Cree® XLamp® CXA1820 LED
PRODUCT DESCRIPTION
FEATURES
The XLamp® CXA1820 LED array expands
• Available in 4-step, 3‑step and 2-step
Characteristics.............................................2
EasyWhite bins at 2700 K, 3000 K,
Operating Limits...........................................2
arrays, offering high performance in an
3500 K, 4000 K & 5000 K CCT and
Flux Characteristics, EasyWhite® Order
easy‑to‑use platform. With XLamp LED
4-step EasyWhite bins at 5700 K &
Codes and Bins............................................3
lighting‑class reliability, the CXA1820’s
6500 K CCT
Flux Characteristics, ANSI White Order
directional and non-directional lighting
applications and luminaire designs.
• Available in ANSI white bins at
Codes and Bins............................................6
4000 K, 5000 K, 5700 K & 6500 K
Relative Spectral Power Distribution..........7
CCT
Electrical Characteristics.............................7
Available in 2-step, 3‑step and 4-step
• Available in 70-, 80-, 90- and
Relative Luminous Flux................................8
color consistency, and featuring a
93‑minimum CRI options
Typical Spatial Distribution..........................9
12‑mm optical source, the CXA1820
• Forward voltage option: 36‑V class
Performance Groups - Brightness..............9
brings new levels of flux and efficacy to
• 85 °C binning and characterization
Performance Groups - Chromaticity........ 10
this form factor.
• Maximum drive current: 1050 mA
Cree EasyWhite® Bins Plotted on the
• 115° viewing angle, uniform
1931 CIE Color Space............................... 13
The CX Family LED Design Guide
chromaticity profile
Cree ANSI White Bins Plotted on the
provides basic information on the
• Top-side solder connections
requirements to use the CXA1820 LED
• Thermocouple attach point
Bin and Order Code Formats.................... 14
successfully in luminaire designs.
• NEMA SSL-3 2011 standard flux bins
Mechanical Dimensions........................... 14
• RoHS and REACh compliant
Thermal Design......................................... 15
• UL recognized component
Notes......................................................... 16
(E349212)
WWW.CREE.COM/XLAMP
TABLE OF CONTENTS
Cree’s family of high‑flux, multi‑die
uniform emitting surface enables both
CLD-DS78 REV 6B
PRODUCT FAMILY DATA SHEET
Packaging.................................................. 17
Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo,
XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
XLAMP ® CXA1820 LED
CHARACTERISTICS
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
115
V
8000
DC forward current
mA
1050*
Reverse current
mA
0.1
Forward voltage (@ 550 mA, 85 °C)
V
Forward voltage (@ 550 mA, 25 °C)
V
36.2
42
Refer to the Operating Limits section.
OPERATING LIMITS
The maximum current rating of the CXA1820 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 14 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 15 for more
information on LES temperature measurement.
CXA1820
1200
1000
If (mA)
800
CXA1820
600
400
200
50
75
100
125
150
Case Temperature (°C)
Copyright © 2013-2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree,
2
XLAMP ® CXA1820 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXA1820 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 13).
