BXRA-W1800-00Q0E
BXRA-W1800-00Q0E
    BRIDGELUX(普瑞)
    LED ES ARRAY WHITE 2000LM
BXRA-W1800-00Q0E 数据手册
Bridgelux ES Array Series Data Sheet DS17 BXRA – W1800, - N2000, - C2500 Introduction The Bridgelux family of LED Array products delivers high performance, compact and cost-effective solidstate lighting solutions to serve the general lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of many conventional lighting sources. The Bridgelux ES Array Series has been specified to enable lamp and luminaire designs surpassing efficacy and quality of light requirements driven by regulatory standards with reasonable system design margins, enabling lighting product compliance to Energy Star, Title 24, Part L and other global standards. The Bridgelux ES Array products provide a high performance alternative to conventional solid state solutions, delivering between 1800 and 2500 lumens under application conditions in warm, neutral and cool white color temperatures. These compact high flux density light sources deliver uniform high quality illumination without pixilation or the multiple shadow effect caused by LED component based solutions. To simplify system design for appropriate light output, Bridgelux LED Arrays are specified to deliver performance under typical use conditions. These integrated plug and play solutions reduce system complexity and enable miniaturized costeffective lamp and luminaire designs. Lighting system designs incorporating these LED Arrays deliver comparable performance to that of 20-100 Watt incandescent and halogen, 7-42 Watt compact fluorescent, and 18-50 Watt HID based luminaires and feature increased system level efficacy and service life. Typical applications include replacement lamps, task, accent, spot, retail, track, down light, low bay, wide area, security, wall pack and street lighting. Features Benefits • Compact high flux density light source • Enhanced optical control • Uniform high quality illumination • Clean white light without pixilation • Streamlined thermal path • • Energy Star / ANSI compliant binning structure Significantly reduced thermal resistance and increased operating temperatures • Uniform consistent white light More energy efficient than incandescent, halogen and fluorescent lamps • Lower operating costs • Increased safety • Low voltage DC operation • • Instant light with unlimited dimming Easy to use with daylight and motion detectors to enable increased energy savings • 5-year warranty • Reduced maintenance costs • RoHS compliant and Pb free • Environmentally friendly, no disposal issue • 1 0 1 P o rt o l a A v e n u e , L i v e rm o re , C A 9 4 5 5 1 • T e l : (9 2 5 ) 5 8 3 -8 4 0 0 • Fa x: (9 2 5 ) 5 8 3 -8 4 0 1 • ww w. b ri d g e l u x. c o m Table of Contents Page Product Nomenclature 3 Average Lumen Maintenance Characteristics 3 Environmental Compliance 3 UL Recognition 4 Minor Product Change Policy 4 Cautionary Statements 4 Case Temperature Measurement Point 5 Flux Characteristics 6 Optical Characteristics 7 Electrical Characteristics 8 Absolute Minimum and Maximum Ratings 9 Typical Performance at Alternative Drive Currents 10 Mechanical Dimensions 12 Typical Radiation Pattern 13 Wavelength Characteristics at Rated Test Current, Tj=25°C 14 Typical Relative Luminous Flux vs. Current, Tj=25° C 16 Typical Light Output Characteristics vs. Temperature 17 Typical Chromaticity Characteristics vs. Temperature 18 Typical Forward Current Characteristics at Tj = 25°C 19 Current Derating Curves 20 Product Binning 21 Color Binning Information 22 Mechanical Assembly and Handling 25 Product Packaging and Labeling 26 Packaging Tube Design 29 Design Resources 30 Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 2 of 31 Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRA–ABCDE–RRRRR Where: B X R A – designates product family A – designates color, C for Cool White, N for Neutral White and W for Warm White B C D – designates LED Array product flux, 18 for a 1800 lumen array, and 20 for a 2000 lumen array, etc E – designates product family R R R R R – used to designate product options, 00000 by default The base