BXRB-30E0740-A-00
BXRB-30E0740-A-00
    BRIDGELUX(普瑞)
    BXRB-30E0740-A-00
BXRB-30E0740-A-00 数据手册
Bridgelux ES Star Array Series Data Sheet DS 21 – Expiration date – 10 May 2011 BXRB – XXX0540-A, - XXX0740-A, - 40E0810-A, - 56C0700-A, - 56C1000-A Introduction The Bridgelux family of LED Array products delivers high performance, compact and cost-effective solidstate lighting solutions to serve the general lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of many conventional lighting sources. The Bridgelux ES Array Series has been specified to enable lamp and luminaire designs surpassing efficacy and quality of light requirements driven by regulatory standards with reasonable system design margins, enabling lighting product compliance to Energy Star, Title 24, Part L and other global standards. The Bridgelux ES Array products provide a high performance alternative to conventional solid state solutions, delivering between 400 and 1000 lumens under application conditions in warm, neutral and cool white color temperatures. These compact high flux density light sources deliver uniform high quality illumination without pixilation or the multiple shadow effect caused by LED component based solutions. To simplify system design for appropriate light output, Bridgelux LED Arrays are specified to deliver performance under typical use conditions. These integrated plug and play solutions reduce system complexity and enable miniaturized costeffective lamp and luminaire designs. Lighting system designs incorporating these LED Arrays deliver comparable performance to that of 20-40 Watt incandescent and halogen, 7-18 Watt compact fluorescent, and 8-50 Watt HID based luminaires and feature increased system level efficacy and service life. Typical applications include replacement lamps, task, accent, spot, retail, track, down light, low bay, wide area, security, wall pack and street lighting. Features Benefits • Compact high flux density light source • Enhanced optical control • Uniform high quality illumination • Clean white light without pixilation • Streamlined thermal path • • Energy Star / ANSI compliant binning structure Significantly reduced thermal resistance and increased operating temperatures • Uniform consistent white light More energy efficient than incandescent, halogen and fluorescent lamps • Lower operating costs • Increased safety • Low voltage DC operation • • Instant light with unlimited dimming Easy to use with daylight and motion detectors to enable increased energy savings • 5-year warranty • Reduced maintenance costs • RoHS compliant and Pb free • Environmentally friendly, no disposal issue • 1 0 1 P o rt o l a A v e n u e , L i v e rm o re , C A 9 4 5 5 1 • T e l : (9 2 5 ) 5 8 3 -8 4 0 0 • Fa x: (9 2 5 ) 5 8 3 -8 4 0 1 • ww w. b ri d g e l u x. c o m Table of Contents Page Product Nomenclature 3 Average Lumen Maintenance Characteristics 3 Environmental Compliance 3 UL Recognition 4 Minor Product Change Policy 4 Cautionary Statements 4 Case Temperature Measurement Point 5 Flux Characteristics 6 Optical Characteristics 8 Electrical Characteristics 9 Absolute Minimum and Maximum Ratings 10 Typical Performance at Alternative Drive Currents 11 Mechanical Dimensions 13 Wavelength Characteristics at Rated Test Current, Tj=25°C 15 Typical Relative Luminous Flux vs. Current, Tj=25° C 16 Typical Light Output Characteristics vs. Temperature 17 Typical Chromaticity Characteristics vs. Temperature 18 