CHM-18-30-80-36-AA02-F2-3 数据手册
Sensus™ LED Series Product Datasheet
Preliminary
Sensus™ LED Series
Pure White Targeted COB Arrays
Below the Black Body Locus (BBL)
Preliminary Data Sheet
Features:
• Matching the human perception of “Pure white” light
Table of Contents
Technology Overview. . . . . . 2
Test Specifications . . . . . . . . . 2
• Designed to provide the look and feel of ceramic metal halide lights
• Wide product range from 300lm to over 7,500lm
• 3000K, 80 CRI standard
• 2-step and 3-step MacAdam Ellipse color binning accuracy
Chromaticity Bins. . . . . . . . . . 3
• Excellent optical uniformity and color over angle consistency
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
• Exceptional long term color stability
Product Typical Flux Range. 5
• Environmentally friendly: RoHS and REACh compliant
Operating Characteristics . . 7
• Superior thermal conductivity for uniform heat spreading
• UL Recognized, File # E465703
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . 12
Spectra. . . . . . . . . . . . . . . . . . . 19
Mechanical Dimensions. . . 20
Packaging Information. . . . 20
Handling Notes. . . . . . . . . . . 28
Applications
• Retail Shop Lighting
• Halogen replacement LED lamps
• Spotlights/Track Lights
• Hospitality Lighting
• CMH replacement LED lamps
• Architectural and Specialty
1
PDS-002349 Rev 07
© 2015 Luminus Devices, Inc. - All Rights Reserved
Sensus LED™ Series Product Datasheet
Preliminary
Technology Overview
Luminus XNova™ Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The Sensus LED series has been specially design for retail shop ligthing where enhanced red coloring is a preferred lighting
standard. The selection covers a wide lumen range from less than 300lm to over 3,000lm, and is focused on the major market color and
CRI of 3000K and 80 CRI. These innovative breakthroughs allow illumination engineers and designers to develop lighting solutions with
maximum efficacy, brightness and overall quality.
Reliability
Designed from the ground up, the XNova™ COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications. Delivered with fully
qualified LM-80 test data and TM-21 lifetime results that certify
lumen maintenance at 35,000 hours or more, XNova™ COB LEDs
are ready for the toughest challenges.
UL Recognized Compliance
XNova COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACh & RoHS Compliance
All LED products manufactured by Luminus are REACh and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding XNova™ COB LED Test Specifications
Every XNova™ LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each XNova COB LED is marked with a 2D bar code that contains
a unique serial number. With this serial number, Luminus has
the ability to provide customers with actual test data
measurements for a specific LED. In addition, the 2D bar code is
linked to manufacturing date codes that enables traceability of
production processes and materials.
Chromaticity binning delivers color consistency for every order.
Standard products are delivered with a 3-step MacAdam ellipse.
This ensures color performance matching in the application. For
the most demanding application, Luminus is one of only a few
companies that can provide a 2-step ellipse bin. These tightly
controlled, small distribution bins provide customers
predictable, repeatable colors.
Testing Temperature
XNova™ COB products are measured at temperatures typical for
the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale data sheet
specifications to real world situations.
2
PDS-002349 Rev 07
Preliminary
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.4600
ANSI C78.377-2008
3-SDCM
2-SDCM
A and B Bin Separator
0.4400
3000K
CIEy
0.4200
Black Body Locus
A
0.4000
0.3800
B
0.3600
0.3400
0.3200
0.3800
0.4000
0.4200
0.4400
0.4600
0.4800
0.5000
CIEx
Sensus™ LED White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
3-step Bin
2-step Bin
Center Point
CCT
CIEx
CIEy
θ (°)
a
b
θ (°)
a
b
3000K
0.4285
0.3933
53.6
0.00556
0.00272
53.1
0.00834
0.00408
The chromaticity range is sorted into two sections, “A” and “B” for delivered product. The position for the separator line dividing the bins
is described in the following table by a line connecting points at CIEx and CIEy coordinates that lie on the 2-step and 3-step ellipse.
