CBT-90-B-C11-KJ300
CBT-90-B-C11-KJ300
    LUMINUS(朗明纳斯)
    Module
    CBT-90-B-C11-KJ300
CBT-90-B-C11-KJ300 数据手册
CBT-90 Product Datasheet CBT-90 LEDs Table of Contents Technology Overview. . . . . . 2 Features: • Extremely high optical output: Over 2,250 White Lumens Over 1,800 Green lumens Over 650 Blue Lumens Test Specifications . . . . . . . . . 2 White Binning Structure. . . . 3 White Chromaticity Bins. . . . 4 • High thermal conductivity package - junction to case thermal resistance of only 0.8°C/W Green, Blue Binning Structure . . . . . . . . . . . . . . . . . . 5 • CBT-90-W available in 5700K and 6500K Color points (typ) Product Shipping & Labeling Information. . . . . . . 6 • Unencapsulated die with low profile protective window optimizes optical coupling in etendue-limited applications White Electrical Characteristics. . . . . . . . . . . . . 7 • Large, monolithic chip with uniform emitting area of 9 mm2 • Lumen maintenance of greater than 70% after 60,000 hours • Environmentally friendly: RoHS and Halogen compliant White Optical and Electrical Characteristics. . . . . . . . . . . . . 8 Green/Blue Optical and Electrical Characteristics. . . . . . . . . . 9 Applications • Fiber-coupled Illumination • Displays and Signage Green/Blue Lifetime and Lumen Maintenance. . . . . . . . . . . . . . 13 • Architectural and Entertainment Lighting • General Illumination Radiation Patterns . . . . . . . . 14 • Medical Lighting • Emergency Vehicle Lighting • Machine Vision • Projection Systems Thermal Resistance . . . . . . . 15 • Spot Lighting • Microscopy Mechanical Dimensions . . . 16 Ordering Information . . . . . 17 1 PDS-001230 Rev 16 © 2019 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 www.luminus.com 1145 Sonora Court Sunnyvale, CA 94086 USA CBT-90 Product Datasheet Technology Overview Luminus LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. LED Technology Reliability Luminus LED™ technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. Luminus LEDs are one of the most reliable light sources in the world today. LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus LEDs are ready for even the most demanding applications. (Refer to Luminus’ Reliability application note for more information.) Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 0.8º C/W, Luminus CBT-90 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Environmental Benefits Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All LED products manufactured by Luminus are RoHS and REACH compliant and free of hazardous materials, including lead and mercury. Luminus LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Specification Measurement Condition (9A,13.5 A) Luminus core board products are measured in an equivalent way the devices will operate in a system. The device is mounted on a 40ºC heat sink and allowed to reach thermal equilibrium under full power. The measurement is taken after equilibrium is reached. This method of measurement ensures that Luminus LEDs perform in the field just as they are specified. The tables on the following pages provide typical optical and electrical characteristics measured at 9A for white, 13.5A for Green and Blue. The associated junction temperature is TJ = 70 ºC for white and TJ = 75 º - 90 º C for GB. The CBT-90 can be operated over a wide range of current drive conditions from 200mA to 18A and duty cycle from
CBT-90-B-C11-KJ300 价格&库存
很抱歉,暂时无法提供与“CBT-90-B-C11-KJ300”相匹配的价格&库存,您可以联系我们找货