Typical Forward Current Characteristics at Tj = 25°C 19 Product Binning 20 Color Binning Information 21 Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 2 of 25 Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRB – AB C DEFG – H – IJ - KLM Where: BXRB – Designates product family AB – Designates the nominal ANSI color temperature; 27 = 2700K; 30 =3000K, etc C - Designates minimum CRI; A=60, C=70, E=80, G=90 DEFG - Designates Nominal Flux; 0400=400lm, 0800=800lm, 1200=1200lm, etc H – Designates configuration IJ – Designates CCT Bin options (3000K as an example) 00=Full ANSI - Q3, Q4, R3, R4; Q1=2 bins - Q3+Q4; Q3=Single bin - Q3 bin; Q4=Single bin - Q4 bin; 03=3 SDCM KLM – Designates wire option Average Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation with case temperature maintained at or below 70°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Bridgelux LED Arrays are compliant to the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux will not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 3 of 25 UL Recognition Bridgelux secures UL Recognition for all the LED Array products. We continue to add arrays as they are recognized by UL. Please refer to the UL file E333389 for the latest list of UL Recognized Arrays. Bridgelux uses UL Recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 Driver to facilitate the UL listing process. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Contact with the resin area should be avoided. Applying stress to the resin area can result in damage to the product. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC – EN62471 Photobiological Safety of Lamps and Lamp Systems specification. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below the rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 4 of 25 Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Measuring the top surface of the product can lead to inaccurate results due to the poor thermal conductivity of the top layers of the array such as the solder mask and other materials. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 5 of 25 Quick Selection Guide Table 1: Quick Selection Guide for ES Arrays Base Part Number CCT CRI (Nominal) (min) Typ Flux 25ºC Min Flux 25ºC Typ Flux 60ºC (lm) (lm) (lm) Efficacy Vf Power (mA) (Typ) (V) (Typ) (W) (Typ at Tc 25ºC) (lm/W) Current BXRB-27E0540-A-00 2700 80 550 500 500 365 17.2 7.0 79 BXRB-30E0540-A-00 3000 80 600 540 540 365 17.2 7.0 86 BXRB-27G0540-A-00 2700 90 500 450 450 365 17.2 7.0 72 BXRB-30G0540-A-00 3000 90 540 490 490 365 17.2 7.0 77 BXRB-27E0740-A-00 2700 80 750 680 680 350 25.7 10.0 75 BXRB-30E0740-A-00 3000 80 820 740 740 350 25.7 10.0 82 BXRB-27G0740-A-00 2700 90 680 610 610 350 25.7 10.0 68 BXRB-30G0740-A-00 3000 90 740 670 670 350 25.7 10.0 74 BXRB-40E0810-A-00 4000 80 900 810 810 350 25.7 10.0 90 BXRB-56C0700-A-00 5600 70 780 700 700 365 17.2 7.0 112 BXRB-56C1000-A-00 5600 70 1070 960 960 350 25.7 10.0 107 Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 6 of 25 Flux Characteristics Table 2: Flux Characteristics Color Warm White Neutral White Cool White Part Number CRI (min) Typ Luminous Flux (lm), [3] Tc=60°C Min Luminous Flux (lm), [1] Tj=25°C Typ Luminous Flux (lm), Tj=25°C Max Luminous Flux (lm), Tj=25°C Test Current [2] (mA) BXRB-27E0540-A-00 80 500 500 550 610 365 BXRB-30E0540-A-00 80 540 540 600 660 365 BXRB-27G0540-A-00 90 450 450 500 550 365 BXRB-30G0540-A-00 90 490 490 540 600 365 BXRB-27E0740-A-00 80 