BXRA-40E0600-A-00
BXRA-40E0600-A-00
    BRIDGELUX(普瑞)
    LED ARRAY 600LM NEUTRAL WHT
BXRA-40E0600-A-00 数据手册
Bridgelux ES Star Array Series Product Data Sheet DS23 BXRA-27x0540, BXRA-27x0740, BXRA-30x0540, BXRA-30x0740, BXRA-40E0810, BXRA-56C0700, BXRA-56C1000 Introduction The Bridgelux family of LED Array products delivers high performance, compact and cost-effective solidstate lighting solutions to serve the general lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of many conventional lighting sources. The Bridgelux ES Array Series has been specified to enable lamp and luminaire designs surpassing efficacy and quality of light requirements driven by regulatory standards with reasonable system design margins, enabling lighting product compliance to Energy Star, Title 24, Part L and other global standards. The Bridgelux ES Array products provide a high performance alternative to conventional solid state solutions, delivering between 450 and 1000 lumens under application conditions in warm, neutral and cool white color temperatures. These compact high flux density light sources deliver uniform high quality illumination without pixilation or the multiple shadow effect caused by LED component based solutions. To simplify system design for appropriate light output, Bridgelux LED Arrays are specified to deliver performance under typical use conditions. These integrated plug and play solutions reduce system complexity and enable miniaturized costeffective lamp and luminaire designs. Lighting system designs incorporating these LED Arrays deliver comparable performance to that of 40-60 Watt incandescent and halogen and 7-13 Watt compact fluorescent based luminaires and feature increased system level efficacy and service life. Typical applications include replacement lamps, task, accent, spot, track, down light, wide area, security, and wall pack. Features Benefits • Compact high flux density light source • Enhanced optical control • Uniform high quality illumination • Clean white light without pixilation • Minimum 70, 80 and 90 CRI options • High quality true color reproduction • Streamlined thermal path • • Energy Star / ANSI compliant color binning structure with 3SDCM options Significantly reduced thermal resistance and increased operating temperatures • Uniform consistent white light More energy efficient than incandescent, halogen and fluorescent lamps • Lower operating costs • Increased safety • Low voltage DC operation • • Instant light with unlimited dimming Easy to use with daylight and motion detectors to enable increased energy savings • 5-Year warranty • Reduced maintenance costs • RoHS compliant and Pb free • Environmentally friendly, no disposal issue • 1 0 1 P o rt o l a A v e n u e , L i v e rm o re , C A 9 4 5 5 1 • T e l : (9 2 5 ) 5 8 3 -8 4 0 0 • Fa x: (9 2 5 ) 5 8 3 -8 4 0 1 • ww w. b ri d g e l u x. c o m Table of Contents Page Product Nomenclature 3 Average Lumen Maintenance Characteristics 3 Environmental Compliance 3 UL Recognition 4 Minor Product Change Policy 4 Cautionary Statements 4 Case Temperature Measurement Point 5 Quick Selection Guide 6 Quick Selection Guide 6 The following configurations are available: 6 Flux Characteristics 7 Optical Characteristics 8 Electrical Characteristics 9 Absolute Minimum and Maximum Ratings 10 Typical Performance at Alternative Drive Currents 11 Typical Performance at Alternative Drive Currents (continued) 12 Mechanical Dimensions 13 Typical Radiation Pattern 14 Wavelength Characteristics at Rated Test Current, Tj=25°C 15 Typical Relative Luminous Flux vs. Current, Tj=25°C 16 Typical Light Output Characteristics vs. Temperature 17 Typical Chromaticity Characteristics vs. Temperature 18 Typical Forward Current Characteristics 19 Color Binning Information 20 Design Resources 23 Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 2 of 24 Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRA – AB C DEFG – H – IJ Where: BXRA – Designates product family AB – Designates the nominal ANSI color temperature; 27 = 2700K; 30 = 3000K, etc. C - Designates minimum CRI; C = 70, E = 80, G = 90 DEFG - Designates Nominal Flux; 0540 = 540lm, 0740 = 740lm, 1000=1000lm, etc. H – Designates configuration IJ – Designates CCT Bin options 3000K as an example: 00 = Full ANSI: Q3, Q4, R3, R4 03 = 3 SDCM Average Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation with case temperature maintained at or below 85°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Bridgelux LED Arrays are compliant to the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 3 of 24 UL Recognition Bridgelux secures UL Recognition for all the LED Array products. We continue to add arrays as they are recognized by UL. Please refer to the UL file E333389 for the latest list of UL Recognized Arrays. Bridgelux uses UL Recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 Driver to facilitate the UL listing process. