SBR-90-WDLS-R71-NB150
    LUMINUS(朗明纳斯)
    Module
SBR-90-WDLS-R71-NB150 数据手册
SBT-90 Product Datasheet SBT-90 LEDs Features: • Extremely high optical output from a 9 mm2 square emitter: Table of Contents • Up to 2300 lumens at 13.5A from a single chip (White) • Over 1,600 lumens at 13.5A (Red) Technology Overview. . . . . . 2 Binning Structure. . . . . . . . . . 3 Chromaticity Bins. . . . . . . . . . 4 Product Shipping & Labeling Information. . . . . . . 5 Ordering Information . . . . . . 6 Electrical Characteristics. . . 7 • Choice of 5700K or 6500K color point • High thermal conductivity package - junction to case thermal resistance of only 0.5 °C/W • Large, monolithic chip with uniform emitting area of 9 mm2 • Unencapsulated die with low profile protective window optimizes optical coupling in etendue-limited applications • Electrically isolated thermal path • Environmentally friendly: RoHS compliant Optical Characteristics. . . . . 8 White Characteristics. . . . . . . 9 Radiation Patterns . . . . . . . . 10 Applications Output vs Temp ,Lifetime and Spectrum. . . . . . . . . . . . . . . . . 11 • Fiber-coupled illumination Mechanical Dimensions . . . 12 • Architectural and Entertainment lighting Solder Profile . . . . . . . . . . . . . 14 • Projection and micro-display based applications 1 PDS-001540 Rev 16 © 2020 Luminus Devices, Inc. - All Rights Reserved • High-Brightness and large format LCD back-light units • Edge-illuminated lighting guides • High output, Etendue-limited lighting applications Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SBT-90 Product Datasheet Technology Overview Luminus LED benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Luminus Technology Luminus’ technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. Designed from the ground up, Luminus LEDs are one of the most reliable light sources in the world today. They have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus LEDs are ready for even the most demanding applications. Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to heat sink of 0.5º C/W, Luminus SBT-90 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Environmental Benefits Luminus LEDs Whitehelp reduce power consumption and the amount of hazardous waste entering the environment. All Luminus LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Reliability Understanding Luminus LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Multiple Operating Points Luminus surface mount LEDs are typically tested with a 20 msec input pulse and a junction temperature of 25ºC. Expected flux values in real world operation can be extrapolated based on the information contained within this product data sheet. The tables on the following pages provide typical optical and electrical characteristics. Since the LEDs can be operated over a wide range of drive conditions (currents from less than 1A to 13.5A, and duty cycle from
SBR-90-WDLS-R71-NB150 价格&库存
很抱歉,暂时无法提供与“SBR-90-WDLS-R71-NB150”相匹配的价格&库存,您可以联系我们找货
