SBT-70-G/B
Product Datasheet
SBT-70-G/B
LEDs
Features:
Table of Contents
• Extremely high optical output from a 7 mm2 circular emitter:
• Over 2000 green lumens at 10 .5 A
• Over 200 blue lumens at 10 .5 A and 445 nm
Technology Overview. . . . . . 2
Ordering Information . . . . . . 3
Binning Structure. . . . . . . . . . 4
Typical Device
Performance. . . . . . . . . . . . . . . 5
Absolute Maximum
Ratings. . . . . . . . . . . . . . . . . . . . 6
Optical & Electrical
Characteristics... . . . . . . . . . . . 7
• Refer to SBT-90-R for companion red product
• Round emitting aperture provides most eficient match to circular optical systems and
narrow beam projectors
• Unencapsulated die with low proffile protective window optimizes optical coupling in
etendue-limited applications
• High thermal conductivity package - junction to case thermal resistance of only
0 .64°C/W
• Variable drive current up to 10 .5 A continuous wave . Up to 2 A/mm2 in pulsed
conditions
• RoHS and REACH compliant
Angular Distribution &
Typical Spectrum . . . . . . . . . . 9
Soldering Profile. . . . . . . . . . 10
Mechanical Dimensions. . . 11
Shipping Tray Outline . . . . . 13
Shipping Label. . . . . . . . . . . . 14
Revision History. . . . . . . . . . . 15
Applications
• Architectural and Entertainment
Lighting
• Machine Vision
• Fiber-coupled Illumination
• Spot Lighting
• Medical Lighting
1
PDS-002014 Rev 10
• Microscopy
© 2022 Luminus Devices, Inc. - All Rights Reserved
Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com
1145 Sonora Ct. • Sunnyvale, CA 94086
SBT-70-G/B
Product Datasheet
Technology Overview
Luminus LEDs™ benefit from a suite of innovations in the fields of LED die technology, packaging and thermal management. These
breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency.
Luminus Technology
Reliability
Luminus’ technology enables large area LED chips with uniform
brightness over the entire LED chip surface. The optical power
and brightness produced by these large monolithic chips enable
solutions which replace arc and halogen lamps where arrays of
traditional high power LEDs cannot.
This product is sensitive to static electricity, and care should
be taken when handling them. Static electricity or surge voltage will damage the LEDs. It is recommended to wear an antielectrostatic wristband or anti-electrostatic gloves when handling the LEDs. All devices, equipment and machinery must be
properly grounded. It is recommended that measures be taken
to isolate LED processing equipment from potential sources of
voltage surges.
Packaging Technology
Reference: APN-002815 Electrical Stress Damage to LEDs and
How to Prevent It
Thermal management is critical in high power LED applications.
With a thermal resistance from junction to case of 0.64°C/W,
Luminus SBT-70 LEDs have the lowest thermal resistance of any
LED on the market. This allows the LED to be driven at higher
current densities while maintaining a low junction temperature,
thereby resulting in brighter solutions and longer lifetimes.
Environmental Benefits
Luminus LEDs help reduce power consumption and the amount
of hazardous waste entering the environment. All LED products
manufactured by Luminus are RoHS compliant and free of
hazardous materials, including lead and mercury.
Understanding Big Chip LED Test Specifications
Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products.
Testing Temperature
Luminus surface mount LEDs are typically tested with a 20 ms single pulse and a case temperature of 25°C. Expected flux values in real
world operation can be extrapolated based on the information contained within this product data sheet.
2
PDS-002014 Rev 10
SBT-70-G/B
Product Datasheet
The table below lists ordering part numbers available for SBT-70 LEDs. The part number includes a bin kit, a group of flux and wavelength
bins described in page 4, that are shippable for a given ordering part number.
Ordering Part Numbers
Luminous Flux
Color
Bin Code
JK
Min. Flux (lm)
1500
Green
JM
2000
DF
120
DG
160
Blue
Wavelength Bin Code
G4, G5, G6, G7
SBT-70-G-F75-JK200
G4, G5
SBT-70-G-F75-JK201
G6, G7
SBT-70-G-F75-JK202
G4, G5, G6, G7
SBT-70-G-F75-JM200
G4, G5
SBT-70-G-F75-JM201
G6, G7
SBT-70-G-F75-JM202
B1, B2, B3, B4
SBT-70-B-F75-KF300
B2, B3
SBT-70-B-F75-KF301
B1, B2, B3, B4
SBT-70-B-F75-KG300
B2, B3
SBT-70-B-F75-KG301
Part Number Nomenclature
SBT
Product Family
70
Chip Area
SBT: Surface Mount
(window)
7.0 mm2
SBR: mounted on an aluminum star board
F75
Color
Package Configuration
G: Green
F75: SBT package
B: Blue
R75: SBR package
Bin kit
Flux and Wavelength bin
kit code - See ordering
information
Note 1: Flux Bin listed is minimum bin shipped, higher bins may be included at Luminus’ discretion.
