CXM-22-27-95-36-AC10-F3-3
    LUMINUS(朗明纳斯)
    LEDCOB2700KSQUARE
CXM-22-27-95-36-AC10-F3-3 数据手册
CXM-22 Product Datasheet Generation 2 CXM-22 COB Arrays White LED Features: • High lumen output and efficacy typical Table of Contents • Over 5,900 lm, 132 LPW @ 3000K, 85ºC Technology Overview. . . . . . 2 • Over 6,500 lm, 150 LPW @ 5000K, 85ºC Test Specifications . . . . . . . . . 2 • CCT 2700K, 3000K, 3500K, 4000K, 5000K and 6500K • CRI Ra 80 or 90 min. in all colors (except 6500K) Chromaticity Bins. . . . . . . . . . 3 • R9 up to 90 min. CRI 98 typical in 2700K, 3000K, 3500K and 4000K Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • 3 SDCM color binning accuracy Product Typical Flux Range. 5 • Exceptional long term color stability Operating Characteristics . . 6 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7 • Excellent optical emission uniformity and color over angle consistency • Package thermal conductivity more than the industry average • Environmentally friendly: RoHS and REACH compliant • Spectra. . . . . . . . . . . . . . . . . . . . 8 Mechanical Dimensions. . . . 9 Packaging Information. . . . . 9 Handling Notes. . . . . . . . . . . 10 Applications • Architectural and Specialty • Parking Lot and Area Lighting • Street Lighting • Tunnel Lighting 1 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 25,000lm, all major color temperatures and can deliver color rendering greater than 95 at 2700K and 3000K and R9 greater than 90. These breakthroughs allow illumination engineers and designers to develop beautifully lit spaces without sacrificing efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 2700K 0.44 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CXM-22 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. Center Point 5-step Bin 3-step Bin Angle CCT CIEx CIEy θ (°) a b a b 2700K 0.4578 0.4101 53.7 0.0081 0.0042 0.0135 0.007 3000K 0.4338 0.403 53.2 0.00834 0.00408 0.0139 0.0068 3500K 0.4073 0.3917 54 0.00927 0.00414 0.01545 0.0069 4000K 0.3818 0.3797 53.7 0.00939 0.00402 0.01565 0.0067 5000K 0.3447 0.3553 59.6 0.00822 0.00354 0.0137 0.0059 6500K 0.3123 0.3282 58.57 0.00669 0.00285 0.01115 0.00475 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CXM-22 products are packaged and labeled with part numbers as outlined in the table on page 5. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 22 NN Product Family Light Emitting Surface Diameter Color Temperature CXM: Chip on Board 22: LES Diameter (mm) Color See Note 1 below CXM-22 XX 36 QQPP FG W Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CRI See Table Below Volts AC10 Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Color Temperature, CRI and R9 Values Color Temperatures Note: XX Value CRI R9 3000K, 3500K, 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K 90 >90 >50 2700K, 3000K 95 >95 >85 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet CXM-22 Part Numbers (Typical Flux) The following tables describe products with typical flux and minimum flux measured at 1,280mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) Reference CCT 2700K 3000K 3500K 4000K 5000K 6500K Ordering Part Number CRI (min.) 3-step MacAdam Ellipse Typ. Typ. (85ºC) Min. (85ºC) (calculated) 5,620 5,225 6,185 80 CXM-22-27-80-36-AC10-F3-3 4,390 4,085 4,830 90 CXM-22-27-90-36-AC10-F3-3 4,130 3,840 4,545 95 CXM-22-27-95-36-AC10-F3-3 6,040 5,620 6,645 70 CXM-22-30-70-36-AC10-F3-3 5,940 5,645 6,535 80 CXM-22-30-80-36-AC10-F3-3 5,050 4,695 5,555 90 CXM-22-30-90-36-AC10-F3-3 4,665 4,340 5,130 95 CXM-22-30-95-36-AC10-F3-3 6,240 5,800 6,865 70 CXM-22-35-70-36-AC10-F3-3 6,140 5,710 6,755 80 CXM-22-35-80-36-AC10-F3-3 5,285 4,915 5,815 90 CXM-22-35-90-36-AC10-F3-3 6,665 6,200 7,330 70 CXM-22-40-70-36-AC10-F3-3 6,345 5,900 6,980 80 CXM-22-40-80-36-AC10-F3-3 5,465 5,180 6,010 90 CXM-22-40-90-36-AC10-F3-3 Color Rendering Index Part Number (25ºC) Output Flux (lm) Reference CCT Color Rendering Index Typ. Typ. (85ºC) Min. (85ºC) (calculated) 6,825 6,345 6,495 CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 7,510 70 CXM-22-50-70-36-AC10-F3-5 CXM-22-50-70-36-AC10-F3-3 6,040 7,145 80 CXM-22-50-80-36-AC10-F3-5 CXM-22-50-80-36-AC10-F3-3 6,800 6,325 7,480 70 CXM-22-65-70-36-AC10-F3-5 CXM-22-65-70-36-AC10-F3-3 6,475 6,020 7,125 80 CXM-22-65-80-36-AC10-F3-5 CXM-22-65-80-36-AC10-F3-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI and R9 measurements. 5 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet CXM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum 32 Power Operating Case Temperature Typical Maximum Unit 1,280 2,560 mA 34 37.5 V 43 90 W 105 ºC Tc Light Emitting Surface Diameter LES 22 mm Thermal Resistance (junction-to-case) Qjc 0.37 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions for maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: CXM-22 COB minimum operating current is suggested to be no less than 20% of the typical value. While lower levels will not harm the device, they may result in uneven lighting across the LES area. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 6: Data sheets are subject to changes without prior notice. Please refer to the Luminus web site for the latest data sheet revisions. 6 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet CXM-22 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 200% 2800 180% 140% Forward Current (mA) Relative Luminous Flux 160% 120% 100% 80% 60% 2300 1800 1300 40% 800 20% 0% 300 400 900 1400 1900 2400 33 34 35 Forward Current (mA) Relative Output Flux vs. Junction Temperature 38 39 40 100.0% 38 Forward Voltage (V) Relative Luminous Flux 37 Change in Voltage vs. Junction Temperature 120.0% 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 30 5 15 25 35 45 55 65 75 85 95 105 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) Change CIEx vs. Junction Temperature (3000K, 80CRI) Change CIEy vs. Junction Temperature (3000K, 80CRI) 0.02 0.02 40 0.01 38 0.01 Forward Voltage (V) Δ CIEy Δ CIEx 36 Forward Voltage (V) 0 -0.01 36 0 34 -0.01 32 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 7 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 30 5 5 1515 2525 3535 45 45 55 55 65 65 Junction Temperature Temperature (ºC) Junction (ºC) 75 75 8585 9595 105 105 CXM-22 Product Datasheet CXM-22 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 550 -20.00% 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 8 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CXM-22 Product Datasheet Mechanical Dimensions Shipping Container Each bag is boxed for easier storage/stacking • • • Trays are sealed in an anti-static bag Label Customer Part Number Lot ID Quantity 9 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved 5 trays are stacked together with one tray as a cover CXM-22 Product Datasheet (Part #) Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with XNova COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the XNova COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 10 PDS-002712 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
CXM-22-27-95-36-AC10-F3-3 价格&库存
很抱歉,暂时无法提供与“CXM-22-27-95-36-AC10-F3-3”相匹配的价格&库存,您可以联系我们找货
