LZC-B3MA07-0000
LZC-B3MA07-0000
    AMSOSRAM(艾迈斯半导体)
    LED EMITTER RGBA 40W 4X3 MCPCB
LZC-B3MA07-0000 数据手册
High Luminous Efficacy RGBA LED Emitter LZC-03MA07 Key Features  Ultra-bright, Ultra-compact 40W RGBA LED  Individually addressable Red, Green, Blue and Amber channels  Small high density foot print – 9.0mm x 9.0mm  Surface mount ceramic package with integrated glass lens  Exceptionally low Thermal Resistance (0.7°C/W)  Electrically neutral thermal path  Extreme Luminous Flux density  JEDEC Level 1 for Moisture Sensitivity Level  Lead (Pb) free and RoHS compliant  Reflow solderable (up to 6 cycles)  Emitter available on 4-channel MCPCB (optional)  Recommended use with LLxx-3T08 family of High Efficiency / High Uniformity color-mixing lenses for perfect color uniformity from 8 to 32 deg. Typical Applications  Architectural lighting  Entertainment  Stage and Studio lighting  Accent lighting Description The LZC-03MA07 RGBA LED emitter enables a full spectrum of brilliant colors with the highest light output, highest flux density, and superior color mixing available. It outperforms other colored lighting solutions with multiple red, green, blue and amber LED die in a single, compact emitter. With 40W power capability and a 9.0mm x 9.0mm ultra-small footprint, this package provides exceptional luminous flux density. LED Engin’s RGBA LED offers ultimate design flexibility with four individually addressable color channels. The patented design with thermally and electrically isolated pads has unparalleled thermal and optical performance. The high quality materials used in the package are chosen to optimize light output and minimize stresses which results in monumental reliability and lumen maintenance. The robust product design thrives in outdoor applications with high ambient temperatures and high humidity. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Part Number Options Base part number Part number Description LZC-03MA07-xxxx LZC emitter LZC-B3MA07-xxxx LZC emitter on 4 channel 4x3 Star MCPCB Bin kit option codes MA, Red-Green-Blue-Amber (RGBA) Kit number suffix Min flux Bin Color Bin Range 0000 11R R2 – R2 14G G2 – G3 03B B03 – B03 11A A9 – A9 Description Red, full distribution flux; full distribution wavelength Green, full distribution flux; full distribution wavelength Blue, full distribution flux; full distribution wavelength Amber, full distribution flux; full distribution wavelength Notes: 1. Default bin kit option is -0000 COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 2 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Luminous Flux Bins Table 1: Minimum Maximum Luminous Flux (ΦV) Luminous Flux (ΦV) @ IF = 700mA [1,2] @ IF = 700mA [1,2] (lm) (lm) Bin Code 3 Red 11R 3 Green 3 Blue 3 Amber 260 3 Red 3 Green 3 Blue 3 Amber 420 14G 300 480 03B 48 04B 77 11A 77 130 240 400 Notes for Table 1: 1. Luminous flux performance guaranteed within published operating conditions. LED Engin maintains a tolerance of ±10% on flux measurements. 2. Each flux value consists of 3 dies from the same color in series for binning purposes. Dominant Wavelength Bins Table 2: Bin Code R2 G2 G3 B03 A9 Minimum Dominant Wavelength (λD) @ IF = 700mA [1,2] (nm) Red Green [2] Blue Amber 618 520 525 453 590 Maximum Dominant Wavelength (λD) @ IF = 700mA [1,2] (nm) Red Green [2] Blue Amber 630 525 530 460 595 Notes for Table 2: 1. LED Engin maintains a tolerance of ± 0.5nm on dominant wavelength measurements. Forward Voltage Bin Table 3: Bin Code 0 Red 6.00 Minimum Forward Voltage (VF) @ IF = 700mA [1] (V) Green Blue Amber 9.30 9.30 6.00 Red 8.00 Maximum Forward Voltage (VF) @ IF = 700mA [1] (V) Green Blue Amber 12.00 12.00 8.00 Notes for Table 3: 1. Forward Voltage is binned with all three LED dice connected in series. 2. LED Engin maintains a tolerance of ± 0.12V for forward voltage measurements for the three LEDs. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 3 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Absolute Maximum Ratings Table 4: Parameter DC Forward Current [1] Peak Pulsed Forward Current [2] Reverse Voltage Storage Temperature Junction Temperature [Blue, Green] Junction Temperature [Red, Amber] Soldering Temperature [4] Allowable Reflow Cycles Symbol IF IFP VR Tstg TJ TJ Tsol Value 1000 1500 See Note 3 -40 ~ +150 150 125 260 6 Unit mA mA V °C °C °C °C > 8,000 V HBM Class 3B JESD22-A114-D ESD Sensitivity [5] Notes for Table 4: 1. Maximum DC forward current is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 12 for current derating. 2: Pulse forward current conditions: Pulse Width ≤ 10msec and Duty Cycle ≤ 10%. 3. LEDs are not designed to be reverse biased. 4. Solder conditions per JEDEC 020D. See Reflow Soldering Profile Figure 5. 5. LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZC-03MA07in an electrostatic protected area (EPA). An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1. Optical Characteristics @ TC = 25°C Table 5: Parameter Symbol Luminous Flux (@ IF = 700mA) Luminous Flux (@ IF = 1000mA) Dominant Wavelength Viewing Angle [2] Total Included Angle [3] ΦV ΦV λD 2Θ½ Θ0.9 Typical Green Blue [1] 430 100 560 130 523 460 95 115 Red 340 475 623 Amber 320 410 590 Unit lm lm nm Degrees Degrees Notes for Table 5: 1. When operating the Blue LED, observe IEC 60825-1 class 2 rating. Do not stare into the beam. 2. Viewing Angle is the off axis angle from emitter centerline where the luminous intensity is ½ of the peak value. 