PT-54-B-L31-EPD
PT-54-B-L31-EPD
    LUMINUS(朗明纳斯)
    PT-54-B-L31-EPD
PT-54-B-L31-EPD 数据手册
PT-54-TE Product Datasheet PT-54-TE Thermally Enhanced LED Projection Chipset Features: Table of Contents Technology Overview. . . . . . 2 • Matched RGB Chipset with 5.4 mm2 emitting area designed for LED projector applications Understanding LED Test Specifications. . . . . 2 • Ultra low thermal resistance package enables high performance applications [operation up to 16.2 A (3A/mm2)]. Ordering Information . . . . . . 3 • High surface brightness and uniform surface emission Flux /Power Bin Definition. . 4 • Wide color gamut: Red-Amber 613 nm, Green 525 nm, Blue 460 nm typical dominant wavelength Optical & Electrical Characteristics. . . . . . . . . . . 5- 6 Blue Flux Bin Ranges by Wavelength . . . . . . . . . . . . . . . 7 Characterization Curves. . . . .8 Optical Spectrum . . . . . . . . . . 9 • Single emitting area per color allows for collection with single lens for simplified optics • High precision LED placement on copper core PCB for easier thermal management and optical integration • Environmentally friendly: RoHS and REACH compliant Angular Intensity Distribution. . . . . . . . . . . . . . . . 9 Thermal Resistance . . . . . . . 10 Mechanical Dimensions. . . . . . . . . . . 11 - 12 Shipping Tray Outline . . . . . 13 Applications Packing and Shipping Specifications . . . . . . . . . . . . 14 • Specifically engineered for high brightness projectors, including pocket-size, ultra portable projectors, hybrid projectors and head-up projection displays. History of Changes. . . . . . . . 15 • Optimized for Micro-Display diagonal sizes ranging from 0.4” to 0.6”. • Suitable for DLP™ , LCoS and HTPS /3LCD microdisplays. 1 PDS-002026 Rev 07 © 2016 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT-54-TE Product Datasheet Technology Overview Luminus LEDs benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and system designers to achieve solutions that are high brightness and high efficiency. Packaging Technology Environmental Benefits Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 0.7º C/W, Luminus PT-54 LEDs can be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All products manufactured by Luminus are RoHS and REACH compliant and free of hazardous materials, including lead and mercury. Reliability For high power operation, Luminus LEDs are one of the most reliable light sources in the world today. All products have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus LEDs are ready for even the most demanding applications. (Please refer to Luminus’ Reliability application note for more information.) Understanding LED Test Specifications Every Luminus LED is extensively tested at full current to ensure that it meets the high quality standards expected from Luminus’ products. Testing of Luminus LEDs Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus LEDs perform in the field just as they are specified. 