BXRC-30G4000-D-72
BXRC-30G4000-D-72
    BRIDGELUX(普瑞)
BXRC-30G4000-D-72 数据手册
Bridgelux Gen 7 Vero 18 Array ® ® Product Data Sheet DS92 1 Vero® Series Introduction Vero® Series is a revolutionary advancement in chip on board (COB) light source technology and innovation. Vero LED light sources simplify luminaire design and manufacturing processes Vero Chip on Board (COB) LED arrays are available in four LES configurations, engineered to enable new degrees of flexibility and reliability over a broad range of electrical currents. Vero arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero products include an onboard connector port that enables a solder-free electrical interconnect, and simple mounting features for plug-and-play installation. Bridgelux Décor Series™ is our state-of-the-art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and pleasing lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series™ Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and typical R9 value of 98, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen lamps. Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series ™ Entertainment products provide color points developed specifically for the healthcare and entertainment industries. The 5600K cool white color point combined with a CRI of 90 or 97 provides the bright white required by these industries. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features • Efficacy of 160 lm/W typical for 3000K 80 CRI • Lumen output performance ranges from 1,455 to 13,600 lumens • Broad range of CCT options from 1750K to 6500K • CRI options include minimum 65, 70, 80, 90, 95 and Class A Benefits • Broad application coverage for interior and exterior lighting • Flexibility for application driven lighting design requirements • High quality true color reproduction • Uniform consistent white light • Reliable operation at up to 2X nominal drive current • Flexibility in design optimization • Radial die pattern and improved lumen density • Enhanced ease of use and assembly • Thermally isolated solder pads • Solderless connectivity enables plug & play installation and field upgradability • Onboard connector port • Top side part number markings • Vf bin code backside marking • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 20 Eye Safety 21 Absolute Maximum Ratings 22 Performance Curves 23 Typical Radiation Pattern 27 Typical Color Spectrum 28 Mechanical Dimensions 29 Color Binning Information 30 Packaging and Labeling 31 Design Resources 33 Precautions 33 Disclaimers 33 About Bridgelux 34 1 Product Feature Map Vero 18 is the second largest form factor in the Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www.bridgelux.com for more information on the Vero Series family of products. Thermally isolated solder pads reduce manufacturing cycle time and complexity 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Optics location/mounting features Mounting holes Radial die configuration improves lumen density and beam control Zhaga Book 3 compatible mounting locations Top side part number marking improves inventory management and outgoing quality control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Molex Pico-EZmate™ connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 400 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Gen. 7 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI B = 65 CRI min. