SBR-70-B-R75-KF300
SBR-70-B-R75-KF300
    LUMINUS(朗明纳斯)
    Module
    SBR-70-B-R75-KF300
SBR-70-B-R75-KF300 数据手册
SBT-70-G/B Product Datasheet SBT-70-G/B LEDs Features: Table of Contents • Extremely high optical output from a 7 mm2 circular emitter: • Over 2000 green lumens at 10 .5 A • Over 200 blue lumens at 10 .5 A and 445 nm Technology Overview. . . . . . 2 Ordering Information . . . . . . 3 Binning Structure. . . . . . . . . . 4 Typical Device Performance. . . . . . . . . . . . . . . 5 Absolute Maximum Ratings. . . . . . . . . . . . . . . . . . . . 6 Optical & Electrical Characteristics... . . . . . . . . . . . 7 • Refer to SBT-90-R for companion red product • Round emitting aperture provides most eficient match to circular optical systems and narrow beam projectors • Unencapsulated die with low proffile protective window optimizes optical coupling in etendue-limited applications • High thermal conductivity package - junction to case thermal resistance of only 0 .64°C/W • Variable drive current up to 10 .5 A continuous wave . Up to 2 A/mm2 in pulsed conditions • RoHS and REACH compliant Angular Distribution & Typical Spectrum . . . . . . . . . . 9 Soldering Profile. . . . . . . . . . 10 Mechanical Dimensions. . . 11 Shipping Tray Outline . . . . . 13 Shipping Label. . . . . . . . . . . . 14 Revision History. . . . . . . . . . . 15 Applications • Architectural and Entertainment Lighting • Machine Vision • Fiber-coupled Illumination • Spot Lighting • Medical Lighting 1 PDS-002014 Rev 10 • Microscopy © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet Technology Overview Luminus LEDs™ benefit from a suite of innovations in the fields of LED die technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Luminus Technology Reliability Luminus’ technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. This product is sensitive to static electricity, and care should be taken when handling them. Static electricity or surge voltage will damage the LEDs. It is recommended to wear an antielectrostatic wristband or anti-electrostatic gloves when handling the LEDs. All devices, equipment and machinery must be properly grounded. It is recommended that measures be taken to isolate LED processing equipment from potential sources of voltage surges. Packaging Technology Reference: APN-002815 Electrical Stress Damage to LEDs and How to Prevent It Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 0.64°C/W, Luminus SBT-70 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Environmental Benefits Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Big Chip LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Luminus surface mount LEDs are typically tested with a 20 ms single pulse and a case temperature of 25°C. Expected flux values in real world operation can be extrapolated based on the information contained within this product data sheet. 2 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet Ordering Information The table below lists ordering part numbers available for SBT-70 LEDs. The part number includes a bin kit, a group of flux and wavelength bins described in page 4, that are shippable for a given ordering part number. Ordering Part Numbers Luminous Flux Color Bin Code JK Min. Flux (lm) 1500 Green JM 2000 DF 120 DG 160 Blue Wavelength Bin Code Ordering Part Number G4, G5, G6, G7 SBT-70-G-F75-JK200 G4, G5 SBT-70-G-F75-JK201 G6, G7 SBT-70-G-F75-JK202 G4, G5, G6, G7 SBT-70-G-F75-JM200 G4, G5 SBT-70-G-F75-JM201 G6, G7 SBT-70-G-F75-JM202 B1, B2, B3, B4 SBT-70-B-F75-KF300 B2, B3 SBT-70-B-F75-KF301 B1, B2, B3, B4 SBT-70-B-F75-KG300 B2, B3 SBT-70-B-F75-KG301 Part Number Nomenclature SBT Product Family 70 Chip Area SBT: Surface Mount (window) 7.0 mm2 SBR: mounted on an aluminum star board F75 Color Package Configuration G: Green F75: SBT package B: Blue R75: SBR package Bin kit Flux and Wavelength bin kit code - See ordering information Note 1: Flux Bin listed is minimum bin shipped, higher bins may be included at Luminus’ discretion. 