2 PDS-002026 Rev 07 © 2016 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT-54-TE Product Datasheet Ordering Information Ordering Part Number 1 Min Flux or Power Bin 2 Color PT-54-RAX-L35-MPH 4H PT-54-RAX-L35-MPJ 4H Red-Amber (Common Cathode) PT-54-RAX-L35-MPK PT-54-RAX-L35-MPL 4J 4K PT-54-RAX-L35-MPM 4L PT-54-RAX-L35-MPN 4L PT-54-G-L31-MPH 4G PT-54-G-L31-MPJ PT-54-G-L31-MPK Green 4H 4J PT-54-G-L31-MPL 4K PT-54-B-L31-EPD 4F PT-54-B-L31-EPE Blue PT-54-B-L31-EPF PT-54-B-L31-EPG 4G 4H Description Red-Amber LED, consisting of a 5.4 mm2 Red-Amber LED chip, thermistor and connector mounted on a copper-core PCB (Common Cathode). Green LED, consisting of a 5.4 mm2 Green LED chip and connector mounted on a copper-core PCB. Blue LED, consisting of a 5.4 mm2 Blue LED chip and connector mounted on a copper-core PCB. 4J Note 1: Ordering part numbers represent bin kits (group of bins that are shippable for a given ordering part number) Note 2: See Bin Kit and Flux / Power bin definitions on page 4 Ordering Part Number Nomenclature PT mm Product Family PT: Metal Coreboard PCB Note 1: XXXX L3X XYZ Color Package Configuration Bin Kit 1 L31: 26.5mm x 16.0 mm (common anode package,10-pin connector) L35: 26.5mm x 16.0 mm (common cathode package,10-pin connector) See page 4 for bin kit definition Chip Area 54: 5.4 mm2 RAX= Red-Amber G= Green B= Blue See Mechanical Drawing section A Bin Kit represents a group of individual flux or power bins that are shippable for a given ordering part number. Individual flux bins are not orderable. EXAMPLES: PT-54-G-L31-MPJ i s comprised of Red-Amber Flux Bins 4H, 4J, 4K, 4L, 4M. 3 PDS-002026 Rev 07 © 2016 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT-54-TE Product Datasheet PT-54 Bin Kit1 and Flux Bin2,3,4,5 Definitions Note: Please refer to ordering part number table on page 3 for Bin Kit availability RAX (common cathode) Flux Bins Bin 4H Bin 4J Bin 4K Bin 4L Bin 4M Bin 4N Bin 4P Bin 4Q RAX Bin Flux Range4 (lm) 10551125 11251200 12001275 12751355 13551435 14351520 15201610 16101700 PT-54-RAX-L35-MPH þ þ þ þ þ PT-54-RAX-L35-MPJ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-54-RAX-L35-MPM þ þ þ þ PT-54-RAX-L35-MPN þ þ þ þ þ PT-54-RAX-L35-MPK PT-54-RAX-L35-MPL Green Flux Bins Bin 4G Bin 4H Bin 4J Bin 4K Bin 4L Bin 4M Bin 4N Bin 4P Green Bin Flux Range4 (lm) 19002000 20002150 21502300 23002450 24502625 26252800 28003000 30003200 þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-54-G-L31-MPH PT-54-G-L31-MPJ PT-54-G-L31-MPK PT-54-G-L31-MPL Blue Flux Bins Bin 4F Bin 4G Bin 4H Bin 4J Bin 4K Bin 4L Bin 4M Blue Bin Flux Range5 (lm) 350-375 375-400 400-440 440-475 475-510 510-550 550-590 þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ þ PT-54-B-L31-EPD PT-54-B-L31-EPE PT-54-B-L31-EPF PT-54-B-L31-EPG þ Note 1: Bin Kits are defined by a group of flux or power bins. Only one flux bin will be shipped in each individual pack. A shipment will contain packs of different allowed flux bins for a particular ordering part number. Individual Flux or Power bins are not orderable. Note 2: PT-54 LEDs are tested for luminous flux at 13.5 A at 25% duty cycle for Red, Red-Amber and Blue; and at 50% duty cycle for Green Devices. Devices are sorted and packed by flux bin. Not all flux bins are currently populated. Note 3: Luminus maintains a test measurement accuracy for LED flux and power of +/- 6%. Note 4: Red and Green Flux bin limits apply across entire dominant wavelength range. Dominant wavelength range for Red Amber and Green devices are specified on the Optical & Electrical Characteristics section. Note 5: Blue Flux bin limits are defined at reference dominant wavelength of 462 nm. See table on page 7 for Blue bin limits at other dominant wavelengths. 