3
PDS-002014 Rev 10
SBT-70-G/B
Product Datasheet
SBT-70 G/B Binning Structure
SBT-70 monochromatic LEDs are tested for luminous flux and dominant wavelength at a 10.5 A (1.5 A/mm2) drive current and placed into
one of the following flux and wavelength bins. The binning structure is universally applied across each monochromatic color.
Flux Bins
Color
Green
Blue
Luminous Flux Bin (FF)3
Binning @ 10.5 A, Tc= 25°C ⁵
Minimum Flux (lm)
Maximum Flux (lm)
CK
1500
2000
CM
2000
2300
CN
2300
2600
DF
120
160
DG
160
200
DH
200
250
DJ
250
350
DK
350
450
Wavelength Bins
Color
Green
Blue
Minimum Flux (lm)
Maximum Flux (lm)
G4
520
525
G5
525
530
G6
530
535
G7
535
540
B1
435
440
B2
440
445
B3
445
450
B4
450
455
Note 1: Luminus maintains a +/- 6% tolerance on flux measurements.
Note 2: Products are production tested then sorted and packed by bin.
Note 3: Individual bins are not orderable. Please refer to the Product Ordering information page for a list of orderable bin kits.
Note 4: Product test condition: 10.5 A DC, 25°C constant case temperature.
Note 5: Tc = Case Temperature.
4
PDS-002014 Rev 10
SBT-70-G/B
Product Datasheet
Typical Device Performance
General Characteristics
Symbol
Green
Blue
Unit
Emitting Area
Ae
7.0
7.0
mm2
Emitting Area (Diameter)
De
3
3
mm
Characteristics at Recommended Test Drive Current , If 1, 2,3
Current Density
typ
j
1.5
1.5
A/mm2
Test Peak Drive Current
typ
If
10.5
10.5
A
Peak Luminous Flux 4
typ
Φv
2100
245
lm
Peak Radiometric Flux
typ
Φr
10.5
W
Dominant Wavelength 6
typ
λd
530
447
nm
FWHM- Spectral bandwidth at 50% of Φv
typ
Δλ1/2
32
19
nm
typ
x
0.182
0.160
typ
y
0.732
0.017
min
VF min
3.9
2.8
V
typ
VF
4.5
3.2
V
max
VF max
5.3
4.2
V
Thermal Resistance of junction to coreboard ⁸
typ
Rθj-b
0.64
0.64
°C / W
Thermal Resistance of junction to case 8
typ
Rθj-c
2.02
2.02
°C / W
Thermal Resistance of junction to heat sink 8
typ
Rθj-hs
2.15
2.15
°C / W
Thermal Coefficient of Photometric Flux
typ
-0.2
-0.2
% / °C
Thermal Coefficient of Radiometric Flux
typ
-0.2
-0.2
% / °C
Thermal Coefficient of Junction Voltage
typ
-4.6
-3.5
mV / °C
Chromaticity Coordinates 5, 6
Forward Voltage
Device Thermal Characteristics 9
For notes see page 6.
5
PDS-002014 Rev 10
(Part #) Product SBT-70-G/B
Datasheet
Product Datasheet
Absolute Maximum Ratings
Symbol
Green
Blue
Unit
Absolute Minimum Current
0.2
0.2
A
Absolute Maximum Current
14
14
A
150
150
°C
-40/+100
-40/+100
°C
Absolute Maximum Junction Temperature 11
Tjmax
Storage Temperature Range
Note 1: Listed drive conditions are typical for common applications. SBT-70 G,B devices can be driven at currents ranging from 1 A to 10.5 A and at duty
cycles ranging from 1% to 100%. Drive current and duty cycle should be adjusted as necessary to maintain the junction temperature desired to
meet application lifetime requirements.
Note 2: All ratings are based on a constant case temperature Tc = 25°C.
Note 3: Unless otherwise noted, values listed are typical. Devices are production tested and specified at 10.5 A. Other values are for reference only.
