BXRA-35E0800-B-00
BXRA-35E0800-B-00
    BRIDGELUX(普瑞)
    LED Lighting COBs, Engines, Modules Chip On Board (COB) ES White, Warm Rectangle
BXRA-35E0800-B-00 数据手册
Bridgelux ES Rectangle Array Series Product Data Sheet DS24 BXRA-xxx0800, BXRA-xxx1200, BXRA-xxx2000, BXRA-40Exxxx, BXRA-5xC1100, BXRA-5xC1600, BXRA-5xC2600 Introduction The Bridgelux family of LED Array products delivers high performance, compact and cost-effective solidstate lighting solutions to serve the general lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of many conventional lighting sources. The Bridgelux ES Array Series enables lamp and luminaire designs surpassing efficacy and quality of light requirements driven by regulatory standards with reasonable system design margins, enabling lighting product compliance to Energy Star, DLC, Title 24, Part L and other global standards. The Bridgelux ES Array products are a high performance alternative to conventional solid state solutions, delivering between 700 and 3000 lumens under application conditions in warm, neutral and cool white color temperatures. These compact high flux density light sources deliver uniform high quality illumination without pixilation or the multiple shadow effect caused by LED component based solutions. To simplify system design for appropriate light output, Bridgelux LED Arrays are specified to deliver performance under typical use conditions. These integrated plug and play solutions reduce system complexity and enable miniaturized costeffective lamp and luminaire designs. Lighting system designs incorporating these LED Arrays deliver comparable performance to that of 60-200 Watt incandescent and halogen, 7-42 Watt compact fluorescent, and 18-50 Watt HID based luminaires and feature increased system level efficacy and service life. Typical applications include replacement lamps, task, accent, spot, retail, track, down light, low bay, wide area, security, wall pack and street lighting. Features Benefits • Compact high flux density light source • Enhanced optical control • Uniform high quality illumination • Clean white light without pixilation • Minimum 70, 80 and 90 CRI options • High quality true color reproduction • Streamlined thermal path • • Energy Star / ANSI compliant color binning structure with 3SDCM options Significantly reduced thermal resistance and increased operating temperatures • Uniform consistent white light More energy efficient than incandescent, halogen and fluorescent lamps • Lower operating costs • Increased safety • Low voltage DC operation • • Instant light with unlimited dimming Easy to use with daylight and motion detectors to enable increased energy savings • 5-Year warranty • Reduced maintenance costs • RoHS compliant and Pb free • Environmentally friendly, no disposal issue • 1 0 1 P o rt o l a A v e n u e , L i v e rm o re , C A 9 4 5 5 1 • T e l : (9 2 5 ) 5 8 3 -8 4 0 0 • Fa x: (9 2 5 ) 5 8 3 -8 4 0 1 • ww w. b ri d g e l u x. c o m Table of Contents Page Product Nomenclature 3 Average Lumen Maintenance Characteristics 3 IES LM-80 Test Data 3 Environmental Compliance 4 UL Recognition 4 Minor Product Change Policy 4 Cautionary Statements 4 Case Temperature Measurement Point 5 Selection Guide 6 The following configurations are available: 6 Flux Characteristics 6 Optical Characteristics 9 Electrical Characteristics 10 Absolute Minimum and Maximum Ratings 11 Absolute Minimum and Maximum Ratings (continued) 12 Typical Performance at Alternative Drive Currents 