4 PDS-002026 Rev 07 © 2016 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT-54-TE Product Datasheet Optical & Electrical Characteristics General Characteristics Symbol Emitting Area Emitting Area Dimensions Characteristics at Reference Test Drive Current , If (Common Cathode) Green Blue Unit 5.4 5.4 5.4 mm2 2.7 x 2.0 2.7x 2.0 2.7x 2.0 mmxmm 25 50 25 % 1, 2 Reference Duty Cycle 3 Test Peak Drive Current Red-Amber typ IF 13.5 13.5 13.5 A Peak Luminuous Flux 1,2,5 typ Φv 1485 2250 400 lm Peak Radiometric Flux 1,2 typ Φr 5.3 4.8 9.0 W Dominant Wavelength min λdmin 609 516 450 nm typ λd 613 525 460 nm max λdmax 620 540 468 nm 19 34 20 nm 1,2,4 FWHM- Spectral bandwidth at 50% of Φv typ Chromaticity Coordinates 6,7 typ x 0.676 0.167 0.147 typ y 0.323 0.704 0.033 min VF min 2.7 3.5 3.0 V typ VF 3.0 5.2 3.7 V max VF max 3.7 5.9 4.5 V typ 0.05 0.08 0.05 Ω Thermal Coefficient of Photometric Flux typ -1.0 -0.2 ~0 % / oC Thermal Coefficient of Radiometric Flux typ -0.65 -0.2 -0.2 % / oC Forward Voltage Temperature Coefficient typ -2.0 -3.3 -3 mV/ oC Forward Voltage Dynamic Resistance Device Thermal Characteristics Characteristics at Reference Continuous Drive Current IF (continuous wave)1 Reference Drive Current typ IF 8.1 8.1 8.1 A Luminous Flux typ Φv 830 1590 290 lm Radiometric Flux typ Φr 3.0 3.2 5.9 W Dominant Wavelength typ λd 613 528 461 nm 18 36 21 nm FWHM -Spectral bandwidth at 50% of Φv typ Chromaticity Coordinates typ x 0.675 0.177 0.144 nm typ y 0.324 0.713 0.034 nm typ VF 2.7 4.7 3.3 V 6,7 Forward Voltage 5 PDS-002026 Rev 07 © 2016 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 175 New Boston Street • Woburn, MA 01801 PT-54-TE Product Datasheet Optical & Electrical Characteristics Note 1: All ratings are based on testing conditions with a constant heat sink temperature Ths = 40ºC. See Thermal Resistance section for Ths definition. Note 2: Parameters rated at test duty cycle and Pulsed operation frequency f>240 Hz; DC = --t- t T T Note 3: Duty Cycle used to specify device ratings under Pulsed operation. LED devices can operate at duty cycles ranging from 1% to 100%. At higher duty cycles, drive current should be adjusted to maintain the junction temperature at desired levels to meet the application lifetime requirements. Note 4: In pulsed operation, rise time from 10 to 90% of forward current should be larger than 0.5 microseconds Note 5: For Blue devices, total flux from emitting area at typical dominant wavelength. Refer to page 7 for brightness specifications at other wavelength Note 6: CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1 Note 7: For Reference only Absolute Maximum Ratings Symbol Red-Amber (Common Cathode) Green Blue Unit Absolute Minimum Current (CW or Pulsed)1 200 200 200 mA Absolute Maximum Current (CW) 11.9 11.9 11.9 A Absolute Maximum Current (Pulsed) (frequency > 240Hz, duty cycle 240 Hz, duty cycle =10%, t=1ms) 18.9 18.9 18.9 A 2 2,3 Maximum Operating Junction Temperature 4 Tj 100 140 130 o Absolute Maximum Junction Temperature 4 Tj abs. max 125 170 170 o -40 / +100 -40 / +100 -40 / +100 o Storage Temperature Range C C C Note 1: Product performance and lifetime data is specified at recommended forward drive currents. Sustained operation at or near absolute minimum currents may result in a reduction of device performance and device lifetime compared to recommended forward currents. Note 2: Maximum forward drive current conditions for continuous operation are 11.9 A, CW (2.2 A/mm2 ), and 16.2 A, f>240 Hz, duty cycle
PT-54-B-L31-EPD 价格&库存
很抱歉,暂时无法提供与“PT-54-B-L31-EPD”相匹配的价格&库存,您可以联系我们找货