3 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet SBT-70 G/B Binning Structure SBT-70 monochromatic LEDs are tested for luminous flux and dominant wavelength at a 10.5 A (1.5 A/mm2) drive current and placed into one of the following flux and wavelength bins. The binning structure is universally applied across each monochromatic color. Flux Bins Color Green Blue Luminous Flux Bin (FF)3 Binning @ 10.5 A, Tc= 25°C ⁵ Minimum Flux (lm) Maximum Flux (lm) CK 1500 2000 CM 2000 2300 CN 2300 2600 DF 120 160 DG 160 200 DH 200 250 DJ 250 350 DK 350 450 Wavelength Bins Color Green Blue Luminous Flux Bin (FF)3 Binning @ 10.5 A, Tc= 25°C ⁵ Minimum Flux (lm) Maximum Flux (lm) G4 520 525 G5 525 530 G6 530 535 G7 535 540 B1 435 440 B2 440 445 B3 445 450 B4 450 455 Note 1: Luminus maintains a +/- 6% tolerance on flux measurements. Note 2: Products are production tested then sorted and packed by bin. Note 3: Individual bins are not orderable. Please refer to the Product Ordering information page for a list of orderable bin kits. Note 4: Product test condition: 10.5 A DC, 25°C constant case temperature. Note 5: Tc = Case Temperature. 4 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet Typical Device Performance General Characteristics Symbol Green Blue Unit Emitting Area Ae 7.0 7.0 mm2 Emitting Area (Diameter) De 3 3 mm Characteristics at Recommended Test Drive Current , If 1, 2,3 Current Density typ j 1.5 1.5 A/mm2 Test Peak Drive Current typ If 10.5 10.5 A Peak Luminous Flux 4 typ Φv 2100 245 lm Peak Radiometric Flux typ Φr - 10.5 W Dominant Wavelength 6 typ λd 530 447 nm FWHM- Spectral bandwidth at 50% of Φv typ Δλ1/2 32 19 nm typ x 0.182 0.160 typ y 0.732 0.017 min VF min 3.9 2.8 V typ VF 4.5 3.2 V max VF max 5.3 4.2 V Thermal Resistance of junction to coreboard ⁸ typ Rθj-b 0.64 0.64 °C / W Thermal Resistance of junction to case 8 typ Rθj-c 2.02 2.02 °C / W Thermal Resistance of junction to heat sink 8 typ Rθj-hs 2.15 2.15 °C / W Thermal Coefficient of Photometric Flux typ -0.2 -0.2 % / °C Thermal Coefficient of Radiometric Flux typ -0.2 -0.2 % / °C Thermal Coefficient of Junction Voltage typ -4.6 -3.5 mV / °C Chromaticity Coordinates 5, 6 Forward Voltage Device Thermal Characteristics 9 For notes see page 6. 5 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 (Part #) Product SBT-70-G/B Datasheet Product Datasheet Absolute Maximum Ratings Symbol Green Blue Unit Absolute Minimum Current 0.2 0.2 A Absolute Maximum Current 14 14 A 150 150 °C -40/+100 -40/+100 ­ °C Absolute Maximum Junction Temperature 11 Tjmax Storage Temperature Range Note 1: Listed drive conditions are typical for common applications. SBT-70 G,B devices can be driven at currents ranging from 1 A to 10.5 A and at duty cycles ranging from 1% to 100%. Drive current and duty cycle should be adjusted as necessary to maintain the junction temperature desired to meet application lifetime requirements. Note 2: All ratings are based on a constant case temperature Tc = 25°C. Note 3: Unless otherwise noted, values listed are typical. Devices are production tested and specified at 10.5 A. Other values are for reference only. Note 4: Total flux from emitting area at listed dominant wavelength. Reported performance is included to show trends for a selected power level. For