2-step Bin
Separator
*Note:
3-step Bin
Position
CIEx
CIEy
CIEx
CIEy
Right Side
0.4274
0.3863
0.4285
0.3856
Left Side
0.4229
0.3892
0.4218
0.3899
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002349 Rev 07
Preliminary
Product Ordering and Shipping Part Number Nomenclature
All Sensus LED products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. Luminus will include any
smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a
single flux and chromaticity bin. The part number designation is as follows:
CXM
Sensus™ LED Series
XX
36
XX
30
Product Family
Light Emitting
Surface Diameter1
Color
Temperature
Color Rendering Index (CRI)3
CXM: Chip on
Board
XX: LES
Diameter (mm) Approximate
3000K
CRI
QQPP
FG
W
Voltage
(typical)
Package
Configurator
Flux Bin
Chromaticity
Bin
Volts
AA02
(Basic package)
Lumens
See page 4 for
bins
Note 1 : XX nomenclature corresponds to the following:
6 = 6.3mm
7 = 7.5mm
9 = 9mm
14 = 13.5mm
18 = 17.5mm
22 = 22mm
Note2:
AA02 is a standard package configurator
AC02 is an alternative substrate size
Note 3:
Shipped product will be delivered with the 2-step or 3-step chromaticity bin divided into section “A” an d section “B” as shown in the chromaticty
diagram. While these sub-bins are not availalbe for direct purchse, it is hoped this fine binning can add another design dimension to select
customer’s products. The packaged product will have the sub bin shown on the label at the end of the Customer Part Number from page 5 and 6.
Color Temperature, CRI and R9 Values
Color Temperatures
3000K
Note:
XX Value
CRI
R9
80
>80
>0
90
>90
>50
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002349 Rev 07
Preliminary
Sensus™ LED Series Part Numbers (Typical)
The following tables describe products with typical flux and minimum flux measured at typical currents and specified at 85ºC. The values
at 25ºC are calculated and shown for reference only. All products are measured and specified at 85ºC junction temperature. Luminus may
choose to ship a smaller chromatiticy bin in an order for a larger.
Output Flux (lm)
Ordering Part Number
Typ.
Typ. (85ºC)
Min. (85ºC) (calculated)
(25ºC)
Typ.
Current
(mA)
2-step MacAdam Ellipse
445
420
495
120
CXM-6-30-80-36-AA02-F2-3
CXM-6-30-80-36-AA02-F2-2
585
555
645
160
CHM-6-30-80-36-AA02-F2-3
CHM-6-30-80-36-AA02-F2-2
615
585
685
160
CXM-7-30-80-36-AA02-F2-3
CXM-7-30-80-36-AA02-F2-2
625
590
695
160
CLM-9-30-80-36-AC02-F2-3
CLM-9-30-80-36-AC02-F2-2
CLM-9-30-80-36-AA02-F2-3
930
885
1,025
CXM-9-30-80-36-AC02-F2-3
CXM-9-30-80-36-AC02-F2-2
CXM-9-30-80-36-AA02-F2-3
CXM-9-30-80-36-AA02-F2-2
CXM-9-30-90-36-AC02-F2-3
CXM-9-30-90-36-AC02-F2-2
CXM-9-30-90-36-AA02-F2-3
CXM-9-30-90-36-AA02-F2-2
CHM-9-30-80-36-AC02-F2-3
CHM-9-30-80-36-AC02-F2-2
CHM-9-30-80-36-AA02-F2-3
CHM-9-30-80-36-AA02-F2-2
CHM-9-30-90-36-AC02-F2-3
CHM-9-30-90-36-AC02-F2-2
CHM-9-30-90-36-AA02-F2-3
CHM-9-30-90-36-AA02-F2-2
CXM-14-30-80-36-AC02-F2-3
CXM-14-30-80-36-AC02-F2-2
CXM-14-30-80-36-AA02-F2-3
CXM-14-30-80-36-AA02-F2-2
CXM-14-30-90-36-AC02-F2-3
CXM-14-30-90-36-AC02-F2-2
CXM-14-30-90-36-AA02-F2-3
CXM-14-30-90-36-AA02-F2-2
CHM-14-30-80-36-AC02-F2-3
CHM-14-30-80-36-AC02-F2-2
CHM-14-30-80-36-AA02-F2-3
CHM-14-30-80-36-AA02-F2-2
CHM-14-30-90-36-AC02-F2-3
CHM-14-30-90-36-AC02-F2-2
CHM-14-30-90-36-AA02-F2-3
CHM-14-30-90-36-AA02-F2-2
240
780
750
870
1,310
1,245
1,455
360
1,110
1,050
1,230
1,930
1,830
2,135
480
1,635
1,550
1,810
2,660
2,525
2,925
720
2,255
2,140
2,475
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002349 Rev 07
Preliminary
at 25ºC are calculated and shown for reference only. All product is measured and specified at 85ºC junction temperature. Luminus may
Output Flux (lm)
Typ.
Typ. (85ºC)
(25ºC)
Typ.
