CVM-32-56-95-54-AC00-F2-3
    LUMINUS(朗明纳斯)
CVM-32-56-95-54-AC00-F2-3 数据手册
CVM Product Datasheet CVM Studio COB Arrays LED Entertainment Lighting Features: Table of Contents • High lumen output • Over 25,000 lm @ 3150K, 25ºC Technology Overview. . . . . . 2 • Over 27,000 lm @ 5600K, 25ºC Test Specifications . . . . . . . . . 2 • 3150K and 5600K CCT Chromaticity Bins. . . . . . . . . . 3 • 95 CRI minimum Product Ordering & Shipping Part Numbers. . . . . . . . . . . . . . 4 Product Typical Flux Range. 5 Operating Characteristics . . 5 Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7 Spectra. . . . . . . . . . . . . . . . . . . 11 • 90 TLCI minimum • 2 SDCM color binning accuracy • Excellent optical emission uniformity and color over angle consistency • Exceptional long term color stability • Superior thermal conductivity for uniform heat spreading • Environmentally friendly: RoHS and REACH compliant • UL certified, file # E465703 • Mechanical Dimensions. . . 12 Packaging Information. . . . 12 Handling Notes. . . . . . . . . . . 17 Applications • TV Studio • Stage/Set Lights • Film Production • Architectural/Hospitality • Still Photography 1 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved CVM Product Datasheet Technology Overview Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and designers to develop lighting solutions with maximum efficacy, brightness and overall quality. Reliability UL Recognized Compliance Designed from the ground up, the Luminus COB LED is one of the most reliable light sources in the world today. Having passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity. Only then are the devices qualified for use in a wide range of lighting application including some of the most demanding commercial applications. Luminus COB arrays are tested in accordance with ANSI/UL 8750 to ensure safe operation for their intended applications. REACH & RoHS Compliance All LED products manufactured by Luminus are REACH and RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Luminus COB LED Test Specifications Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products. Traceability Chromaticity Bin Range Each Luminus COB LED is marked with a 2D bar code that contains a unique serial number. With this serial number, Luminus has the ability to provide customers with actual test data measurements for a specific LED. In addition, the 2D bar code is linked to manufacturing date codes that enables traceability of production processes and materials. Chromaticity binning delivers color consistency for every order. Studio products are delivered with a 2-step MacAdam ellipse. This ensures color performance matching in the application. These tightly controlled, small distribution bins provide customers predictable, repeatable colors. Testing Temperature Luminus Studio products are measured at temperatures typical for the LED operating in the fixture. Each device is tested at 85ºC junction temperature eliminating the need to scale datasheet specifications to real world situations. 2 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved CVM Product Datasheet Chromaticity Bin Structure Chromaticity Bins: 1931 CIE Curve 0.4600 ANSI C78.377-2008 2-step Ellipse 3-step Ellipse 0.4400 3150K Black Body 0.4200 CIE y 0.4000 0.3800 5600K 0.3600 0.3400 0.3200 0.3000 0.3000 0.3200 0.3400 0.3600 0.3800 0.4000 0.4200 0.4400 0.4600 0.4800 0.5000 CIE x CVM White Chromaticity Bins The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for the ellipses. The ANSI Bin is provided for reference. CCT Center Point Angle 2-step Bin 3-step Bin CIEx CIEy θ (°) a b a b 3150K 0.4263 0.4003 53.2 0.00556 0.00272 0.00834 0.00408 5600K 0.3287 0.3417 59.1 0.00497 0.00213 0.00746 0.0032 *Note: Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements. 