SBR-90-WDLS-R71-NA150 数据手册
SBT-90 Product Datasheet
SBT-90 LEDs
Features:
• Extremely high optical output from a 9 mm2 square emitter:
Table of Contents
• Up to 2300 lumens at 13.5A from a single chip (White)
• Over 1,600 lumens at 13.5A (Red)
Technology Overview. . . . . . 2
Binning Structure. . . . . . . . . . 3
Chromaticity Bins. . . . . . . . . . 4
Product Shipping &
Labeling Information. . . . . . . 5
Ordering Information . . . . . . 6
Electrical Characteristics. . . 7
• Choice of 5700K or 6500K color point
• High thermal conductivity package - junction to case thermal resistance of only
0.5 °C/W
• Large, monolithic chip with uniform emitting area of 9 mm2
• Unencapsulated die with low profile protective window optimizes optical coupling in
etendue-limited applications
• Electrically isolated thermal path
• Environmentally friendly: RoHS compliant
Optical Characteristics. . . . . 8
White Characteristics. . . . . . . 9
Radiation Patterns . . . . . . . . 10
Applications
Output vs Temp ,Lifetime and
Spectrum. . . . . . . . . . . . . . . . . 11
• Fiber-coupled illumination
Mechanical Dimensions . . . 12
• Architectural and Entertainment
lighting
Solder Profile . . . . . . . . . . . . . 14
• Projection and micro-display based
applications
1
PDS-001540 Rev 16
© 2020 Luminus Devices, Inc. - All Rights Reserved
• High-Brightness and large format
LCD back-light units
• Edge-illuminated lighting guides
• High output, Etendue-limited
lighting applications
Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com
1145 Sonora Court • Sunnyvale, CA 94086
Technology Overview
Luminus LED benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These
breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency.
Luminus Technology
Luminus’ technology enables large area LED chips with uniform
brightness over the entire LED chip surface. The optical power
and brightness produced by these large monolithic chips
enable solutions which replace arc and halogen lamps where
arrays of traditional high power LEDs cannot.
Designed from the ground up, Luminus LEDs are one of the
most reliable light sources in the world today. They have passed
a rigorous suite of environmental and mechanical stress tests,
including mechanical shock, vibration, temperature cycling and
humidity, and have been fully qualified for use in extreme high
power and high current applications. With very low failure rates
and median lifetimes that typically exceed 60,000 hours,
Luminus LEDs are ready for even the most demanding
applications.
Packaging Technology
Thermal management is critical in high power LED applications.
With a thermal resistance from junction to heat sink of 0.5º C/W,
Luminus SBT-90 LEDs have the lowest thermal resistance of any
LED on the market. This allows the LED to be driven at higher
current densities while maintaining a low junction temperature,
thereby resulting in brighter solutions and longer lifetimes.
Environmental Benefits
Luminus LEDs Whitehelp reduce power consumption and the
amount of hazardous waste entering the environment. All
Luminus LED products manufactured by Luminus are RoHS
compliant and free of hazardous materials, including lead and
mercury.
Reliability
Understanding Luminus LED Test Specifications
Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products.
Testing Temperature
Multiple Operating Points
Luminus surface mount LEDs are typically tested with a 20 msec
input pulse and a junction temperature of 25ºC. Expected flux
values in real world operation can be extrapolated based on the
information contained within this product data sheet.
The tables on the following pages provide typical optical and
electrical characteristics. Since the LEDs can be operated over a
wide range of drive conditions (currents from less than 1A to
13.5A, and duty cycle from
SBR-90-WDLS-R71-NA150 价格&库存
很抱歉,暂时无法提供与“SBR-90-WDLS-R71-NA150”相匹配的价格&库存,您可以联系我们找货
