OLMA-40C000-A01A-AA000
    BRIDGELUX(普瑞)
    LED MOD OLM 4000K 70CRI A01A
OLMA-40C000-A01A-AA000 数据手册
Bridgelux OLM Series Product Data Sheet DS60 Introduction TM Bridgelux OLM Series of outdoor lighting modules introduce a simple and easy way to develop innovative and leading LED luminaires. The highly adaptable platform allows for rapid product development and portfolio expansion. Proprietary optics and environmental protection enable cost and performance advantages within the exterior and industrial market segments. Luminaires used in outdoor lighting require long life combined with stable and consistent performance over the life of the product. The OLM subsystems are designed to deliver high quality, energy efficient lighting for commercial, industrial, and exterior applications. Designed around the unique and innovative Bridgelux LED arrays, the modules deliver targeted lumen output levels to replace incumbent products that utilize high pressure sodium (HPS) and metal halide technologies. Designed for integration, the lighting subsystems mechanically attach with four screws. Soldering, glues, and epoxies are removed from the assembly process and replaced with a robust electrical connection. The integration of optics, environmental protection and the LED source are unparalleled in the LED lighting industry. TM The OLM subsystems leverages the Bridgelux Vero Series, the latest generation of Bridgelux LED arrays, which deliver high performance, compact and cost-effective solid-state lighting solutions to serve the general lighting market. These products combine higher efficiency, lifetime, and reliability benefits of LEDs with the light output levels of many conventional light sources. Features Benefits  Typical efficacy of 90 lm/W to 118 lm/W  Designed to replace HPS bulbs in application  Typical lumen output ranges from 2100 to 4500 lumens  Optimized for color and efficacy  Broad range of CCT options from 4000K to 5600K  High quality true color reproduction  CRI options include; minimum 70 and 80  Long lifetime with a strong return on investment  Reliable operation for outdoor use  Uniform lighting patterns designed for targeted  Asymmetric and symmetric lighting patterns  IP66 rated for outdoor use  Improved thermal management  High level component integration  Simplified robust luminaire design and assembly  Ease of assembly  Improved inventory management and quality control Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) applications Page 1 of 10 Contents Product Feature Map .............................................................................................................................................................. 3 Product Nomenclature............................................................................................................................................................ 3 Product Selection Guide ......................................................................................................................................................... 4 Absolute Maximum Ratings .................................................................................................................................................... 5 Typical Relative Luminous Flux Characteristics....................................................................................................................... 6 Optical Characteristics ............................................................................................................................................................ 8 Photometric Performance (Optical Code: A01A) ................................................................................................................ 8 Photometric Performance (Optical Code: A06A) ................................................................................................................ 7 Mechanical Dimensions .......................................................................................................................................................... 8 Design Resources .................................................................................................................................................................... 9 Precautions ............................................................................................................................................................................. 9 Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 2 of 10 Product Feature Map OLM is the first product line in the exciting new Bridgelux series of next generation solid-state lighting subsystems. In addition to delivering the performance and light quality required for many exterior and industrial lighting applications, OLM incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please consult the Bridgelux OLM Brochure for more information on the OLM products. Figure 1: Product Feature Map Four mechanical mounting through holes Aluminum mounting plate adds stability and thermal spreading Proprietary asymmetric and symmetric optics Tc Measurement point located directly under the array IP66 rated protection from water and dust 2D Bar code provides full manufacturing traceability Electrical connection wire harness Pressure vent allows moisture and gas removal during thermal cycling Product Nomenclature The part number designation for the Bridgelux OLM Series is explained as follows: 1234 56 7 8 9 10 11 12 13 14 15 16 17 18 19 OLMA – 40 E 000 – A 02A - AA000 Internal Code Product Family Typical CCT Optical Pattern 40 = 4000K 50 = 5000K See characterizations in Table 5 Minimum CRI C = 70 CRI E = 80 CRI Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Optical Orientation Internal Code A = Asymmetric S = Symmetric Page 3 of 10 Product Selection Guide The following product