13 Typical Performance at Alternative Drive Currents (continued) 14 Mechanical Dimensions 15 Typical Radiation Pattern 16 Wavelength Characteristics at Rated Test Current, Tj=25°C 17 Typical Light Output Characteristics vs. Temperature 19 Typical Chromaticity Characteristics vs. Temperature 20 Forward Current Characteristics 21 Forward Current Characteristics (continued) 22 Color Binning Information 23 Design Resources 26 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 2 of 27 Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRA – AB C DEFG – H – IJ - KLM Where: BXRA – Designates product family AB – Designates the nominal ANSI color temperature; 27 = 2700K; 30 = 3000K, etc. C - Designates minimum CRI; C = 70, E = 80, G = 90 DEFG - Designates Nominal Flux; 0800 = 800lm, 1200 = 1200lm, 2000 = 2000lm, etc. H – Designates array configuration IJ – Designates CCT Bin options 3000K as an example: 00 = Full ANSI: Q3, Q4, R3, R4 03 = 3 SDCM KLM – Designates wire option Average Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation with case temperature maintained at or below 85°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. IES LM-80 Test Data Bridgelux has carried out extensive testing on multiple LED arrays according to the IES LM-80 test protocols. LM80 data is available to support all BXRA LED array products. The IES LM-80 qualification test method is required for an LED light source. The LM-80 test method does not apply to an LED luminaire light fixture. LM-80 is a rigorous test procedure that has been designed to provide LED light source test data to support an ENERGY STAR rating for a luminaire light fixture. When a manufacturer requires an ENERGY STAR rating for a fixture, the manufacture must have the luminaire light fixture tested to LM-79 by an accredited test facility. This test ensures that the fixture meets the photometric performance required for the ENERGY STAR rating under the specified operating conditions of the fixture. The fixture manufacturer must provide an LM-80 report with the appropriate test data to support the operating conditions of the fixture that is to be submitted. Bridgelux can supply an LM-80 report for specific requests, contact your local Bridgelux sales representative. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 3 of 27 Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Bridgelux LED Arrays comply with the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). UL Recognition Bridgelux secures UL Recognition for all the LED Array products. Please refer to the UL file E333389 for the latest list of UL Recognized Arrays. Bridgelux uses UL Recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 Driver to facilitate the UL listing process. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Avoid any contact with the optical area. Do not touch the optical area of the LED Array or apply stress to the yellow phosphor resin area – it could damage to the LED Array. Optics and reflectors must not be mounted in contact with the yellow phosphor resin area or the white ring that surrounds the yellow phosphor area. Using the white ring to secure optics can result in damage to the LED Array as the ring is not designed to act as a mechanical locating feature. Optical devices may be mounted on the top surface of the LED Array substrate outside of the white ring maximum OD as specified in the product data sheet. Use the mechanical features of the LED Array substrate edges and/or mounting holes to locate and secure the optical device as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below their rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 4 of 27 CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED Array. Please consult Application Note AN11 for additional information. Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Measuring the top surface of the product can lead to inaccurate results due to the poor thermal conductivity of the top layers of the array such as the solder mask and other materials. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 5 of 27 Selection Guide The following configurations are available Table 1: Selection Guide for ES Rectangular Arrays BXRA Part [1] Number 1 CCT CRI (Nominal) (min) Typical DC Flux Tcase= 70ºC Typical Pulsed Flux Tj = 25ºC (lm) (lm) Test Current Efficacy Vf Power (mA) (Typ) (V) (Typ) (W) (Typ at Tj 25ºC) (lm/W) BXRA-27E0800-B-00 2700 80 855 950 500 20.7 10.4 92 BXRA-27G0800-B-00 2700 90 730 810 500 20.7 10.4 78 BXRA-27E1200-B-00 2700 80 1260 1400 500 29.6 14.8 95 BXRA-27G1200-B-00 2700 90 1070 1190 500 29.6 14.8 80 BXRA-27E2000-B-00 2700 80 2010 2260 700 37.0 25.9 87 BXRA-27G2000-B-00 2700 90 1750 1975 700 37.0 25.9 76 BXRA-30E0800-B-00 3000 80 900 1010 500 20.7 10.4 98 BXRA-30G0800-B-00 3000 90 800 890 500 20.7 10.4 86 BXRA-30E1200-B-00 3000 80 1320 1475 500 29.6 14.8 100 BXRA-30G1200-B-00 3000 90 1170 1300 500 29.6 14.8 88 BXRA-30E2000-B-00 3000 80 2130 2400 700 37.0 25.9 93 BXRA-30G2000-B-00 3000 90 1780 2000 700 37.0 25.9 77 BXRA-35E0800-B-00 3500 80 980 1095 500 20.7 10.4 106 BXRA-35E1200-B-00 3500 80 1430 1595 500 29.6 14.8 108 BXRA-35E2000-B-00 3500 80 2270 2550 700 37.0 25.9 98 BXRA-40E0950-B-00 4000 80 1030 1150 500 20.7 10.4 111 BXRA-40E1350-B-00 4000 80 1520 1690 500 29.6 14.8 114 BXRA-40E2200-B-00 4000 80 2450 2750 700 37.0 25.9 106 BXRA-50C1100-B-00 5000 70 1180 1320 500 20.7 10.4 128 BXRA-50C1600-B-00 5000 70 1725 1920 500 29.6 14.8 130 BXRA-50C2600-B-00 5000 70 2760 3100 700 37.0 25.9 120 BXRA-56C1100-B-00 5600 70 1180 1320 500 20.7 10.4 128 BXRA-56C1600-B-00 5600 70 1725 1920 500 29.6 14.8 130 BXRA-56C2600-B-00 5600 70 2760 3100 700 37.0 25.9 120 3SDCM (3-step) color control available on certain configurations Color Control Options Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 6 of 27 ES LED Series Arrays are available in the following color control options. Table 2: Color Control Options Product CCT CRI 7SDCM Part Number 3SDCM Part Number ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array 2700K 2700K 2700K 2700K 2700K 2700K 3000K 3000K 3000K 3000K 3000K 3000K 3500K 3500K 3500K 4000K 4000K 4000K 5000K 5000K 5000K 5600K 5600K 5600K 80 90 80 90 80 90 80 90 80 90 80 90 80 80 80 80 80 80 70 70 70 70 70 70 BXRA-27E0800-B-00 BXRA-27G0800-B-00 BXRA-27E1200-B-00 BXRA-27G1200-B-00 BXRA-27E2000-B-00 BXRA-27G2000-B-00 BXRA-30E0800-B-00 BXRA-30G0800-B-00 BXRA-30E1200-B-00 BXRA-30G1200-B-00 BXRA-30E2000-B-00 BXRA-30G2000-B-00 BXRA-35E0800-B-00 BXRA-35E1200-B-00 BXRA-35E2000-B-00 BXRA-40E0950-B-00 BXRA-40E1350-B-00 BXRA-40E2200-B-00 BXRA-50C1100-B-00 BXRA-50C1600-B-00 BXRA-50C2600-B-00 BXRA-56C1100-B-00 BXRA-56C1600-B-00 BXRA-56C2600-B-00 BXRA-27E0800-B-03 BXRA-27G0800-B-03 BXRA-27E1200-B-03 BXRA-27G1200-B-03 BXRA-27E2000-B-03 BXRA-27G2000-B-03 BXRA-30E0800-B-03 BXRA-30G0800-B-03 BXRA-30E1200-B-03 BXRA-30G1200-B-03 BXRA-30E2000-B-03 BXRA-30G2000-B-03 BXRA-35E0800-B-03 BXRA-35E1200-B-03 BXRA-35E2000-B-03 BXRA-40E0950-B-03 