3 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved CVM Product Datasheet Product Ordering and Shipping Part Number Nomenclature All CVM products are packaged and labeled with part numbers as outlined in the table on page 5. When shipped, each package will contain only a single flux and chromaticity bin. The part number designation is as follows: CVM XX NN 95 VV QQPP FG W Product Family Light Emitting Surface Diameter Color Temperature Color Rendering Index (CRI) Voltage (typical) Package Configurator Flux Bin Chromaticity Bin CVM: Chip on Board, Studio Approx. LES Diameter (mm) Color See Note 1 below CRI See Note 2 below Volts See Note 3 below Lumens See page 3 for bins Note 1: NN nomenclature corresponds to the following: 31 = 3150K 56 = 5600K Note 2: XX CRI is specified as minimum value 95 CRI is 95 minimum Note 3: AA00 - Standard Package Configurator AC00 /AB00- Alternative Package Configurator Example 1: The ordered part number CVM-27-56-95-36-AA00-F2-2 which refers to a 26.5 millimeter diameter emitter, at color temperature 5600K, a minimum CRI of 95, a typical voltage of 36V, a standard package, a typical flux of 10,500 lumens and a 2-step MacAdam ellipse chromaticity range. Note: Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part number described above will always be included. 4 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved CVM Product Datasheet CVM Part Numbers The following tables describe products with typical flux and minimum flux measured at the maximum rated current and specified at junction temperature, Tj = 85ºC. The values at 25ºC are calculated and shown for reference only. CCT 3150K 5600K LES (mm) Test Currant (A) Output Flux (lm) Reference Typ. Typ. (85ºC) Min. (85ºC) (calculated) 2-step MacAdam Ellipse 3-step MacAdam Ellipse (25ºC) 13.5 1.0 2,575 2,395 3,085 CVM-14-31-95-36-AC00-F2-2 CVM-14-31-95-36-AC00-F2-3 17.5 1.8 5,140 4,880 5,655 CVM-18-31-95-36-AA00-F2-2 CVM-18-31-95-36-AA00-F2-3 26.5 4.2 11,500 10,750 13,800 CVM-27-31-95-36-AA00-F2-2 CVM-27-31-95-36-AA00-F2-3 26.5 4.2 11,500 10,750 13,800 CVM-27-31-95-36-AB00-F2-2 CVM-27-31-95-36-AB00-F2-3 32 5.0 22,800 21,250 25,150 CVM-32-31-95-54-AC00-F2-2 CVM-32-31-95-54-AC00-F2-3 13.5 1.0 2,800 2,600 3,350 CVM-14-56-95-36-AC00-F2-2 CVM-14-56-95-36-AC00-F2-3 17.5 1.8 5,625 5,345 6,190 CVM-18-56-95-36-AA00-F2-2 CVM-18-56-95-36-AA00-F2-3 26.5 4.2 12,500 11,500 15,000 CVM-27-56-95-36-AA00-F2-2 CVM-27-56-95-36-AA00-F2-3 26.5 4.2 12,500 11,500 15,000 CVM-27-56-95-36-AB00-F2-2 CVM-27-56-95-36-AB00-F2-3 32 5.0 24,800 23,110 27,350 CVM-32-56-95-54-AC00-F2-2 CVM-32-56-95-54-AC00-F2-3 CVM Operating Characteristics1 CVM-14 Parameter Symbol Typical Maximum Unit Forward Current2 If 1 1 A Forward Voltage Vf 36 40 V 36 40 W 100 ºC Power Operating Case Temperature3 Tc Light Emitting Surface Diameter LES 13.5 mm Thermal Resisitance (junction-to-case) Qjc 0.46 ºC/W 120 Degree Viewing Angle *Note: Luminus maintains a +/- 6% tolerance on flux measurements. Luminus maintains a +/- 2% tolerance on CRI measurements. 5 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved (Part #) CVM Product Product Datasheet Datasheet CVM Operating Characteristics CVM-18 Parameter Forward Current Symbol Typical Maximum Unit If 1.8 1.8 A Vf 36 40 V 65 72 W 100 ºC 2 Forward Voltage Power Operating Case Temperature3 Tc Light Emitting Surface Diameter LES 17.5 mm Thermal Resisitance (junction-to-case) Qjc 0.30 ºC/W 120 Degree Viewing Angle CVM-27 Parameter Symbol Typical Maximum Unit Forward Current2 If 4.2 4.2 A Forward Voltage Vf 36 40 V 150 168 W 100 ºC Power Operating Case Temperature Tc Light Emitting Surface Diameter LES 26.5 mm Thermal Resisitance (junction-to-case) Qjc 0.16 ºC/W 120 Degree 3 Viewing Angle CVM-32 Parameter Symbol Typical Maximum