CBT-90-RX-L15-BM100
CBT-90-RX-L15-BM100
    LUMINUS(朗明纳斯)
    Module
    CBT-90-RX-L15-BM100
CBT-90-RX-L15-BM100 数据手册
CBT-90-RX/B TE Product Datasheet CBT-90-RX/B Thermally Enhanced LED Package Features Table of Contents Technology Overview. . . . . . 2 Ordering Information . . . . . . 3 Binning Structure. . . . . . . . . . 4 Typical Device Performance. . . . . . . . . . . . . . . 6 • Large, monolithic chip with uniform emitting area of 9 mm2 • Wide color gamut available for Red and Blue single color LEDs. Green, White and UV CBT-90 LEDs are also available with the same package format • Ultra High thermal conductivity package allows operation at up to 27A CW • High precision LEDs placement on copper core PCB for easier thermal management and optical integration • Unencapsulated die with low profile protective window optimizes optical coupling in etendue-limited applications • Environmentally friendly: RoHS and REACH compliant Absolute Maximum Ratings. . . . . . . . . . . . . . . . . . . . 7 Optical and Electrical Characteristics. . . . . . . . . . . . . 8 Angular Intensity Distribution. . . . . . . . . . . . . . . 10 Typical Spectrum . . . . . . . . . 11 Applications • Fiber-coupled Illumination • Displays and Signage • Architectural and Entertainment Lighting • General Illumination • Medical Lighting Packaging Information. . . . 15 • Emergency Vehicle Lighting • Machine Vision • Projection Systems Revision History . . . . . . . . . . 17 • Microscopy Thermal Resistance . . . . . . . 12 Mechanical Dimensions . . . 13 1 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved • Spot Lighting Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Technology Overview Luminus LEDs benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Luminus LED Technology Reliability Luminus’ Devices vertical chip LED technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. Designed from the ground up, Luminus LEDs are one of the most reliable light sources in the world today. Luminus LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus LEDs are ready for even the most demanding applications. Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to heat sink of 0.5º C/W, Luminus CBT-90 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Environmental Benefits Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Static Electricity The products are sensitive to static electricity, and care should be taken when handling them. Static electricity or surge voltage willdamage the LEDs. It is recommended to wear an antielectrostatic wristband or an anti-electrostatic gloves when handling the LEDs. All devices, equipment and machinery must be properly grounded. It is recommended that measures be taken against surge voltage to the equipment that mounts the LEDs. Reference: APN-002815 Electrical Stress Damage to LEDs and How to Prevent It Understanding Luminus LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing of Luminus LEDs Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches 2 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved equilibrium are the measurements taken. This method of measurement ensures that Luminus LEDs perform in the field just as they are specified. Expected flux values in real world operation can be extrapolated based on the information contained within this product data sheet. Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Ordering Information Ordering Part Numbers Luminous Flux Color Min. Flux/ Power Bin Min. Flux/ Power BM 770 lm BN 970 lm G 8.30 W H 9.10 W J 10.0 W Red Blue Wavelength Bins Ordering Part Number R2, R3, R4, R5, R6 CBT-90-RX-L15-BM100 R3, R4, R5 CBT-90-RX-L15-BM101 R2, R3, R4, R5, R6 CBT-90-RX-L15-BN100 R3,R4,R5 CBT-90-RX-L15-BN101 445,450,455,460,465 CBT-90-B-L11-G100 450,455,460 CBT-90-B-L11-G101 445,450,455,460,465 CBT-90-B-L11-H100 450,455,460 CBT-90-B-L11-H101 445,450,455,460,465 CBT-90-B-L11-J100 450,455,460 CBT-90-B-L11-J101 Part Number Nomenclature CBT Product Family CBT: Copper-core PCB, no encapsulation 90 Chip Area 90: 9 mm2 CC L## Color Package Configuration Bin Kit 1 RX = Red B = Blue L15: 28 mm x 26.75 mm - Common Cathode Package L11: 28 mm x 26.75 mm - Common Anode Package See Mechanical Drawing section Refer to ordering part numbers in this document Note 1: Flux Bin listed is minimum bin shipped, higher bins may be included at Luminus’ discretion. 