Nominal
CCT
CRI
Min
70
Minimum Luminous Flux
Typ
75
2-Step
3-Step
4-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
Q4
2260
2560
R2
2420
2741
R4
2600
2916
CXA1820-0000000N00R465F
Q2
2100
2379
CXA1820-0000000N0HQ265F
Q4
2260
2560
R2
2420
2741
CXA1820-0000000N0HR265F
Q4
2260
2560
CXA1820-0000000N00Q457F
R2
2420
2741
R4
2600
2916
CXA1820-0000000N00R457F
Q2
2100
2379
CXA1820-0000000N0HQ257F
Q4
2260
2560
R2
2420
2741
Q4
2260
2560
R2
2420
2741
R4
2600
2916
CXA1820-0000000N00R450H
Q2
2100
2379
CXA1820-0000000N0HQ250H
Q4
2260
2560
R2
2420
2741
CXA1820-0000000N0HR250H
P2
1830
2073
CXA1820-0000000N0UP250H
P4
1965
2226
Q2
2100
2379
Group
Order Code
Group
Order Code
Group
CXA1820-0000000N00Q465F
65F
6500 K
80
70
75
65F
57F
5700 K
80
70
5000 K
80
90
75
95
Order Code
57F
CXA1820-0000000N00R265F
CXA1820-0000000N0HQ465F
CXA1820-0000000N00R257F
CXA1820-0000000N0HQ457F
CXA1820-0000000N0HR257F
CXA1820-0000000N00Q450H
50H
50H
50H
CXA1820-0000000N00Q450F
CXA1820-0000000N00R250H
CXA1820-0000000N0HQ450H
CXA1820-0000000N0UP450H
CXA1820-0000000N0UQ250H
50F
CXA1820-0000000N00R250F
CXA1820-0000000N00R450F
CXA1820-0000000N0HQ250G
50G
CXA1820-0000000N0HQ450G
CXA1820-0000000N0HQ250F
50F
CXA1820-0000000N0HR250G
CXA1820-0000000N0HQ450F
CXA1820-0000000N0HR250F
CXA1820-0000000N0UP250F
50G
CXA1820-0000000N0UP450G
CXA1820-0000000N0UQ250G
50F
CXA1820-0000000N0UP450F
CXA1820-0000000N0UQ250F
Notes
Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI
measurements. See the Measurements section (page 16).
Cree XLamp CXA1820 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
Flux values @ 25 °C are calculated and for reference only.
3
XLAMP ® CXA1820 LED
FLUX CHARACTERISTICS, EASYWHITE® ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C) - CONTINUED
Nominal
CCT
CRI
Min
70
4000 K
80
90
80
Typ
75
95
2-Step
80
95
Group
Q4
2260
2560
R2
2420
2741
R4
2600
2916
CXA1820-0000000N00R440H
Q2
2100
2379
CXA1820-0000000N0HQ240H
Q4
2260
2560
R2
2420
2741
CXA1820-0000000N0HR240H
N4
1710
1937
CXA1820-0000000N0UN440H
P2
1830
2073
P4
1965
2226
CXA1820-0000000N0UP440H
Q2
2100
2379
CXA1820-0000000N00Q235H
Q4
2260
2560
R2
2420
2741
CXA1820-0000000N00R235H
N2
1590
1801
CXA1820-0000000N0YN235H
N4
1710
1937
P2
1830
2073
CXA1820-0000000N0YP235H
CXA1820-0000000N0YP235G
CXA1820-0000000N0YP235F
P4
1965
2226
CXA1820-0000000N00P430H
CXA1820-0000000N00P430G
CXA1820-0000000N00P430F
Q2
2100
2379
Q4
2260
2535
CXA1820-0000000N00Q430H
M4
1485
1682
CXA1820-0000000N0YM430H
N2
1590
1801
N4
1710
1937
Group
95
Order Code
Group
Order Code
Group
CXA1820-0000000N00Q440H
40H
40H
40H
35H
35H
30H
3000 K
93
4-Step
Flux (lm)
@ 25 °C*
3500 K
93
3-Step
Flux (lm)
@ 85 °C
30H
CXA1820-0000000N00Q440F
CXA1820-0000000N00R240H
CXA1820-0000000N0HQ440H
CXA1820-0000000N0UP240H
CXA1820-0000000N00Q435H
CXA1820-0000000N0YN435H
CXA1820-0000000N00Q230H
CXA1820-0000000N0YN230H