Unit Forward Current2 If 5.0 5.0 A Forward Voltage Vf 54.5 58 V 272.5 290 W 100 ºC 3 Power Operating Case Temperature4 Tc Light Emitting Surface Diameter LES 32 mm Thermal Resisitance (junction-to-case) Qjc 0.10 (est.) ºC/W 120 Degree Viewing Angle Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC. Note 2: Although products are specified at Maximum Current, they are all capable to be driven down to currents as low as 20% of the typical value. Operation below these current levels may result in uneven light distribution across the LES surface. Note 3: Voltage is rated at typical forward current. For voltage at lower drive current, refer to performance graphs Note 3: Maximum operating case temperature combined with maximum drive current defines the total maximum operating condition for the device. To prevent damage, please follow derating curves for all operating conditions. Note 4: All product specifications are subject to change without prior notice. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 6 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved CVM Product Datasheet CVM-14 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 100% 1000 90% 900 800 Forward Current (mA) Relative Luminous Flux 80% 70% 60% 50% 40% 700 600 500 400 30% 20% 300 400 500 600 700 800 900 300 1000 31 31.5 32 32.5 Forward Current (mA) 33 33.5 34 34.5 35 Forward Voltage (V) Relative Output Flux vs. Junction Temperature Change in Voltage vs. Junction Temperature 120% 38 Forward Voltage (V) Relative Luminous Flux 37 100% 80% 36 35 34 60% 33 40% 5 15 25 35 45 55 65 75 85 95 105 32 5 15 25 35 Junction Temperature (ºC) 55 65 75 85 95 105 Change in CIEy vs. Junction Temperature (3100K) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx Change in CIEx vs. Jucntion Temperature (3100K) 0 0 -0.01 -0.01 -0.02 45 Junction Temperature (ºC) 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 7 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CVM Product Datasheet CVM-18 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 100% 1600 Forward Current (mA) 1800 Relative Luminous Flux 120% 80% 60% 40% 1400 1200 1000 20% 0% 800 600 800 1000 1200 1400 1600 600 1800 31 31.5 32 32.5 Forward Current (mA) Relative Output Flux vs. Junction Temperature Forward Voltage (V) Relative Luminous Flux 34.5 35 35.5 38 80% 60% 40% 36 34 32 20% 5 15 25 35 45 55 65 75 85 95 105 30 5 15 25 35 Junction Temperature (ºC) 45 55 65 75 85 95 105 Junction Temperature (ºC) Change in CIEx vs. Junction Temperature (3100K) Change in CIEy vs. Junction Temperature (3100K) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 34 40 100% 0 0 -0.01 -0.01 -0.02 33.5 Change in Voltage vs. Junction Temperature 120% 0% 33 Forward Voltage (V) 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 8 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 (PartCVM #) Product ProductDatasheet Datasheet CVM-27 Optical & Electrical Characteristics Forward Current vs. Forward Voltage @ 85ºC 120.0% 4200 100.0% 3700 Forward Current (mA) Relative Luminous Flux Relative Output Flux vs. Forward Current @ 85ºC 80.0% 60.0% 40.0% 20.0% 0.0% 3200 2700 2200 1700 700 1200 1700 2200 2700 3200 3700 1200 4200 31 31.5 32 32.5 Forward Current (mA) Relative Output Flux vs. Junction Temperature 34.5 35 38 Forward Voltage (V) Relative Luminous Flux 34 40 100.0% 80.0% 60.0% 40.0% 36 34 32 20.0% 0.0% 5 15 25 35 45 55 65 75 85 95 105 30 5 15 25 35 45 Junction Temperature (ºC) 55 65 75 85 95 105 Junction Temperature (ºC) Change in CIEx vs. Junction Temperature (3100K) Change in CIEy vs. Junction Temperature (3100K) 0.02 0.02 0.01 0.01 Δ CIEy Δ CIEx 33.5 Change in Voltage vs. Junction Temperature 120.0% 0 0 -0.01 -0.01 -0.02 33 Forward Voltage (V) 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 9 