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Target Flux Indicator 400x = 4000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-17E4000-B-74 1750 80 900 2774 2497 34.8 31.3 89 BXRC-17E4000-C-74 1750 80 1170 3624 3261 34.8 40.7 89 BXRC-17E4000-D-74 1750 80 1050 2710 2439 29.0 30.5 89 BXRC-20B4001-C-73 2000 65 1170 6081 5473 34.8 40.7 149 BXRC-20B4001-D-73 2000 65 1050 4548 4093 29.0 30.5 149 BXRC-25E4000-B-74 2500 80 900 4484 4036 34.8 31.3 143 BXRC-25E4000-C-74 2500 80 1170 5829 5246 34.8 40.7 143 BXRC-25E4000-D-74 2500 80 1050 4360 3924 29.0 30.5 143 BXRC-27E4000-B-7x 2700 80 900 4807 4326 34.8 31.3 153 BXRC-27E4000-C-7x 2700 80 1170 6249 5624 34.8 40.7 153 BXRC-27E4000-D-7x 2700 80 1050 4673 4206 29.0 30.5 153 BXRC-27G40H0-B-7x 2700 90 900 4166 3749 34.8 31.3 133 BXRC-27G40H0-C-7x 2700 90 1170 5415 4874 34.8 40.7 133 BXRC-27G40H0-D-7x 2700 90 1050 4050 3645 29.0 30.5 133 BXRC-27G4000-B-7x 2700 90 900 4000 3600 34.8 31.3 128 BXRC-27G4000-C-7x 2700 90 1170 5200 4680 34.8 40.7 128 BXRC-27G4000-D-7x 2700 90 1050 3889 3500 29.0 30.5 128 BXRC-27H4000-B-7x 2700 97 900 3484 3136 34.8 31.3 111 BXRC-27H4000-C-7x 2700 97 1170 4529 4076 34.8 40.7 111 BXRC-27H4000-D-7x 2700 97 1050 3387 3049 29.0 30.5 111 BXRC-30C4001-B-74 3000 70 900 5512 4961 34.8 31.3 176 176 BXRC-30C4001-C-74 3000 70 1170 7166 6449 34.8 40.7 BXRC-30C4001-D-74 3000 70 1050 5359 4823 29.0 30.5 176 BXRC-30E4000-B-7x 3000 80 900 5000 4500 34.8 31.3 160 BXRC-30E4000-C-7x 3000 80 1170 6500 5850 34.8 40.7 160 BXRC-30E4000-D-7x 3000 80 1050 4861 4375 29.0 30.5 160 BXRC-30G40H0-B-7x 3000 90 900 4353 3918 34.8 31.3 139 BXRC-30G40H0-C-7x 3000 90 1170 5660 5094 34.8 40.7 139 BXRC-30G40H0-D-7x 3000 90 1050 4233 3809 29.0 30.5 139 BXRC-30G4000-B-7x 3000 90 900 4161 3745 34.8 31.3 133 BXRC-30G4000-C-7x 3000 90 1170 5410 4869 34.8 40.7 133 BXRC-30G4000-D-7x 3000 90 1050 4046 3641 29.0 30.5 133 BXRC-30G400C-B-73 3000 90 900 3871 3484 34.8 31.3 124 BXRC-30G400C-D-73 3000 90 1050 3764 3387 29.0 30.5 124 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary 3 depending on fixture design and performance. Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30H4000-B-7x 3000 97 900 3710 3339 34.8 31.3 118 BXRC-30H4000-C-7x 3000 97 1170 4823 4341 34.8 40.7 118 BXRC-30H4000-D-7x 3000 97 1050 3607 3246 29.0 30.5 118 BXRC-30A4001-B-738,9 3000 93 900 3758 3383 34.8 31.3 120 BXRC-30A4001-C-738,9 3000 93 1170 4886 4397 34.8 40.7 120 BXRC-30A4001-D-738,9 3000 93 1050 3654 3289 29.0 30.5 120 BXRC-35E4000-B-7x 3500 80 900 5162 4645 34.8 31.3 165 BXRC-35E4000-C-7x 3500 80 1170 6710 6039 34.8 40.7 165 BXRC-35E4000-D-7x 3500 80 1050 5018 4516 29.0 30.5 165 BXRC-35G4000-B-7x 3500 90 900 4291 3861 34.8 31.3 137 BXRC-35G4000-C-7x 3500 90 1170 5578 5020 34.8 40.7 137 BXRC-35G4000-D-7x 3500 90 1050 4171 3754 29.0 30.5 137 BXRC-35A4001-B-738,9 3500 93 900 4040 3636 34.8 31.3 129 BXRC-35A4001-C-738,9 3500 93 1170 5252 4727 34.8 40.7 129 BXRC-35A4001-D-73 3500 93 1050 3928 3535 29.0 30.5 129 BXRC-40C4001-B-74 4000 70 900 5645 5081 34.8 31.3 180 8,9 BXRC-40C4001-C-74 4000 70 1170 7339 6605 34.8 40.7 180 BXRC-40C4001-D-74 4000 70 1050 5489 4940 29.0 30.5 180 BXRC-40E4000-B-7x 4000 80 900 5194 4674 34.8 31.3 166 BXRC-40E4000-C-7x 4000 80 1170 6752 6077 34.8 40.7 166 BXRC-40E4000-D-7x 4000 80 1050 5050 4545 29.0 30.5 166 BXRC-40G4000-B-7x 4000 90 900 4452 4007 34.8 31.3 142 BXRC-40G4000-C-7x 4000 90 1170 5787 5209 34.8 40.7 142 BXRC-40G4000-D-7x 4000 90 1050 4328 3895 29.0 30.5 142 BXRC-40A4001-B-738,9 4000 97 900 3821 3439 34.8 31.3 122 BXRC-40A4001-C-738,9 4000 97 1170 4967 4471 34.8 40.7 122 BXRC-40A4001-D-738,9 4000 97 1050 3715 3343 29.0 30.5 122 BXRC-50C4001-B-7x 4000 93 900 4322 3890 34.8 31.3 138 BXRC-50C4001-C-7x 4000 93 1170 5619 5057 34.8 40.7 138 BXRC-50C4001-D-7x 4000 93 1050 4202 3782 29.0 30.5 138 BXRC-50E4001-B-7x 5000 80 900 5355 4820 34.8 31.3 171 BXRC-50E4001-C-7x 5000 80 1170 6962 6265 34.8 40.7 171 BXRC-50E4001-D-7x 5000 80 1050 5206 4686 29.0 30.5 171 BXRC-50G4001-B-7x 5000 90 900 4549 4094 34.8 31.3 145 BXRC-50G4001-C-7x 5000 90 1170 5913 5322 34.8 40.7 145 BXRC-50G4001-D-7x 5000 90 1050 4422 3980 29.0 30.5 145 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-56G4000-B-74 5600 90 900 4774 4297 34.8 31.3 152 BXRC-56G4000-C-74 5600 90 1170 6207 5586 34.8 40.7 152 BXRC-56G400x-D-74 5600 90 1050 4642 4178 29.0 30.5 152 BXRC-56H4000-D-74 5600 97 1050 4015 3613 29.0 30.5 132 BXRC-57C4001-B-7x 5700 70 900 5516 4965 34.8 31.3 176 176 BXRC-57C4001-C-7x 5700 70 1170 7171 6454 34.8 40.7 BXRC-57C4001-D-7x 5700 70 1050 5363 4827 29.0 