CXA1820-0000000N0YN430H
Order Code
40F
CXA1820-0000000N00R240F
CXA1820-0000000N00R440F
CXA1820-0000000N0HQ240G
40G
CXA1820-0000000N0HQ440G
CXA1820-0000000N0HQ240F
40F
CXA1820-0000000N0HR240G
CXA1820-0000000N0HQ440F
CXA1820-0000000N0HR240F
CXA1820-0000000N0UN440F
40G
CXA1820-0000000N0UP240G
40F
CXA1820-0000000N0UP440G
CXA1820-0000000N0UP240F
CXA1820-0000000N0UP440F
CXA1820-0000000N00Q235F
35G
CXA1820-0000000N00Q435G
35F
CXA1820-0000000N00R235G
CXA1820-0000000N00Q435F
CXA1820-0000000N00R235F
CXA1820-0000000N0YN235F
35G
30G
CXA1820-0000000N0YN435G
CXA1820-0000000N00Q230G
35F
30F
CXA1820-0000000N00Q430G
CXA1820-0000000N0YN435F
CXA1820-0000000N00Q230F
CXA1820-0000000N00Q430F
CXA1820-0000000N0YM430F
30G
CXA1820-0000000N0YN230G
CXA1820-0000000N0YN430G
30F
CXA1820-0000000N0YN230F
CXA1820-0000000N0YN430F
Notes
4
XLAMP ® CXA1820 LED
Nominal
CCT
CRI
Min
80
Typ
2-Step
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
P4
1965
2226
Q2
2100
2379
Q4
2260
2535
CXA1820-0000000N00Q427H
M2
1380
1563
CXA1820-0000000N0YM227H
M4
1485
1682
N2
1590
1801
Group
95
Group
CXA1820-0000000N00P427H
27H
2700 K
93
Order Code
3-Step
27H
CXA1820-0000000N00Q227H
CXA1820-0000000N0YM427H
CXA1820-0000000N0YN227H
Order Code
4-Step
Group
CXA1820-0000000N00P427G
27G
CXA1820-0000000N00Q227G
Order Code
CXA1820-0000000N00P427F
27F
CXA1820-0000000N00Q427G
CXA1820-0000000N00Q227F
CXA1820-0000000N00Q427F
CXA1820-0000000N0YM227F
27G
CXA1820-0000000N0YM427G
CXA1820-0000000N0YN227G
27F
CXA1820-0000000N0YM427F
CXA1820-0000000N0YN227F
Notes
5
XLAMP ® CXA1820 LED
FLUX CHARACTERISTICS, ANSI WHITE ORDER CODES AND BINS (IF = 550 mA, TJ = 85 °C)
Nominal
CCT
CRI
Min
70
Typ
75
6500 K
80
70
75
5700 K
80
70
75
5000 K
80
4000 K
70
75
Chromaticity Regions
Order Code
Group
Flux (lm)
@ 85 °C
Flux (lm)
@ 25 °C*
Q4
2260
2560
R2
2420
2741
R4
2600
2916
CXA1820-0000-000N00R40E1
Q2
2100
2379
CXA1820-0000-000N0HQ20E1
Q4
2260
2560
R2
2420
2741
CXA1820-0000-000N0HR20E1
Q4
2260
2560
CXA1820-0000-000N00Q40E2
R2
2420
2741
R4
2600
2916
CXA1820-0000-000N00R40E2
Q2
2100
2379
CXA1820-0000-000N0HQ20E2
Q4
2260
2560
R2
2420
2741
CXA1820-0000-000N0HR20E2
Q4
2260
2560
CXA1820-0000-000N00Q40E3
R2
2420
2741
CXA1820-0000-000N00Q40E1
1A0, 1B0, 1C0, 1D0, 65F
2A0, 2B0, 2C0, 2D0, 57F
3A0, 3B0, 3C0, 3D0, 50F
CXA1820-0000-000N00R20E1
CXA1820-0000-000N0HQ40E1
CXA1820-0000-000N00R20E2
CXA1820-0000-000N0HQ40E2
CXA1820-0000-000N00R20E3
R4
2600
2916
CXA1820-0000-000N00R40E3
Q2
2100
2379
CXA1820-0000-000N0HQ20E3
Q4
2260
2560
R2
2420
2741
CXA1820-0000-000N0HR20E3
Q4
2260
2560
CXA1820-0000-000N00Q40E5
R2
2420
2741
R4
2600
2916
5A0, 5B0, 5C0, 5D0, 40F
CXA1820-0000-000N0HQ40E3
CXA1820-0000-000N00R20E5
CXA1820-0000-000N00R40E5
Notes
6
XLAMP ® CXA1820 LED
RELATIVE SPECTRAL POWER DISTRIBUTION
The following graph is the result of a series of pulsed measurements at 550 mA and TJ = 85 °C.