specific minimum and maximum values, use bin tables. For product roadmap and future performance of devices, contact Luminus. Note 5: In CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1. Note 6: For reference only. Note 7: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 8: Measurements are in accordance with JEDEC 51-14. For more about thermal resistance calculation, please see https://luminusdevices.zendesk. com/hc/en-us/articles/4416807960717-Thermal-Heatsink-Required-Rth-Calculator Note 9: For more about calculating thermistor temperature, please see https://luminusdevices.zendesk.com/hc/en-us/articles/4412023747341-How-doI-determine-the-temperature-from-Luminus-on-board-ThermistorNote 10: Luminus LEDs are designed for operation to an absolute maximum current as specified above. Product lifetime data is specified at recommended forward drive currents. Sustained operation at or beyond absolute maximum currents will result in a reduction of device lifetime compared to recommended forward drive currents. Actual device lifetimes will also depend on junction temperature. Refer to the lifetime derating curves for further information. In pulsed operation, rise time from 10-90% of forward current should be larger than 0.5 microseconds. Note 11: Lifetime dependent on LED junction temperature. Input power and thermal system must be properly managed to ensure lifetime. 6 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet Optical & Electrical Characteristics Forward Current vs. Forward Voltage - Green 1.2 12.0 1.0 10.0 0.8 8.0 Current (A) Relative Luminous Flux Relative Luminous Flux vs. Forward Current - Green 0.6 0.4 0.2 0.0 6.0 4.0 2.0 1 2 3 4 5 6 7 8 9 0.0 10 11 Current (A) Voltage (V) Forward Current vs. Forward Voltage - Blue 1.2 15.0 1.0 12.5 0.8 10.0 Current (A) Relative Luminous flux Relative Luminous Flux vs. Forward Current - Blue 0.6 0.4 7.5 5.0 2.5 0.2 0.0 2.4 2.7 3.0 3.3 3.6 3.9 4.2 4.5 4.8 5.1 1 2 3 4 5 6 7 Current(A) 8 7 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved 9 10 11 0.0 2.0 2.2 2.4 2.6 2.8 3.0 3.2 3.4 3.6 3.8 4.0 Voltage (V) Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 (Part #) Product SBT-70-G/B Datasheet Product Datasheet Optical & Electrical Characteristics Heat Sink Temperature vs. Relative Luminous Flux Heat Sink Temperature vs. Relative Dominant Wavelength Shift Median Lifetime Estimate vs. Junction Temperature 1 Lumen Maintenance 2 Note 1: Median lifetime estimate as a function of junction temperature at 1.5 A/mm2 in continuous operation. Lifetime defined as time to 70% of initial intensity. Based on preliminary lifetime test data. Data can be used to model failure rate over typical product lifetime. Note 2: Lumen maintenance vs. time at 1.5 A/mm2 in continuous operation, case temperature equal to 25°C. 8 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet Typical Spectrum Iref = f(Φ); Tc = 25°C Angular Intensity Distribution (Typical) Φref = f(λ); If = 10.5 A; Tc = 25°C 9 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet Soldering Profile Peak Temperature (235 - 245°C) Temperature Liquidus Temperature, TL (SAC305 = 220°C) Time Above Liquidus (45 - 90 sec) 65 -> 200°C, 120 - 250 sec max Preheat RT to 150°C 1 - 2.5°C/sec Soak 150°C to 180°C 0.4 - 1°C/sec Reflow 180 to TL + 20°C 3 - 6°C/sec Cool down Peak to below 150°C 3 - 7°C/sec Time SMT Rework Guideline Manual Hotplate Reflow Heating Time Hot Air Gun Reflow < 60 sec Hotplate Temperature < 245°C < 150°C Note 1: Product complies to Moisture Sensitivity Level 3 (MSL 3) Note 2: The numbers in the table are specific to SAC305. Luminus recommends using an SAC305 solder