BXRA-40E1350-B-03 BXRA-40E2200-B-03 Not Available Not Available Not Available Not Available Not Available Not Available Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 7 of 27 Flux Characteristics Table 3: Flux Characteristics Color ANSI CCT (K) BXRA Part Number CRI [4] (min) Typical DC Flux Tcase= 70ºC (lm) 2700 Warm White 3000 3500 Neutral White 4000 5000 Cool White 5600 BXRA-27E0800-B-00 BXRA-27G0800-B-00 BXRA-27E1200-B-00 BXRA-27G1200-B-00 BXRA-27E2000-B-00 BXRA-27G2000-B-00 BXRA-30E0800-B-00 BXRA-30G0800-B-00 BXRA-30E1200-B-00 BXRA-30G1200-B-00 BXRA-30E2000-B-00 BXRA-30G2000-B-00 BXRA-35E0800-B-00 BXRA-35E1200-B-00 BXRA-35E2000-B-00 BXRA-40E0950-B-00 BXRA-40E1350-B-00 BXRA-40E2200-B-00 BXRA-50C1100-B-00 BXRA-50C1600-B-00 BXRA-50C2600-B-00 BXRA-56C1100-B-00 BXRA-56C1600-B-00 BXRA-56C2600-B-00 80 90 80 90 80 90 80 90 80 90 80 90 80 80 80 80 80 80 70 70 70 70 70 70 [1, 3] 855 730 1260 1070 2010 1750 900 800 1320 1170 2130 1780 980 1430 2270 1030 1520 2450 1180 1725 2760 1180 1725 2760 Minimum Pulsed Flux Tj= 25ºC (lm) [1, 2] 850 720 1200 1020 1980 1730 900 790 1270 1120 2110 1850 970 1370 2280 1030 1450 2400 1170 1650 2740 1170 1650 2740 Typical Pulsed Flux Tj = 25ºC Test Current 950 810 1400 1190 2260 1975 1010 890 1475 1300 2400 2000 1095 1595 2550 1150 1690 2750 1320 1920 3100 1320 1920 3100 500 500 500 500 700 700 500 500 500 500 700 700 500 500 700 500 500 700 500 500 700 500 500 700 (lm) [1, 2] (mA) [2] Notes for Table 3: 1. Bridgelux maintains a ± 7% tolerance of flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Typical performance when driven at DC (direct current) test current with LED Array case temperature maintained at 70°C, mounted to heat sink with thermal interface material. Please contact a Bridgelux sales representative for additional details. 4. Typical R9 value for 90 CRI product options is 50. 5. Reference Table 8 and 9 for typical performance at other driver currents (including those commonly available in the market). Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 8 of 27 Optical Characteristics Table 4: Optical Characteristics Color Temperature (CCT) ANSI CCT (K) Color 2700 Warm White 3000 3500 Neutral White 4000 5000 Cool White 5600 [1], [2], [3] Min Typ Max Minimum Color Rendering Index 2580 K 2580 K 2580 K 2580 K 2580 K 2580 K 2870 K 2870 K 2870 K 2870 K 2870 K 2870 K 3220 K 3220 K 3220 K 3700 K 3700 K 3700 K 5028 K 5028 K 5028 K 5310 K 5310 K 5310 K 2725 K 2725 K 2725 K 2725 K 2725 K 2725 K 3045 K 3045 K 3045 K 3045 K 3045 K 3045 K 3465 K 3465 K 3465 K 4000 K 4000 K 4000 K 5100 K 5100 K 5100 K 5665 K 5665 K 5665 K 2870 K 2870 K 2870 K 2870 K 2870 K 2870 K 3220 K 3220 K 3220 K 3220 K 3220 K 3220 K 3710 K 3710 K 3710 K 4250 K 4250 K 4250 K 5665 K 5665 K 5665 K 6020 K 6020 K 6020 K 80 90 80 90 80 90 80 90 80 90 80 90 80 80 80 80 80 80 70 70 70 70 70 70 BXRA Part Number BXRA-27E0800-B-00 BXRA-27G0800-B-00 BXRA-27E1200-B-00 BXRA-27G1200-B-00 BXRA-27E2000-B-00 BXRA-27G2000-B-00 BXRA-30E0800-B-00 BXRA-30G0800-B-00 BXRA-30E1200-B-00 BXRA-30G1200-B-00 BXRA-30E2000-B-00 BXRA-30G2000-B-00 BXRA-35E0800-B-00 BXRA-35E1200-B-00 BXRA-35E2000-B-00 BXRA-40E0950-B-00 BXRA-40E1350-B-00 BXRA-40E2200-B-00 BXRA-50C1100-B-00 BXRA-50C1600-B-00 BXRA-50C2600-B-00 BXRA-56C1100-B-00 BXRA-56C1600-B-00 BXRA-56C2600-B-00 Typical Viewing Angle (Degrees) 1/2 [4] 2θ Typical Center Beam Candle Power [5] (cd) 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 300 255 445 380 720 625 320 280 470 410 760 630 350 500 810 360 535 875 420 610 985 420 610 985 Notes for Table 4: 1. 