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CVM Product Datasheet CVM-32 Optical & Electrical Characteristics Relative Output Flux vs. Forward Current @ 85ºC Forward Current vs. Forward Voltage @ 85ºC 120% 5000 4500 Forward Current (mA) Relative Luminous Flux 100% 80% 60% 40% 20% 4000 3500 3000 2500 2000 0% 1000 1500 1500 2000 2500 3000 3500 4000 4500 5000 50 50.5 51 51.5 Relative Output Flux vs. Junction Temperature 53 53.5 54 54.5 55 58 57 100% 56 Forward Voltage (V) Relative Luminous Flux 52.5 Change in Voltage vs. Junction Temperature 120% 80% 60% 40% 55 54 53 52 20% 0% 51 25 35 45 55 65 75 85 95 50 105 5 15 25 35 Change in CIEx vs. Junction Temperature (3100K) 55 65 75 85 95 105 Change in CIEy vs. Junction Temperature (3100K) 0.02 0.01 0.01 Δ CIEy 0.02 0 0 -0.01 -0.01 -0.02 45 Junction Temperature (ºC) Junction Temperature (ºC) Δ CIEx 52 Forward Voltage (V) Forward Current (mA) 5 15 25 35 45 55 65 75 Junction Temperature (ºC) 10 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved 85 95 105 -0.02 5 15 25 35 45 55 65 Junction Temperature (ºC) 75 85 95 105 CVM Product Datasheet CVM Optical & Electrical Characteristics Typical Spectrum (5600K) 1 1 0.8 0.8 Relative Output Relative Output Typical Spectum (3150K) 0.6 0.4 0.2 0 0.6 0.4 0.2 400 500 600 700 0 800 400 500 Wavelength (nm) 600 700 800 Wavelength (nm) Typical Polar Radiation Pattern Typical Angular Radiation Pattern 120% 100% Relative Intensity (%) 80% 60% 40% 20% 0% -80 -60 -40 -20 0 20 Anglular Displacement (Degrees) 11 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved 40 60 80 CVM Product Datasheet (Part #) Product Datasheet Mechanical Dimensions (CVM-14-AC00) Shipping Container (CVM-14-AC00) 225 pcs per box Each bag is boxed for easier storage/ stacking 45 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: Bar code Rev XX Bar code XXX-XX-XX-XX-XX-XXXX-XX-X (Customer Part Number) XXXXXXXXXXXXXX (Box ID) Bar code 12 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved Qty: XX Bar code RoHS Compliant Luminus Devices Inc XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) (PartCVM #) Product ProductDatasheet Datasheet Mechanical Dimensions (CVM-18-AA00) Shipping Container (CVM-18-AA00) 180 pcs per box Each bag is boxed for easier storage/ stacking 36 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) Bar code Rev XX Bar code XXX-XX-XX-XX-XX-XXXX-XX-X (Customer Part Number) XXXXXXXXXXXXXX (Box ID) Bar code 13 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved Qty: XX Bar code RoHS Compliant Luminus Devices Inc CVM Product Datasheet Mechanical Dimensions (CVM-27-AA00) Mechanical Dimensions (CVM-27-AB00) 14 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved CVM Product Datasheet Shipping Container (CVM-27) 100 pcs per box Each bag is boxed for easier storage/ stacking 20 pcs per tray 5 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) Bar code Rev XX Bar code XXX-XX-XX-XX-XX-XXXX-XX-X (Customer Part Number) XXXXXXXXXXXXXX (Box ID) Bar code 15 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved Qty: XX Bar code RoHS Compliant Luminus Devices Inc CVM Product Datasheet Mechanical Dimensions (CVM-32-AC00) Shipping Container (CVM-32-AC00) 60 pcs per box Each bag is boxed for easier storage/ stacking 20 pcs per tray 3 trays are stacked together with separate cover Trays are sealed in an anti-static bag Label Luminus Label Model: XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits) Bar code Rev XX Bar code XXX-XX-XX-XX-XX-XXXX-XX-X (Customer Part Number) XXXXXXXXXXXXXX (Box ID) Bar code 16 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved Qty: XX Bar code RoHS Compliant Luminus Devices Inc Product Datasheet (PartCVM #) Product Datasheet Handling Notes for Luminus