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Do not touch the optical area of the LED Array. Avoid any contact with the optical area. Applying stress to the yellow phosphor resin area can result in damage to the LED Array. Optics and reflectors must not be mounted in contact with the white phosphor resin area or the white ring that surrounds the yellow phosphor area. Using the white ring to secure optics can result in damage to the LED Array as the ring is not designed to act as a mechanical locating feature. Optical devices may be mounted on the top surface of the LED Array substrate outside of the white ring maximum OD as specified in the product data sheet. Use the mechanical features of the LED Array substrate edges and/or mounting holes to locate and secure the optical device as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC specification EN62471; Photobiological Safety of Lamps and Lamp Systems. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below their rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED Array. Please consult Application Note AN11 for additional information. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 4 of 24 Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Measuring the top surface of the product can lead to inaccurate results due to the poor thermal conductivity of the top layers of the array such as the solder mask and other materials. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 5 of 24 Quick Selection Guide The following configurations are available: Table 1: Selection Guide for ES Star Arrays Base Part Number Typical Pulsed CRI CCT Flux (Nominal) (min) Tj 25ºC Typical DC Flux Tcase 70ºC (lm) (lm) Test Current Efficacy Vf Power (mA) (Typ) (V) (Typ) (W) (Typ at Tj 25ºC) (lm/W) BXRA-27E0540-A-00 2700 80 560 500 350 18.8 6.6 85 BXRA-27G0540-A-00 2700 90 480 430 350 18.8 6.6 73 BXRA-27E0740-A-00 2700 80 810 725 350 28.1 9.8 82 BXRA-27G0740-A-00 2700 90 690 615 350 28.1 9.8 70 BXRA-30E0540-A-00 3000 80 600 525 350 18.8 6.6 91 BXRA-30G0540-A-00 3000 90 530 465 350 18.8 6.6 81 BXRA-30E0740-A-00 3000 80 860 770 350 28.1 9.8 88 BXRA-30G0740-A-00 3000 90 760 680 350 28.1 9.8 77 BXRA-40E0810-A-00 4000 80 980 860 350 28.1 9.8 100 BXRA-56C0700-A-00 5600 70 780 685 350 18.8 6.6 118 BXRA-56C1000-A-00 5600 70 1120 1000 350 28.1 9.8 114 Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 6 of 24 Flux Characteristics Table 2: Flux Characteristics Color ANSI CCT Base Part Number (K) CRI (4) (min) Typical DC Flux Tcase = 70ºC (3) (lm) 2700 Warm White 3000 Neutral White 4000 Cool White 5600 Minimum Pulsed Flux Tj = 25ºC (1) (lm) Typical Pulsed Flux Tj = 25ºC Test Current (2) (mA) (lm) BXRA-27E0540-A-00 80 500 500 560 350 BXRA-27G0540-A-00 90 430 430 480 350 BXRA-27E0740-A-00 80 725 730 810 350 BXRA-27G0740-A-00 90 615 620 690 350 BXRA-30E0540-A-00 80 525 540 600 350 BXRA-30G0540-A-00 90 465 480 530 350 BXRA-30E0740-A-00 80 770 770 860 350 BXRA-30G0740-A-00 90 680 680 760 350 BXRA-40E0810-A-00 80 860 880 980 350 BXRA-56C0700-A-00 70 685 700 780 350 BXRA-56C1000-A-00 70 1000 1010 1120 350 Notes for Table 2: 1. Bridgelux maintains a ± 7% tolerance of flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Typical performance when driven at DC (direct current) test current with LED Array case temperature maintained at 70°C, mounted to heat sink with thermal interface material. Please contact a Bridgelux sales representative for additional details. 4. Typical R9 value for 90 CRI product options is 50. 5. Reference Table 7 and 8 for typical performance at other driver currents (including those commonly available in the market). Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 7 of 24 Optical Characteristics Table 3: Optical Characteristics Color Temperature Color ANSI CCT (CCT) [1], [2], [3] CRI Base Part Number Min (K) Typ Max (min) Typical Viewing Angle (Degrees) 2θ 2700 Warm White 3000 Neutral White 4000 Cool White 5600 1/2 [4] Typical Center Beam Candle Power (cd) [5] BXRA-27E0540-A-00 2580 K 2725 K 2870 K 80 120 175 BXRA-27G0540-A-00 2580 K 2725 K 2870 K 90 120 155 BXRA-27E0740-A-00 2580 K 2725 K 2870 K 80 120 235 BXRA-27G0740-A-00 2580 K 2725 K 2870 K 90 120 215 BXRA-30E0540-A-00 2870 K 3045 K 3220 K 80 120 190 BXRA-30G0540-A-00 2870 K 3045 K 3220 K 90 120 170 BXRA-30E0740-A-00 2870 K 3045 K 3220 K 80 120 260 BXRA-30G0740-A-00 2870 K 3045 K 3220 K 90 120 235 BXRA-40E0810-A-00 3700K 4000 K 4250K 80 120 285 BXRA-56C0700-A-00 5310 K 5665 K 6020 K 70 120 245 BXRA-56C1000-A-00 5310 K 5665 K 6020 K 70 120 340 Notes for Table 3: 1. 