CXM-22-65-80-54-AC30-F4-5
    LUMINUS(朗明纳斯)
CXM-22-65-80-54-AC30-F4-5 数据手册
CXM-22 Product Datasheet Preliminary Generation 3 CXM-22 COB Arrays White LED Features: • High lumen output and efficacy typical Table of Contents • Over 8,280 lm, 148 LPW @ 3000K, 80 CRI, Tj = 85ºC Technology Overview. . . . . . 2 • Over 9,420 lm, 168 LPW @ 5000K, 70 CRI, Tj = 85ºC Test Specifications . . . . . . . . . 2 • CCT 2700K, 3000K, 3500K, 4000K, 5000K and 6500K • CRI Ra 80 or 90 min. in all colors (except 6500K) Chromaticity Bins. . . . . . . . . . 3 • R9 up to 90 min. CRI 98 typical in 2700K, 3000K, 3500K and 4000K Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 • 3 SDCM color binning accuracy Product Typical Flux Range. 5 Operating Characteristics . . 6 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7 • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Package thermal conductivity more than the industry average • Environmentally friendly: RoHS and REACH compliant • Spectra. . . . . . . . . . . . . . . . . . . . 8 Mechanical Dimensions. . . . 9 Packaging Information. . . . . 9 Handling Notes. . . . . . . . . . . 10 Applications • Architectural and Specialty • Parking Lot and Area Lighting • Street Lighting • Tunnel Lighting 1 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Preliminary Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACh & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. For the most demanding application, Luminus is one of only a few companies that can provide a 2-step ellipse bin. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale data sheet specifications to real world situations. 2 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Preliminary Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.46 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 2700K 0.44 3000K 3500K 0.42 Black Body 4000K CIE y 0.4 5000K 0.38 0.36 6500K 0.34 0.32 0.3 0.3 0.32 0.34 0.36 0.38 0.4 0.42 0.44 0.46 0.48 0.5 CIE x CXM-22 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. CCT Center Point Angle 3-step Bin 5-step Bin CIEx CIEy θ (°) a b 2700K 0.4578 0.4101 53.7 0.0081 0.0042 3000K 0.4338 0.403 53.2 0.00834 0.00408 3500K 0.4073 0.3917 54 0.00927 0.00414 4000K 0.3818 0.3797 53.7 0.00939 0.00402 5000K 0.3447 0.3553 59.6 0.00822 6500K 0.3123 0.3282 58.57 0.00669 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved a b 0.00354 0.0137 0.0059 0.00285 0.01115 0.00475 CXM-22 Product Datasheet Preliminary Product Ordering and Shipping Part Number Nomenclature All CXM-22 products are packaged and labeled with part numbers as outlined in the table on page 5. Luminus may include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 22 NN XX 54 QQPP FG W Product Family Light Emitting Surface Diameter Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CXM: Chip on Board 22: LES Diameter (mm) Color See Note 1 below CRI See Table Below Volts AC30 Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI R9 3000K, 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 95 >95 2700K, 3000K 3500K, 4000K Note: >85 >75 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Preliminary CXM-22 Part Numbers The following tables describe products with typical flux and minimum flux measured at 1,100mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Output Flux (lm) CCT 3000K 3500K 4000K CRI (min.) 3-step MacAdam Ellipse Typ. 7,840 7,290 8,470 80 CXM-22-27-80-54-AC30-F4-3 6,460 6,010 6,980 90 CXM-22-27-90-54-AC30-F4-3 6,180 5,750 6,675 95 CXM-22-27-95-54-AC30-F4-3 8,425 7,835 9,090 70 CXM-22-30-70-54-AC30-F4-3 8,285 7,705 8,950 80 CXM-22-30-80-54-AC30-F4-3 6,970 6,480 7,525 90 CXM-22-30-90-54-AC30-F4-3 6,510 6,050 7,030 95 CXM-22-30-95-54-AC30-F4-3 8,530 7,935 9,215 80 CXM-22-35-80-54-AC30-F4-3 7,105 6,610 7,675 90 CXM-22-35-90-54-AC30-F4-3 6,795 6,320 7,340 95 CXM-22-35-95-54-AC30-F4-3 9,270 8,620 10,010 70 