Note 4: Total flux from emitting area at listed dominant wavelength. Reported performance is included to show trends for a selected power level. For
specific minimum and maximum values, use bin tables. For product roadmap and future performance of devices, contact Luminus.
Note 5: In CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1.
Note 6: For reference only.
Note 7: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
Note 8: Measurements are in accordance with JEDEC 51-14. For more about thermal resistance calculation, please see https://luminusdevices.zendesk.
com/hc/en-us/articles/4416807960717-Thermal-Heatsink-Required-Rth-Calculator
Note 9: For more about calculating thermistor temperature, please see https://luminusdevices.zendesk.com/hc/en-us/articles/4412023747341-How-doI-determine-the-temperature-from-Luminus-on-board-ThermistorNote 10: Luminus LEDs are designed for operation to an absolute maximum current as specified above. Product lifetime data is specified at recommended
forward drive currents. Sustained operation at or beyond absolute maximum currents will result in a reduction of device lifetime compared to
recommended forward drive currents. Actual device lifetimes will also depend on junction temperature. Refer to the lifetime derating curves for
further information. In pulsed operation, rise time from 10-90% of forward current should be larger than 0.5 microseconds.
Note 11: Lifetime dependent on LED junction temperature. Input power and thermal system must be properly managed to ensure lifetime.
6
PDS-002014 Rev 10
SBT-70-G/B
Product Datasheet
Optical & Electrical Characteristics
Forward Current vs. Forward Voltage - Green
1.2
12.0
1.0
10.0
0.8
8.0
Current (A)
Relative Luminous Flux
Relative Luminous Flux vs. Forward Current - Green
0.6
0.4
0.2
0.0
6.0
4.0
2.0
1
2
3
4
5
6
7
8
9
0.0
10 11
Current (A)
Voltage (V)
Forward Current vs. Forward Voltage - Blue
1.2
15.0
1.0
12.5
0.8
10.0
Current (A)
Relative Luminous flux
Relative Luminous Flux vs. Forward Current - Blue
0.6
0.4
7.5
5.0
2.5
0.2
0.0
2.4 2.7 3.0 3.3 3.6 3.9 4.2 4.5 4.8 5.1
1
2
3
4
5
6
7
Current(A)
8
7
PDS-002014 Rev 10
9
10
11
0.0
2.0 2.2 2.4 2.6 2.8 3.0 3.2 3.4 3.6 3.8 4.0
Voltage (V)
Datasheet
Product Datasheet
Heat Sink Temperature vs. Relative Luminous Flux
Heat Sink Temperature vs. Relative Dominant Wavelength
Shift
Median Lifetime Estimate vs. Junction Temperature 1
Lumen Maintenance 2
Note 1: Median lifetime estimate as a function of junction temperature at 1.5 A/mm2 in continuous operation. Lifetime defined as time to 70% of initial
intensity. Based on preliminary lifetime test data. Data can be used to model failure rate over typical product lifetime.
Note 2: Lumen maintenance vs. time at 1.5 A/mm2 in continuous operation, case temperature equal to 25°C.
8
PDS-002014 Rev 10
SBT-70-G/B
Product Datasheet
Typical Spectrum
Iref = f(Φ); Tc = 25°C
Angular Intensity Distribution (Typical)
Φref = f(λ); If = 10.5 A; Tc = 25°C
9
PDS-002014 Rev 10
SBT-70-G/B
Product Datasheet
Soldering Profile
Peak Temperature (235 - 245°C)
Temperature
Liquidus Temperature, TL (SAC305 = 220°C)
Time Above Liquidus
(45 - 90 sec)
65 -> 200°C, 120 - 250 sec max
Preheat
RT to 150°C
1 - 2.5°C/sec
Soak
150°C to 180°C
0.4 - 1°C/sec
Reflow
180 to TL + 20°C
3 - 6°C/sec
Cool down
Peak to below 150°C
3 - 7°C/sec
Time
SMT Rework Guideline
Manual Hotplate Reflow
Heating Time
Hot Air Gun Reflow
< 60 sec
Hotplate Temperature
< 245°C
< 150°C
Note 1: Product complies to Moisture Sensitivity Level 3 (MSL 3)
Note 2: The numbers in the table are specific to SAC305. Luminus recommends using an SAC305 solder paste with a no-clean flux for RoHS compliant
products.
Note 3: During the pick and place process, axial forces on the dome (or window) should not exceed 0.5 Newtons (N)
Note 4: Use of a multi-zone IR reflow oven with a nitrogen blanket is recommended.
