SBT-90 Binning and Labeling
SBT-90 LEDs
Table of Contents
Table of Products. . . . . . . . . . . 2
Shipping and Labeling
Nomenclature . . . . . . . . . . . . . 3
Bin Kit Ordering
Nomenclature . . . . . . . . . . . . . 4
Flux Binning
Structure . . . . . . . . . . . . . . . . . . 5
Chromaticity
Binning Structure. . . . . . . . . . 5
Introduction:
This document describes the binning and labeling nomenclature for SBT-90 specialty LED
product as well as the orderable bin kits for each part.
With each build of parts, there is a distribution of performance in both flux and wave
length or chromaticity. In order to guarantee specific performance for customers, each
device is measured and subsequently grouped into flux and wavelength or chromaticity
bins. Each individual package or reel of parts contains only one combination of flux and
wavelength or chromaticity bin. Furthermore, bins are combined into orderable bin kits
comprising of a selection of flux and wavelength or chromaticity bins to ease the
ordering process.
SBT-90 Bin Kit Codes. . . . . . . . 7
1
PDS-001788 Rev 12
© 2020 Luminus Devices, Inc. - All Rights Reserved
Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com
1145 Sonora Court • Sunnyvale, CA 94086
SBT-90
(Part #)Binning
Product
and
Datasheet
Labeling
Table of Products
Products
Ordering Part Number
SBT-90-W57S
SBT-90-W57S-F71-XX123
SBT-90-W65S
SBT-90-W65S-F71-XX123
SBT-90-WDLS
SBT-90-WDLS-F71-XX123
SBR-90-W57S
SBR-90-W57S-R71-XX123
SBR-90-W65S
SBR-90-W65S-R71-XX123
SBR-90-WDLS
SBR-90-WDLS-R71-XX123
Description
White specialty LED SBT-90 surface mount device consisting of a 9 mm2 LED on a
ceramic subtrate, tray pack
SBR-90 evaluation module consisting of a SBT-90 surface mount device mounted
on an aluminum star-board
SBT-90-R
SBT-90-R-F75-xx123
SBT-90 surface mount device consisting of a 9.0 mm2
LED on ceramic substrate
SBR-90-R
SBR-90-R-R75-xx123
mounted on an aluminum star board
2
PDS-001788 Rev 12
SBT-90 Shipping and Labeling Nomenclature
All SBT-90 products are packaged and labeled with their respective bin as outlined in the following pages. Each package or reel will only
contain one bin. The part number designation is as follows:
A B C
1 2 3
Chip Area
D 4 5 E
Color
F 6 7
Chip Area
Package
Config.
D - Color: “W” denotes white
4 5 - Color temperature: “65” denotes 6500K; “57” denotes 5700K
E - Color rendering: “S” (standard) denotes a typical CRI of 70
Flux Bin
G H
Flux Bin
I8
Chromaticity Bin
A - Package type: “S” denotes surface mount
B - Lens type: “B” denotes window (no lens)
C - Chip quantity: “T” denotes single chip, and “R” denotes prototyping board
1 2 3 - Total LED chip area (mm2) x 10: “90” denotes 9mm2
Chromaticity
Bin
Package Configuration
Color
Product
Family
Product Family
F 6 7 - Package configuration (for internal use)
G H - Flux bin
I 8 - Chromaticity bin
Example:
The part number SBT-90-W65S-F71-NA-G4 refers to a 6500K standard CRI white, SBT-90 emitter, with a minimum flux range from
1,590 to 1,710 lumens and a chromaticity value within the box defined by the four points (0.313, 0.338), (0.321, 0.348), (0.322, 0.336),
(0.312, 0.328).
3
PDS-001788 Rev 12
SBT-90 Bin Kit Ordering Nomenclature
All SBT-90 White products are sold in sets of flux and chromaticity bins called bin kits. Each bin kit specifies a minimum flux bin and a
specific selection of chromaticity bins. The ordering part number designation is as follows:
A B C
1 2 3
Chip Area
D 4 5 E
Color
Chip Area
Package
Config.
Bin Kit
F 6 7
G H 8 9 0
Bin Kit
Color
Product
Family
Product Family
G H - Flux bin
8 9 0 - Chromaticity bin kit code
Example:
The ordering part number SBT-90-W65S-F71-NA101 refers to a 6500K standard CRI white, SBT-90 emitter, with a minimum flux value of
1,590 lumens and falling in the F4, F3, G4, G3, EF, and DG chromaticity bins.
