SSR-90-R-R11-HH102
SSR-90-R-R11-HH102
    LUMINUS(朗明纳斯)
    LEDSTARBRDRED619NMSMD
SSR-90-R-R11-HH102 数据手册
SST-90-R Product Datasheet SST-90-R LEDs Features: • Extremely high optical output Red LEDs: Typ.1500 lumens at 9A • High thermal conductivity package - junction to case thermal resistance of only 0.5 °C/W Table of Contents Technology Overview. . . . . . 2 Test Specifications . . . . . . . . . 2 Binning Structure. . . . . . . . . . 3 • Large, monolithic chip with uniform emitting area of 9 mm2 • Environmentally friendly: RoHS compliant • Variable drive currents: less than 1 A through 18 A continuous waveform • High reliability • Electrically isolated thermal path Part Number Nomenclature.4 Product Shipping & Labeling Information. . . . . . . 5 Optical & Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . . 6 Thermal Resistance . . . . . . . . 9 Applications Mechanical Dimensions . . . 10 • Machine vision • Emergency Vehicle Lighting • High-output strobing applications • Displays and Signage • Beacons, obstruction lighting • Industrial Applications • High-output, directional transportation lighting • Consumer Portable • Search Light Solder Profile . . . . . . . . . . . . . 13 History of Changes. . . . . . . . 14 • Medical Lighting 1 PDS-002760 Rev 01 © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 SST-90-R Product Datasheet Technology Overview Luminus LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Luminus Technology Luminus’ technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. Designed from the ground up, Luminus LEDs are one of the most reliable light sources in the world today. Luminus LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus LEDs are ready for even the most demanding applications. Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 0.5°C/W. Luminus SST-90 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Environmental Benefits Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Reliability Understanding Luminus LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Luminus surface mount LEDs are typically tested with a 20mSec input pulse and a junction temperature of 25ºC. Expected flux values in real world operation can be extrapolated based on the information contained within this product data sheet. Multiple Operating Points (3.15, 9.0 A and above) The tables on the following pages provide typical optical and electrical characteristics. Since the LEDs can be operated over a wide range of drive conditions (currents from less than 1.0 A to 18.0 A, and duty cycle from
SSR-90-R-R11-HH102 价格&库存
很抱歉,暂时无法提供与“SSR-90-R-R11-HH102”相匹配的价格&库存,您可以联系我们找货
