PT-39-G-L21-MPH
PT-39-G-L21-MPH
    LUMINUS(朗明纳斯)
    Module
    PT-39-G-L21-MPH
PT-39-G-L21-MPH 数据手册
PT39-TE Product Datasheet PT39-TE Product Datasheet PT39 LEDs Thermally Enhanced Features: Table of Contents • Matched RGB Chipset with 3.9 mm2 emitting area designed for LED projector applications Technology Overview. . . . . . 2 • Enhanced thermal performance allows for operation up to 12 A (3A/mm2) Understanding Big Chip Test Specifications. . . . . . . . . . . . . . 2 • Ultra low thermal resistance, common anode copper-core PCB package Ordering Information . . . . . . 3 • Wide color gamut: Red-Amber 613nm, GREEN 525 nm, Blue 460nm typical dominant wavelength Flux /Power Bin Definition. . 4 • Photonic lattice technology for very high surface brightness and uniform surface emission Optical & Electrical Characteristics. . . . . . . . . . . 5- 6 • Single emitting area per color allows for collection with single lens for simplified optics Blue Flux Bin Ranges by Wavelength . . . . . . . . . . . . . . . 7 • Aspect ratio optimized and compatible with micro-display diagonal sizes ranging from 0.45” to 0.55” Characterization Curves. . . . 8 • RoHS (EU-2002/95/EC Directive) and REACH compliant • LED mounted on MC-PCB for easier thermal and optical integration Spectrum and Angular Intensity Distribution. . . . . . . 9 Thermal Resistance . . . . . . . 10 Mechanical Dimensions. . . . . . . . . . . . 11-12 Shipping Tray Outline . . . . . 13 Applications Packing and Shipping Specifications . . . . . . . . . . . . 14 • Specifically engineered for high brightness pocket-size, ultra portable front projectors, head-up projection displays and hybrid projectors History of Changes. . . . . . . . 15 • Optimized for Micro-Display diagonal sizes ranging from 0.45” to 0.55” • Suitable for DLP™ ( 0.45” WXGA, 0.55” SVGA), LCoS and HTPS /3LCD microdisplays 1 PDS-001992 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT39-TE Product Datasheet Technology Overview Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and system designers to achieve solutions that are high brightness and high efficiency. Photonic Lattice Technology Luminus’ photonic lattice technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus Big Chip LEDs are ready for even the most demanding applications. (Please refer to Luminus’ Reliability application note for more information.) Environmental Benefits Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 1.0º C/W, Luminus PT39 LEDs can be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All Big Chip LED products manufactured by Luminus are RoHS and REACH compliant and free of hazardous materials, including lead and mercury. Reliability For high power operation, Luminus Big Chip LEDs are one of the most reliable light sources in the world today. Big Chip LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature Understanding Big Chip LED Test Specifications Every Luminus LED is extensively tested at rated current to ensure that it meets the high quality standards expected from Luminus products. Testing of Big Chip LEDs Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40º C heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus Big Chip LEDs perform in the field just as they are specified. values in real world operation can be extrapolated based on the information contained within this product data sheet. Luminus surface mount LEDs are typically tested with a 20 ms input pulse and a junction temperature of 25º C. Expected flux 2 