F4-3 3,030 2,760 3,210 90 CXM-14-30-90-36-AA30-F4-3 2,830 2,580 2,995 95 CXM-14-30-95-36-AA30-F4-3 2,850 2,650 3,135 95 CXM-14-32-95-36-AA30-F4-3 3,710 3,380 3,925 80 CXM-14-35-80-36-AA30-F4-3 3,090 2,815 3,270 90 CXM-14-35-90-36-AA30-F4-3 2,955 2,695 3,130 95 CXM-14-35-95-36-AA30-F4-3 4,030 3,675 4,265 70 CXM-14-40-70-36-AA30-F4-3 3,755 3,425 3,975 80 CXM-14-40-80-36-AA30-F4-3 3,260 2,970 3,450 90 CXM-14-40-90-36-AA30-F4-3 3,020 2,750 3,190 95 CXM-14-40-95-36-AA30-F4-3 Reference Color Rendering Index Part Number CCT (25ºC) Typ. Min. (85ºC) (calculated) 4,095 3,735 3,785 Typ. (85ºC) 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 4,335 70 CXM-14-50-70-36-AA30-F4-5 CXM-14-50-70-36-AA30-F4-3 3,450 4,005 80 CXM-14-50-80-36-AA30-F4-5 CXM-14-50-80-36-AA30-F4-3 3,275 2,985 3,470 90 CXM-14-50-90-36-AA30-F4-5 CXM-14-50-90-36-AA30-F4-3 3,020 2,750 3,195 95 CXM-14-50-95-36-AA30-F4-5 CXM-14-50-95-36-AA30-F4-3 4,100 3,740 4,340 70 CXM-14-65-70-36-AA30-F4-5 CXM-14-65-70-36-AA30-F4-3 3,770 3,435 3,990 80 CXM-14-65-80-36-AA30-F4-5 CXM-14-65-80-36-AA30-F4-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance for flux measurements. Luminus maintains a +/- 2% tolerance for CRI measurements. 6 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-14 Product Datasheet CXM-14 Operating Characteristics1 Optical and Electrical Characteristics Parameter Forward Current Symbol 2 If Forward Voltage3 Vf Minimum 31 Power Operating Case Temperature4 Typical Maximum Unit 720 1,440 mA 34 37 V 24.5 54 W 105 ºC Tc Light Emitting Surface Diameter LES 14.3 mm Thermal Resistance (junction-to-case) Qjc 0.27 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: Device operation not recommended at drive currents less than 10% of the typical value Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 6: All product operating specifications are subject to change without advance notice. 7 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-14 Product Datasheet CXM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 1440 200% 180% 1240 140% 1040 Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 840 640 440 40% 240 20% 0% 240 440 640 840 1040 Forward Current (mA) 1240 40 1440 Relative Output Flux vs. Junction Temperature 32 33 34 35 Forward Voltage (V) 38 Forward Voltage (V) 60% 36 34 32 5 15 25 35 45 55 65 75 85 95 105 30 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) Change in CIEx vs. Junction Temp. (3000K, 80CRI) Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 37 38 80% 0 0 -0.01 -0.01 -0.02 36 40 100% Relative Luminous Flux 31 Change in Voltage vs. Junction Temperature 120% 40% 30 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 8 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CXM-14 Product Datasheet CXM-14 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 9 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CXM-14 Product Datasheet Mechanical Dimensions (AC30) Mechanical Dimensions (AA30) 10 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-14 Product Datasheet Shipping Container 225 pcs per box Each bag is boxed for easier storage/ stacking 45 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: (Manufacturer Part Number & Bin Kits) XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 11 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved Rev XX Bar code Bar code (Box ID) (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc XXXXXX-XX-XX CXM-14 Product Datasheet (Part #) Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guidelines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 12 PDS-002820 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
物料型号:Luminus CXM-14 COB Arrays
器件简介:Luminus的CXM-14 COB LED系列提供高性能照明应用的完整照明解决方案。该系列产品覆盖了从不到400lm到超过20,000lm的广泛流明范围,所有主要色温和超过97的显色指数。
引脚分配:文档中没有提供具体的引脚分配图,但提到了COB LED设计有接触垫在其顶面上,并标有正负极性。
参数特性: - 高流明输出和效率典型值 - 完整的色温范围:2700K, 3000K, 3500K, 4000K, 5000K 和 6500K - 显色指数(CRI)最小80,暖白色可达到95 - 3 SDCM色度分选精度 - 出色的光学发射均匀性和色彩角度一致性 - 卓越的长期色彩稳定性 - 优越的热传导性,均匀散热 - 环保:符合RoHS和REACH标准
功能详解: - 可靠性:经过一系列环境和机械应力测试 - UL认证合规性:根据ANSI/UL 8750测试,确保安全运行 - 色度分选:确保每批订单的颜色一致性
应用信息: - 聚光灯/轨道灯 - 建筑和特殊照明 - 筒灯 - 街道照明 - 商店照明 - 停车场和区域照明 - 酒店照明 - 隧道照明
封装信息: - 机械尺寸图提供了不同配置的产品尺寸 - 包装信息:每盘45个产品,5盘一箱,每箱225个产品
处理注意事项: - 避免静电放电(ESD)损害 - 适当的化学兼容性 - 适当的热界面材料(TIM)对LED系统至关重要
CXM-14-50-70-36-AC30-F4-5 价格&库存
很抱歉,暂时无法提供与“CXM-14-50-70-36-AC30-F4-5”相匹配的价格&库存,您可以联系我们找货