100%
90%
80%
70%
60%
5000 K, 70 CRI
50%
4000 K, 70 CRI
40%
3000 K, 80 CRI
30%
3000 K, 93 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
ELECTRICAL CHARACTERISTICS
The following graph is the result of a series of steady-state measurements.
41
40
Voltage (V)
39
Tc = 25 °C
38
Tc = 55 °C
Tc = 85 °C
37
Tc = 105 °C
36
35
34
350
450
550
650
750
850
950
1050
Current (mA)
7
XLAMP ® CXA1820 LED
RELATIVE LUMINOUS FLUX
The relative luminous flux values provided below are the ratio of:
• Measurements of CXA1820 at steady-state operation at the given conditions, divided by
• Flux measured during binning, which is a pulsed measurement at 550 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 55 °C, IF = 850 mA, the relative luminous flux ratio is 140% in the chart below. A CXA1820
LED that measures 2100 lm during binning will deliver 2940 lm (2100 * 1.4) at steady-state operation of Tc = 55 °C, IF = 850 mA.
180%
160%
140%
120%
Tc = 25 °C
100%
Tc = 55 °C
80%
Tc = 85 °C
Tc = 105 °C
60%
40%
20%
0%
350
450
550
650
750
850
950
1050
Current (mA)
8
XLAMP ® CXA1820 LED
Far Field
TYPICAL SPATIAL DISTRIBUTION
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
PERFORMANCE GROUPS - BRIGHTNESS (I F = 550 mA, TJ = 85 °C)
XLamp CXA1820 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
M2
1380
1485
M4
1485
1590
N2
1590
1710
N4
1710
1830
P2
1830
1965
P4
1965
2100
Q2
2100
2260
Q4
2260
2420
R2
2420
2600
R4
2600
2780
S2
2780
2990
9
XLAMP ® CXA1820 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C)
XLamp CXA1820 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
50H
40H
35H
30H
27H
CCT
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3429
0.3507
0.3434
0.3571
0.3475
0.3604
0.3469
0.3539
0.3784
0.3741
0.3804
0.3818
0.3867
0.3857
0.3844
0.3778
0.4030
0.3857
0.4061
0.3941
0.4132
0.3976
0.4099
0.3890
0.4291
0.3973
0.4333
0.4062
0.4395
0.4084
0.4351
0.3994
0.4528
0.4046
0.4578
0.4138
0.4638
0.4152
0.4586
0.4060
EasyWhite Color Temperatures – 3-Step Ellipse
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
40G
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
Bin Code
CCT
50G
Center Point
10
XLAMP ® CXA1820 LED
PERFORMANCE GROUPS - CHROMATICITY (TJ = 85 °C) - CONTINUED
EasyWhite Color Temperatures – 4-Step
Code
65F
57F
50F
40F
35F
30F
27F
CCT
6500 K
5700 K
5000 K
4000 K
3500 K
3000 K
2700 K
x
y
0.3097
0.3196
0.3079
0.3297
0.3164
0.3382
0.3176
0.3275
0.3253
0.3325
0.3249
0.3439
0.3331
0.3514
0.3330
0.3393
0.3407
0.3459
0.3415
0.3586