680 680 750 830 350 BXRB-30E0740-A-00 80 740 740 820 900 350 BXRB-27G0740-A-00 90 610 610 679 750 350 BXRB-30G0740-A-00 90 670 670 740 810 350 BXRB-40E0810-A-00 80 810 810 900 1000 350 BXRB-56C0700-A-00 70 700 700 780 860 365 BXRB-56C1000-A-00 70 960 960 1070 1200 350 Notes for Table 1: 1. Bridgelux maintains a ± 7% tolerance of flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Typical performance when driven with direct current using Bridgelux test set-up. Please contact a Bridgelux sales representative for additional details. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 7 of 25 Optical Characteristics Table 3: Optical Characteristics Color Temperature [1],[2],[3] (CCT) Min Typ Max BXRB-27E0540-A-00 2580 K 2725 K 2870 K 80 120 BXRB-30E0540-A-00 2870 K 3045 K 3220 K 80 120 BXRB-27G0540-A-00 2580 K 2725 K 2870 K 90 120 175 BXRB-30G0540-A-00 2870 K 3045 K 3220 K 90 120 190 BXRB-27E0740-A-00 2580 K 2725 K 2870 K 80 120 265 BXRB-30E0740-A-00 2870 K 3045 K 3220 K 80 120 285 BXRB-27G0740-A-00 2580 K 2725 K 2870 K 90 120 240 BXRB-30G0740-A-00 2870 K 3045 K 3220 K 90 120 260 BXRB-40E0810-A-00 3700K 4000K 4250K 80 120 320 BXRB-56C0700-A-00 5310 K 5665 K 6020 K 70 120 275 BXRB-56C1000-A-00 5310 K 5665 K 6020 K 70 120 380 Part Number Neutral White Cool White Typical Center Beam Candle Power [5] (cd) Minimum Color Rendering [4] Index Color Warm White Typical Viewing Angle (Degrees) [6] 2 θ½ 195 210 Notes for Table 3: 1. 2. 3. 4. 5. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Refer to Flux Characteristic Table for test current data. Product is binned for color in x y coordinates. Higher CRI options available upon request. Center beam candle power is a calculated value based on lambertian radiation pattern at nominal test current (365mA). 6. Viewing angle is the off axis angle from the centerline where Iv is ½ of the peak value. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 8 of 25 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Vf [1],[2] (V) Color Warm White Neutral White Cool White Base Part Number Turn On Test Current (mA) Typical Temperature Coefficient of Forward Voltage (mV/°C) ΔVf/ΔTj Typical Thermal Resistance Junction to Case (°C/W) RѲ j-c Min Typ Max BXRB-27E0540-A-00 17.2 19.1 21.0 365 -1 to -3 2.5 BXRB-30E0540-A-00 17.2 19.1 21.0 365 -1 to -3 2.5 BXRB-27G0540-A-00 17.2 19.1 21.0 365 -1 to -3 2.5 BXRB-30G0540-A-00 17.2 19.1 21.0 365 -1 to -3 2.5 BXRB-27E0740-A-00 25.7 28.6 31.5 350 -1 to -3 1.5 BXRB-30E0740-A-00 25.7 28.6 31.5 350 -1 to -3 1.5 BXRB-27G0740-A-00 25.7 28.6 31.5 350 -1 to -3 1.5 BXRB-30G0740-A-00 25.7 28.6 31.5 350 -1 to -3 1.5 BXRB-40E0810-A-00 25.7 28.6 31.5 350 -1 to -3 1.5 BXRB-56C0700-A-00 17.2 19.1 21.0 365 -1 to -3 2.5 BXRB-56C1000-A-00 25.7 28.6 31.5 350 -1 to -3 1.5 Notes for Table 4: 1. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 9 of 25 Absolute Minimum and Maximum Ratings Table 5: Minimum and Maximum Current and Reverse Voltage Ratings Part Number Maximum DC Forward Current (mA) Maximum Peak Pulsed [3] Current (mA) Maximum Reverse [1] Voltage (Vr) BXRB-27E0540-A-00 700 700 -30 Volts BXRB-30E0540-A-00 700 700 -30 Volts BXRB-27G0540-A-00 700 700 -30 Volts BXRB-30G0540-A-00 700 700 -30 Volts BXRB-27E0740-A-00 700 700 -45 Volts BXRB-30E0740-A-00 700 700 -45 Volts BXRB-27G0740-A-00 700 700 -45 Volts BXRB-30G0740-A-00 700 700 -45 Volts BXRB-40E0810-A-00 700 700 -45 Volts BXRB-56C0700-A-00 700 700 -30 Volts BXRB-56C1000-A-00 700 700 -45 Volts Notes for Table 5: 1. Light emitting diodes are not designed to be driven in reverse voltage. 2. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature 3.5 seconds, 350°C or lower Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 10 of 25 Typical Performance at Alternative Drive Currents The Bridgelux LED Arrays are tested and binned against the specifications shown in Tables 2, 3 and 4. Customers also have options to drive the LED Arrays at alternative drive currents dependent on the specific application. The typical performance at any drive current can be derived from the flux vs. current characteristics shown in Figure 6 and 7 and from the current vs. voltage characteristics shown in Figures 10-11. The typical performance at common drive currents is also summarized in Table 7. Table 7: Typical Product Performance at Alternative Drive Currents Color Part Number BXRB-27E0540-A-00 BXRB-30E0540-A-00 BXRB-27G0540-A-00 Warm White BXRB-30G0540-A-00 BXRB-27E0740-A-00 BXRB-30E0740-A-00 BXRB-27G0740-A-00 BXRB-30G0740-A-00 Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) 370 480 495 645 400 520 540 700 330 430 445 580 405 535 550 720 440 580 600 780 365 480 495 645 360 470 485 630 505 680 900 550 740 980 455 615 810 495 665 880 395 520 540 700 565 755 1005 615 820 1090 510 680 905 555 740 980 18.3 19.0 19.1 20.0 18.3 19.0 19.1 20.0 18.3 19.0 19.1 20.0 18.3 19.0 19.1 20.0 27.5 28.5 30 27.5 28.5 30 27.5 28.5 30 27.5 28.5 30 250 350 [1] 365 500 250 350 [1] 365 500 250 350 [1] 365 500 250 350 [1] 365 500 250 [1] 350 500 250 [1] 350 500 250 [1] 350 500 250 [1] 350 500 Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 11 of 25 Table 8: Typical Product Performance at Alternative Drive Currents Color Neutral White Part Number BXRB-40E0810-A-00 BXRB-56C0700-A-00 Cool White BXRB-56C1000-A-00 Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) 610 810 675 900 27.5 28.5 250 [1] 350 1080 510 680 700 900 720 960 1200 565 750 780 1000 800 1070 30.0 18.3 19.0 19.1 20.0 27.5 28.5 500 250 350 [1] 365 500 250 [1] 350 1290 1430 30.0 500 Notes for Table 7 and 8: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Table 6 and 7, with a case temperature maintained at or below 70°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 12 of 25 Mechanical Dimensions Figure 1: Drawing for all ES BXRB arrays. Notes for Figure 1: 1. 2. 3. 4. 5. 6. Slots are for M2.5 or #4 screws. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. Drawings are not to scale. Drawing dimensions are in millimeters. Unless otherwise specified, tolerances are ± 0.20mm. Refer to product Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. 7. The optical center of the LED Array is defined by the mechanical center of the array. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 13 of 25 Typical Radiation Pattern Figure 2: Typical Far Field Radiation Pattern Figure 3: Typical Far Field Polar Radiation Pattern Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 14 of 25 Wavelength Characteristics at Rated Test Current, Tj=25°C Figure 4: Typical Warm White CoolColor WhiteSpectrum Color Spectrum Figure 6: Typical Cooland White 1.2 Relative Intensity 1.0 Cool White Warm White Neutral White 0.8 0.6 0.4 0.2 0.0 400 450 500 550 Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) 600 650 Wavelength 700 750 800 Page 15 of 25 Typical Relative Luminous Flux vs. Current, Tj=25° C Nomalized Luminous Flux Figure 5: Typical Flux vs. Current 2.2 