30.5 176 BXRC-57E4001-B-7x 5700 80 900 5293 4764 34.8 31.3 169 BXRC-57E4001-C-7x 5700 80 1170 6881 6193 34.8 40.7 169 BXRC-57E4001-D-7x 5700 80 1050 5146 4631 29.0 30.5 169 BXRC-65C4001-B-7x 6500 70 900 5613 5052 34.8 31.3 179 BXRC-65C4001-C-7x 6500 70 1170 7297 6567 34.8 40.7 179 BXRC-65C4001-D-7x 6500 70 1050 5457 4912 29.0 30.5 179 BXRC-65E4001-B-7x 6500 80 900 5387 4848 34.8 31.3 172 BXRC-65E4001-C-7x 6500 80 1170 7003 6303 34.8 40.7 172 BXRC-65E4001-D-7x 6500 80 1050 5237 4714 29.0 30.5 172 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A4001-B-73 3000 80 93 900 3495 3146 34.3 30.9 112 BXRC-30A4001-C-73 3000 80 93 1170 4544 4090 34.3 40.2 112 BXRC-30A4001-D-73 3000 80 93 1050 3398 3058 28.5 29.9 112 BXRC-35A4001-B-73 3500 80 93 900 3757 3382 34.3 30.9 120 BXRC-35A4001-C-73 3500 80 93 1170 4885 4396 34.3 40.2 120 BXRC-35A4001-D-73 3500 80 93 1050 3653 3288 28.5 29.9 120 BXRC-40A4001-B-73 4000 80 93 900 4020 3618 34.3 30.9 129 BXRC-40A4001-C-73 4000 80 93 1170 5225 4703 34.3 40.2 129 BXRC-40A4001-D-73 4000 80 93 1050 3908 3517 28.5 29.9 129 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 82 BXRC-17E4000-B-74 1750 80 900 2497 2247 33.9 30.5 BXRC-17E4000-C-74 1750 80 1170 3261 2935 33.9 39.7 82 BXRC-17E4000-D-74 1750 80 1050 2439 2195 28.1 29.5 83 BXRC-20B4001-C-73 2000 65 1170 5473 4926 33.9 39.7 138 BXRC-20B4001-D-73 2000 65 1050 4093 3684 28.1 29.5 139 BXRC-25E4000-B-74 2500 80 900 4036 3632 33.9 30.5 132 BXRC-25E4000-C-74 2500 80 1170 5246 4722 33.9 39.7 132 BXRC-25E4000-D-74 2500 80 1050 3924 3531 28.1 29.5 133 BXRC-27E4000-B-7x 2700 80 900 4326 3893 33.9 30.5 142 BXRC-27E4000-C-7x 2700 80 1170 5624 5061 33.9 39.7 142 BXRC-27E4000-D-7x 2700 80 1050 4206 3785 28.1 29.5 143 BXRC-27G40H0-B-7x 2700 90 900 3749 3374 33.9 30.5 123 BXRC-27G40H0-C-7x 2700 90 1170 4874 4386 33.9 39.7 123 BXRC-27G40H0-D-7x 2700 90 1050 3645 3280 28.1 29.5 124 BXRC-27G4000-B-7x 2700 90 900 3600 3240 33.9 30.5 118 BXRC-27G4000-C-7x 2700 90 1170 4680 4212 33.9 39.7 118 BXRC-27G4000-D-7x 2700 90 1050 3500 3150 28.1 29.5 119 BXRC-27H4000-B-7x 2700 97 900 3136 2822 33.9 30.5 103 BXRC-27H4000-C-7x 2700 97 1170 4076 3669 33.9 39.7 103 BXRC-27H4000-D-7x 2700 97 1050 3049 2744 28.1 29.5 103 BXRC-30C4001-B-74 3000 70 900 4961 4465 33.9 30.5 163 BXRC-30C4001-C-74 3000 70 1170 6449 5804 33.9 39.7 163 BXRC-30C4001-D-74 3000 70 1050 4823 4341 28.1 29.5 163 BXRC-30E4000-B-7x 3000 80 900 4500 4050 33.9 30.5 147 BXRC-30E4000-C-7x 3000 80 1170 5850 5265 33.9 39.7 147 BXRC-30E4000-D-7x 3000 80 1050 4375 3938 28.1 29.5 148 BXRC-30G40H0-B-7x 3000 90 900 3918 3526 33.9 30.5 128 BXRC-30G40H0-C-7x 3000 90 1170 5094 4584 33.9 39.7 128 BXRC-30G40H0-D-7x 3000 90 1050 3809 3428 28.1 29.5 129 BXRC-30G4000-B-7x 3000 90 900 3745 3371 33.9 30.5 123 BXRC-30G4000-C-7x 3000 90 1170 4869 4382 33.9 39.7 123 BXRC-30G4000-D-7x 3000 90 1050 3641 3277 28.1 29.5 123 BXRC-30G400C-B-73 3000 90 900 3484 3136 33.9 30.5 114 BXRC-30G400C-D-73 3000 90 1050 3387 3049 28.1 29.5 115 BXRC-30H4000-B-7x 3000 97 900 3339 3005 33.9 30.5 109 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30H4000-C-7x 3000 97 1170 4341 3906 33.9 39.7 109 BXRC-30H4000-D-7x 3000 97 1050 3246 2922 28.1 29.5 110 BXRC-30A4001-B-738,9 3000 93 900 3383 3044 33.9 30.5 111 BXRC-30A4001-C-738,9 3000 93 1170 4397 3958 33.9 39.7 111 BXRC-30A4001-D-738,9 3000 93 1050 3289 2960 28.1 29.5 111 152 BXRC-35E4000-B-7x 3500 80 900 4645 4181 33.9 30.5 BXRC-35E4000-C-7x 3500 80 1170 6039 5435 33.9 39.7 152 BXRC-35E4000-D-7x 3500 80 1050 4516 4065 28.1 29.5 153 BXRC-35G4000-B-7x 3500 90 900 3861 3475 33.9 30.5 127 BXRC-35G4000-C-7x 3500 90 1170 5020 4518 33.9 39.7 127 BXRC-35G4000-D-7x 3500 90 1050 3754 3379 28.1 29.5 127 BXRC-35A4001-B-73 8,9 3500 93 900 3636 3273 33.9 30.5 119 BXRC-35A4001-C-738,9 3500 93 1170 4727 4254 33.9 39.7 119 BXRC-35A4001-D-738,9 3500 93 1050 3535 3182 28.1 29.5 120 BXRC-40C4001-B-74 4000 70 900 5081 4573 33.9 30.5 167 BXRC-40C4001-C-74 4000 70 1170 6605 5945 33.9 39.7 167 BXRC-40C4001-D-74 