product part number (BXRA-ABCDE) is indicated on each individual unit, printed on the bottom of the LED Array. Average Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation with case temperature maintained at or below 70°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Bridgelux LED Arrays are compliant to the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux will not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 3 of 31 UL Recognition Bridgelux has UL Recognition for all the LED Array products listed in this data sheet. Please refer to the UL file E333389 for the latest list of UL Recognized Arrays. Bridgelux uses UL Recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 Driver to facilitate the UL listing process. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Do not touch the optical area of the LED Array. Avoid any contact with the optical area. Applying stress to the yellow phosphor resin area can result in damage to the LED Array. Optics and reflectors must not be mounted in contact with the white phosphor resin area or the white ring that surrounds the yellow phosphor area. Using the white ring to secure optics can result in damage to the LED Array as the ring is not designed to act as a mechanical locating feature. Optical devices may be mounted on the top surface of the LED Array substrate outside of the white ring maximum OD as specified in the product data sheet. Use the mechanical features of the LED Array substrate edges and/or mounting holes to locate and secure the optical device as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below their rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED Array. Please consult Application Note AN11 for additional information. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 4 of 31 Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Measuring the top surface of the product can lead to inaccurate results due to the poor thermal conductivity of the top layers of the array such as the solder mask and other materials. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 5 of 31 Flux Characteristics Table 1: Flux Characteristics Color ANSI CCT (K) 2700K 2700K Warm White 3000K 3000K Neutral White 4000K Cool White 5700K Part Number BXRAW180000S0E BXRAW180000S0G BXRAW180000Q0E BXRAW180000Q0G BXRAN200000L0E BXRAC250000E0C Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Test Current [2] (mA) [3] Minimum Luminous Flux фv (lm), [1] Tj=25°C 80 1650 1650 1840 700 90 1500 1500 1665 700 80 1800 1800 2000 700 90 1600 1600 1800 700 80 2000 2000 2200 700 70 2400 2400 2650 700 CRI Notes for Table 1: 1. Bridgelux maintains a ± 7% tolerance of flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Typical performance when driven with direct current using Bridgelux test set-up. Please contact a Bridgelux sales representative for additional details Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 6 of 31 Optical Characteristics Table 2: Optical Characteristics Color Temperature [1],[2],[3] (CCT) Color ANSI CCT (K) 2700K 2700K Warm White 3000K 3000K Neutral White 4000K Cool White 5700K Typical Center Beam Candle Power [5] (cd) Min Typ Max Minimum Color Rendering [4] Index 2580 K 2725 K 2870 K 80 120 585 2580 K 2725 K 2870 K 90 120 530 2870 K 3045 K 3220 K 80 120 635 2870 K 3045 K 3220 K 90 120 575 3700 K 4000 K 4250 K 80 120 700 5310 K 5665 K 6020 K 70 120 845 Part Number BXRAW180000S0E BXRAW180000S0G BXRAW180000Q0E BXRAW180000Q0G BXRAN200000L0E BXRAC250000E0C Typical Viewing Angle (Degrees) [6] 2 θ½ Notes for Table 2: 1. 2. 3. 4. 5. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Refer to Flux Characteristic Table for test current data. Product is binned for color in x y coordinates. Higher CRI options available upon request. Center beam candle power is a calculated value based on lambertian radiation pattern at nominal test current. 6. Viewing angle is the off axis angle from the centerline where Iv is ½ of the peak value. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 7 of 31 Electrical Characteristics Table 3: Electrical Characteristics Forward Voltage Vf [2] (V) Color Base Part [1] Number Warm White Neutral White Cool White BXRA-W1800XXXXX BXRA-N2000XXXXX BXRA-C2500XXXXX Test Current [3] (mA) Typical Temperature Coefficient of Forward Voltage (mV/°C) ΔVf/ΔTj Typical Thermal Resistance Junction to Case (°C/W) RѲ j-c Min Typ Max 33.7 38.1 41.9 700 -12 to -36 0.75 33.7 38.1 41.9 700 -12 to -36 0.75 33.7 38.1 41.9 700 -12 to -36 0.75 Notes for Table 3: 1. XXXXX indicates specification applies for all versions with base number. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 8 of 31 Absolute Minimum and Maximum Ratings Table 4: Minimum and Maximum Current and Reverse Voltage Ratings Part Number Maximum DC Forward Current (mA) Minimum DC Forward [2] Current (mA) Maximum Peak Pulsed [3] Current (mA) Maximum Reverse Voltage [1] (Vr) 1000 300 1400 -60 Volts 1000 300 1400 -60 Volts 1000 300 1400 -60 Volts BXRA-W1800XXXXX BXRA-N2000XXXXX BXRA-C2500XXXXX Notes for Table 4: 1. Light emitting diodes are not designed to be driven in reverse voltage. 2. Driving these high current devices at low currents can result in variations in performance. For low current operation pulse width modulation is recommended. 3. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature 3.5 seconds, 350°C or lower Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 9 of 31 Typical Performance at Alternative Drive Currents The Bridgelux LED Arrays are tested and binned against the specifications shown in Tables 1, 2 and 3. Customers also have options to drive the LED Arrays at alternative drive currents dependent on the specific application. The typical performance at any drive current can be derived from the flux vs. current characteristics shown in Figure 7 and from the current vs. voltage characteristics shown in Figure 11. The typical performance at common drive currents is also summarized in Table 6. Table 6: Typical Product Performance at Alternative Drive Currents Color Part Number Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) 2700K BXRAW180000S0E 900 1260 1650 1000 1375 1840 35.5 36.7 38.1 350 500 [1] 700 2700K BXRAW180000S0G 810 1125 1475 900 1250 1650 35.5 36.7 38.1 350 500 [1] 700 3000K BXRAW180000Q0E 1000 1350 1800 1100 1500 2000 35.5 36.7 38.1 350 500 [1] 700 3000K BXRAW180000Q0G 875 1225 1625 975 1350 1800 35.5 36.7 38.1 350 500 [1] 700 ANSI CCT (K) Warm White Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 10 of 31 Typical Performance at Alternative Drive Currents (continued) Table 7: Typical Product Performance at Alternative Drive Currents Color Neutral White ANSI CCT (K) 4000K Part Number BXRAN200000L0E Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) 1075 1200 35.5 350 1475 1975 1650 2200 36.7 38.1 500 [1] 700 Table 8: Typical Product Performance at Alternative Drive Currents Color Cool White ANSI CCT (K) 5700K Part Number Typical Luminous Flux фv (lm), Tcase=60°C Typical Luminous Flux фv (lm), Tj=25°C Typical Forward Voltage Vf (V) Forward Current [2] (mA) BXRAC250000E0C 1300 1800 2400 1450 2000 2650 35.5 36.7 38.1 350 500 [1] 700 Notes for Table 6, 7 and 8: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Table 6, with a case temperature maintained at or below 70°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 11 of 31 Mechanical Dimensions Figure 1: Drawing for 2000 lumen product options (part numbers BXRA-C2500, BXRA-N2000, BXRA-W1800 Notes for Figure 1: 1. 2. 3. 4. 5. 6. 7. 8. 9. 10. Mounting holes are for M2.5 or #4 screws. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. Drawings are not to scale. Drawing dimensions are in millimeters. Bridgelux recommends two tapped holes for mounting screws with 26.92 ± 0.10mm center-to-center spacing. Unless otherwise specified, tolerances are ± 0.10mm. Dimensions with parentheses “( )” are for reference only. Refer to product Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. The optical center of the LED Array is defined by the mechanical center of the array. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 12 of 31 Typical Radiation Pattern Figure 2: Typical Spatial Radiation Pattern Figure 3: Typical Polar Radiation Pattern Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 13 of 31 Wavelength Characteristics at Rated Test Current, Tj=25°C Figure 4: Typical Warm White Color Spectrum Figure 5: Typical Neutral White Color Spectrum Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 14 of 31 Wavelength Characteristics at Rated Test Current, Tj=25°C (Continued) Figure 6: Typical Cool White Color Spectrum Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 15 of 31 Typical Relative Luminous Flux vs. Current, Tj=25° C Figure Typical Fluxvs.vs. Current Figure 7:7:Typical Flux Current 1.80 Normalized Luminous Flux 1.60 1.40 1.20 1.00 0.80 0.60 BXRA-W1800 BXRA-N2000 BXRA-C2500 0.40 0.20 0.00 0 200 400 600 800 1000 1200 1400 1600 Current (mA) Note for Figure 7: Bridgelux does not recommend driving high power LED Arrays at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 16 of 31 Typical Light Output Characteristics vs. Temperature Figure Flux vs. vs. Junction JunctionTemperature Temperature Figure11: 8: Typical Typical Flux Normalized Luminous Flux 1.20 1.00 0.80 0.60 Cool White 0.40 Warm White Neutral White 0.20 0.00 -10 0 10 20 30 40 50 60 70 80 90 100 Junction Temperature, ºC Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 17 of 31 Typical Chromaticity Characteristics vs. Temperature Figure Typical xx Shift Shift vs. vs. Junction JunctionTemperature Temperature Figure12: 9: Typical 0.02 0.01 0.00 ∆x -0.01 -0.02 -0.03 Cool White -0.04 Neutral White Warm White -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, ºC Figure Temperature Figure13: 10: Typical Typical yy Shift Shift vs. vs. Junction Junction Temperature 0.02 0.01 0.00 ∆y -0.01 -0.02 -0.03 Cool White -0.04 Neutral White Warm White -0.05 -0.06 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, ºC Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 18 of 31 Forward Current Characteristics at Tj = 25°C Figure 11: Current vs. Voltage, BXRA-W1800, BXRA-N2000 and BXRA-C2500 Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 19 of 31 Current Derating Curves The graph below illustrates the relationship between the system thermal resistance, drive current, and ambient temperature. Please note that absolute maximum ratings requirements, including that of maximum case temperature, must be adhered to in the system design. The thermal resistance values indicated in Figure 12 are total system values (junction to ambient) including the thermal resistance of the LED Array. Individual LED Array thermal resistance values are listed in Table 3. Figure 12: Derating Curve, 700mA Drive Current If - Forward Current (mA) 800 700 600 500 1.0˚C/W 400 300 0.7˚C/W 200 0.4˚C/W 100 0 0 10 20 30 40 50 60 70 80 90 100 110 120 Ta - Ambient Temperature, C Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 20 of 31 Product Binning Typical manufacturing processes of semiconductor products result in a variation in performance surrounding the typical data sheet values. In order to minimize variation in the end product or application, Bridgelux bins its LED Arrays for color. Bridgelux LED Arrays are labeled using a 3-digit alphanumeric bin code. This bin code is printed on the back of each LED Array in the following format: BCD Where: B C – designates color bin (P3, P4, Q3, etc.) D – designates color rendering index (0, A, B, C, etc) All product packaged within a single tube are of the same color bin combination (or bin code). Using these codes it is possible to determine the best product utilization to deliver the consistency required in a given application. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 21 of 31 Color Binning Information Figure 13: Graph of Warm White Test Bins in xy Color Space 0.44 0.43 T3 S3 Y 0.42 3000K 3SDCM 0.41 R3 Q3 T4 S4 0.40 R4 Q4 2700K 3SDCM 0.39 0.38 0.37 0.41 0.42 0.43 0.44 0.45 0.46 0.47 0.48 0.49 X Table 9: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code Q3 Q4 R3 R4 3SDCM X Y 0.4223 0.4299 0.4431 0.4345 0.4147 0.4223 0.4345 0.4260 0.4345 0.4431 0.4562 0.4468 0.4260 0.4345 0.4468 0.4373 0.4413 0.4325 0.4274 0.4350 0.3990 0.4165 0.4213 0.4033 0.3814 0.3990 0.4033 0.3854 0.4033 0.4213 0.4260 0.4077 0.3854 0.4033 0.4077 0.3893 0.4107 0.4075 0.3958 0.3984 ANSI CCT (K) Bridgelux ES Array Series Product Data Sheet DS17 3000 3000 3000 Bin Code S3 S4 T4 3000 T3 3000 3SDCM September 8, 2011 X Y 0.4468 0.4562 0.4688 0.4585 0.4373 0.4468 0.4585 0.4483 0.4585 0.4688 0.4813 0.4703 0.4483 0.4585 0.4703 0.4593 0.4665 0.4557 0.4500 0.4595 0.4077 0.4260 0.4290 0.4104 0.3893 0.4077 0.4104 0.3919 0.4104 0.4290 0.4319 0.4132 0.3919 0.4104 0.4132 0.3944 0.4175 0.4145 0.4026 0.4050 ANSI CCT (K) 2700 2700 2700 2700 2700 Page 22 of 31 Color Binning Information (continued) Figure 14: Graph of Neutral White Test Bins in xy Color Space 0.41 0.40 M3 Y 0.39 4000K 3SDCM 0.38 L3 M4 0.37 L4 0.36 0.35 0.36 0.37 0.38 0.39 0.40 0.41 Z Table 10: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code L3 L4 M3 M4 3SDCM Bridgelux ES Array Series Product Data Sheet DS17 X Y 0.3703 0.3736 0.3871 0.3828 0.3670 0.3703 0.3828 0.3784 0.3828 0.3871 0.4006 0.3952 0.3784 0.3828 0.3952 0.3898 0.3881 0.3791 0.3769 0.3845 0.3726 0.3874 0.3959 0.3803 0.3578 0.3726 0.3803 0.3647 0.3803 0.3959 0.4044 0.3880 0.3647 0.3803 0.3880 0.3716 0.3879 0.3823 0.3724 0.3770 September 8, 2011 ANSI CCT (K) 4000 4000 4000 4000 4000 Page 23 of 31 Color Binning Information (continued) Figure 15: Graph of Cool White Test Bins in xy Color Space 0K H4 G4 E3 D3 C3 0.32 C4 0.31 0.30 0.31 K E4 D4 0.32 0.33 0.34 K F4 474 5 0.33 F3 5310 K 0.34 H3 G3 5028 0K 704 0.35 6 53 0.36 Y 60 20 K 0.37 5665 K 0.38 0.35 0.36 X Table 11: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code E3 E4 F3 F4 Bridgelux ES Array Series Product Data Sheet DS17 X Y 0.3215 0.3293 0.3292 0.3207 0.3222 0.3294 0.3293 0.3215 0.3292 0.3293 0.3371 0.3376 0.3294 0.3366 0.3371 0.3293 0.3353 0.3423 0.3539 0.3462 0.3243 0.3306 0.3423 0.3353 0.3539 0.3423 0.3493 0.3616 0.3306 0.3369 0.3493 0.3423 ANSI CCT (K) 5700 5700 5700 5700 September 8, 2011 Page 24 of 31 Mechanical Assembly and Handling Recommended assembly is illustrated below. When handling parts, please avoid contacting and do not apply stress to the resin area (see Figure 1, resin area is indicated in yellow). Product should be firmly secured onto appropriate heat sink by fastening M2.5 or #4 screws on both sides of the product as illustrated in Figure 16. The recommended center-to-center spacing for these the two tapped holes for mounting screws is 19.20 ± 0.05mm for hexagonal star products and 26.92 ± 0.10mm for rectangular array products. Bridgelux recommends the use of hard non-electrically conductive flat washers with lock washers. Refer to Application Note AN11 – Handling and Assembly of Bridgelux LED Arrays, for more details. A thin layer of thermal grease should be applied to the bottom surface of the LED Array, between the bottom of the array and the heat sink. All air gaps and voids between the heat sink and array should be eliminated. Ensure that sufficient thermal grease is used to cover the entire bottom surface of the array, but not so much that the thermal grease creeps up to the top of the array. Figure 16: Recommended Assembly Method Drawing Not to Scale Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 25 of 31 Product Packaging and Labeling All Bridgelux LED Array products are 100% tested, binned and labeled. Products are labeled by printing pertinent information on the back side of the LED Array. The following format is used for labeling the Bridgelux LED Arrays: ABCD BXRA–xxxxx EFGHJ–WWYY Where: B C D – designates the bin code (Q30, etc.) x x x x x – designates the base part number (W3000, etc.) E F G H J or E F G H J K– designates the production lot code (12345, etc.). The Lot Code may be a five or six character number. W W Y Y – designates the date code (production week and production year, 0210, etc.) Individual Bridgelux LED Arrays are packaged in tubes for shipment. All product packaged within a single tube are of the same flux and color bin combination (or bin code). Each tube is labeled with the information required for effective inventory management. An example of the tube label is shown in Figure 18. Figure 17: Tube Label Example Where: X X X X X – designates the base part number (W3000, etc.) B C D – designates the bin code (Q30, etc.) E F G H J or E F G H J K – designates the production lot code (12345, etc.). The lot code may be a five or six character number. W W Y Y – designates the date code (production week and production year, 0210, etc.) Z Z – designates the quantity (10 products per tube). Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 26 of 31 Product Packaging and Labeling (continued) Tubes of Bridgelux LED Arrays are packaged in bags prior to loading into boxes for shipment. One tube is loaded per bag, resulting in an SPI of 10. All products packaged within a single bag are of the same flux and color bin combination (or bin code). Each bag is labeled with the information required for effective inventory management. An example of the bag label is shown in Figure 18. Figure 18: Bag Label Example Where: X X X X X – designates the base part number (W3000, etc.) B C D – designates the bin code (Q30, etc.) E F G H J – designates product lot code W W Y Y – designates the date code (production week and production year, 0210, etc.) Z Z Z – designates the quantity (10 products per tube). Bags of Bridgelux LED Arrays are packaged in boxes prior to shipment. Multiple bags are packaged into a box. All products packaged within a box are of the same base part number. Each box is labeled with the information required for effective inventory management. An example of the box label shown in Figure 19. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 27 of 31 Product Packaging and Labeling (continued) Figure 19: Box Label Example Where: X X X X X– designates the base part number (W3000, etc.) R R R R R – used to designate product options, 00000 by default. Q Q Q – designates the total quantity of LED Arrays contained in the box. E F G H J – designates product lot code. (The lot code may be a five or six character number.) B C D – designates the bin code (Q30, etc.) W W Y Y – designates the date code (production week and production year, 0210, etc.) Z Z Z – designates the quantity per listed bin code contained in the box. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 28 of 31 Packaging Tube Design Figure 20: Tube Design for Rectangular Array Products Notes for Figures 20: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 29 of 31 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes • • • • • • AN10: AN11: AN12: AN14: AN15: AN16: Effective Thermal Management of Bridgelux LED Arrays Assembly Considerations for Bridgelux LED Arrays Electrical Drive Considerations for Bridgelux LED Arrays Reliability Data Sheet for Bridgelux LED Arrays Reflow Soldering of Bridgelux LED Arrays Optical Considerations for Bridgelux LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance. • • • • • • • • • Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 30 of 31 About Bridgelux Bridgelux LED Arrays are developed, manufactured and marketed by Bridgelux, Inc. Bridgelux is a U.S. lighting company and leading developer of technologies and solutions that will transform the $40 billion global lighting industry into a $100 billion market opportunity. Based in Silicon Valley, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for solid state lighting by driving down the cost of light through innovation. Bridgelux’s patented light source technology replaces traditional lighting technologies (such as incandescent, halogen and fluorescent lamps) with integrated, solid-state solutions, enabling lamp and luminaire manufacturers to develop high performance and energy-efficient white light products. The plug and play simplicity of the Bridgelux LED Arrays enable our customers to address the rapidly growing interior and exterior solid state lighting markets, including street lights, retail lighting, commercial lighting and consumer applications. With more than 500 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2011 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux ES Array Series Product Data Sheet DS17 September 8, 2011 Page 31 of 31
BXRA-W1800-00Q0E 价格&库存
很抱歉,暂时无法提供与“BXRA-W1800-00Q0E”相匹配的价格&库存,您可以联系我们找货