2. 3. 4. 5. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Refer to Flux Characteristic Table for test current data. Product is binned for color in x y coordinates. Viewing angle is the off axis angle from the centerline where Iv is ½ of the peak value. Center beam candle power is a calculated value based on lambertian radiation pattern at nominal test current. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 9 of 27 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Vf [2] (V) Color Warm White Neutral White Cool White Base Part Number [1] BXRA-27E0800-B-00 BXRA-27G0800-B-00 BXRA-27E1200-B-00 BXRA-27G1200-B-00 BXRA-27E2000-B-00 BXRA-27G2000-B-00 BXRA-30E0800-B-00 BXRA-30G0800-B-00 BXRA-30E1200-B-00 BXRA-30G1200-B-00 BXRA-30E2000-B-00 BXRA-30G2000-B-00 BXRA-35E0800-B-00 BXRA-35E1200-B-00 BXRA-35E2000-B-00 BXRA-40E0950-B-00 BXRA-40E1350-B-00 BXRA-40E2200-B-00 BXRA-50C1100-B-00 BXRA-50C1600-B-00 BXRA-50C2600-B-00 BXRA-56C1100-B-00 BXRA-56C1600-B-00 BXRA-56C2600-B-00 Min Typ Max 18.6 18.6 26.6 26.6 33.3 33.3 18.6 18.6 26.6 26.6 33.3 33.3 18.6 26.6 33.3 18.6 26.6 33.3 18.6 26.6 33.3 18.6 26.6 33.3 20.7 20.7 29.6 29.6 37.0 37.0 20.7 20.7 29.6 29.6 37.0 37.0 20.7 29.6 37.0 20.7 29.6 37.0 20.7 29.6 37.0 20.7 29.6 37.0 22.8 22.8 32.6 32.6 40.7 40.7 22.8 22.8 32.6 32.6 40.7 40.7 22.8 32.6 40.7 22.8 32.6 40.7 22.8 32.6 40.7 22.8 32.6 40.7 Test Current (mA) [1] 500 500 500 500 700 700 500 500 500 500 700 700 500 500 700 500 500 700 500 500 700 500 500 700 Power Typical Coefficient of Forward Voltage (mV/ºC) ∆Vf/∆Tj Typical Thermal Resistance Junction to Case (ºC/W) Rθj-c 10.4 10.4 14.8 14.8 25.9 25.9 10.4 10.4 14.8 14.8 25.9 25.9 10.4 14.8 25.9 10.4 14.8 25.9 10.4 14.8 25.9 10.4 14.8 25.9 -7 to -21 -7 to -21 -10 to -30 -10 to -30 -12 to -36 -12 to -36 -7 to -21 -7 to -21 -10 to -30 -10 to -30 -12 to -36 -12 to -36 -7 to -21 -10 to -30 -12 to -36 -7 to -21 -10 to -30 -12 to -36 -7 to -21 -10 to -30 -12 to -36 -7 to -21 -10 to -30 -12 to -36 0.95 0.95 0.80 0.80 0.65 0.65 0.95 0.95 0.80 0.80 0.65 0.65 0.95 0.80 0.65 0.95 0.80 0.65 0.95 0.80 0.65 0.95 0.80 0.65 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 10 of 27 Absolute Minimum and Maximum Ratings Table 6: Maximum Current and Reverse Voltage Ratings Color Warm White Neutral White Cool White Base Part Number Maximum DC Forward Current (mA) BXRA-27E0800-B-00 750 Maximum Peak Pulsed Current [1] (mA) 1000 BXRA-27G0800-B-00 750 1000 -35 BXRA-27E1200-B-00 750 1000 -50 BXRA-27G1200-B-00 750 1000 -50 BXRA-27E2000-B-00 750 1000 -60 BXRA-27G2000-B-00 750 1000 -60 BXRA-30E0800-B-00 750 1000 -35 BXRA-30G0800-B-00 750 1000 -35 BXRA-30E1200-B-00 750 1000 -50 BXRA-30G1200-B-00 750 1000 -50 BXRA-30E2000-B-00 750 1000 -60 BXRA-30G2000-B-00 750 1000 -60 BXRA-35E0800-B-00 750 1000 -35 BXRA-35E1200-B-00 750 1000 -50 BXRA-35E2000-B-00 BXRA-40E0950-B-00 750 1000 -60 750 1000 -35 Maximum Reverse Voltage [2] (Vr) -35 BXRA-40E1350-B-00 BXRA-40E2200-B-00 750 1000 -50 750 1000 -60 BXRA-50C1100-B-00 750 1000 -35 BXRA-50C1600-B-00 750 1000 -50 BXRA-50C2600-B-00 750 1000 -60 BXRA-56C1100-B-00 750 1000 -35 BXRA-56C1600-B-00 750 1000 -50 BXRA-56C2600-B-00 750 1000 -60 Notes for Table 6: 1. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. 2. Light emitting diodes are not designed to be driven in reverse voltage. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 11 of 27 Absolute Minimum and Maximum Ratings (continued) Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature* 350°C or lower for a maximum of 3.5 seconds *See Bridgelux Application Note AN15: Reflow Soldering of Bridgelux LED Arrays for solder procedure (www.Bridgelux.com) Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 12 of 27 Typical Performance at Alternative Drive Currents Bridgelux LED Arrays are tested to the specifications shown in Tables 3, 4 and 5. Arrays may also be driven at alternative drive currents dependent on the specific application. Typical performance at any drive current can be derived from the flux vs. current characteristics shown in Figures 5 and 6 and from the current vs. voltage characteristics shown in Figures 10, 11 and 12. Typical performance at common drive currents is summarized in Tables 8 and 9. Table 8: Typical Product Performance at Alternative Drive Currents Color ANSI CCT (K) 2700 Warm White 3000 BXRA Part Number CRI BXRA-27E0800-B-00 80 BXRA-27G0800-B-00 90 BXRA-27E1200-B-00 80 BXRA-27G1200-B-00 90 BXRA-27E2000-B-00 80 BXRA-27G2000-B-00 90 BXRA-30E0800-B-00 80 BXRA-30G0800-B-00 90 BXRA-30E1200-B-00 80 BXRA-30G1200-B-00 90 BXRA-30E2000-B-00 80 BXRA-30G2000-B-00 90 Typical DC Luminous Flux Фv (lm) Tcase = 70ºC Typical Pulsed Luminous Flux Фv (lm) Tj = 25ºC Typical Forward Voltage Vf (V) Forward Current [2] (mA) 620 865 525 735 960 1260 775 1070 1085 1500 1990 950 1310 1735 655 920 580 810 965 1325 845 1170 1155 1590 2110 950 1325 1750 680 950 580 810 1055 1400 850 1190 1195 1665 2260 1045 1455 1975 720 1010 640 890 1060 1475 930 1300 1270 1770 2400 1050 1475 2000 20.0 20.7 20.0 20.7 28.6 29.6 28.6 29.6 34.3 35.5 37.0 34.3 35.5 37.0 20.0 20.7 20.0 20.7 28.6 29.6 28.6 29.6 34.3 35.5 37.0 34.3 35.5 37.0 350 500 350 500 350 500 350 500 350 500 700 350 500 700 350 500 350 500 350 500 350 500 350 500 700 350 500 700 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 13 of 27 Typical Performance at Alternative Drive Currents (continued) Table 9: Typical Product Performance at Alternative Drive Currents Color Warm White Neutral White ANSI CCT (K) 3500 4000 5000 BXRA Part Number CRI BXRA-35E0800-B-00 80 BXRA-35E1200-B-00 80 BXRA-35E2000-B-00 80 BXRA-40E0950-B-00 80 BXRA-40E1350-B-00 80 BXRA-40E2200-B-00 80 BXRA-50C1100-B-00 70 BXRA-50C1600-B-00 70 BXRA-50C2600-B-00 Cool White 5600 BXRA-56C1100-B-00 70 BXRA-56C1600-B-00 70 BXRA-56C2600-B-00 70 Typical DC Luminous Flux Фv (lm) Tcase = 70ºC Typical Pulsed Luminous Flux Фv (lm) Tj = 25ºC Typical Forward Voltage Vf (V) Forward Current (2) (mA) 750 995 1040 1435 1225 1650 2225 785 1045 1100 1520 1320 1820 2420 860 1200 1275 1725 1475 2050 2725 860 1200 1275 1725 1475 2050 2725 825 1095 1145 1595 1350 1875 2550 865 1150 1210 1690 1450 2025 2750 945 1320 1400 1920 1625 2290 3100 945 1320 1400 1920 1625 2290 3100 20.0 20.7 28.6 29.6 34.8 36.0 37.0 20.7 20.7 28.6 29.6 34.3 35.5 37.0 20.0 20.7 28.6 29.6 34.3 35.5 37.0 20.0 20.7 28.6 29.6 34.3 35.5 37.0 350 500 350 500 350 500 700 350 500 350 500 350 500 700 350 500 350 500 350 500 700 350 500 350 500 350 500 700 Notes for Table 8 and 9: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Tables 8 and 9, with a case temperature maintained at or below 70°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 14 of 27 Mechanical Dimensions Figure 1: Drawing for ES Rectangular Arrays Notes for Figure 1: 1. 2. 3. 4. 5. 6. 7. 8. 9. Mounting holes are for M2.5 or #4 screws. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. Drawings are not to scale. Drawing dimensions are in millimeters. Bridgelux recommends two tapped holes for mounting screws with 26.92 ± 0.10mm center-to-center spacing. Unless otherwise specified, tolerances are ± 0.10mm. Refer to product Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. The optical center of the LED Array is defined by the mechanical center of the array. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 15 of 27 Typical Radiation Pattern Figure 2: Typical Spatial Radiation Pattern Figure 3: Typical Polar Radiation Pattern Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 16 of 27 Wavelength Characteristics at Rated Test Current, Tj=25°C Figure 6:Figure Typical White Color Spectrum 4: Cool Typical Color Spectrum 1.2 1.0 Relative Intensity Cool White 0.8 Warm White Neutral White 0.6 0.4 0.2 0.0 400 450 500 550 600 650 700 750 800 Wavelength Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 17 of 27 Typical Relative Luminous Flux vs. Current, Tj=25°C Normalized Luminous Flux Figure 5: Typical Flux vs. Current 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 BXRA-xxx0800-B-00, BXRA-xxx0950-B-00, BXRA-xxx1100-B-00 BXRA-xxx1200-B-00, BXRA-xxx1350-B-00, BXRA-xxx1600-B-00 0.2 0.0 0 200 400 600 800 1000 Current (mA) Figure 6: Typical Flux vs. Current Normalized Luminous Flux 1.6 1.4 1.2 1.0 0.8 0.6 0.4 BXRA-xxx2000-B-00, BXRA-xxx2200-B-00, BXRA-xxx2600-B-00 0.2 0.0 0 200 400 600 800 1000 Current (mA) Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 18 of 27 Typical Light Output Characteristics vs. Temperature Figure 7: Typical FluxFlux vs. Junction Temperature Figure 9: Typical vs. Junction Temperature 1.2 Neutral White Normalized Luminous Flux 1.0 Warm White 0.8 Cool White 0.6 Warm White Neutral White 0.4 Cool White 0.2 0.0 -10 0 10 20 30 40 50 60 Junction Temperature, °C Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) 70 80 90 100 110 Page 19 of 27 Typical Chromaticity Characteristics vs. Temperature Figure 8: Typical ccy Shift vs. Junction Temperature 0.02 Neutral White Warm White 0.01 0.00 ∆y -0.01 Cool White -0.02 -0.03 Warm White Cool White -0.04 Neutral White -0.05 -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C 70 80 90 100 110 Figure 9: Typical ccx Shift vs. Junction Temperature 0.02 Warm White Neutral White 0.01 0.00 -0.01 ∆x Cool White -0.02 -0.03 Warm White -0.04 Cool White -0.05 Neutral White -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) 70 80 90 100 110 Page 20 of 27 Forward Current Characteristics Figure 10: Current vs. Voltage BXRA-xxx2000-B-00, BXRA-xxx2200-B-00, BXRA-xxx2600-B-00 TYP Vf Tc=25°C MIN Vf Tc=70°C MAX Vf Tc=25°C MIN Vf Tc=25°C Figure 11: Current vs. Voltage BXRA-xxx1200-B-00, BXRA-xxx1350-B-00, BXRA-xxx1600-B-00 MIN Vf Tc=25°C MAX Vf Tc=25°C TYP Vf Tc=25°C MIN Vf Tc=70°C Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 21 of 27 Forward Current Characteristics (continued) Figure 12: Current vs. Voltage BXRA-xxx0800-B-00, BXRA-xxx0950-B-00, BXRA-xxx1100-B-00 MIN Vf Tc=25°C MIN Vf Tc=70°C MAX Vf Tc=25°C TYP Vf Tc=25°C Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 22 of 27 Color Binning Information 37 10 K 0.42 0.41 32 20 K R3 Q3 P3 3500K 3SDCM N3 P4 2700K 3SDCM T4 S4 R4 0.39 0.38 T3 S3 Q4 27 25 K 0K N4 0.37 0.36 0.35 0.38 0.4 0.42 25 8 Y 0.4 34 65 K 0.43 30 45 K 3000K 3SDCM 0.44 28 70 K Figure 13: Graph of Warm White Test Bins in xy Color Space 0.44 0.46 0.48 X Table 10: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code Q3 Q4 R3 R4 X3 (3SDCM) X Y 0.4223 0.4299 0.4431 0.4345 0.4147 0.4223 0.4345 