4000 70 1050 4940 4446 28.1 29.5 167 BXRC-40E4000-B-7x 4000 80 900 4674 4207 33.9 30.5 153 BXRC-40E4000-C-7x 4000 80 1170 6077 5469 33.9 39.7 153 BXRC-40E4000-D-7x 4000 80 1050 4545 4090 28.1 29.5 154 131 BXRC-40G4000-B-7x 4000 90 900 4007 3606 33.9 30.5 BXRC-40G4000-C-7x 4000 90 1170 5209 4688 33.9 39.7 131 BXRC-40G4000-D-7x 4000 90 1050 3895 3506 28.1 29.5 132 BXRC-40H4000-B-7x 4000 97 900 3439 3095 33.9 30.5 113 BXRC-40H4000-C-7x 4000 97 1170 4471 4024 33.9 39.7 113 BXRC-40H4000-D-7x 4000 97 1050 3343 3009 28.1 29.5 113 BXRC-40A4001-B-737,8 4000 93 900 3890 3501 33.9 30.5 127 BXRC-40A4001-C-737,8 4000 93 1170 5057 4551 33.9 39.7 127 BXRC-40A4001-D-737,8 4000 93 1050 3782 3404 28.1 29.5 128 BXRC-50C4001-B-74 5000 70 900 5139 4625 33.9 30.5 168 BXRC-50C4001-C-74 5000 70 1170 6681 6013 33.9 39.7 168 BXRC-50C4001-D-74 5000 70 1050 4996 4497 28.1 29.5 169 BXRC-50E4001-B-74 5000 80 900 4820 4338 33.9 30.5 158 BXRC-50E4001-C-74 5000 80 1170 6265 5639 33.9 39.7 158 BXRC-50E4001-D-74 5000 80 1050 4686 4217 28.1 29.5 159 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-50G4001-B-7x 5000 90 900 4094 3684 33.9 30.5 134 BXRC-50G4001-C-7x 5000 90 1170 5322 4790 33.9 39.7 134 BXRC-50G4001-D-7x 5000 90 1050 3980 3582 28.1 29.5 135 141 BXRC-56G4000-B-74 5600 90 900 4297 3867 33.9 30.5 BXRC-56G4000-C-74 5600 90 1170 5586 5027 33.9 39.7 141 BXRC-56G400x-D-74 5600 90 1050 4178 3760 28.1 29.5 142 BXRC-56H4000-D-74 5600 97 1050 3613 3252 28.1 29.5 122 BXRC-57C4001-B-7x 5700 70 900 4965 4468 33.9 30.5 163 BXRC-57C4001-C-7x 5700 70 1170 6454 5809 33.9 39.7 163 BXRC-57C4001-D-7x 5700 70 1050 4827 4344 28.1 29.5 164 BXRC-57E4001-B-7x 5700 80 900 4764 4287 33.9 30.5 156 BXRC-57E4001-C-7x 5700 80 1170 6193 5574 33.9 39.7 156 BXRC-57E4001-D-7x 5700 80 1050 4631 4168 28.1 29.5 157 BXRC-65C4001-B-7x 6500 70 900 5052 4547 33.9 30.5 166 BXRC-65C4001-C-7x 6500 70 1170 6567 5911 33.9 39.7 166 BXRC-65C4001-D-7x 6500 70 1050 4912 4420 28.1 29.5 166 BXRC-65E4001-B-7x 6500 80 900 4848 4364 33.9 30.5 159 BXRC-65E4001-C-7x 6500 80 1170 6303 5673 33.9 39.7 159 BXRC-65E4001-D-7x 6500 80 1050 4714 4242 28.1 29.5 160 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ±3 tolerance for all CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 9 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-17E4000-B-7x 80 BXRC-17E4000-C-7x 80 BXRC-17E4000-D-7x 80 BXRC-20B4001-C-73 65 BXRC-20B4001-D-73 65 BXRC-25E4000-B-74 80 BXRC-25E4000-C-74 80 BXRC-25E4000-D-74 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 1490 1954 2774 4126 5310 1946 2552 3624 5390 6935 1455 1909 2710 4031 5187 3265 4283 6081 9044 11638 2442 3203 4548 6764 8704 2408 3158 4484 6669 8582 3130 4106 5829 8670 11157 2341 3070 4360 6484 8344 1338 1753 2497 3636 4616 1748 2289 3261 4749 6029 1307 1712 2439 3551 4509 2934 3841 5473 7969 10117 2194 2873 4093 5960 7566 2163 2833 4036 5876 7460 2812 3682 i102 7639 9698 2103 2754 3924 5713 7253 100 96 89 86 82 100 96 89 86 82 100 97 89 84 78 168 161 149 145 138 168 162 149 141 131 161 155 143 139 132 161 155 143 139 132 161 155 143 135 126 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27E4000-B-7x 80 BXRC-27E4000-C-7x 80 BXRC-27E4000-D-7x 80 BXRC-27G40H0-B-7x 90 BXRC-27G40H0-C-7x 90 BXRC-27G40H0-D-7x 90 BXRC-27G4000-B-7x 90 BXRC-27G4000-C-7x 90 BXRC-27G4000-D-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 2581 3385 4807 7149 9200 3265 4278 6249 8989 11531 2489 3237 4673 6675 8497 2236 2934 4166 6195 7972 2829 3708 5415 7790 9993 2157 2805 4050 5785 7364 2148 2817 4000 5949 7656 2717 3561 5200 7481 9596 2072 2694 3889 5555 7072 2319 3036 4326 6299 7997 3090 3965 5624 7912 9938 2311 2967 4206 5902 7389 2010 2631 3749 5459 6930 2678 3436 4874 6857 8613 2002 2571 3645 5115 6404 1930 2527 3600 5242 6655 2571 3300 4680 6585 8271 1923 2469 3500 4912 6149 173 166 153 149 141 168 161 153 144 136 171 164 153 139 128 150 144 133 129 123 146 140 133 125 118 148 142 133 121 111 144 138 128 124 118 140 134 128 120 113 142 136 128 116 