0.3499
0.3654
0.3484
0.3521
0.3744
0.3685
0.3782
0.3837
0.3912
0.3917
0.3863
0.3758
0.3981
0.3800
0.4040
0.3966
0.4186
0.4037
0.4116
0.3865
0.4242
0.3919
0.4322
0.4096
0.4449
0.4141
0.4359
0.3960
0.4475
0.3994
0.4573
0.4178
0.4695
0.4207
0.4589
0.4021
11
XLAMP ® CXA1820 LED
ANSI White Bins
Code
Bin
Code
CCT
1A0
1B0
0E1
6500 K
1C0
1D0
ANSI White Bins
x
y
0.3048
0.3130
0.3144
0.3186
0.3068
0.3028
CCT
y
0.3207
0.3215
0.3350
0.3290
0.3290
0.3417
0.3290
0.3300
0.3113
0.3222
0.3243
0.3304
0.3207
0.3462
0.3115
0.3391
0.3290
0.3538
0.3130
0.3290
0.3290
0.3417
0.3048
0.3207
0.3215
0.3350
0.3115
0.3391
0.3290
0.3538
0.3205
0.3481
0.3376
0.3616
0.3213
0.3373
0.3371
0.3490
0.3130
0.3290
0.3290
0.3417
0.3130
0.3290
0.3290
0.3417
0.3213
0.3373
0.3371
0.3490
0.3221
0.3261
0.3366
0.3369
0.3290
0.3300
2A0
2B0
0E2
5700 K
2C0
2D0
0.3186
ANSI White Bins
Code
CCT
Bin
Code
3A0
3B0
0E3
5000 K
3C0
3D0
Bin
Code
x
0.3144
Code
ANSI White Bins
x
y
.3371
.3451
.3440
.3427
.3366
.3369
.3376
.3463
.3451
.3554
.3371
.3490
.3463
.3687
.3551
.3760
.3533
.3620
.3451
.3554
.3451
.3533
.3515
.3487
.3440
.3427
Code
CCT
Bin
Code
x
y
.3490
.3670
.3578
.3554
.3702
.3722
.3825
.3798
.3783
.3646
.3616
.3702
.3722
.3687
.3736
.3874
.3869
.3958
.3825
.3798
.3825
.3798
.3869
.3958
.4006
.4044
.3950
.3875
.3554
.3783
.3646
.3620
.3825
.3798
.3950
.3875
.3898
.3716
5A0
5B0
0E5
4000 K
5C0
5D0
12
XLAMP ® CXA1820 LED
CREE EASYWHITE® BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.44
2700 K
ANSI C78.377 Quadrangle
0.43
3000 K
EasyWhite 4-Step
EasyWhite 3-Step
0.42
EasyWhite 2-Step
3500 K
0.41
4000 K
0.40
4500 K
CCy
0.39
5000 K
0.38
0.37
5700 K
0.36
6500 K
0.35
0.34
0.33
0.32
0.49
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
CREE ANSI WHITE BINS PLOTTED ON THE 1931 CIE COLOR SPACE (TJ = 85 °C)
0.41
4000 K
0.40
4500 K
5C
0.39
5D
0.37
CCy
5B
5000 K
0.38
5700 K
0.36
5A
3C
3B
6500 K
0.35
2B
0.34
1C
1B
0.33
3D
2C
1D
3A
2D
2A
1A
0.32
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.31
CCx
13
XLAMP ® CXA1820 LED
BIN AND ORDER CODE FORMATS
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXA18
Series = CXA18
Internal code
Chromaticity bin
CRI Specification
0 = Standard CRI
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
Vf class
N0 = 36-V class
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Y = 93 CRI minimum
SSSSSCC-HHHH-HHHGGRNNNNN
Kit code
Vf class
N0 = 36-V class
Flux bin
Performance class
Performance class
MECHANICAL DIMENSIONS
Dimensions are in mm.