0.4260 0.4345 0.4431 0.4562 0.4468 0.4260 0.4345 0.4468 0.4373 0.3990 0.4165 0.4213 0.4033 0.3814 0.3990 0.4033 0.3854 0.4033 0.4213 0.4260 0.4077 0.3854 0.4033 0.4077 0.3893 0.4413 0.4325 0.4274 0.4350 0.4107 0.4075 0.3958 0.3984 ANSI CCT (K) Bin Code 3000 S3 3000 S4 3000 T4 3000 T3 3000 X3 (3SDCM) X Y 0.4468 0.4562 0.4688 0.4585 0.4373 0.4468 0.4585 0.4483 0.4585 0.4688 0.4813 0.4703 0.4483 0.4585 0.4703 0.4593 0.4077 0.4260 0.4290 0.4104 0.3893 0.4077 0.4104 0.3919 0.4104 0.4290 0.4319 0.4132 0.3919 0.4104 0.4132 0.3944 0.4656 0.4573 0.4510 0.4583 0.4174 0.4154 0.4032 0.4049 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) ANSI CCT (K) Bin Code 2700 N4 2700 N3 2700 P3 2700 P4 2700 X3 (3SDCM) X Y 0.3943 0.3996 0.4148 0.4083 0.3889 0.3943 0.4083 0.4018 0.4083 0.4148 0.4299 0.4223 0.4018 0.4083 0.4223 0.4147 0.4148 0.4047 0.4012 0.4098 0.3853 0.4015 0.4090 0.3921 0.3690 0.3853 0.3921 0.3752 0.3921 0.4090 0.4165 0.3990 0.3752 0.3921 0.3990 0.3814 0.4000 0.3950 0.3841 0.3883 Page 23 of 27 ANSI CCT (K) 3500 3500 3500 3500 3500 Color Binning Information (continued) Figure 14: Graph of Neutral White Test Bins in xy Color Space 0.41 0.40 M3 Y 0.39 4000K 3SDCM 0.38 L3 M4 0.37 L4 0.36 0.35 0.36 0.37 0.38 0.39 0.40 0.41 Z Table 11: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code L3 L4 M3 M4 X3 (3SDCM) X Y 0.3703 0.3736 0.3871 0.3828 0.3670 0.3703 0.3828 0.3784 0.3828 0.3871 0.4006 0.3952 0.3784 0.3828 0.3952 0.3898 0.3881 0.3791 0.3769 0.3845 0.3726 0.3874 0.3959 0.3803 0.3578 0.3726 0.3803 0.3647 0.3803 0.3959 0.4044 0.3880 0.3647 0.3803 0.3880 0.3716 0.3879 0.3823 0.3724 0.3770 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) ANSI CCT (K) 4000 4000 4000 4000 4000 Page 24 of 27 Color Binning Information (continued) Figure 15: Graph of Cool White Test Bins in xy Color Space 5665K 0.38 K 60 20 0.37 0.36 H3 G3 H4 0.35 G4 K E3 0.34 F4 5310K 0.33 5 02 8 K E4 47 4 5 Y F3 0.32 0.31 0.32 0.33 0.34 0.35 0.36 X Table 12: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code G3 G4 H3 H4 X Y 0.3376 0.3464 0.3452 0.3371 0.3371 0.3452 0.3441 0.3366 0.3464 0.3551 0.3533 0.3452 0.3452 0.3533 0.3515 0.3441 0.3616 0.3688 0.3558 0.3493 0.3493 0.3558 0.3428 0.3369 0.3688 0.376 0.3624 0.3558 0.3558 0.3624 0.3487 0.3428 ANSI CCT (K) Bin Code 5000 E3 5000 E4 5000 F3 5000 F4 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) X Y 0.3215 0.3293 0.3292 0.3207 0.3222 0.3294 0.3293 0.3215 0.3292 0.3293 0.3371 0.3376 0.3294 0.3366 0.3371 0.3293 0.3353 0.3423 0.3539 0.3462 0.3243 0.3306 0.3423 0.3353 0.3539 0.3423 0.3493 0.3616 0.3306 0.3369 0.3493 0.3423 ANSI CCT (K) 5600 5600 5600 5600 Page 25 of 27 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes • • • • • • AN10: AN11: AN12: AN14: AN15: AN16: Effective Thermal Management of Bridgelux LED Arrays Assembly Considerations for Bridgelux LED Arrays Electrical Drive Considerations for Bridgelux LED Arrays Reliability Data Sheet for Bridgelux LED Arrays Reflow Soldering of Bridgelux LED Arrays Optical Considerations for Bridgelux LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance. • • • • • • • • • Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 26 of 27 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid-state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 550 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2012 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (10/11/12) Page 27 of 27
BXRA-35E0800-B-00 价格&库存
很抱歉,暂时无法提供与“BXRA-35E0800-B-00”相匹配的价格&库存,您可以联系我们找货