107 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27H4000-B-7x 97 BXRC-27H4000-C-7x 97 BXRC-27H4000-D-7x 97 BXRC-30C4001-B-74 70 BXRC-30C4001-C-74 70 BXRC-30C4001-D-74 70 BXRC-30E4000-B-7x 80 BXRC-30E4000-C-7x 80 BXRC-30E4000-D-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 1871 2454 3484 5182 6668 2366 3101 4529 6516 8358 1804 2346 3387 4838 6159 2960 3882 5512 8198 10550 3744 4906 7166 10309 13224 2855 3712 5359 7655 9745 2685 3522 5000 7437 9570 3396 4451 6500 9351 11995 2590 3367 4861 6944 8839 1723 2212 3136 4401 5509 2239 2875 4076 5721 7162 1675 2150 3049 4278 5356 2726 3499 4961 6962 8716 3543 4549 6449 9051 11331 2650 3402 4823 6769 8474 2412 3159 4500 6553 8319 3214 4124 5850 8231 10339 2404 3086 4375 6140 7687 125 120 111 108 102 122 117 111 104 99 124 119 111 101 93 198 190 176 170 162 193 185 176 165 156 196 188 176 160 147 180 173 160 155 147 175 168 160 150 142 178 170 160 145 133 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30G40H0-B-7x 90 BXRC-30G40H0-C-7x 90 BXRC-30G40H0-D-7x 90 BXRC-30G4000-B-7x 90 BXRC-30G4000-C-7x 90 BXRC-30G4000-D-7x 90 BXRC-30G400C-B-73 90 BXRC-30G400C-D-73 BXRC-30H4000-B-7x 90 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 2337 3066 4353 6475 8332 2957 3875 5660 8142 10444 2255 2932 4233 6046 7696 2234 2931 4161 6189 7965 2827 3704 5410 7783 9983 2155 2803 4046 5779 7357 2078 2726 3871 5758 7409 2005 2607 3764 5376 6843 1992 2613 3710 5518 7100 2100 2750 3918 5705 7243 2798 3591 5094 7166 9001 2093 2687 3809 5346 6693 2008 2629 3745 5453 6923 2675 3433 4869 6850 8604 2000 2568 3641 5110 6397 1868 2445 3484 5073 6440 1861 2389 3387 4754 5951 1834 2355 3339 4686 5866 156 150 139 135 128 152 146 139 130 123 155 148 139 126 116 149 144 133 129 122 145 140 133 124 118 148 142 133 121 111 139 134 124 120 114 138 132 124 112 103 133 128 118 115 109 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30H4000-C-7x 97 BXRC-30H4000-D-7x 97 BXRC-30A4001-B-73 93 BXRC-30A4001-C-73 93 BXRC-30A4001-D-73 93 BXRC-35E4000-B-7x 80 BXRC-35E4000-C-7x 80 BXRC-35E4000-D-7x 80 BXRC-35G4000-B-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.3 33.9 35.0 36.7 38.0 33.4 34.0 35.0 36.8 38.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 15.0 20.4 31.2 49.5 68.4 19.5 26.5 40.6 64.5 89.3 14.6 19.8 30.4 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 2520 3302 4823 6938 8900 1921 2498 3607 5152 6558 2018 2647 3758 5590 7193 2553 3345 4886 7029 9016 1947 2531 3654 5219 6644 2771 3635 5162 7677 9879 3506 4594 6710 9653 12382 2673 3476 5018 7168 9125 2304 3022 4291 6381 8212 2385 3062 4341 6091 7626 1783 2290 3246 4556 5703 1813 2374 3383 4925 6253 2416 3100 4397 6187 7771 1807 2320 3289 4615 5778 2490 3261 4645 6764 8587 3318 4257 6039 8496 10672 2481 3186 4516 6338 7935 2070 2710 3861 5623 7138 130 124 118 111 105 132 126 118 107 99 135 130 120 113 105 131 126 120 109 101 134 128 120 109 100 185 178 165 160 152 180 173 165 154 146 184 176 165 150 138 154 148 137 133 126 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35G4000-C-7x 90 BXRC-35G4000-D-7x 90 BXRC-35A4001-B-73 80 BXRC-35A4001-C-73 80 BXRC-35A4001-D-73 80 BXRC-40C4001-B-74 80 BXRC-40C4001-C-74 80 BXRC-40C4001-D-74 80 BXRC-40E4000-B-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 2914 3819 5578 8024 10293 2222 2889 4171 5958 7585 2169 2846 4040 6009 7733 2744 3596 5252 7556 9692 2092 2721 3928 5611 7142 2169 2846 4040 6009 7733 2744 3596 5252 7556 9692 2092 2721 3928 5611 7142 2789 3658 5194 7725 9940 2758 3539 5020 7062 8871 2063 2648 3754 5269 6596 1949 2552 3636 5295 6722 2597 3333 4727 6651 8354 1942 2494 3535 4961 6211 1949 2552 3636 5295 6722 2597 3333 4727 6651 8354 1942 2494 3535 4961 6211 2506 3281 4674 6806 8641 150 144 137 128 122 153 146 137 124 115 145 139 129 125 119 141 136 129 121 115 144 138 129 117 108 145 139 129 125 119 141 136 129 121 115 144 138 129 117 108 187 179 166 161 153 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E4000-C-7x 80 BXRC-40E4000-D-7x 80 