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 BXRB-XXX0540-A BXRB-56C0700-A 0 100 200 300 400 Current (mA) 500 600 700 800 Figure Figure9:6:Typical TypicalFlux Fluxvs. vs.Current Current 2.2 Nomalized Luminous Flux 2.0 1.8 1.6 1.4 BXRB-XXX0740-A BXRB-40E0810-A BXRB-56C1000-A 1.2 1.0 0.8 0.6 0.4 0.2 0.0 0 100 200 300 400 Current (mA) Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) 500 600 700 800 Page 16 of 25 Typical Light Output Characteristics vs. Temperature Figure 9: Figure 7: Typical TypicalFlux Fluxvs. vs.Junction JunctionTemperature Temperature 1.2 Normalized Luminous Flux Neutral White 1.0 0.8 Cool White Warm White 0.6 Warm White 0.4 Cool White Neutral White 0.2 0.0 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) 90 100 110 120 130 Page 17 of 25 Typical Chromaticity Characteristics vs. Temperature Figure 10: Typical x Shif t vs. Junction Temperature Figure 8: Typical ccx Shift vs. Junction Temperature 0.02 Neutral White Warm White 0.01 0.00 -0.01 ∆x -0.02 Cool White -0.03 Warm White Neutral White -0.04 Cool White -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C 90 100 110 120 130 Figure 11: 9: Typical y Shif vs. Junction Temperature Figure Typical ccyt Shift vs. Junction Temperature 0.02 Neutral White Warm White 0.01 0.00 ∆y -0.01 -0.02 Cool White -0.03 Warm White Neutral White -0.04 Cool White -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) 90 100 110 120 130 Page 18 of 25 Typical Forward Current Characteristics at Tj = 25°C Figure 10: Typical Current vs. Voltage, BXRB-XXX0540-A, BXRB-56C0700-A Forward Voltage versus Current 0.7 Current (mA) 0.6 0.5 0.4 0.3 MIN MAX TYP MIN Tc=70 0.2 0.1 0.0 13.0 16.0 19.0 Forward Voltage (V) 22.0 25.0 Figure 11: Typical Current vs. Voltage BXRB-XXX0740-A, BXRB-40E0810-A, BXRA-56C1000 Forward Voltage versus Current 0.7 Current (mA) 0.6 0.5 0.4 0.3 MIN MAX TYP MIN Tc=70 0.2 0.1 0.0 20.0 24.0 28.0 32.0 Forward Voltage (V) Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) 36.0 Page 19 of 25 Product Binning Typical manufacturing processes of semiconductor products result in a variation in performance surrounding the typical data sheet values. In order to minimize variation in the end product or application, Bridgelux bins its LED Arrays for color. Bridgelux LED Arrays are labeled using a 2-digit alphanumeric bin code. This bin code is printed on the back of each LED Array in the following format: AB Where: A B – designates color bin (P3, P4, Q3, etc.) All product packaged within a single tube are of the same color bin combination (or bin code). Using these codes it is possible to determine the best product utilization to deliver the consistency required in a given application. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 20 of 25 Color Binning Information Figure 12: Graph of Warm White Test Bins in xy Color Space 0.44 0.43 3000K 3SDCM 0.42 T3 S3 R3 Q3 Y 0.41 0.40 R4 Q4 0.39 T4 S4 2700K 3SDCM 0.38 0.37 0.41 0.42 0.43 0.44 0.45 0.46 0.47 0.48 0.49 X Table 9: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code Q3 Q4 R3 R4 3SDCM X Y 0.4223 0.4299 0.4431 0.4345 0.4147 0.4223 0.4345 0.4260 0.4345 0.4431 0.4562 0.4468 0.4260 0.4345 0.4468 0.4373 0.4413 0.4325 0.4274 0.4350 0.3990 0.4165 0.4213 0.4033 0.3814 0.3990 0.4033 0.3854 0.4033 0.4213 0.4260 0.4077 0.3854 0.4033 0.4077 0.3893 0.4107 0.4075 0.3958 0.3984 ANSI CCT (K) 3000 3000 3000 Bin Code S3 S4 T4 3000 T3 3000 3SDCM Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) X