Note 5: Time-temperature profile of the reflow process showing the four functional profile zones are defined in IPC-7801. Temperature is referenced to
the center of the PCB.
Note 6: Luminus recommends to use the solder paste data sheet information as a starting point in time-temperature process development.
Note 7: These are general guidelines. Consult the solder paste manufacturer’s datasheet for guidelines specific to the alloy and flux combination used
in your application. For more information, please refer to: https://luminusdevices.zendesk.com/hc/en-us/articles/360060306692-How-do-IReflow-Solder-Luminus-SMD-ComponentsNote 8: For any technical questions about soldering process, please contact Luminus at techsupport@luminus.com.
Note 9: This part is not compatible with vapor phase reflow processes.
10
PDS-002014 Rev 10
1145 Sonora Ct., Sunnyvale, CA 94086 USA
SBT-70-G/B
Product Datasheet
Mechanical Dimensions – SBT-70 Emitter
11
PDS-002014 Rev 10
SBT-70-G/B
Product Datasheet
8
4
2
3
Mechanical Dimensions – SBT-70 Star Board
5
6
7
5
6
7
4
2
3
DESCRIPTION OF CHANGE
REV ECO
01
ECO03911
1
REVISION HISTORY
1
INITIAL RELEASE
BY
DATE
SKK
02/04/13
REVISION HISTORY
REV ECO
01
D
±0.30
.012
16.4
.65
6X 60
R1.60±0.30
.063±.012
19.0±0.3
.748±.012
19.0±0.3
.748±.012
7.1
4X .28 3.44±0.22
SEE NOTE.136±.009
1
TOP OF WINDOW TO
BACK OF COREBOARD
7.1
4X .28
16.4
.65 SEE NOTE 1
ECO03911
INITIAL RELEASE
BY
DATE
SKK
02/04/13
D
3.44±0.22
.136±.009
TOP OF WINDOW TO
BACK OF COREBOARD
D
4X 30°
C
4X 30°
0.15
10.00+0.00
4.1
.16
SEE NOTE 1
+.006
.394 - .000
4X
3.00
.118
EMITTING AREA
0.15
11.00+0.00
+.006
.433 - .000
SBT-70
SEE NOTE 2
-70
OTE 2
0.15
11.00+0.00
3.00
.118
EMITTING AREA
B
B
1.8
.071
1.8
.071
+.006
.433 - .000
1100 TECHNOLOGY PARK DRIVE
BILLERICA, MA 01821
CATHODE
978-528-8000
This document and its contents
are
confidential
information
of
PADS
DESCRIPTION:
PROPRIETARY AND
CONFIDENTIAL
Copyright 2005 Luminus Device,Inc.
BILLERICA, MA 01821
All rights reserved.
DRAWING, OUTLINE, 002153, SBR-70
978-528-8000
PROPRIETARY AND
CONFIDENTIAL
ANODE
PADS
A
ANODE
CATHODE
PADS
PADS
NOTES:
1.
TOLERANCES PER IPC-610, CLASS 2.
2.
FOR DETAIL DRAWING OF SBT-70 SEE DWG-002087.
SEE DWG-002087.
8
7
C
19.9
.783
19.9
.783
B
C
4.1
4X
.16
SEE NOTE 1
6
7
6
5
are confidential information of
UNLESS OTHERWISE SPECIFIED
TOLERANCES ARE
ANGLES 0.5
SURFACES
5
X = 0.5mm
0.8 MICRONS
.X = 0.127mm
.XX = 0.050mm
.XXX = 0.010mm
4
Note 1: Tolerances per IPC-610, Class 2. All dimensions in millimeters
DESCRIPTION:
DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE:
TOLERANCES ARE
MILLIMETERS [INCHES]
ANGLES 0.5
SURFACES
DRAFTER:
X = 0.5mm
ENGINEER:
0.8 MICRONS
.X = 0.127mm
SHEET:
.XX = 0.050mm
1 OF 1
S.KEDDIE
.XXX MILLIMETERS
= 0.010mm
[INCHES]
SCALE:
B
DRAFTER:
4
B
3 NUMBER:
ENGINEER:
2
NUMBER:
REV:
01
SHEET:
SCALE:
1 OF 1
6/1
DWG-002153
1
DWG-002153
S.KEDDIE
3
6/1
A
2
1
Note 2: For detail drawing of SBT-70, please see page 11.
Note 3: Recommended mounting screw: M3 or #4
Note 4: All anode pads and all cathode pads on board are interconnected.
