CXM-27-50-80-54-AA30-F4-5
    LUMINUS(朗明纳斯)
CXM-27-50-80-54-AA30-F4-5 数据手册
CXM-27 Product Datasheet Generation 3 CXM-27 COB Arrays White LED Features: Table of Contents • High lumen output and efficacy typical • Over 12,400 lm, over 152 LPW @ 3000K, 80CRI, Tj = 85ºC Technology Overview. . . . . . 2 • Over 14,100 lm, over 173 LPW @ 5000K, 70CRI, Tj = 85ºC Test Specifications . . . . . . . . . 2 • CCT range 2000K, 2200K, 2700K, 3000K, 3500K, 4000K, 5000K and 6500K Chromaticity Bins. . . . . . . . . . 3 • 80 or 90 CRI min. up to 95 min. in warm white Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 Product Typical Flux Range. 5 • 3 SDCM color binning accuracy • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading Product Flux Bins. . . . . . . . . . . 6 • Environmentally friendly: RoHS and REACH compliant Operating Characteristics . . 6 • Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7 Spectra. . . . . . . . . . . . . . . . . . . . 8 Mechanical Dimensions. . . . 9 Packaging Information. . . . . 9 Handling Notes. . . . . . . . . . . 10 Applications • Architectural and Specialty • Parking Lot and Area Lighting • Street Lighting • Tunnel Lighting 1 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-27 Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Delivered with fully qualified LM80 test data and TM21 lifetime results that certify lumen maintenance at 35,000 hours or more, Luminus COB LEDs are ready for the toughest challenges. UL Recognized Compliance Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACH & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Standard products are delivered with a 3-step MacAdam ellipse. This ensures color performance matching in the application. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus COB products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale datasheet specifications to real world situations. 2 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-27 Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.47 ANSI C78.377-2008 3-step Ellipse 5-step Ellipse 0.45 0.43 2000K 3500K 4000K 0.41 Black Body 5000K 0.39 CIE y 2200K 2700K 3000K 0.37 6500K 0.35 0.33 0.31 0.29 0.27 0.29 0.34 0.39 0.44 0.49 0.54 CIE x CXM-27 White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. CCT Center Point Angle 3-step Bin 5-step Bin CIEx CIEy θ (°) a b 2000K 0.5282 0.4177 49.88 0.0098 0.00453 2200K 0.5014 0.4153 53.7 0.0081 0.0042 2700K 0.4578 0.4101 53.7 0.0081 0.0042 3000K 0.4338 0.403 53.2 0.00834 0.00408 3500K 0.4073 0.3917 54 0.00927 0.00414 4000K 0.3818 0.3797 53.7 0.00939 0.00402 5000K 0.3447 0.3553 59.6 0.00822 6500K 0.3123 0.3282 58.57 0.00669 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved a b 0.00354 0.0137 0.0059 0.00285 0.01115 0.00475 CXM-27 Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CXM-27 products are packaged and labeled with part numbers as outlined in the table on page 5 and 6. Luminus may include any smaller chromaticity bin that is contained in the larger bin as part of the ordered part. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CXM 27 NN Product Family Light Emitting Surface Diameter CXM: Chip on Board 26.5: LES Diameter (mm) XX 54 QQPP FG W Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin Color See Note 1 below CRI See Note 2 below Volts AB30 (Basic package) Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 20 = 2000K 22 = 2200K 27 = 2700K 30 = 3000K 35 = 3500K 40 = 4000K 50 = 5000K 65 = 6500K Color Temperature, CRI and R9 Values Color Temperatures XX Value CRI R9 2000K, 2200K, 3000K, 4000K, 5000K, 6500K 70 >70 - 2700K, 3000K, 3500K, 4000K, 5000K, 6500K 80 >80 >0 2700K, 3000K, 3500K, 4000K, 5000K 90 >90 >50 95 >95 2700K, 3000K 3500K, 4000K Note: >85 >75 Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-27 Product Datasheet CXM-27 Part Numbers The following tables describe products with typical flux and minimum flux measured at 1,600mA and specified at Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. Luminus may choose to ship a smaller chromatiticy bin in an order for a larger. Output Flux (lm) CCT Typ. (85ºC) Color Reference Rendering Index Ordering Part Number Typ. Min. (85ºC) (calculated) CRI (min.) 3-step MacAdam Ellipse (25ºC) 2000K 10,500 9,780 11,290 70 CXM-27-20-70-54-AB30-F4-3 2200K 10,615 9,875 11,455 70 CXM-27-22-70-54-AB30-F4-3 11,735 10,915 12,675 80 CXM-27-27-80-54-AB30-F4-3 9,670 8,995 10,445 90 CXM-27-27-90-54-AB30-F4-3 9,250 8,605 9,990 95 CXM-27-27-95-54-AB30-F4-3 12,610 11,730 13,605 70 CXM-27-30-70-54-AB30-F4-3 12,400 11,530 13,390 80 CXM-27-30-80-54-AB30-F4-3 10,430 9,700 11,265 90 CXM-27-30-90-54-AB30-F4-3 9,740 9,060 10,520 95 CXM-27-30-95-54-AB30-F4-3 12,770 11,875 13,790 80 CXM-27-35-80-54-AB30-F4-3 