paste with a no-clean flux for RoHS compliant products. Note 3: During the pick and place process, axial forces on the dome (or window) should not exceed 0.5 Newtons (N) Note 4: Use of a multi-zone IR reflow oven with a nitrogen blanket is recommended. Note 5: Time-temperature profile of the reflow process showing the four functional profile zones are defined in IPC-7801. Temperature is referenced to the center of the PCB. Note 6: Luminus recommends to use the solder paste data sheet information as a starting point in time-temperature process development. Note 7: These are general guidelines. Consult the solder paste manufacturer’s datasheet for guidelines specific to the alloy and flux combination used in your application. For more information, please refer to: https://luminusdevices.zendesk.com/hc/en-us/articles/360060306692-How-do-IReflow-Solder-Luminus-SMD-ComponentsNote 8: For any technical questions about soldering process, please contact Luminus at techsupport@luminus.com. Note 9: This part is not compatible with vapor phase reflow processes. 10 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct., Sunnyvale, CA 94086 USA SBT-70-G/B Product Datasheet Mechanical Dimensions – SBT-70 Emitter 11 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet 8 4 2 3 Mechanical Dimensions – SBT-70 Star Board 5 6 7 5 6 7 4 2 3 DESCRIPTION OF CHANGE REV ECO 01 ECO03911 1 REVISION HISTORY 1 INITIAL RELEASE BY DATE SKK 02/04/13 REVISION HISTORY DESCRIPTION OF CHANGE REV ECO 01 D 0 ±0.30 .012 16.4 .65 6X 60 R1.60±0.30 .063±.012 19.0±0.3 .748±.012 19.0±0.3 .748±.012 7.1 4X .28 3.44±0.22 SEE NOTE.136±.009 1 TOP OF WINDOW TO BACK OF COREBOARD 7.1 4X .28 16.4 .65 SEE NOTE 1 ECO03911 INITIAL RELEASE BY DATE SKK 02/04/13 D 3.44±0.22 .136±.009 TOP OF WINDOW TO BACK OF COREBOARD D 4X 30° C 4X 30° 0.15 10.00+0.00 4.1 .16 SEE NOTE 1 +.006 .394 - .000 4X 3.00 .118 EMITTING AREA 0.15 11.00+0.00 +.006 .433 - .000 SBT-70 SEE NOTE 2 -70 OTE 2 0.15 11.00+0.00 3.00 .118 EMITTING AREA B B 1.8 .071 1.8 .071 +.006 .433 - .000 1100 TECHNOLOGY PARK DRIVE BILLERICA, MA 01821 CATHODE 978-528-8000 This document and its contents are confidential information of PADS DESCRIPTION: PROPRIETARY AND 1100 TECHNOLOGY PARK DRIVE Luminus Devices, Inc. CONFIDENTIAL Copyright 2005 Luminus Device,Inc. BILLERICA, MA 01821 All rights reserved. DRAWING, OUTLINE, 002153, SBR-70 978-528-8000 This document and its contents PROPRIETARY AND CONFIDENTIAL ANODE PADS A ANODE CATHODE PADS PADS NOTES: 1. TOLERANCES PER IPC-610, CLASS 2. 2. FOR DETAIL DRAWING OF SBT-70 SEE DWG-002087. NCES PER IPC-610, CLASS 2. TAIL DRAWING OF SBT-70 SEE DWG-002087. 8 7 C 19.9 .783 19.9 .783 B C 4.1 4X .16 SEE NOTE 1 6 7 6 5 are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. UNLESS OTHERWISE SPECIFIED TOLERANCES ARE ANGLES 0.5 SURFACES 5 X = 0.5mm 0.8 MICRONS .X = 0.127mm .XX = 0.050mm .XXX = 0.010mm 4 Note 1: Tolerances per IPC-610, Class 2. All dimensions in millimeters DESCRIPTION: UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: TOLERANCES ARE MILLIMETERS [INCHES] ANGLES 0.5 SURFACES DRAFTER: X = 0.5mm ENGINEER: 0.8 MICRONS .X = 0.127mm SHEET: DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: .XX = 0.050mm 1 OF 1 S.KEDDIE .XXX MILLIMETERS = 0.010mm [INCHES] SCALE: B DRAWING, OUTLINE, 002153, SBR-70 DRAFTER: 4 B 3 NUMBER: ENGINEER: 2 NUMBER: REV: 01 SHEET: SCALE: 1 OF 1 6/1 DWG-002153 1 DWG-002153 S.KEDDIE 3 6/1 A 2 1 Note 2: For detail drawing of SBT-70, please see page 11. Note 3: Recommended mounting screw: M3 or #4 Note 4: All anode pads and all cathode pads on board are interconnected. 