CBT-120-R-C11-HK101
CBT-120-R-C11-HK101
    LUMINUS(朗明纳斯)
    Module
    CBT-120-R-C11-HK101
CBT-120-R-C11-HK101 数据手册
CBT-120 CBT-120Product Product Datasheet CBT-120 LEDs Features: Table of Contents Technology Overview. . . . . . 2 Test Specifications . . . . . . . . . 2 Bin Codes. . . . . . . . . . . . . . . . . . 3 • Extremely high optical output: Over 1225 Red Lumens Over 2000 Green lumens Over 470 Blue Lumens • High thermal conductivity package - junction to heat sink thermal resistance of only 0.7 ºC/W • Photonic lattice technology for very high surface brightness and uniform emission • Large, monolithic chip with surface emitting area of 12 mm2 Product Shipping & Labeling Information. . . . . . . 4 • High luminous efficacy Optical & Electrical Characteristics. . . . . . . . . . . . . 5 • Environmentally friendly: RoHS compliant Flux & Spectral Characteristics vs. Temperature. . . . . . . . . . . . 9 • Currently available in Red, Green and Blue; other colors to follow Lifetime & Lumen Maintenance. . . . . . . . . . . . . . . 9 Spectral Characteristics. . . . .9 • Lumen maintenance of greater than 70% after 60,000 hours • Variable drive currents: less than 1 A through 30 A Applications • Entertainment • Machine Vision • Architectural Lighting • Projection Systems Thermal Resistance . . . . . . . 10 • Medical Lighting • Displays and Signage Mechanical Dimensions. . . 11 • Spot Lighting • General Illumination Radiation Patterns . . . . . . . . 10 Ordering Information . . . . . 12 • Fiber Coupled Illumination • Emergency Vehicle Lighting 1 PDS-001226 Rev 06 © 2016 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 USA CBT-120 Product Datasheet Technology Overview Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Photonic Lattice Technology Luminus’ photonic lattice technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. For red, green and blue LEDs, the photonic lattice structures extract more light and create radiation patterns that are more collimated than traditional LEDs. Having higher collimation from the source increases optical collection efficiencies and simplifies optical designs. Reliability Designed from the ground up, Luminus Big Chip LEDs are one of the most reliable light sources in the world today. Big Chip LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus Big Chip LEDs are ready for even the most demanding applications. Environmental Benefits Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to heat sink of 0.7º C/W, Luminus CBT-120 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer lifetimes. Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All Big Chip LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Big Chip LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Multiple Operating Points (4.2 A, 18 A, 30 A) Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus Big Chip LEDs perform in the field just as they are specified. The tables on the following pages provide typical optical and electrical characteristics. Since the LEDs can be operated over a wide range of drive conditions(currents from
CBT-120-R-C11-HK101 价格&库存
很抱歉,暂时无法提供与“CBT-120-R-C11-HK101”相匹配的价格&库存,您可以联系我们找货