BXRC-40G4000-B-7x 90 BXRC-40G4000-C-7x 90 BXRC-40G4000-D-7x 90 BXRC-40H4000-B-7x 97 BXRC-40H4000-C-7x 97 BXRC-40H4000-D-7x 97 BXRC-40A4001-B-73 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 3528 4623 6752 9713 12459 2690 3498 5050 7213 9182 2390 3135 4452 6621 8520 3024 3962 5787 8326 10680 2306 2998 4328 6182 7870 2052 2691 3821 5683 7313 2595 3401 4967 7146 9166 1979 2573 3715 5306 6755 2321 3044 4322 6428 8272 3339 4284 6077 8549 10739 2497 3205 4545 6378 7984 2148 2812 4007 5834 7407 2862 3672 5209 7328 9205 2140 2748 3895 5467 6844 1843 2414 3439 5007 6357 2456 3152 4471 6290 7900 1837 2358 3343 4692 5874 2085 2730 3890 5664 7191 182 174 166 155 147 185 177 166 150 139 160 154 142 138 131 156 149 142 133 126 158 152 142 129 119 137 132 122 118 112 134 128 122 114 108 136 130 122 111 102 155 149 138 134 127 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40A4001-C-73 80 BXRC-40A4001-D-73 80 BXRC-50C4001-B-74 70 BXRC-50C4001-C-74 70 BXRC-50C4001-D-74 70 BXRC-50E4001-B-74 80 BXRC-50E4001-C-7x 80 BXRC-50E4001-D-7x 80 BXRC-50G4001-B-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 2936 3847 5619 8083 10368 2238 2911 4202 6002 7641 3066 4022 5710 8492 10928 3878 5082 7423 10679 13698 2957 3845 5551 7929 10094 2875 3772 5355 7965 10249 3637 4766 6962 10015 12846 2773 3606 5206 7437 9467 2442 3204 4549 6765 8706 2778 3565 5057 7115 8937 2078 2667 3782 5307 6644 2755 3607 5139 7483 9500 3670 4710 6681 9399 11806 2745 3524 4996 7012 8778 2584 3383 4820 7018 8909 3442 4417 6265 8815 11072 2574 3305 4686 6576 8232 2194 2873 4094 5961 7568 151 145 138 129 123 154 147 138 125 115 205 197 182 177 168 200 192 182 171 162 203 195 182 165 152 192 185 171 166 158 187 180 171 160 152 190 183 171 155 143 163 157 145 141 134 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50G4001-C-7x 90 BXRC-50G4001-D-7x 90 BXRC-56G4000-B-74 90 BXRC-56G4000-C-74 90 BXRC-56G400x-D-74 90 BXRC-56H4000-D-74 97 BXRC-57C4001-B-7x 70 BXRC-57C4001-C-7x 70 BXRC-57C4001-D-7x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 3090 4049 5913 8507 10912 2356 3063 4422 6317 8041 2543 3307 4774 6820 8681 3306 4299 6207 8865 11286 2473 3215 4642 6630 8440 2139 2781 4015 5734 7300 2962 3885 5516 8205 10558 3747 4910 7171 10317 13233 2857 3715 5363 7661 9752 2924 3752 5322 7487 9405 2187 2807 3980 5586 6992 2361 3031 4297 6030 7549 3069 3940 5586 7839 9814 2295 2947 4178 5863 7340 1985 2548 3613 5071 6348 2661 3485 4965 7229 9178 3546 4550 6454 9080 11406 2652 3405 4827 6774 8480 159 153 145 136 129 162 155 145 132 121 170 162 152 142 133 170 162 152 142 133 170 163 152 138 127 147 141 132 120 110 198 190 176 171 162 193 185 176 165 156 196 188 176 160 147 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-57E4001-B-7x 80 BXRC-57E4001-C-7x 80 BXRC-57E4001-D-7x 80 BXRC-65C4001-B-7x 70 BXRC-65C4001-C-7x 70 BXRC-65C4001-D-7x 70 BXRC-65E4001-B-7x 80 BXRC-65E4001-C-7x 80 BXRC-65E4001-D-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 450 600 900 1350 1800 585 780 1170 1755 2340 525 700 1050 1575 2100 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 33.2 34.0 34.8 35.6 36.1 33.2 34.0 34.8 35.6 36.1 27.7 28.2 29.0 30.4 31.5 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 14.9 20.4 31.3 48.1 65.1 19.4 26.5 40.7 62.5 84.6 14.6 19.8 30.5 47.9 66.2 2842 3728 5293 7872 10130 3595 4711 6881 9899 12698 2741 3565 5146 7350 9357 3014 3953 5613 8348 10743 3813 4996 7297 10498 13466 2907 3780 5457 7795 9923 2892 3794 5387 8012 10310 3659 4795 7003 10075 12923 2790 3628 5237 7481 9523 2554 3344 4764 6936 8806 3402 4366 6193 8713 10944 2544 3267 4631 6500 8137 2708 3546 5052 7356 9339 3608 4630 6567 9240 11606 2698 3464 4912 6893 8629 2599 3403 4848 7059 8962 3463 4443 6303 8867 11138 2590 3325 4714 6615 8281 190 183 169 164 156 185 178 169 158 150 188 180 169 153 141 202 194 179 174 165 196 188 179 168 159 200 191 179 163 150 194 186 172 167 158 188 181 172 161 153 192 184 172 156 144 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 