3 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Binning Structure All CBT-90 monochromatic LEDs are tested for luminous flux/ wavelength and placed into one of the following flux/ wave length bins. The binning structure is universally applied across each monochromatic color of the CBT-90 product line. Flux Bins Color Red Blue Luminous Flux Bin (FF)3 Minimum Flux/ Power Maximum Flux/ Power BM 770 lm 970 lm BN 970 lm 1150 lm BP 1150 lm 1350 lm BQ 1350 lm 1570 lm BR 1570 lm 1850 lm G 8.3 W 9.1 W H 9.1 W 10.0 W J 10.0 W 11.0 W K 11.0 W 12.1 W L 12.1 W 13.3 W M 13.3 W 14.6 W 4 PDS-002547 Rev08 Binning @ 13.5A, Ths= 40°C⁵ © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Wavelength Bins Color Red (Dominant WL) Blue (Peak WL) Wavelength Bin3 Binning @ 13.5A, Ths= 40°C⁵ Minimum Wavelength (nm) Maximum Wavelength (nm) R2 611 615 R3 615 619 R4 619 623 R5 623 627 R6 627 631 445 445 450 450 450 455 455 455 460 460 460 465 465 465 470 Note 1: Luminus maintains a +/- 6% tolerance on flux measurements. Note 2: Products are production tested then sorted and packed by bin. Note 3: Individual bins are not orderable. Please refer to the Product ordering information page for a list of orderable bin kits. Note 4: Product test condition: 13.5A DC, 40°C heat sink temperature. Note 5: Ths=Testing Heat Sink Temperature. 5 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Typical Device Performance General Characteristics Symbol Emitting Area Emitting Area Dimensions Red Blue Unit 9.0 9.0 mm2 3.0x3.0 3.0x3.0 mm x mm 100 100 % Characteristics at Recommended Test Drive Current , If 1, 2,3 Reference Duty Cycle Test Peak Drive Current typ IF 13.5 13.5 A Peak Luminuous Flux4,5,6 typ Φv 1250 630 lm Peak Radiometric Flux typ Φr 6.6 13 W Dominant Wavelength4 typ λd 620 461 nm Peak Wavelength typ λd 631 456 nm FWHM- Spectral bandwidth at 50% of Φv4 typ 20 21 nm 4,5,6 4 Chromaticity Coordinates 7 Forward Voltage Dynamic Resistance typ x 0.694 0.146 typ y 0.306 0.035 min VF min 2 2.9 V typ VF 2.8 3.5 V max VF max 3.8 4.8 V typ Ωdyn 0.03 0.02 Ω Device Thermal Characteristics Thermal Coefficient of Photometric Flux typ -1 -0.08 % / oC Thermal Coefficient of Radiometric Flux typ -0.7 -0.2 % / oC Forward Voltage Temperature Coefficient typ -2.9 -3.75 mV/ oC 6 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Absolute Maximum Ratings Symbol Red Blue Unit Absolute Minimum Current (CW or Pulsed)8,9 0.2 0.2 A Absolute Maximum Current (CW) 10 27 27 A 31.5 31.5 A 125 150 ºC -40/+100 -40/+100 ­ºC Absolute Maximum Surge Current 10, (Frequency > 240 Hz, duty cycle =10%, t=1ms) Absolute Maximum Junction Temperature 10 Tjmax Storage Temperature Range Note 1: All ratings are based on operation with a constant heat sink temperature Ths =40ºC. See Thermal Resistance section for Ths definition. Note 2: CBT-90-RX/B device can be driven at currents ranging from 200mA to 27A and at duty cycles ranging from 1% to 100%. Drive current and duty cycle should be adjusted as necessary to maintain the junction temperature desired to meet application lifetime requirements.I n pulsed operation, rise time from 10-90% of forward current should be larger than 0.5 microseconds. Note 3: Tested at Current Density of 1.5 A/mm2. Note 4: Unless otherwise noted, values listed are typical. Devices are production tested and specified at 13.5 A. Note 5: Total flux from emitting area at listed wavelength. Reported performance is included to show trends for a selected power level. For specific minimum and maximum values, use bin tables. For product roadmap and future performance of devices, contact Luminus. Note 6: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. Note 7: In CIE 1931 chromaticity diagram coordinates, normalized to X+Y+Z=1. Note 8: For reference only. Note 9: Special design considerations must be observed for operation under 1 A. Please contact Luminus for further information. Note 10: CBT-90-RX/B LED is designed for operation to an absolute maximum current and temperature as specified above. Product lifetime data is specified at recommended forward drive currents. Sustained operation at or beyond absolute maximum currents or temperatures will result in a reduction of device life ime compared to recommended conditions. Refer to the lifetime derating curves for further information. 7 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Optical & Electrical Characteristics (Red) Relative Luminous Flux vs Forward Current Relative Luminous Flux vs Temperature Relative Forward Voltage vs Forward Current Relative Forward Voltage vs Temperature Dom Wavelength Shift vs Forward Current Dom Wavelength Shift vs Temperature φv/φv(13.5A) CW Ths = 40°C ΔVf = V(If) - V(13.5A) CW Ths = 40°C ΔWL= WL(If) - WL(13.5A) CW Ths = 40°C 8 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved φv/φv(40°C) CW If = 13.5A ΔVf = V(Ths) - V(40°C) CW If = 13.5A ΔWL= WL(Ths) - WL(40°C) CW If = 13.5A Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Optical & Electrical Characteristics (Blue) Relative Luminous Flux vs Forward Current Relative Luminous Flux vs Temperature Relative Forward Voltage vs Forward Current Relative Forward Voltage