L22-ML2W
L22-ML2W
    BIVAR
    STARG22 XM-L2 WW C-TYPE
L22-ML2W 数据手册
REV. DESCRIPTION F Engineering Release G Engineering Update w/o Changes DATE APPROVED 04/09/14 08/09/16 J. C. J. C. 0.08 [2.0mm] 0.20 [5.0mm] REF. 0.375 [9.5mm] R0.063 [R1.6mm] Solder Pad x2 For Use With: Wire Harness: BIVAR L2CON-24 or Housing : LEOCO 2530S020000 Terminal : LEOCO 2533TPB0000 1.21 [30.7mm] 0.78 [19.9mm] ORDERING INFORMATION L22-ML2X C: COOL WHITE N: NEUTRAL WHITE W: WARM WHITE LED POLARITY Table 1: Assembly Configurations Part Number LED P/N Color CCT (K) Typical Luminous Flux (lm) Cree P/N Reference L22-ML2C BDL-1480 Cool White 6500 300 XMLBWT-00-0000-0000U20E1 L22-ML2N BDL-1481 Neutral White 4000 260 XMLBWT-00-0000-000LT50E5 L22-ML2W BDL-1482 Warm White 3000 220 XMLBWT-00-0000-000HT30E7 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: B. Oliver CHECKED: J. Chiang ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 07/22/13 DATE: 07/22/13 FAX: (949) 951-3974 L22 Starboard Light Engine PART NO: REVISION: L22-ML2X CAGE CODE : 32559 G SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
L22-ML2W 价格&库存
很抱歉,暂时无法提供与“L22-ML2W”相匹配的价格&库存,您可以联系我们找货