Current
(mA)
3,210
3,050
3,560
800
CXM-18-30-80-36-AA02-F2-3
CXM-18-30-80-36-AA02-F2-2
4,435
4,210
4,875
1,200
CHM-18-30-80-36-AA02-F2-2
5,130
4,870
5,700
1,280
CXM-22-30-80-36-AC02-F2-3
CXM-22-30-80-36-AC02-F2-2
7,090
6,735
7,800
1,920
CHM-22-30-80-36-AC02-F2-3
CHM-22-30-80-36-AC02-F2-2
*Note:
6
PDS-002349 Rev 07
Preliminary
CXM-6 Operating Characteristics1
Parameter
Symbol
Minimum
Typical
Maximum
120
240
240
480
480
960
33.5
35
37.5
16.8
17.5
18.8
8.4
8.8
9.4
4.3
9
W
105
ºC
Forward Current (36V)
2
Forward Current (18V)2
If
Forward Current (9V)
2
Forward Voltage3
Vf
Power
Unit
mA
V
Operating Case Temperature
Tc
Light Emitting Surface Diameter
LES
6.3
mm
Thermal Resisitance (junction-to-case)
Qjc
2.33
ºC/W
Junction Temperature
Tj
4
140
Viewing Angle
120
ºC
Degree
CXM-7 Operating Characteristics1
Parameter
Symbol
Minimum
Typical
Maximum
160
320
320
640
640
1280
33.5
35
37.5
16.8
17.5
18.8
8.4
8.8
9.4
5.6
13
W
105
ºC
2
If
Forward Current (9V)2
Forward Voltage3
Vf
Power
Unit
mA
V
Tc
LES
7.5
mm
Qjc
1.9
ºC/W
Tj
4
Viewing Angle
120
7
PDS-002349 Rev 07
140
ºC
Degree
Preliminary
CHM-6 Operating Characteristics1
Parameter
Symbol
Minimum
Typical
Maximum
160
320
640
1280
33.5
35
37.5
8.4
8.8
9.4
5.6
13
W
105
ºC
2
If
Forward Voltage3
Vf
Power
Unit
mA
V
Operating Case Temperature4
Tc
LES
6.3
mm
Qjc
1.55
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CLM-9 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Power
Minimum
33.5
Typical
Maximum
Unit
160
350
mA
35
37.5
V
5.6
12
W
105
ºC
Tc
LES
9.0
mm
Qjc
1.55
ºC/W
Tj
Viewing Angle
120
8
PDS-002349 Rev 07
140
ºC
Degree
Preliminary
CXM-9 Operating Characteristics1
Parameter
Symbol
Forward Current2
If
Forward Voltage3
Vf
Minimum
Typical
Maximum
Unit
240
530
mA
35
37.5
V
8.6
21
W
100
ºC
33.5
Power
Tc
LES
9
mm
Qjc
1.51
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CHM-9 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
Typical
Maximum
Unit
360
720
mA
35
37.5
V
12.6
26
W
105
ºC
33.5
Power
Tc
LES
9
mm
Qjc
0.85
ºC/W
Tj
4
140
Viewing Angle
120
ºC
Degree
CXM-14 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Power
Minimum
33.5
Typical
Maximum
Unit
480
1,000
mA
35
37.5
V
17.3
40
W
105
ºC
Tc
LES
13.5
mm
Qjc
0.87
ºC/W
Tj
Viewing Angle
120
9
PDS-002349 Rev 07
140
ºC
Degree
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
CHM-14 Operating Characteristics1
Parameter
Symbol
Forward Current2
If
Forward Voltage3
Vf
Minimum
Maximum
Unit
720
1,440
mA
35
37.5
V
25.2
50.4
W
105
ºC
33.5
Power
Typical
Tc
LES
13.5
mm
Qjc
0.46
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CXM-18 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
Typical
Maximum
Unit
800
1,600
mA
35
37.5
V
29
65
W
105
ºC
33.5
Power
Tc
4
LES
17.5
mm
Qjc
0.56
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CHM-18 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Power
Minimum
33.5
Typical
Maximum
Unit
1,200
2,400
mA
35
37.5
V
42
96
W
105
ºC
Tc
LES
17.5
mm
Qjc
0.30
ºC/W
Tj
Viewing Angle
120
10
PDS-002349 Rev 07
140
ºC
Degree
Preliminary
CXM-22 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
33.5
Power
Typical
Maximum
Unit
1,280
2,560
mA
35
37.5
V
45
90
W
105
ºC
Tc
LES
22
mm
Qjc
0.37
ºC/W
Tj
140
Viewing Angle
120
ºC
Degree
CHM-22 Operating Characteristics1
Parameter
Symbol
2
Forward Current
If
Forward Voltage3
Vf
Minimum
33.5
Power
Typical
Maximum
Unit
1,920
3,840
mA
35
37.5
V
67
90
W
105
ºC
Tc
LES
22
mm
Qjc
0.2
ºC/W
Tj
Viewing Angle
140
120
ºC
Degree
Operating Characteristics Notes
Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC.
Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions
Note 3: Forward voltage range is specified at a typical current drive condition and Tj = 85ºC .
Note 4: CXM COB LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Refer to the current vs. case
temperature derating curves for further information.
Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
11
PDS-002349 Rev 07
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
CXM-6 Optical & Electrical Characteristics
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
200%
300
180%
Forward Current (mA)
Relative Luminous Flux
160%
140%
120%
100%
80%
60%
200
100
40%
20%
0%
50
75
100
125
150
175
200
225
32
250
32.5
33
33.5
34
Relative Output Flux vs. Junction Temperature
35
35.5
36
36.5
37
Change in Voltage vs. Junction Temperature
40
120.0%
100.0%
38
Forward Voltage (V)
34.5
Forward Voltage (V)
80.0%
60.0%
40.0%
36
34
32
20.0%
0.0%
5
15
25
35
45
55
65
75
85
95
30
105
5
15
25
35
Junction Temperature (ºC)
45
55
65
75
85
95
105
CHM-6 , CXM-7, CLM-9 Optical & Electrical Characteristics
350
200.0%
180.0%
300
160.0%
140.0%
120.0%
100.0%
80.0%
60.0%
40.0%
250
200
150
100
20.0%
50
0.0%
50
100
150
200
250
12
PDS-002349 Rev 07
300
32
33
34
35
36
37
Forward Voltage (V)
38
39
40
Preliminary
CHM-6, CXM-7, CLM-9 Optical & Electrical Characteristics
40
1.2
38
Forward Voltage (V)
1
0.8
0.6
0.4
36
34
32
0.2
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
55
65
75
85
95
105
CXM-9 Optical & Electrical Characteristics
250.0%
500
450
200.0%
150.0%
100.0%
400
350
300
250
200
50.0%
150
0.0%
100
100
150
200
250
300
350
400
450
32
500
33
34
35
37
38
39
40
40
1.2
1
38
Forward Voltage (V)
36
Forward Voltage (V)
0.8
0.6
0.4
36
34
32
0.2
30
15
25
35
45
55
65
75
13
PDS-002349 Rev 07
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Preliminary
CHM-9 Optical & Electrical Characteristics
200.0%
700
180.0%
600
140.0%
160.0%
120.0%
100.0%
80.0%
60.0%
40.0%
500
400
300
200
20.0%
100
0.0%
100
200
300
400
500
600
32
700
33
34
35
37
38
39
40
120.0%
40
100.0%
38
Forward Voltage (V)
36
Forward Voltage (V)
80.0%
60.0%
40.0%
36
34
32
20.0%
0.0%
30
5
15
25
35
45
55
65
75
85
95
105
5
15
25
35
45
55
65
75
85
95
105
CXM-14 Optical & Electrical Characteristics
200%
960
180%
860
160%
760
140%
660
120%
100%
80%
60%
40%
560
460
360
260
160
20%
60
0%
250
350
450
550
650
750
14
PDS-002349 Rev 07
850
950
-40 33
34
35
36
Forward Voltage (V)
37
38
39
Preliminary
40
120%
38
Forward Voltage (V)
100%
80%
60%
40%
36
34
32
20%
30
0%
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
55
65
75
85
95
105
CHM-14 Optical & Electrical Characteristics
1600
200%
180%
1400
1200
140%
160%
120%
100%
80%
60%
1000
800
600
400
40%
200
20%
0%
250
450
650
850
1050
34
1250
35
36
38
39
40
40
120%
100%
38
80%
Forward Voltage (V)
37
Forward Voltage (V)
60%
40%
36
34
32
20%
0%
30
5
15
25
35
45
55
65
75
15
PDS-002349 Rev 07
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
CXM-18 Optical & Electrical Characteristics
250%
1700
1500
200%
150%
100%
50%
1300
1100
900
700
0%
600
700
800
900
1000
1100
1200
1300
1400
1500
500
1600
33
34
35
37
38
39
40
120%
100%
38
Forward Voltage (V)
36
Forward Voltage (V)
80%
60%
40%
36
34
32
20%
30
0%
5
15
25
35
45
55
65
75
85
95
5
105
15
25
35
45
55
65
75
85
95
105
CHM-18 Optical & Electrical Characteristics
180.0%
2800
160.0%
140.0%
120.0%
100.0%
80.0%
60.0%
40.0%
2300
1800
1300
800
20.0%
300
0.0%
400
600
800
1000
1200
1400
1600
1800
16
PDS-002349 Rev 07
2000
2200
33
34
35
36
Forward Voltage (V)
37
38
39
(Part
#) Product
Sensus™ LED
Series
Product Datasheet
Preliminary
120.0%
40
38
Forward Voltage (V)
100.0%