configurations are available: Table 1: Product Selection Guide Nominal CCT (K) Part Number OLMA-50C000-xxxx-xx000 OLMA-40E000-xxxx-xx000 OLMA-40C000-xxxx-xx000 OLMA-56C000-xxxx-xx000 5000 CRI 70 4000 80 4000 70 5600 70 Drive Current (mA) Typical Pulsed [1] Flux Tc = 25ºC (lm) Typical [2,3, 4] Flux Tc = 70ºC (lm) Typical [5] Vf (V) Typical Power (W) Typical Pulsed Efficacy Tc = 25ºC (lm) Typical Efficacy Tc = 70ºC (lm/W) 350 2,438 2,144 53 18.6 131.1 115 500 3,335 2,932 55.3 27.6 120.8 106 700 4,429 3,894 58 40.6 109.1 96 350 2,284 2,022 53 18.6 122.8 109 500 3,123 2,765 55.3 27.6 113.2 100 700 4,139 3,665 58 40.6 102.0 90 350 2,389 2,115 53 18.6 128.4 114 500 3,266 2,892 55.3 27.6 118.3 105 700 4,329 3,833 58 40.6 106.6 94 350 2,498 2,196 53 18.6 134.3 118 500 3,417 3,005 55.3 27.6 123.8 109 700 4,535 3,987 58 40.6 111.7 98 Notes for Tables 1: 1. Tested in pulsed conditions at the 350mA drive current, Tc = 25°C. Pulse width is 10 ms. 2. Typical performance when driven under DC (direct current) at test current with LED array case temperature maintained at 70°C, mounted to heat sink with thermal interface material. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3. Bridgelux maintains a ± 10% tolerance on flux values. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Bridgelux maintains a tester tolerance of ± 0.20 V on forward voltage measurements. Table 2: Electrical Characteristics and Driver Selection Voltages Drive Current [1] (mA) Forward Voltage [2] Pulsed, Tc = 25ºC (V) Typical Thermal Resistance Array case to Module case (C/W) Minimum Typical Maximum Typical Coefficient of Forward Voltage ΔVf / ΔTc (mV/°C) 350 49 53 57 -28 0.41 700 53 58 62.4 -28 0.47 Notes for Table 2: 1. Tested in pulsed conditions at the 350mA drive current, Tc = 25°C. Pulse width is 10 ms. 2. Bridgelux maintains a tester tolerance of ± 0.20 V on forward voltage measurements. Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 4 of 10 Absolute Maximum Ratings Table 3: Maximum Drive Current and Reverse Voltage Ratings Part Number Maximum DC Forward [3] Current (mA) Maximum Peak Pulsed [1] Current (mA) Maximum Reverse [2] Voltage (Vr) OLMA-xxx000-xxxx-xx000 700 1500 -90 Notes for Table 3: 1. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 2. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 3. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for the Bridgelux Vero Series of COB arrays used in the OLM Series subsystems. Contact your Bridgelux sales representatives for LM-80 report. Table 4: Maximum Ratings Parameter LED Junction Temperature Storage Temperature Maximum Rating 150 -40°C to +55°C Maximum Ambient Temperature 55°C Operating Module Case Temperature 70°C Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 5 of 10 Typical Relative Luminous Flux Characteristics Typical performance at any drive current and temperature can be derived from the characteristics shown in Figures 1 and 2. Figure 1: Relative Luminous Flux vs. Drive Current Figure 2: Relative Luminous Flux vs. Module Case Temperature Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 6 of 10 Figure 3: Typical DC ccy Shift vs. Case Temperature 25°C pulse reference point Figure 4: Typical DC ccx Shift vs Case Temperature 25°C pulse reference point Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 7 of 10 Optical Characteristics Table 5: Optical Pattern Descriptions Optical Code Description IES Classification NEMA Classification EN 13-201 Guidance A01A Asymmetric; Narrow, Short Width Type II, Med 7H x 7V ME2 – ME4 A06A Asymmetric; Medium, Short Width Type III, Short 7H x 7V ME2 – ME4 Photometric Performance (Optical Code: A01A) Photometric Performance (Optical Code: A06A) Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 8 of 10 Mechanical Dimensions Figure 5: Mechanical Dimensions Notes for Figure 5: 1. Mounting holes (4X) accommodate M4 or #8 screws. 2. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 3. Drawing dimensions are in millimeters. 4. Unless otherwise specified, tolerances are ± 1.00mm. 5. Refer to Application Notes AN30 and AN61 for product handling, mounting and heat sink recommendations. Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 9 of 10 Design Resources Design Guide Bridgelux has developed a comprehensive design guide and design resources to assist customers in successfully designing with the OLM modules. For a list of resources under development, visit www.bridgelux.com. Optical Files Far field optical files are available in .IES and .LDT format. 3D CAD Models Three dimensional CAD models depicting the product outline are available in both SAT and STEP formats. Please contact your Bridgelux sales representative for assistance. Precautions CAUTION: CONTACT WITH OPTICAL AREA The OLM is manufactured with molded polycarbonate lenses. The lens is extremely durable, but not indestructible. Contact may cause damage to the module. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult the Bridgelux Design Guide for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vero LED arrays and the OLM sub-system is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. Vero LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum DC forward current (2x the nominal rated test current as is defined in Table 3 of this data sheet). Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the module lens area during operation. Allow the module to cool for a sufficient period of time before handling. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. About Bridgelux At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux WeChat ID: BridgeluxInChina © 2015 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux OLM Module Series Product Data Sheet 60 Rev. B (03/07/2016) Page 10 of 10
OLMA-40C000-A01A-AA000 价格&库存
很抱歉,暂时无法提供与“OLMA-40C000-A01A-AA000”相匹配的价格&库存,您可以联系我们找货