COBs Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guidelines. The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More detailed information is available on the Luminus web site at www.luminus.com. General Handling Electrical Contact Devices are made to be lifted or carried with tweezers on two adjacent corners opposite the contact pads. At no time should the devices be handled by or should anything come in contact with the light emitting surface (LES) area. This area includes the yellow colored circular area and the ring surrounding it. There are electrical connections under the LES which if damaged will cause the device to fail. Luminus COBs are designed with contact pads on their top surface. These pads are clearly marked with + and – polarity. Wires can be soldered to the contact pads for electrical connections or other solderless connector products are available. In addition, the ring frame itself should not be used for moving, lifting or carrying the device. Also do not attach any optics or mechanical holders to the ring as it is not capable to handle the mechanical stress. If wires are being soldered to the COB product, we recommend attaching these wires prior to mounting the devices to a heat sink. Please contact Luminus for specific recommendations on how to solder wires if not familiar with the standard practice. Luminus can also offer design recommendations for jigs to allow easily soldering multiple products in rapid succession. Static Electricity Chemical Compatibility Luminus COBs are electronic devices which can be damaged by electrostatic discharge (ESD). Please use appropriate measures to assure the devices do not experience ESD during their handling and or storage. ESD protection guidelines should be used at all times when working with Luminus COBs. The resin material used to form the LES can getter hydrocarbons from the surrounding environment. As a results, certain chemical compounds are not recommended for use with the Luminus products. Use of these compounds can cause damage to the light output of the device and may permanently damage the device. Please refer to www.luminus.com for a list of the compounds not recommended for use with the Luminus COB products. Storage: Luminus products are delivered in ESD shielded bags and should be stored in these bags until used. Assembly: Individuals handling Luminus COBs during assembly should be trained in ESD protection practices. Assemblers should maintain constant conductive contact with a path to ground by means of a wrist strap, ankle straps, mat or other ESD protection system. Transporting: When transporting the devices from one assembly area to another, ESD shielded carts and carriers should be used. 17 PDS-002321 Rev 10 © 2017 Luminus Devices, Inc. - All Rights Reserved Thermal Interface Material (TIM) Proper thermal management is critical for successful operation of any LED system. Excess operating temperature can reduce the light output of the device. And excessive heating can cause permanent damage to the device. Proper TIM material is a crucial component for effective heat transfer away from the LED during normal operation. Please refer to www.luminus.com for specific recommendations for TIM solutions. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Luminus Devices: CVM-14-31-95-36-AC00-F2-2 CVM-18-31-95-36-AA00-F2-2 CVM-14-56-95-36-AC00-F2-2 CVM-27-56-95-36-AA00F2-2 CVM-18-56-95-36-AA00-F2-2 CVM-27-31-95-36-AA00-F2-2 CVM-14-31-95-36-AC00-F2-3 CVM-27-56-95-36AA00-F2-3 CVM-27-31-95-36-AA00-F2-3 CVM-18-31-95-36-AA00-F2-3 CVM-18-56-95-36-AA00-F2-3 CVM-14-56-9536-AC00-F2-3 CVM-32-31-95-54-AC00-F2-2 CVM-32-56-95-54-AC00-F2-3 CVM-32-56-95-54-AC00-F2-2 CVM-3231-95-54-AC00-F2-3
CVM-32-56-95-54-AC00-F2-3 价格&库存
很抱歉,暂时无法提供与“CVM-32-56-95-54-AC00-F2-3”相匹配的价格&库存,您可以联系我们找货
    库存:10