Tolerances unless otherwise
specified: ±.13
x° ±1°
1820N = 36‑V CXA1820
1820N
Meaning of 1820N
14
XLAMP ® CXA1820 LED
THERMAL DESIGN
The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum
TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to
ensure that the CXA LED is being operated within its designed limits. LES temperature measurement provides additional verification of
good thermal design. Please refer to page 2 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient
(Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to
the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials
(TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CX Family LEDs soldering and handling
document. The CX Family LED Design Guide provides basic information on the requirements to use Cree XLamp CXA LEDs successfully
To keep the CXA1820 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
R_j-c
R_j-c
scale.
Tc
Tc
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_tim
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXA1820
Ta
Ta
100.00
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
350
450
550
650
750
850
950
1050
Current (mA)
15
XLAMP ® CXA1820 LED
NOTES
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp
LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance.
For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting.
Please read the Thermal Management application note for details for details on how thermal design, ambient temperature, and drive
current affect the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product
Ecology section of the Cree website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to
insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available
upon request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
16
XLAMP ® CXA1820 LED
PACKAGING
Cree CXA1820 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100
LEDs per carton. Each carton contains 100 LEDs from the same performance bin.
Dimensions are in inches.
REV
DATE
BY
CHK.
Tolerances:
±.13
DESC.
x° ± 1°
5
7.875
6
4
3
5
2
R.375
4
NOTICE
FIDENTIAL. THIS PLOT AND THE INFORMATION
D WITHIN ARE THE PROPRIETARY AND
TIAL
INFORMATION OF CREE, INC. THIS PLOT
NSENT
E COPIED, REPRODUCED OR DISCLOSED TO ANY
IZED PERSON WITHOUTTHE WRITTEN CONSENT
C.
1
3
2
1
.75
5.875
5.875
R .375
1.125
R.375
7.125
.875
.875
5.875
.38
1.125
.38
.75
PATENT LABEL IS LOCATED
WITH CREE
ON LABEL
UNDERSIDE
OF CARTON
BIN CODE, QTY, LOT#
SECTION C-C
.19
.38
.875
.38
PATENT
TH CREE BIN
.875LABEL
ANTITY, LOTIS# LOCATED ON UNDERSIDE OF
CARTON
UNLESS OTHERWISE NOTED ALL
TOLERANCES ARE AS FOLLOWS:
FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm
ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm
DRAFT ±1°
X.XXX" ±.005 X.XXmm ±.10mm
L IS LOCATED
IDE OF COVER
DATE:
DR. BY:
CHK. BY:
4-3-13
KJS
SCALE: 0.750
SIZE
B
DWG. NO.
022489-00
SHEET 2 OF 2
LABEL WITH CREE
BIN CODE, QTY, LOT#
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE
BIN CODE, QTY, LOT#
.X
.XX ±
.XXX ±
X°
THIRD ANGLE PROJECTION
WITH CREE
BIN
6
QUANTITY, LOT #
PART DRAWING
BAG
DO NOT
SCALE DWG.
BAG
THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION
AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS
REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED.
THIS DOCUMENT AND THE INFORMATION IT CONTAINS
DWG.TITLE
MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY
THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL
0.1
.05
.005
1°
FOR SHEET METAL PARTS ONLY
.X
.06
.XX ±
.03
.XXX ±
.010
DRAWN BY
X°
2
5
4
DIMENSIONS
ARE IN
3
notice.
Cree
, the
Cree logo,
TOLERANCE
UNLESS
SPECIFIED:
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
.X
.06
DRAWN BY
DATE
CHECK
DATE
APPROVED
DATE
4600 Silicon Dri
Durham, N.C 27
Phone (919) 361
Fax (919) 313-5
TITLE
CXA15XX_DATASHEET
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
SCALE
DATE
CHECK
DATE
APPROVED
DATE
C
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
0.500
2
SHEET
Phone (919) 361-4770
Fax (919) 313-5303
TITLE
CXA15XX_DATASHEET
17
MATERIAL
SIZE
OF
4600 Silicon Drive
1 27703
Durham, N.C
DRAWING NO.
