CBM-380-RGBW-D11-QF100
    LUMINUS(朗明纳斯)
    Module
    BIG CHIP LED HB MODULE RGB, WHT
CBM-380-RGBW-D11-QF100 数据手册
CBM-380 Product Datasheet CBM-380 LEDs Features: Table of Contents Technology Overview. . . . . . 2 • Extremely high optical output: up to 700 Red lumens up to 2,000 Green lumens up to 300 Blue lumens up to 1,600 White lumens Test Specifications . . . . . . . . . 2 • High thermal conductivity package - junction to case thermal resistance of only 0.8 °C/W White Binning Structure. . . . 3 • Large, monolithic chip with emitting area of 12 mm2 Chromaticity Bins. . . . . . . . . . 3 • Unencapsulated die with low profile protective window optimizes optical coupling in etendue-limited applications Monochromatic Binning Structure . . . . . . . . . . . . . . . . . . 5 • Lumen maintenance of greater than 70% after 60,000 hours Shipping and Labeling information. . . . . . . . . . . . . . . . 6 • Environmentally friendly: RoHS compliant • Variable drive current: less than 1 A through 12 A • Available in RGBW combination Electrical Characteristics. . . 7 Lifetime & Lumen Maintenance. . . . . . . . . . . . . . 12 Radiation Patterns . . . . . . . . 13 Thermal Resistance . . . . . . . 13 Mechanical Dimensions . . . 14 Ordering Information . . . . . 15 Applications • Fiber-coupled Illumination • Microscopy • Architectural and Entertainment Lighting • Spot Lighting • Medical Lighting • Displays and Signage • Machine Vision 1 PDS-001362Rev 05 • Emergency Vehicle Lighting © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 CBM-380 Product Datasheet Technology Overview Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Photonic Lattice Technology lifetimes. Luminus’ photonic lattice technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. Reliability For red, green and blue LEDs, the photonic lattice structures extract more light and create radiation patterns that are more collimated than traditional LEDs. Having higher collimation from the source increases optical collection efficiencies and simplifies optical designs. Designed from the ground up, Luminus Big Chip LEDs are one of the most reliable light sources in the world today. Big Chip LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus Big Chip LEDs are ready for even the most demanding applications. Environmental Benefits Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to heat sink of 0.8º C/W, Luminus CBM-380 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions and longer Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All Big Chip LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Big Chip LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Multiple Operating Points Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus Big Chip LEDs perform in the field just as they are specified. The tables on the following pages provide typical optical and electrical characteristics. Since the LEDs can be operated over a wide range of drive conditions (currents from less than 1A to 12A, and duty cycle from
CBM-380-RGBW-D11-QF100 价格&库存
很抱歉,暂时无法提供与“CBM-380-RGBW-D11-QF100”相匹配的价格&库存,您可以联系我们找货