4
PDS-001788 Rev 12
SBT-90 Binning Structure
SBT-90 LEDs are tested for luminous flux and chromaticity at a drive current as listed in the table and placed into one of the following
luminous flux (FF) and chromaticity (WW) bins:
Color
W57S / W65S
5700K / 6500K, Standard CRI (typ. 70)
Flux Bin (FF)
Minumum Flux (lm) @
9.0A
Maximum Flux (lm) @
9.0A
NA
1,590
1,710
NB
1,710
1,830
PA
1830
1966
PB
1966
2100
QA
2100
2260
QB
2260
2420
RA
2420
Minumum Flux (lm) @
13.5A
2600
Minumum Flux (lm) @
13.5A
Flux Bin (FF)
Red
Color
Red
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
BM
770
970
BN
970
1150
BP
1150
1350
BQ
1350
1570
BR
1570
1850
Wavelength Bin (FF)
Minimum Wavelength
@ 13.5A
Maximum Wavelength
@ 13.5A
R3
615
619
R4
619
623
R5
623
627
Luminus maintains a +/- 2% tolerance on CRI measurements.
Chromaticity Bins
Luminus’ Standard Chromaticity Bins: 1931 CIE Curve
5
PDS-001788 Rev 12
The following tables describe the four chromaticity points that bound each chromaticity bin. Chromaticity bins are grouped together
based on the color temperature.
6500K Chromaticity Bins
Bin Code
(WW)
DG
F3*
F4*
G3*
G4*
EF
DE
DF
5700K Chromaticity Bins
CIEx
CIEy
0.307
0.322
0.323
0.316
0.309
0.302
0.305
0.313
0.315
0.319
0.307
0.311
0.303
0.312
0.313
0.329
0.305
0.313
0.321
0.337
0.322
0.326
0.315
0.312
0.321
0.348
0.321
0.337
0.313
0.302
0.320
0.354
0.321
0.348
0.303
0.330
0.283
0.304
0.303
0.330
0.307
0.311
0.289
0.293
0.289
0.293
0.307
0.311
0.309
0.302
0.293
0.285
Bin Code
(WW)
CIEx
CIEy
0.311
0.322
0.324
0.326
0.337
0.337
0.336
0.326
0.323
0.314
0.321
0.321
0.335
0.329
0.329
0.342
0.329
0.331
0.322
0.324
0.330
0.321
0.346
0.339
0.329
0.354
0.329
0.342
0.321
0.321
0.335
0.329
0.329
0.342
0.337
0.349
0.337
0.337
0.319
0.330
0.331
0.339
0.329
0.354
0.338
0.362
0.337
0.349
0.329
0.329
0.342
0.335
0.320
0.352
0.338
0.368
0.338
0.362
0.321
0.346
DJ
H3*
H4*
J3*
J4*
EH
*Sub-bins within ANSI defined quadrangles per ANSI C78.377-2008
6
PDS-001788 Rev 12
SBT-90 and SBR-90 Bin Kit Order Codes
The following tables describe the bin kit ordering codes for the SBT-90 and SBR-90. The flux and chromaticity bins included in the bin kit.
Each kit specifies a minimum flux and the listed chromaticity bins. A maximum flux is not specified. Within each kit, Luminus may ship
any part meeting or exceeding the minimum flux specification. Shipments will always meet the listed chromaticity bins. For information
on ordering bin kits not listed below, please contact Luminus or an official distributor.
Luminous Flux
Color
Bin Kit Flux
Code
NA
White
W57S
5700K,
NB
Min. Flux
1,590
1,710
Chromaticity Bins
Kit Number
F4, F3, G4, G3, EF, DG, DE, DF
NA100
NA101
F4, F3, G4, G3
NA102
H3, H4, J3, J4, DJ, EH
NA200
NA100
NA101
F4, F3, G4, G3
NA102
NB200
H3, H4, J3, J4
NB202
Wavelength Bins
Kit Number
R3, R4, R5
HM100
R4
HM101
R3, R4, R5
HN100
R4
HN101
Luminous Flux
Color
Bin Kit Flux
Code
Min. Flux
HM
770
HN
970
Red
The products, their specifications and other information appearing in this document are subject to change by Luminus Devices without notice. Luminus
Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product or
information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of the
product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as
accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No
information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices
may have in such information. Big Chip LEDs™ is a registered trademark of Luminus Devices, Inc., all rights reserved.
This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871; 7,170,100;
7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059 Patents Pending in the U.S. and
other countries.
7
PDS-001788 Rev 12