vs Temperature Dom Wavelength Shift vs Forward Current Dom Wavelength Shift vs Temperature φv/φv(13.5A) CW Ths = 40°C ΔVf = V(If) - V(13.5A) CW Ths = 40°C ΔWL= WL(If) - WL(13.5A) CW Ths = 40°C 9 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved φv/φv(40°C) CW If = 13.5A ΔVf = V(Ths) - V(40°C) CW If = 13.5A ΔWL= WL(Ths) - WL(40°C) CW If = 13.5A Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Angular Intensity Distribution (Typical) 10 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Typical Spectrum Red Blue 11 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Thermal Resistance Typical Thermal Resistance Rθj-b1 0.5 ºC/W Rθj-ref1 0.5 ºC/W Note 1: Thermal resistance measurements are in accordance with JEDEC 51-14. Thermistor Information Electrical Pinout For more about calculating thermistor temperature, please see https://7w4gu55aofsagtmy.anvil.app/S2C6EXFFQQ7SQYTBQ7MIUG2N Temperature (° C) 125 100 75 50 25 0 0 5 10 15 20 Resistance (K ohm) 12 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Mechanical Dimensions (Red) Recommended connector for Anode and Cathode: Panduit Disco Lok™ Series P/N: DNF14-250FIB-C or JST Manufacturing Co: SPS-61T-250 for AWG 16 to 14 Panduit Disco Lok™ Series P/N: DNF10-250FIB-L or JST Manufacturing Co: SPS-91T-250 for AWG 12 to 10 (Check NEC standards for ampacity of the power cable being used) Recommended Female: MOLEX P/N 51146-0200 (not recommended for new designs), GCT P/N WTB06-020H-A or equivalent For detailed drawing please refer to DWG-002309 document 13 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Mechanical Dimensions (Blue) Recommended connector for Anode and Cathode: Panduit Disco Lok™ Series P/N: DNF14-250FIB-C or JST Manufacturing Co: SPS-61T-250 for AWG 16 to 14 Panduit Disco Lok™ Series P/N: DNF10-250FIB-L or JST Manufacturing Co: SPS-91T-250 for AWG 12 to 10 (Check NEC standards for ampacity of the power cable being used) Recommended Female: MOLEX P/N 51146-0200 (not recommended for new designs), GCT P/N WTB06-020H-A or equivalent For detailed drawing please refer to DWG-002309 document 14 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Shipping Tray Outline 15 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Shipping Label Label Fields: XXX-XX-XXXX-XXXX-XXXXX XXXX • CPN: Luminus ordering part number • CID: Customer’s part number • QTY: Quantity of devices in pack • Flux: Bin as defined on page 4 • Voltage: NA • Color: Bin as defined on page 5 50 Box ID • CRI: NA Packing Configuration: • Maximum: stack of 5 trays with 10 devices per tray per pack • Partial pack or tray may be shipped • Each pack is enclosed in antistatic bag • Shipping label is placed on top of each pack 16 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 CBT-90-RX/B TE Product Datasheet Revision History Rev Date Description of Change 01 12/01/2015 Initial Release - Preliminary Specifications 02 02/09/2015 Editorial Changes and Update of Blue Bin Kit Offering 03 02/15/2015 Corrected Green Bin Kit Definition 04 06/17/2017 Revised wording in last page; Removed “Preliminary” 05 07/19/2017 Updated Red flux bin 06 08/03/2020 Updated optical and electrical graphs 07 12/01/2020 Updated maximum flux bins to support improved production output 08 05/10/2022 Rename PDS from CBT-90 TE to CBT-90-RX/B TE, remove CBT-90 Green information, update product photo, typical device performance, typical spectrum, thermal resistance, shipping information and add ESD information Luminus Devices assumes no liability for errors that may appear in this document, and no liability otherwise arising from the application or use of the product or information contained herein. None of the information provided herein should be considered to be a representation of the fitness or suitability of the product for any particular application or as any other form of warranty. Luminus Devices’ product warranties are limited to only such warranties as accompany a purchase contract or purchase order for such products. Nothing herein is to be construed as constituting an additional warranty. No information contained in this publication may be considered as a waiver by Luminus Devices of any intellectual property rights that Luminus Devices may have in such information. This product is protected by U.S. Patents 6,831,302; 7,074,631; 7,083,993; 7,084,434; 7,098,589; 7,105,861; 7,138,666; 7,166,870; 7,166,871; 7,170,100; 7,196,354; 7,211,831; 7,262,550; 7,274,043; 7,301,271; 7,341,880; 7,344,903; 7,345,416; 7,348,603; 7,388,233; 7,391,059 Patents Pending in the U.S. and other countries. 17 PDS-002547 Rev08 © 2022 Luminus Devices, Inc . - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086
CBT-90-RX-L15-BM100 价格&库存
很抱歉,暂时无法提供与“CBT-90-RX-L15-BM100”相匹配的价格&库存,您可以联系我们找货