PDS-001992 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT39-TE Product Datasheet Ordering Information Ordering Part Number 1 PT-39-RA-L21-MPF Min Flux or Power Bin 2 Color Red-Amber (Discontinued) PT-39-RA-L21-MPG PT-39-RA-L21-MPH PT-39-RA-L21-MPJ PT-39-G-L21-MPF Description 2E 2F 2G Red-Amber LED, consisting of a 3.9 mm2 Red-Amber LED chip, thermistor and connector mounted on a copper-core PCB. 2H 2F PT-39-G-L21-MPG 2G Green PT-39-G-L21-MPH 2H PT-39-G-L21-MPJ Green LED, consisting of a 3.9 mm2 Green LED chip, thermistor and connector mounted on a copper-core PCB. 2J PT-39-B-L21-EPD 2G Blue PT-39-B-L21-EPE 2H Blue LED, consisting of a 3.9 mm2 Blue LED chip, thermistor and connector mounted on a copper-core PCB. Note 1: Ordering part numbers represent bin kits (group of bins that are shippable for a given ordering part number) Note 2: See Bin Kit and Flux / Power bin definitions on page 4 Ordering Part Number Nomenclature XXX Product Family PT: Metal Coreboard PCB 00 XXXX X00 XXX Chip Area Color Package Configuration Bin Kit 1 39: 3.9 mm2 RA= Red -Amber (615nm, typ) G= Green B= Blue L21: 26.5mm x 16.0 mm (standard) L22: 26.5mm x 16.0 mm (die-rotated configuration) See Mechanical Drawing section See page 4 for bin kit definition Note 1: A Bin Kit represents a group of individual flux or power bins that are shippable for a given ordering part number. Individual flux bins are not orderable. EXAMPLE: PT-39-RA-L21-MPF i s comprised of Red-Amber Flux Bins 2E, 2F, 2G, 2H, 2J. 3 PDS-001992 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT39-TE Product Datasheet PT39 Bin Kit1 and Flux Bin2,3 ,4 Definitions Note: Please refer to ordering part number table on page 3 for Bin Kit availability Red -Amber Flux Bins Bin 2E Bin 2F Bin 2G Bin 2H Bin 2J Bin 2K Bin 2L Bin 2M Red -Amber Bin Flux Range (lm) (Discontinued) 635-690 690-745 745-800 800-860 860-925 925-990 990-1055 1055 -1125 þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-39-RA-L21-MPF PT-39-RA-L21-MPG PT-39-RA-L21-MPH PT-39-RA-L21-MPJ Green Flux Bins Bin 2F Bin 2G Bin 2H Bin 2J Bin 2K Bin 2L 2M Green Bin Flux Range (lm) 1250 -1330 1330 -1450 1450 -1550 1550 -1660 1660 -1780 1780 -1900 1900 -2020 þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-39-G-L21-MPF PT-39-G-L21-MPG PT-39-G-L21-MPH PT-39-G-L21-MPJ Blue Flux Bins Bin 2G Bin 2H Bin 2J Bin 2K Bin 2L Bin 2M Blue Bin Flux Range (lm) 255-280 280-300 300-320 320-345 345-370 370-400 þ þ þ þ þ PT-39-B-L21-EPD þ Note 1: Bin Kits are defined by a group of flux or power bins. Only one flux bin will be shipped in each individual pack. A shipment will contain packs of different allowed flux bins for a particular ordering part number. Individual Flux or Power bins are not ordereable. Note 2: PT39 LEDs are tested for luminous flux at 9.8 A at 25% duty cycle for Red, Red-Amber and Blue. and at 50% duty cycle for Green Devices Devices are sorted and packed by flux bin. Not all flux bins are are currrently populated. Note 3: Luminus maintains a test measurement accuracy for LED flux and power of +/- 6%. Note 4: Blue Flux bin limits are defined at reference dominant wavelength of 462nm. See table on page 7 for Blue bin limits at other dominant wavelengths. 