19 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx400x-B-7x BXRC-xxx400x-C-7x BXRC-xxx400x-D-7x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.15 31.0 38.4 -14.9 0.19 32.2 39.8 37.4 -14.9 0.11 31.0 38.4 36.1 38.8 -14.9 0.13 32.2 39.8 26.8 29.0 31.2 -12.2 0.16 25.8 32.0 29.2 31.5 33.9 -12.2 0.19 28.2 34.7 Minimum Typical Maximum 900 32.2 34.8 37.4 -14.9 1800 33.4 36.1 38.8 1170 32.2 34.8 2340 33.4 1050 2100 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 20 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx400x-B-7x BXRC-xxx400x-C-7x BXRC-xxx400x-D-7x Drive Current 5 (mA) CCT1,5 2700K/3000K 4000K2 5000K3 6500K4 900 RG1 RG1 RG1 RG1 1350 RG1 RG1 RG1 RG2 1800 RG1 RG1 RG2 RG2 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG1 RG2 RG2 1050 RG1 RG1 RG1 RG1 1575 RG1 RG1 RG1 RG2 2100 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 21 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRC-xxx400x-B-7x BXRC-xxx400x-C-7x BXRC-xxx400x-D-7x Maximum Drive Current3 1800mA 2340mA 2100mA Maximum Peak Pulsed Drive Current4 2570mA 3340mA 3000mA Maximum Reverse Voltage5 -60V -60V -50V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN31: Assembly Considerations for Bridgelux Vero LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 22 Performance Curves Figure 2: Vero 18C Drive Current vs. Voltage 2000 2700 1800 2400 1600 2100 1400 Forward Current (mA) Forward Current (mA) Figure 1: Vero 18B Drive Current vs. Voltage 1200 1000 800 600 1800 1500 1200 900 600 400 300 200 0 0 32 33 34 35 36 37 38 39 32 33 34 200% 2000 180% 1750 160% 1500 140% Relative Luminous Flux Forward Current (mA) 2250 1250 37 38 39 1000 750 500 120% 100% 80% 60% 40% 250 20% 26 27 28 29 30 31 0% 32 0 200 400 600 Forward Voltage (V) 800 1000 1200 1400 1600 1800 2000 Forward Current (mA) Figure 5: Vero 18C Typical Relative Flux vs. Current Figure 6 Vero 18D Typical Relative Flux vs. Current y = -7E-08x + 0.001x + 0.027 2 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 36 Figure 4: Vero 18B Typical Relative Flux vs. Current Figure 3: Vero 18D Drive Current vs. Voltage 0 35 Forward Voltage (V) Forward Voltage (V) 120% 100% 80% 60% 40% 120% 100% 80% 60% 40% 20% 20% 0% 100 400 700 1000 1300 1600 Forward Current (mA) 1900 2200 2500 0% 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 2400 Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 23 Performance Curves Figure 8: Typical DC ccy Shift vs. Case Temperature Figure 7: Typical DC Flux vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 125 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Case Temperature (°C) Figure 9: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 7-9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 24 Performance Curves Figure 11: 2000K, 65 CRI Color Shift vs. Case Temperature Figure 10: 1750K Color Shift vs. Case Temperature1 0.3705 0.37 0.4101 Pulsed Center Point Tc = 25°C 15°C 0.41 0.4099 25°C 0.4098 Pulsed Center Point Tc=25°C 15°C 25°C 0.4097 0.3695 0.369 ccy ccy 45°C 45°C 0.4096 0.4095 65°C 0.4094 70°C 0.4093 85°C 85°C 0.4092 0.3685 105°C 0.368 0.5196 105°C 0.4091 0.5198 0.52 0.5202 0.5204 0.409 0.525 0.5206 0.526 0.527 0.528 Figure 12: 2500K Color Shift vs. Case Temperature1 25°C 0.4135 0.413 Pulsed Center Point Tc = 25°C 0.532 0.4125 0.399 85°C 0.397 105°C 0.396 0.47 65°C 0.398 85°C 0.4105 0.468 45°C 0.4 70°C 0.4115 Pulsed Center Point Tc=25°C 25°C 0.401 45°C 0.412 15°C 0.402 ccy ccy 0.531 0.403 15°C 0.414 0.472 0.474 0.476 0.395 0.444 0.478 105°C 0.4445 0.445 0.4455 Figure 14: 2700K, 97 CRI Color Shift vs. Case Temperature1 0.446 0.4465 0.447 ccx ccx Figure 15: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.53 Figure 13: 3000K, 90 CRI Color Shift vs. Case Temperature1,3 0.4145 0.411 0.529 ccx ccx 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.4572 0.4574 0.4576 0.4578 0.458 ccx Note for Figures 10-15: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRC-30G400C-x-73 0.3950 0.4323 0.4328 0.4333 0.4338 0.4343 