80.0%
60.0%
40.0%
36
34
32
20.0%
0.0%
30
5
15
25
35
45
55
65
75
85
95
105
5
15
25
35
45
55
65
75
85
95
105
CXM-22 Optical & Electrical Characteristics
200.0%
2800
180.0%
140.0%
160.0%
120.0%
100.0%
80.0%
60.0%
40.0%
2300
1800
1300
800
20.0%
0.0%
300
400
900
1400
1900
2400
33
34
35
37
38
39
120.0%
40
100.0%
38
Forward Voltage (V)
36
Forward Voltage (V)
80.0%
60.0%
40.0%
36
34
32
20.0%
0.0%
30
5
15
25
35
45
55
65
75
17
PDS-002349 Rev 07
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
CHM-22 Optical & Electrical Characteristics
4000
200.0%
180.0%
3500
140.0%
160.0%
120.0%
100.0%
80.0%
60.0%
3000
2500
2000
1500
40.0%
1000
20.0%
0.0%
500
500
1000
1500
2000
2500
3000
3500
4000
32
33
34
35
37
38
39
40
120.0%
40
100.0%
38
Forward Voltage (V)
36
Forward Voltage (V)
80.0%
60.0%
40.0%
36
34
32
20.0%
0.0%
30
5
15
25
35
45
55
65
75
18
PDS-002349 Rev 07
85
95
105
5
15
25
35
45
55
65
75
85
95
105
Preliminary
Typical Spectrum
120.00%
Relative Intensity
100.00%
80.00%
60.00%
40.00%
20.00%
0.00%
400
450
500
550
600
650
700
750
800
Wavelength (nm)
Change CIEx vs. Junction Temperature (3000K, 80CRI)
Change CIEy vs. Junction Temperature (3000K, 80CRI)
0.02
40
38
Forward Voltage (V)
Δ CIEx
0.01
36
34
32
30
-0.02
5
15
25
35
45
55
65
75
85
95
105
5
15
25
35
45
55
65
75
85
95
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
19
PDS-002349 Rev 07
40
60
80
105
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
Mechanical Dimensions, CXM-6
Shipping Container, CXM-6
Each bag is boxed for
easier storage/stacking
Trays are sealed in an
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
PDS-002349 Rev 07
5 trays are stacked together
with one tray as a cover
Preliminary
Mechanical Dimensions, CXM-7
Shipping Container, CXM-7
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
21
PDS-002349 Rev 07
Preliminary
Mechanical Dimensions, CXM-9 (AA00)
Shipping Container, CXM-9 (AA00)
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
22
PDS-002349 Rev 07
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
Mechanical Dimensions, CLM/CXM/CHM-9 (AC00)
Shipping Container, CLM/CXM/CHM-9 (AC00)
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
23
PDS-002349 Rev 07
Preliminary
Mechanical Dimensions, CXM/CHM-14 (AA00)
Mechanical Dimensions CXM/CHM-14(AC00)
24
PDS-002349 Rev 07
Preliminary
Shipping Container, CXM/CHM-14 (AA00 and AC00)
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
25
PDS-002349 Rev 07
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
Mechanical Dimensions, CXM/CHM-18
Shipping Container, CXM/CHM-18
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
26
PDS-002349 Rev 07
Preliminary
Mechanical Dimensions, CXM/CHM-22
Shipping Container, CXM/CHM-22
anti-static bag
Label
Customer
Part Number
Lot ID
Quantity
27
PDS-002349 Rev 07
Sensus™ LED
Product
Datasheet
(PartSeries
#) Product
Datasheet
Preliminary
Handling Notes for XNova COBs
XNova products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging XNova COBs please follow these guide lines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
XNova COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
XNova COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with XNova COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
XNova products. Use of these compounds can cause damage to
the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the XNova COB
products.
Storage: XNova products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling XNova COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
28
PDS-002349 Rev 07
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