4 PDS-001992 Rev 03 © 2015 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT39-TE Product Datasheet Optical & Electrical Characteristics Symbol Red -Amber Green Blue Unit Emitting Area x 3.9 3.9 3.9 mm2 Emitting Area Dimensions x 2.09 x 1.87 2.09 x 1.87 2.09 x 1.87 mmxmm 25 50 25 % General Characteristics (Discontinued) Characteristics at Recommended Test Drive Current , If 1, 2 Reference Duty Cycle 3 Test Peak Drive Current typ IF 9.8 9.8 9.8 A Peak Luminuous Flux 1,2,5 typ Φv 800 1660 300 lm Peak Radiometric Flux 1,2 typ Φr 3.2 3.5 6.2 W min λdmin 609 516 450 nm typ λd 613 525 460 nm max λdmax 620 540 468 nm 19 34 20 nm 1,2,4 Dominant Wavelength FWHM- Spectral bandwidth at 50% of Φr typ typ x 0.675 0.167 0.147 typ y 0.325 0.704 0.033 min VF min 2.2 3.5 3.2 V typ VF 2.6 5.2 3.9 V max VF max 3.2 5.9 5.2 V typ 0.1 0.12 0.09 Ω Thermal Coefficient of Photometric Flux typ -1.0 -0.2 ~0 % / oC Thermal Coefficient of Radiometric Flux typ -0.7 -0.2 -0.2 % / oC Forward Voltage Temperature Coefficient typ -2 -4.7 -3 mV/ oC Chromaticity Coordinates 6,7 Forward Voltage Dynamic Resistance Device Thermal Characteristics Characteristics at Reference Continuous Drive Current IF (continuous wave)1 Reference Drive Current typ IF 5.9 5.9 5.9 A Luminous Flux typ Φv 450 1175 210 lm Radiometric Flux typ Φr 1.8 2.5 4.3 W Dominant Wavelength typ λd 612 528 461 nm FWHM -Spectral bandwidth at 50% of Φr typ 18 36 21 nm Chromaticity Coordinates 6,7 Forward Voltage 5 PDS-001992 Rev03 © 2015 Luminus Devices, Inc. - All Rights Reserved typ x 0.677 0.177 0.144 nm typ y 0.322 0.713 0.034 nm typ VF 2.3 4.5 3.4 V Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT39 Product Datasheet Optical & Electrical Characteristics Note 1: All ratings are based on testing conditions with a constant heat sink temperature Ths = 40º C. See Thermal Resistance section for Ths definition. Note 2: Parameters rated at test duty cycle and Pulsed operation frequency f>240 Hz; t DC = --T t T Note 3: Duty Cycle used to specify device ratings under Pulsed operation. Big Chip LED devices can operate at duty cycles ranging from 1% to 100%. At higher duty cycles, drive current should be adjusted to maintain the junction temperature at desired levels to meet the application lifetime requirements. Note 4: In pulsed operation, rise time from 10% to 90% of forward current should be larger than 0.5 microseconds Note 5: For Blue devices, total flux from emitting area at typical dominant wavelength. Refer to page 7 for brightness specifications at other wavelength Note 6: In CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1 Note 7: For Reference only Absolute Maximum Ratings Red -Amber (Discontinued) Green Blue Unit 200 200 200 mA 9.8 9.8 9.8 A Absolute Maximum Current (Pulsed) 2,3 ( frequency > 240Hz, duty cycle 240 Hz, duty cycle =tbd, t=tbd) TBD TBD TBD A 125 170 170 o -40 / +100 -40 / +100 -40 / +100 o Symbol Absolute Minimum Current (CW or Pulsed)1 Absolute Maximum Current (CW) 2 Absolute Maximum Junction Temperature 4 Storage Temperature Range Tjmax C C Note 1: Product performance and lifetime data is specified at recommended forward drive currents. Sustained operation at or near absolute minimum currents may result in a reduction of device performance and device lifetime compared to recommended foward drive currents. Note 2: Luminus LEDs’ absolute maximum forward drive current density is 2.5 A/mm2 CW, and 3.5A/mm2 pulsed (f>240 Hz, duty cycle
PT-39-G-L21-MPH
PDF文档中包含以下信息: 1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压型开关稳压器。
3. 引脚分配:共有8个引脚,包括输入、输出、使能、地和反馈引脚。
4. 参数特性:输入电压范围为4.5V至38V,输出电压范围为0.6V至38V,最大输出电流为3A。
5. 功能详解:具有内部软启动、可编程频率控制、可编程输出电压和可编程软启动时间等功能。
6. 应用信息:适用于需要高效率、高电流输出的电源管理应用。
7. 封装信息:采用8引脚的SOIC封装。
PT-39-G-L21-MPH 价格&库存
很抱歉,暂时无法提供与“PT-39-G-L21-MPH”相匹配的价格&库存,您可以联系我们找货
