NJM2122D
NJM2122D
    JRC(⽇本无线)
    DIP-8
    IC OPAMP GP 2 CIRCUIT 8DIP
NJM2122D 数据手册
NJM2122 ULTRA LOW NOISE DUAL OPERATIONAL AMPLIFIER ■ GENERAL DESCRIPTION The NJM2122 is an ultra low noise dual operational amplifier. The features of ultra low noise, low operating voltage, and low saturation voltage are suitable for microphone amplifier of digital audio items such as portable MD,DAT,and others. ■ FEATURES ● Operating Voltage ● Ultra Low Noise Voltage ● Low Saturation Output Voltage ● Bipolar Technology ● Package Outline ■ PACKAGE OUTLINE ( ±2.0V~±7.0V ) ( 1.5nV/√Hz typ.@ f=1kHz ) ( 0.3V typ. ) NJM2122D NJM2122M DIP8,DMP8 ■ PIN CONFIGURATION PIN FUNCTION 1.A OUTPUT 2.A –INPUT 3.A +INPUT - 4.V 5.B +INPUT 6.B –INPUT 7.B OUTPUT + 8.V NJM2122D NJM2122M ■ EQUIVALENT CIRCUIT ( 1/2 Shown ) Ver.2007-05-21 -1- NJM2122 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER SYMBOL + V /V VID VIC Supply Voltage Differential Input Voltage Input Voltage Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 10 ± 0.5 ± 10 ( note ) ( DIP8 ) 500 ( DMP8 ) 300 -20~+75 -40~+125 UNIT V V V mW ˚C ˚C ( note ) When the supply voltage is less than ±10V,the absolute maximum input voltage is equal to the supply voltage. ■ ELECTRICAL CHARACTERISTICS PARAMETER Operating Voltage 1 Operating Voltage 2 Operating Current Input Offset Voltage Input Offset Current Input Bias Current Large Signal Voltage Gain Input Common Mode Voltage Range Common Mode Rejection Ratio Supply Voltage Rejection Ratio Maximum Output Voltage Slew Rate Gain Bandwidth Product Equivalent Input Noise Voltage 1 Equivalent Input Noise Voltage 2 Channel Separation Total Harmonic Distortion ( V+=5V,Ta=25˚C ) SYMBOL Vope1 Vope2 ICC VIO IIO IB AV VICM CMR SVR VOM SR GB en1 en2 CS THD TEST CONDITION DIP Package DMP Package VIN=0V,RL=∞Ω RS=500Ω RL≥10kΩ RL≥2.5kΩ GV=20dB,VIN=± 0.1V RS=10Ω,f=1kHz *Figure1 f=1kHz VO=1Vrms,f=1kHz GV=20dB,RL=2.5kΩ MIN. ± 2.0 ± 2.0 80 ± 0.7 60 60 ± 2.0 - TYP. 7.0 1.0 0.45 3.6 100 ± 1.0 74 80 ± 2.2 2.4 12 1.5 0.56 90 0.003 MAX. ± 10.0 ± 7.0 9.5 6.0 1.50 8.0 0.75 - UNIT V V mA mV µA µA dB V dB dB V V/µs MHz nV√Hz µVrms dB % ( note ) Between 30 to 50dB voltage gain is recommended. In case of voltage gain less than 30dB,phase compensation by external circuit is required. The voltage follower circuit must not be used. DMP package should be used in operating voltage less than ±7V,because of the PD limitation. Figure1 -2- Ver.2007-05-21 NJM2122 ■ TYPICAL CHARACTERISTICS Ver.2007-05-21 -3- NJM2122 ■ TYPICAL CHARACTERISTICS -4- Ver.2007-05-21 NJM2122 ■ TYPICAL CHARACTERISTICS -- 4 1. 0×10 [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2007-05-21 -5-
NJM2122D 价格&库存
很抱歉,暂时无法提供与“NJM2122D”相匹配的价格&库存,您可以联系我们找货