10,640 9,895 11,490 90 CXM-27-35-90-54-AB30-F4-3 10,175 9,460 10,990 95 CXM-27-35-95-54-AB30-F4-3 13,875 12,905 14,985 70 CXM-27-40-70-54-AB30-F4-3 12,935 12,030 13,970 80 CXM-27-40-80-54-AB30-F4-3 11,220 10,435 12,120 90 CXM-27-40-90-54-AB30-F4-3 10,415 9,690 11,235 95 CXM-27-40-95-54-AB30-F4-3 Reference Color Rendering Index Part Number 2700K 3000K 3500K 4000K Output Flux (lm) CCT 5000K 6500K *Note: Typ. Min. (85ºC) (calculated) 14,105 13,120 13,025 Typ. (85ºC) CRI (min.) 5-step MacAdam Ellipse 3-step MacAdam Ellipse 15,235 70 CXM-27-50-70-54-AB30-F4-5 CXM-27-50-70-54-AB30-F4-3 12,115 14,065 80 CXM-27-50-80-54-AB30-F4-5 CXM-27-50-80-54-AB30-F4-3 11,280 10,490 12,180 90 CXM-27-50-90-54-AB30-F4-5 CXM-27-50-90-54-AB30-F4-3 14,120 13,135 15,250 70 CXM-27-65-70-54-AB30-F4-5 CXM-27-65-70-54-AB30-F4-3 12,975 12,070 14,015 80 CXM-27-65-80-54-AB30-F4-5 CXM-27-65-80-54-AB30-F4-3 (25ºC) Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-27 Product Datasheet CXM-27 Operating Characteristics1 Optical and Electrical Characteristics Parameter Forward Current Symbol 2 If Forward Voltage3 Vf Minimum Power Operating Case Temperature4 48.3 Typical Maximum Unit 1,600 3,200 mA 51.3 56.3 V 82 180 W 105 ºC Tc Light Emitting Surface Diameter LES 26.5 mm Thermal Resistance (junction-to-case) Qjc 0.15 ºC/W Junction Temperature Tj Viewing Angle 140 120 ºC Degree Note 1: Ratings are based on operation at a constant junction temperature Tj = 85ºC. Note 2: To prevent damage refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Forward voltage is rated at typical forward current. For voltage at different forward currents, refer to the voltage versus current performance graphs. Note 4: COB LEDs are designed for operation to a minimum of 20% of the typical forward current value. Operation at currents lower than this value will not harm the device but may result in uneven light emission across the LES surface. Note 5: Luminus may change any specifications without prior notice. Please refer to the company web site for the latest datasheet revision Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 6 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved CXM-27 Product Datasheet CXM-27 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 3200 200% 180% 2800 160% 2400 Forward Current (mA) Relative Luminous Flux 140% 120% 100% 80% 60% 2000 1600 1200 40% 800 20% 0% 400 800 1200 1600 2000 Forward Current (mA) 2400 2800 400 3200 48 Relative Output Flux vs. Junction Temperature 49 50 51 52 53 Forward Voltage (V) 54 55 56 Change in Voltage vs. Junction Temperature 120% 52 100% Forward Voltage (V) Relative Luminous Flux 54 80% 60% 50 48 46 44 42 40% 5 15 25 35 45 55 65 75 85 95 105 40 5 15 25 35 Junction Temperature (ºC) 55 65 75 85 95 105 Change in CIEy vs. Junction Temp. (3000K, 80CRI) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx Change in CIEx vs. Junction Temp. (3000K, 80CRI) 0 0 -0.01 -0.01 -0.02 45 Junction Temperature (ºC) 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 7 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CXM-27 Product Datasheet CXM-27 Optical & Electrical Characteristics Typical Spectrum 120.00% 100.00% Relative Intensity 80.00% Warm White 60.00% Neutral White Cool White 40.00% 3000K-90CRI 3000K-97CRI 20.00% 0.00% 400 450 500 -20.00% 550 600 650 700 750 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 8 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CXM-27 Product Datasheet Mechanical Dimensions Shipping Container 100 pcs per box Each bag is boxed for easier storage/ stacking 20 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) Bar code XXX-XX-XX-XX-XX-XXXX-XX-X XXXXXXXXXXXXXX Bar code 9 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved (Box ID) Rev XX Bar code (Customer Part Number) Qty: XX Bar code RoHS Compliant Luminus Devices Inc CXM-27 ProductDatasheet Datasheet (Part #) Product Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guidelines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 10 PDS-002857 Rev 07 © 2018 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions.
物料型号:CXM-27
器件简介:Luminus的CXM-27 COB(板上芯片)LED系列提供了一种针对高性能照明应用的完整照明解决方案。该系列产品覆盖了从少于400流明到超过10,000流明的广泛流明范围,所有主要色温和在2700K和3000K时色渲染指数大于97,R9等于95。
引脚分配:文档中没有明确提供引脚分配信息,但提到了COB LED设计有接触垫在其顶面上,这些垫子清晰地标有正负极性。
参数特性: - 高流明输出和效率典型值 - 色温范围从2000K到6500K - 色渲染指数(CRI)最小80,暖白色可达95 - 3 SDCM色度分选精度 - 出色的光学发射均匀性和颜色角度一致性 - 卓越的长期色彩稳定性 - 优越的热传导性,用于均匀散热 - 环保:符合RoHS和REACH标准
功能详解: - 该系列产品经过了包括机械冲击、振动、温度循环和湿度在内的一系列严格的环境和机械应力测试。 - 提供了完全合格的LM80测试数据和TM21寿命结果,证明在35,000小时或更长时间内保持流明维持性。
应用信息: - 适用于建筑和特殊照明、停车场和区域照明、街道照明、隧道照明等。
封装信息: - 提供了详细的机械尺寸图和包装信息,包括每个托盘20个单位,每个盒子100个单位的包装方式。
CXM-27-50-80-54-AA30-F4-5 价格&库存
很抱歉,暂时无法提供与“CXM-27-50-80-54-AA30-F4-5”相匹配的价格&库存,您可以联系我们找货