12 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086 REV: 01 A SBT-70-G/B Product Datasheet Shipping Tray Outline LAYOUT IQC 工程專用發行章 Engineering Stamp 8 7 5 6 4 2 3 1 REVISION HISTORY NOTES: 1. MATERIAL: .020[.50] THK STARTING GAUGE CLEAR POLYESTER SHEET (KPET) OR IT'S OTHER REACH 6.89DISSAPATIVE 175.01 COMPLIANT VARIANTS. MUST BE ANTISTATIC OR STATIC WITH RESISITIVITY LESS THAN 1012 OHMS PER SQUARE. D 6.22 157.94 2. ALL UNSPECIFIED RADII TO BE .030[.76]. B REVISION LETTER/NUMBER. 3. MOLD "TO-1171" .18[4.6] HIGH AS SHOWN. DO NOT MOLD 4. DIMENSIONS DO NOT ACCOUNT FOR MATERIAL SHRINKAGE/FLUCTUATION FACTOR OF .005[.13] PER INCH. 5. TO BE USED WITH LUMINUS PART NUMBER TO-0945, COVER. X0 REV A DESCRIPTION OF CHANGE REV ECO A B ENG00742 INITIAL PROTOTYPE BY DAT MEH 07/09/ MEH CHANGED MATERIAL THICKNESS FROM .015" TO .020" 08/19 CUSTOMER DWG NO. TO-1171 REV A A C 4.36 110.62 3.76 95.58 R.030 0.76 TYP B .020 0.51 B SECTION B-B .405 10.29 7.0° TYP SECTION A-A 1100 TECHNOLOGY PARK DRIVE BILLERICA, MA 01820 978-528-8000 PROPRIETARY AND CONFIDENTIAL NOTES: 1. MATERIAL: 20 MIL THICK POLYESTER SHEET (PET) OR ITS OTHER REACH COMPIANT VARIANTS; NEED TO BE ANTISTATIC OR PDS-002014STATIC Rev 10 DISSAPATIVE © 2022 Luminus Devices, Inc. - All Rights Reserved 10¹² OHMS PER SQUARE. WITH RESISTIVITY LESS THAN 2. CCI PART NUMBER: 05N-8433. 3. MATES WITH LUMINUS PART NUMBER TO-0944. A 13 This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. DESCRIPTION: Luminus Devices, Inc. • T 408.708.7000 COVER, • www.luminus.com SHIPPING, SST UNLESS OTHERWISE SPECIFIED 1145 Sonora Ct. • Sunnyvale, CA 940861 OF 1 TOLERANCES ARE INCHES [MILLIMETERS] B NONE ANGLES 0.5 SURFACES DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: SHEET: SCALE: X 0.03 .X 0.020 .XX 0.010 .XXX 0.005 0.8 MICRONS DRAFTER: M. HADLEY NUMBER: ENGINEER: - TO-0945 REV: B SBT-70-G/B Product Datasheet Shipping Label Label Fields: XXX-XX-XXXX-XXXX-XXXXXXXXX • CPN: Luminus ordering part number • CID: Customer’s part number • QTY: Quantity of devices in pack • Flux: Bin as defined on page 4 • Voltage: NA • Color: Bin as defined on page 4 50 • CRI: NA Box ID Packing Configuration: • Maximum stack of 2 trays per pack with 25 devices per tray • Partial pack or tray may be shipped • Each pack is enclosed in anti-static bag • Shipping label is placed on top of each pack 14 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SBT-70-G/B Product Datasheet Revision History Rev Date Description of Change 08 07/20/2015 Added Angular Distribution Pattern on Page 9 09 04/10/2016 Updated Vf min for SBT-70-G from 4.5V to 3.9V and typical Vf from 4.9V to 4.5V Corrected maximum current value to 14 A (2 A/mm2) on page 8 10 11/29/2022 Updated template, added DJ & DK flux bin, updated Typical Device Performance, added Soldering Profile, Ship­ping Tray Outline, Shipping Label Outline sections The products, their specifications and other information appearing in this document are subject to change by Luminus Devices without notice. Luminus Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product or information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of the product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices may have in such information. LEDs™ is a registered trademark of Luminus Devices, Inc., all rights reserved. This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871; 7,170,100; 7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059 Patents Pending in the U.S. and other countries. 15 PDS-002014 Rev 10 © 2022 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Ct. • Sunnyvale, CA 94086
SBR-70-B-R75-KF300 价格&库存
很抱歉,暂时无法提供与“SBR-70-B-R75-KF300”相匹配的价格&库存,您可以联系我们找货
