PT-40-G-L51-MPJ
PT-40-G-L51-MPJ
    LUMINUS(朗明纳斯)
    Module
    PT-40-G-L51-MPJ
PT-40-G-L51-MPJ 数据手册
PT-40-TE Product Datasheet Preliminary PT-40-TE Product Datasheet PT-40-TE LED™ Thermally Enhanced LED Projection Chipset Features: Table of Contents Technology Overview. . . . . . . . . . 2 Understanding Luminus Test Specifications. . . . . . . . . . . . . . . . . . 2 • Matched RGB Chipset with 2.4 mm x 1.6 mm (3.9 mm2) emitting area designed for LED projector applications • Ultra low thermal resistance, copper-core PCB package Ordering Information . . . . . . . . . . 3 • Wide color gamut: Red-Amber 613 nm, Green 525 nm, Blue 460 nm typical dominant wavelength Flux /Power Bin Definition. . . . . . 4 • Single emitting area per color allows for collection with single lens for simplified optics Optical & Electrical Characteristics. . . . . . . . . . . . . . . 5- 6 • LED mounted on MC-PCB for easier thermal and optical integration Blue Flux Bin Ranges by Wavelength . . . . . . . . . . . . . . . . . . . 7 • LED emitting area optimized and compatible with micro-display diagonal sizes ranging from 0.45” to 0.55” • Environmentally friendly: RoHS and REACH compliant Characterization Curves. . . . . . . . 8 Spectrum and Angular Intensity Distribution. . . . . . . . . . . 9 Thermal Resistance and Electrical Pin Out. . . . . . . . . . . . . . 10 Mechanical Dimensions. . . . . . . 11 Shipping Tray Outline . . . . . . . . . 12 Applications Packing and Shipping Specifications . . . . . . . . . . . . . . . . 13 • Specifically engineered for high brightness pocket-size, ultra portable front projectors, head-up projection displays and hybrid projectors History of Changes. . . . . . . . . . . . 14 • Optimized for Micro-Display diagonal sizes ranging from 0.45” to 0.55” • Suitable for DLP™ ( 0.45” WXGA), LCoS and HTPS /3LCD microdisplays 1 PDS-002100 Rev 03 © 2014 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT-40-TE Product Datasheet Technology Overview Luminus LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and system designers to achieve solutions that are high brightness and high efficiency. Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 1.0º C/W, Luminus PT-40 LEDs can be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Environmental Benefits Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All Luminus LED products manufactured by Luminus are RoHS and REACH compliant and free of hazardous materials, including lead and mercury. Reliability For high power operation, Luminus LEDs are one of the most reliable light sources in the world today. Luminus LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus LEDs are ready for even the most demanding applications. (Please refer to Luminus’ Reliability application note for more information.) Understanding Luminus LED Test Specifications Every Luminus LED is extensively tested at rated current to ensure that it meets the high quality standards expected from Luminus products. Testing of Luminus LEDs Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40º C heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus LEDs perform in the field just as they are specified. 2 PDS-002100 Rev 03 © 2014 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT-40-TE Product Datasheet Ordering Information Ordering Part Number 1 PT-40-RAX-L55-MPH PT-40-RAX-L55-MPJ PT-40-G-L51-MPH PT-40-G-L51-MPJ Min Flux or Power Bin 2 Color Red-Amber 2J 2H Blue PT-40-B-L51-EPJ 2J 2H Green PT-40-B-L51-EPH 2H 2J Description Red-Amber LED, consisting of a 3.9 mm2 Red-Amber LED chip and connector mounted on a copper-core PCB (note: reverse polarity pin-out). Green LED, consisting of a 3.9 mm2 Green LED chip and connector mounted on a copper-core PCB. Blue LED, consisting of a 3.9 mm2 Blue LED chip and connector mounted on a copper-core PCB. Note 1: Ordering part numbers represent bin kits (group of bins that are shippable for a given ordering part number) Note 2: See Bin Kit and Flux / Power bin definitions on page 4 Ordering Part Number Nomenclature XXX 00 Product Family PT: Metal Coreboard PCB Note 1: XXXX X00 XXX Chip Area Color Package Configuration Bin Kit 1 40: 3.9 mm2 RAX= Red -Amber (613nm, typ) G= Green B= Blue L51: 21.85 mm x 15.0 mm (See Mechanical Drawing section) See page 4 for bin kit definition A Bin Kit represents a group of individual flux or power bins that are shippable for a given ordering part number. Individual flux bins are not orderable. EXAMPLE: PT-40-G-L51-MPH i s comprised of Green Flux Bins 2H, 2J, 2K, 2L, 2M 3 PDS-002100 Rev 03 © 2014 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT-40-TE Product Datasheet