3. Total Included Angle is the total angle that includes 90% of the total luminous flux. Electrical Characteristics @ TC = 25°C Table 6: Parameter Symbol Forward Voltage (@ IF = 700mA) [1] Forward Voltage (@ IF = 1000mA) [1] Temperature Coefficient of Forward Voltage Thermal Resistance (Junction to Case) VF VF 3 Red 7.5 8.1 ΔVF/ΔTJ -5.7 Typical 3 Green 3 Blue 10.8 9.6 11.2 10.0 RΘJ-C -8.7 -9.0 0.7 3 Amber 7.2 7.8 -5.7 Unit V V mV/°C °C/W Notes for Table 6: 1. Forward Voltage typical value is for three LED dice from the same color dice connected in series. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 4 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin IPC/JEDEC Moisture Sensitivity Level Table 7 - IPC/JEDEC J-STD-20D.1 MSL Classification: Soak Requirements Floor Life Standard Accelerated Level Time Conditions Time (hrs) Conditions Time (hrs) Conditions 1 Unlimited ≤ 30°C/ 85% RH 168 +5/-0 85°C/ 85% RH n/a n/a Notes for Table 7: 1. The standard soak time includes a default value of 24 hours for semiconductor manufacturer’s exposure time (MET) between bake and bag and includes the maximum time allowed out of the bag at the distributor’s facility. Average Lumen Maintenance Projections Lumen maintenance generally describes the ability of a lamp to retain its output over time. The useful lifetime for solid state lighting devices (Power LEDs) is also defined as Lumen Maintenance, with the percentage of the original light output remaining at a defined time period. Based on long-term WHTOL testing, LED Engin projects that the LZ Series will deliver, on average, 70% Lumen Maintenance at 65,000 hours of operation at a forward current of 700 mA. This projection is based on constant current operation with junction temperature maintained at or below 125°C. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 5 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Mechanical Dimensions (mm) Pin Out Figure 1: Package Outline Drawing Notes for Figure 1: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. Pin Die Color Polarity 1 G Red + 2 G Red - 3 C Green + 4 C Green - 5 B Amber + 6 B Amber - 7 F Blue - 8 F Blue + 9 E Green + 10 E Green - 11 J Red - 12 J Red + 13 K Amber - 14 K Amber + 15 P Blue - 16 P Blue + 17 Q Red - 18 Q Red + 19 L Green + 20 L Green - 21 M Blue - 22 M Blue + 23 H Amber + 24 H Amber - Recommended Solder Pad Layout (mm) Figure 2a: Recommended solder pad layout for anode, cathode, and thermal pad. Note for Figure 2a: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 6 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Recommended Solder Mask Layout (mm) Figure 2b: Recommended solder mask opening (hatched area) for anode, cathode, and thermal pad. Note for Figure 2b: 1. Unless otherwise noted, the tolerance = ± 0.20 mm. Reflow Soldering Profile Figure 3: Reflow soldering profile for lead free soldering. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 7 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Typical Radiation Pattern 100 90 Relative Intensity (%) 80 70 60 50 40 30 20 10 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Displacement (Degrees) Figure 4: Typical representative spatial radiation pattern. Typical Relative Spectral Power Distribution 1 0.9 Relative Spectral Power 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 650 700 Wavelength (nm) Figure 5: Typical relative spectral power vs. wavelength @ T C = 25°C. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 8 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Typical Dominant Wavelength Shift over Forward Current Relative Dominant Wavlength (nm) 4 3 2 1 0 Red Green Blue Amber -1 -2 300 400 500 600 700 800 900 1000 1100 IF - Forward Current (mA) Figure 6: Typical dominant wavelength shift vs. forward current @ T C = 25°C. Dominant Wavelength Shift over Temperature 9 Dominant Wavelength Shift (nm) 8 7 6 5 4 Red Green Blue Amber 3 2 1 0 0 20 40 60 80 100 120 Case Temperature (ºC) Figure 7: Typical dominant wavelength shift vs. case temperature. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 9 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Typical Relative Light Output 140 Relative Light Output (%) 120 100 80 60 Red Green Blue Amber 40 20 0 0 200 400 600 800 1000 IF - Forward Current (mA) Figure 8: Typical relative light output vs. forward current @ T C = 25°C. Typical Relative Light Output over Temperature 160 Relative Light Output (%) 140 120 100 80 60 Red Green Blue Amber 40 20 0 0 20 40 60 80 100 120 Case Temperature (ºC) Figure 9: Typical relative light output vs. case temperature. COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED. 10 LZC-03MA07 (1.8 - 11/14/2018) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin Typical Forward Current Characteristics 1200 IF - Forward Current (mA) 1000 800 600 400 Red Green 200 Blue Amber 0 5 6 7 8 9 10 VF - Forward Voltage (V) 11 12 Figure 10: Typical forward current vs. forward voltage @ T C = 25°C. Current De-rating IF - Maximum Current (mA) 1200 1000 800 700 (Rated) 600 400 RΘJ-A = 2.0°C/W RΘJ-A = 2.5°C/W RΘJ-A = 3.0°C/W 200 0 0 25 50 75 100 125 150 Maximum Ambient Temperature (°C) Figure 11: Maximum forward current vs. ambient temperature based on T J(MAX) = 150°C. Notes for Figure 11: 1. Maximum current assumes that all 12 LED dice are operating concurrently at the same current. 2. RΘJ-C [Junction to Case Thermal Resistance] for the LZC-03MA07 is typically
LZC-B3MA07-0000 价格&库存
很抱歉,暂时无法提供与“LZC-B3MA07-0000”相匹配的价格&库存,您可以联系我们找货