0.4348 0.4353 ccx 25 Performance Curves Figure 16: 5600K Color Shift vs. Case Temperature1,3 Figure 17: 3000K Class A Color Shift vs. Case Temperature1 0.344 0.369 15°C 0.342 0.34 25°C 0.338 0.367 0.332 70°C 0.33 0.365 0.364 70°C 0.363 85°C 0.328 Pulsed Center Point Tc=25°C 45°C 45°C 0.334 ccy ccy 25°C 0.366 0.336 0.326 0.368 Pulsed Center Point Tc = 25°C 15°C 85°C 0.362 105°C 0.361 0.324 0.322 0.32 0.322 0.324 0.326 0.328 105°C 0.36 0.416 0.33 0.4165 0.417 ccx Figure 18: 3500K Class A Color Shift vs. Case Temperature1 ccx 0.4175 0.418 0.4185 Figure 19: 4000K Class A Color Shift vs. Case Temperature1 0.37 0.3760 15°C 0.368 Pulsed Center Point Tc=25°C 25°C 0.366 15°C 0.3740 25°C 0.3720 45°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.364 0.3680 70°C 0.362 85°C 0.3660 0.36 85°C 0.3640 105°C 0.358 0.392 70°C 105°C 0.393 0.394 0.395 0.396 0.397 ccx 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 Note for Figures 16-19: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Color shift shown for product hot targeted at Tc=85°C 26 Typical Radiation Pattern Figure 20: Typical Spatial Radiation Pattern Note for Figure 20: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 21: Typical Polar Radiation Pattern 27 Typical Color Spectrum Figure 22: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 22: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 23: Typical Color Spectrum for Vero 18 with Décor Series 1 17E 20B 0.9 25E 27H 30G (Décor Series Showcase) 0.8 30H Relative Spectral Power Distribution 56G 56H 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 23: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 28 Mechanical Dimensions Figure 24: Drawing for Vero 18 LED Array Notes for Figure 24: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M2.5 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 29 Color Binning Information Figure 25: Warm and Neutral White Test Bins in xy Color Space 0.44 2500K 4SDCM 3 SDCM 4 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2000K 2500K 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) - - - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - - - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - - - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5167, 0.336) (0.5280, 0.4100) (0.4765, 0.4137) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Figure 26: Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5600K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5475K - 5830K) (5481K - 5829K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) (0.3287, 0.3417) (0.3123, 0.3282) Note for Table 9: 1. Select configurations with a CCT of 5600K are available with center point targets at Tc = 85°C or Tc = 25°C. 30 Packaging and Labeling Figure 27: Drawing for Vero 18 Packaging Tray Notes for Figure 27: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 31 Packaging and Labeling Figure 28: Vero Series Packaging and Labeling Notes for Figure 28: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 29: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 32 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 33 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 Vero 18 Array Series Product Data Sheet DS92 Rev. N (10/2018) 34
BXRC-30G4000-D-72
物料型号: - 该文档描述的是Bridgelux公司的Gen 7 Vero® 18 Array系列LED产品,具体型号为30E4000B7。
器件简介: - Vero系列是芯片级封装(COB)光源技术和创新的革命性进步,简化了灯具设计和制造过程。Vero COB LED阵列提供四种不同的配置,以适应广泛的电流范围,提供灵活性和可靠性。
引脚分配: - 文档中提到了Vero产品包括一个板载连接器端口,实现无焊接的电气互连,以及简单的安装特性,实现即插即用安装。
参数特性: - Vero系列产品具有160 lm/W的典型效率(3000K 80 CRI),并且提供从1,455到13,600流明的光输出性能。色温范围从1750K到6500K,CRI选项包括65、70、80、90、95和Class A。
功能详解: - Vero阵列提供增加的光通量密度,以实现改进的光束控制和精确照明。2 SDCM和3 SDCM的色控制标准,提供干净一致的均匀照明。
应用信息: - Vero系列产品适用于室内和室外照明的广泛应用,提供应用驱动的照明设计要求的灵活性,高质量的真实色彩再现,统一一致的白光。
封装信息: - Vero 18是Vero家族中第二大的尺寸,除了提供许多照明应用所需的性能和光质量外,Vero还集成了多个功能,以简化设计集成和制造过程,加速上市时间并降低系统成本。
BXRC-30G4000-D-72 价格&库存
很抱歉,暂时无法提供与“BXRC-30G4000-D-72”相匹配的价格&库存,您可以联系我们找货
BXRC-30G4000-D-72
  • 200+81.15690200+10.51127