12
PDS-002014 Rev 10
REV:
01
A
SBT-70-G/B
Product Datasheet
LAYOUT
IQC
工程專用發行章
Engineering Stamp
8
7
5
6
4
2
3
1
REVISION HISTORY
NOTES:
1. MATERIAL: .020[.50] THK STARTING GAUGE CLEAR POLYESTER SHEET (KPET) OR IT'S OTHER REACH
6.89DISSAPATIVE
175.01
COMPLIANT VARIANTS. MUST BE ANTISTATIC OR STATIC
WITH RESISITIVITY LESS THAN 1012
OHMS
PER
SQUARE.
D
6.22 157.94
2. ALL UNSPECIFIED RADII TO BE .030[.76].
B REVISION LETTER/NUMBER.
3. MOLD "TO-1171" .18[4.6] HIGH AS SHOWN. DO NOT MOLD
4. DIMENSIONS DO NOT ACCOUNT FOR MATERIAL SHRINKAGE/FLUCTUATION FACTOR OF .005[.13] PER INCH.
5. TO BE USED WITH LUMINUS PART NUMBER TO-0945, COVER.
X0
REV
A
REV ECO
A
B
ENG00742
INITIAL PROTOTYPE
BY
DAT
MEH
07/09/
MEH
CHANGED MATERIAL THICKNESS FROM .015" TO .020"
08/19
CUSTOMER DWG NO. TO-1171 REV A
A
C
4.36 110.62
3.76 95.58
R.030 0.76
TYP
B
.020 0.51
B
SECTION B-B
.405 10.29
7.0°
TYP
SECTION A-A
BILLERICA, MA 01820
978-528-8000
PROPRIETARY AND
CONFIDENTIAL
NOTES:
1. MATERIAL: 20 MIL THICK POLYESTER SHEET (PET) OR ITS OTHER REACH
COMPIANT VARIANTS; NEED TO BE ANTISTATIC OR
PDS-002014STATIC
Rev 10 DISSAPATIVE
© 2022 Luminus
Devices,
Inc. - All
Rights
Reserved
10¹² OHMS PER SQUARE.
WITH
RESISTIVITY
LESS
THAN
2. CCI PART NUMBER: 05N-8433.
3. MATES WITH LUMINUS PART NUMBER TO-0944.
A
13
DESCRIPTION:
Luminus Devices, Inc. • T 408.708.7000 COVER,
• www.luminus.com
SHIPPING, SST
1145 Sonora Ct. • Sunnyvale, CA 940861 OF 1
TOLERANCES ARE
INCHES [MILLIMETERS]
B
NONE
ANGLES 0.5
SURFACES
SHEET:
SCALE:
X 0.03
.X 0.020
.XX 0.010
.XXX 0.005
0.8 MICRONS
DRAFTER:
M. HADLEY
NUMBER:
ENGINEER:
TO-0945
REV:
B
SBT-70-G/B
Product Datasheet
Shipping Label
Label Fields:
XXX-XX-XXXX-XXXX-XXXXXXXXX
• CPN: Luminus ordering part number
• CID: Customer’s part number
• QTY: Quantity of devices in pack
• Flux: Bin as defined on page 4
• Voltage: NA
• Color: Bin as defined on page 4
50
• CRI: NA
Box ID
Packing Configuration:
Maximum stack of 2 trays per pack with 25 devices per tray
Partial pack or tray may be shipped
Each pack is enclosed in anti-static bag
Shipping label is placed on top of each pack
14
PDS-002014 Rev 10
© 2022 Luminus Devices, Inc . - All Rights Reserved
1145 Sonora Court • Sunnyvale, CA 94086
SBT-70-G/B
Product Datasheet
Revision History
Rev
Date
Description of Change
08
07/20/2015
Added Angular Distribution Pattern on Page 9
09
04/10/2016
Updated Vf min for SBT-70-G from 4.5V to 3.9V and typical Vf from 4.9V to 4.5V
Corrected maximum current value to 14 A (2 A/mm2) on page 8
10
11/29/2022
Updated template, added DJ & DK flux bin, updated Typical Device Performance, added Soldering Profile,
Shipping Tray Outline, Shipping Label Outline sections
The products, their specifications and other information appearing in this document are subject to change by Luminus Devices without notice. Luminus
Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product or
information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of the
product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as
accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No
information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices may
have in such information. LEDs™ is a registered trademark of Luminus Devices, Inc., all rights reserved.
This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871; 7,170,100;
7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059 Patents Pending in the U.S. and
other countries.
15
PDS-002014 Rev 10