CXM-22-40-70-54-AC30-F4-3 8,645 8,040 9,335 80 CXM-22-40-80-54-AC30-F4-3 7,500 6,970 8,100 90 CXM-22-40-90-54-AC30-F4-3 6,960 6,475 7,510 95 CXM-22-40-95-54-AC30-F4-3 Reference Color Rendering Index Part Number CCT (25ºC) Typ. Min. (85ºC) (calculated) 9,425 8,765 8,700 Typ. (85ºC) 6500K Ordering Part Number (calculated) Output Flux (lm) 5000K Color Rendering Index Min. (85ºC) Typ. (85ºC) 2700K Reference CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 10,180 70 CXM-22-50-70-54-AC30-F4-5 CXM-22-50-70-54-AC30-F4-3 8,095 9,400 80 CXM-22-50-80-54-AC30-F4-5 CXM-22-50-80-54-AC30-F4-3 7,535 7,010 8,140 90 CXM-22-50-90-54-AC30-F4-5 CXM-22-50-90-54-AC30-F4-3 9,435 8,775 10,190 70 CXM-22-65-70-54-AC30-F4-5 CXM-22-65-70-54-AC30-F4-3 8,670 8,065 9,365 80 CXM-22-65-80-54-AC30-F4-5 CXM-22-65-80-54-AC30-F4-3 (25ºC) *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI and R9 measurements. 5 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Preliminary CXM-22 Operating Characteristics1 Optical and Electrical Characteristics Parameter Symbol 2 Forward Current If Forward Voltage3 Vf Minimum 48 Power Operating Case Temperature4 Typical Maximum Unit 1,100 2,200 mA 51.5 55 V 56 125 W 105 ºC Tc Light Emitting Surface Diameter LES 22 mm Thermal Resistance (junction-to-case) Qjc 0.17 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Voltage is rated at typical forward current. For voltage at higher drive current, refer to performance graphs. Note 4: Device operation not recommended at drive currents less than 10% of the typical value Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 6: All product operating specifications are subject to change without advance notice. 6 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved CXM-22 Product Datasheet Preliminary CXM-22 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 200% 2200 180% 2000 160% 1800 140% 1600 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 120% 100% 80% 60% 1400 1200 1000 800 40% 600 20% 400 0% 200 200 400 600 800 1000 1200 1400 Forward Current (mA) 1600 1800 2000 2200 48 Relative Output Flux vs. Junction Temperature 50 51 52 53 Forward Voltage (V) 54 55 56 57 Change in Voltage vs. Junction Temperature 56 120% 100% Forward Voltage (V) Relative Luminous Flux 49 80% 54 52 60% 50 40% 5 15 25 35 45 55 65 75 85 95 5 105 15 25 35 Change CIEx vs. Junction Temperature (3000K, 80CRI) 55 65 75 85 95 105 Change CIEy vs. Junction Temperature (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 45 Junction Temperature (ºC) Junction Temperature (ºC) 0 0 -0.01 -0.01 -0.02 -0.02 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 7 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CXM-22 Product Datasheet Preliminary CXM-22 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 8 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CXM-22 Product Datasheet Preliminary Mechanical Dimensions Shipping Container 100 pcs per box Each bag is boxed for easier storage/ stacking 20 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: (Manufacturer Part Number & Bin Kits) Bar code XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 9 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved (Box ID) Rev XX Bar code (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc XXXXXX-XX-XX CXM-22 Product Datasheet (Part #) Product Datasheet Preliminary Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guide lines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with XNova COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the XNova COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 10 PDS-002831 Rev 04 © 2017 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件支持多种信号路径配置,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
CXM-22-65-80-54-AC30-F4-5 价格&库存
很抱歉,暂时无法提供与“CXM-22-65-80-54-AC30-F4-5”相匹配的价格&库存,您可以联系我们找货
  • 400+105.01974400+13.63629