PT-40 Bin Kit1 and Flux Bin2,3 ,4 Definitions Note: Please refer to ordering part number table on page 3 for Bin Kit availability Red -Amber Flux Bins Bin 2H Bin 2J Bin 2K Bin 2L Bin 2M Red -Amber Bin Flux Range (lm) 800860 860925 925990 9901055 10551125 þ þ þ þ þ þ þ þ PT-40-RAX-L55-MPH PT-40-RAX-L55-MPJ Green Flux Bins Bin 2H Bin 2J Bin 2K Bin 2L Bin 2M Bin 2N Green Bin Flux Range (lm) 1450 -1550 1550 -1660 1660 -1780 1780 -1900 1900 -2020 2020 -2150 þ þ þ þ þ þ þ þ þ þ Blue Flux Bins Bin 2H Bin 2J Bin 2K Bin 2L Bin 2M Bin 2N Blue Bin Flux Range (lm) 280300 300320 320345 345370 370400 400430 þ þ þ þ þ þ þ þ þ PT-40-G-L51-MPH PT-40-G-L51-MPJ PT-40-B-L51-EPH PT-40-B-L51-EPJ þ Note 1: Bin Kits are defined by a group of flux or power bins. Only one flux bin will be shipped in each individual pack. A shipment will contain packs of different allowed flux bins for a particular ordering part number. Individual Flux or Power bins are not orderable. Note 2: PT-40 LEDs are tested for luminous flux at 9.8 A at 25% duty cycle for Red-Amber and Blue, and at 50% duty cycle for Green Devices. Devices are sorted and packed by flux bin. Not all flux bins are currently populated. Note 3: Luminus maintains a test measurement accuracy for LED flux and power of +/- 6%. Note 4: Blue Flux bin limits are defined at reference dominant wavelength of 462 nm. See table on page 7 for Blue bin limits at other dominant wavelengths. 4 PDS-002100 Rev 03 © 2014 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT-40-TE Product Datasheet Optical & Electrical Characteristics General Characteristics Symbol Red -Amber Emitting Area Emitting Area Dimensions Preliminary Preliminary Green Preliminary Blue Unit 3.9 3.9 3.9 mm2 2.42 x 1.61 2.42 x 1.61 2.42 x 1.61 mmxmm 25 50 25 % Characteristics at Recommended Test Drive Current , If 1, 2 Reference Duty Cycle 3 Test Peak Drive Current typ IF 9.8 9.8 9.8 A Peak Luminuous Flux 1,2,5 typ Φv 860 1750 300 lm Peak Radiometric Flux 1,2 typ Φr 3.0 3.5 6.2 W min λdmin 609 516 450 nm typ λd 613 525 460 nm max λdmax 620 540 468 nm 19 34 20 nm 1,2,4 Dominant Wavelength FWHM- Spectral bandwidth at 50% of Φr typ typ x 0.675 0.167 0.147 typ y 0.325 0.704 0.033 min VF min 2.7 3.5 3.2 V typ VF 3.1 5.1 3.8 V max VF max 3.7 5.9 5.2 V typ 0.13 0.12 0.09 Ω Thermal Coefficient of Photometric Flux typ -1 -0.2 ~0 % / oC Thermal Coefficient of Radiometric Flux typ -0.7 -0.2 -0.2 % / oC Forward Voltage Temperature Coefficient typ -2 -4.7 -3 mV/ oC Chromaticity Coordinates 6,7 Forward Voltage Dynamic Resistance Device Thermal Characteristics Note 1: All ratings are based on testing conditions with a constant heat sink temperature Ths = 40º C. See Thermal Resistance section for Ths definition. Note 2: Parameters rated at test duty cycle and Pulsed operation frequency f>240 Hz; DC = --t- t T T Note 3: Duty Cycle used to specify device ratings under Pulsed operation. Big Chip LED devices can operate at duty cycles ranging from 1% to 100%. At higher duty cycles, drive current should be adjusted to maintain the junction temperature at desired levels to meet the application lifetime requirements. Note 4: In pulsed operation, rise time from 10% to 90% of forward current should be larger than 0.5 microseconds. Note 5: For Blue devices, total flux from emitting area at typical dominant wavelength. Refer to page 7 for brightness specifications at other wavelengths. Note 6: CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1. Note 7: For reference only. 5 PDS-002100 Rev 03 © 2014 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 PT-40 Product Datasheet Optical & Electrical Characteristics Absolute Maximum Ratings (Preliminary) Symbol Red -Amber Green Blue Unit 200 200 200 mA 8.6 8.6 8.6 A Absolute Maximum Current (Pulsed) 2,3 ( frequency > 240Hz, duty cycle 240 Hz, duty cycle =10%, t=1ms) 13.7 13.7 13.7 A Tjmax, op 100 140 130 o Tjmax 125 170 170 o -40 / +100 -40 / +100 -40 / +100 o Absolute Minimum Current (CW or Pulsed) 1 Absolute Maximum Current (CW) 2 Maximum Operating Junction Temperature 4 Absolute Maximum Junction Temperature 4 Storage Temperature Range C C C Note 1: Product performance and lifetime data is specified at recommended forward drive currents. Sustained operation at or near absolute minimum currents may result in a reduction of device performance and device lifetime compared to recommended forward currents. Note 2: Maximum forward drive current conditions for continuous operation are 8.6 A, CW (2.2 A/mm2 ), and 11.7 A, f>240 Hz, duty cycle
PT-40-G-L51-MPJ 价格&库存
很抱歉,暂时无法提供与“PT-40-G-L51-MPJ”相匹配的价格&库存,您可以联系我们找货
PT-40-G-L51-MPJ
  • 50+466.2340850+60.52477