Y 0.4468 0.4562 0.4688 0.4585 0.4373 0.4468 0.4585 0.4483 0.4585 0.4688 0.4813 0.4703 0.4483 0.4585 0.4703 0.4593 0.4665 0.4557 0.4500 0.4595 0.4077 0.4260 0.4290 0.4104 0.3893 0.4077 0.4104 0.3919 0.4104 0.4290 0.4319 0.4132 0.3919 0.4104 0.4132 0.3944 0.4175 0.4145 0.4026 0.4050 ANSI CCT (K) 2700 2700 2700 2700 2700 Page 21 of 25 Color Binning Information (continued) Figure 13: Graph of Neutral White Test Bins in xy Color Space 0.41 0.40 M3 Y 0.39 0.38 L3 3 SDCM M4 0.37 L4 0.36 0.35 0.36 0.37 0.38 0.39 X 0.40 0.41 Table 10: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code L3 L4 M3 M4 3SDCM X Y 0.3703 0.3736 0.3871 0.3828 0.3670 0.3703 0.3828 0.3784 0.3828 0.3871 0.4006 0.3952 0.3784 0.3828 0.3952 0.3898 0.3881 0.3791 0.3769 0.3845 0.3726 0.3874 0.3959 0.3803 0.3578 0.3726 0.3803 0.3647 0.3803 0.3959 0.4044 0.3880 0.3647 0.3803 0.3880 0.3716 0.3879 0.3823 0.3724 0.3770 Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) ANSI CCT (K) 4000 4000 4000 4000 4000 Page 22 of 25 Color Binning Information (continued) Figure 14: Graph of Cool White Test Bins in xy Color Space Cool White Test Bins Y 0.36 6020 K 0.37 5665 K 0.38 0.35 F3 E3 0.34 F4 E4 5100 K 0.33 0.32 0.31 X Table 11: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code E4 E3 F3 F4 X Y 0.3222 0.3294 0.3293 0.3215 0.3215 0.3293 0.3292 0.3207 0.3292 0.3293 0.3371 0.3376 0.3294 0.3366 0.3371 0.3293 0.3243 0.3306 0.3423 0.3353 0.3353 0.3423 0.3539 0.3462 0.3539 0.3423 0.3493 0.3616 0.3306 0.3369 0.3493 0.3423 Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) ANSI CCT (K) 5700 5700 5700 5700 Page 23 of 25 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes • • • • • • • AN10: Effective Thermal Management of Bridgelux LED Arrays AN11: Assembly Considerations for Bridgelux LED Arrays AN12: Electrical Drive Considerations for Bridgelux LED Arrays AN14: Reliability Data Sheet for Bridgelux LED Arrays AN15: Reflow Soldering of Bridgelux LED Arrays AN16: Optical Considerations for Bridgelux LED Arrays DS19: Bridgelux LED Array Data Sheet for Packing and Labeling Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance. • • • • • • • • • Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 24 of 25 About Bridgelux Bridgelux LED Arrays are developed, manufactured and marketed by Bridgelux, Inc. Bridgelux is a U.S. lighting company and leading developer of technologies and solutions that will transform the $40 billion global lighting industry into a $100 billion market opportunity. Based in Silicon Valley, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for solid state lighting by driving down the cost of light through innovation. Bridgelux’s patented light source technology replaces traditional lighting technologies (such as incandescent, halogen and fluorescent lamps) with integrated, solid-state solutions, enabling lamp and luminaire manufacturers to develop high performance and energy-efficient white light products. The plug and play simplicity of the Bridgelux LED Arrays enable our customers to address the rapidly growing interior and exterior solid state lighting markets, including street lights, retail lighting, commercial lighting and consumer applications. With more than 250 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2011 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux ES Array Series Product Data Sheet DS21 (04/01/11) Page 25 of 25
BXRB-30E0740-A-00 价格&库存
很抱歉,暂时无法提供与“BXRB-30E0740-A-00”相匹配的价格&库存,您可以联系我们找货