2. 3. 4. 5. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Refer to Flux Characteristic Table for test current data. Product is binned for color in x y coordinates. Viewing angle is the off axis angle from the centerline where Iv is ½ of the peak value. Center beam candle power is a calculated value based on lambertian radiation pattern at nominal test current. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 8 of 24 Electrical Characteristics Table 4: Electrical Characteristics ∆Vf/∆Tj Typical Thermal Resistance Junction to Case (ºC/W) Rθj-c 350 -6 to -18 2.60 20.7 350 -6 to -18 2.60 28.1 30.9 350 -9 to -27 1.75 25.3 28.1 30.9 350 -9 to -27 1.75 BXRA-30E0540-A-00 16.9 18.1 20.7 350 -6 to -18 2.60 BXRA-30G0540-A-00 16.9 18.1 20.7 350 -6 to -18 2.60 BXRA-30E0740-A-00 25.3 28.1 30.9 350 -9 to -27 1.75 BXRA-30G0740-A-00 25.3 28.1 30.9 350 -9 to -27 1.75 BXRA-40E0810-A-00 25.3 28.1 30.9 350 -9 to -27 1.75 BXRA-56C0700-A-00 16.9 18.1 20.7 350 -6 to -18 2.60 BXRA-56C1000-A-00 25.3 28.1 30.9 350 -9 to -27 1.75 Forward Voltage Vf [2] Test Current (V) Color Base Part Number [1] (mA) Warm White Neutral White Cool White Min Typ Max BXRA-27E0540-A-00 16.9 18.1 20.7 BXRA-27G0540-A-00 16.9 18.1 BXRA-27E0740-A-00 25.3 BXRA-27G0740-A-00 Typical Coefficient of Forward Voltage (mV/ºC) Notes for Table 4: 1. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 9 of 24 Absolute Minimum and Maximum Ratings Table 5: Maximum Current and Reverse Voltage Ratings Color Base Part Number Maximum DC Forward Current (mA) Warm White Neutral White Cool White Maximum Peak Pulsed Current [1] (mA) Maximum Reverse Voltage [2] (Vr) BXRA-27E0540-A-00 500 700 -30 V BXRA-27G0540-A-00 500 700 -30 V BXRA-27E0740-A-00 500 700 -45 V BXRA-27G0740-A-00 500 700 -45 V BXRA-30E0540-A-00 500 700 -30 V BXRA-30G0540-A-00 500 700 -30 V BXRA-30E0740-A-00 500 700 -45 V BXRA-30G0740-A-00 500 700 -45 V BXRA-40E0810-A-00 500 700 -45 V BXRA-56C0700-A-00 500 700 -30 V BXRA-56C1000-A-00 500 700 -45 V Notes for Table 5: 1. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. 2. Light emitting diodes are not designed to be driven in reverse voltage. Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature 350°C or lower for a maximum of 3.5 seconds Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 10 of 24 Typical Performance at Alternative Drive Currents The Bridgelux LED Arrays are tested and binned against the specifications shown in Tables 2, 3 and 4. Customers also have options to drive the LED Arrays at alternative drive currents dependent on the specific application. The typical performance at any drive current can be derived from the flux vs. current characteristics shown in Figure 5 and 6 and from the current vs. voltage characteristics shown in Figures 10 and 11. The typical performance at common drive currents is also summarized in Tables 7 and 8. Table 7: Typical Product Performance at Alternative Drive Currents Color ANSI CCT Part Number CRI (K) Typical DC Luminous Flux фv Typical Pulsed Luminous Flux фv (lm), (lm), Typical Forward Voltage Vf Tcase=70°C 385 682 Tj=25°C 410 560 17.8 18.8 250 [1] 350 [2] (mA) (V) BXRA-27E0540-A-00 80 BXRA-27G0540-A-00 90 317 430 353 480 17.8 18.8 250 [1] 350 BXRA-27E0740-A-00 80 585 725 650 810 18.4 28.1 250 [1] 350 BXRA-27G0740-A-00 90 450 615 505 690 26.7 28.1 250 [1] 350 BXRA-30E0540-A-00 80 385 525 440 600 17.8 18.8 250 [1] 350 BXRA-30G0540-A-00 90 340 465 390 530 17.8 18.8 250 [1] 350 BXRA-30E0740-A-00 80 565 770 630 860 17.8 28.1 250 [1] 350 BXRA-30G0740-A-00 90 500 680 570 760 26.7 28.1 250 [1] 350 2700 Warm White Forward Current 3000 Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 11 of 24 Typical Performance at Alternative Drive Currents (continued) Table 8: Typical Product Performance at Alternative Drive Currents Color ANSI CCT Part Number CRI (K) Neutral White Cool White Typical DC Luminous Flux фv Typical Pulsed Luminous Flux фv (lm), (lm), Typical Forward Voltage Vf Tcase=70°C 630 860 Tj=25°C 720 980 26.7 28.1 250 [1] 350 Forward Current [2] (mA) (V) 4000 BXRA-40E0810-A-00 80 5600 BXRA-56C0700-A-00 70 500 685 575 780 17.8 18.1 250 [1] 350 BXRA-56C1000-A-00 70 735 1000 825 1120 26.7 28.1 250 [1] 350 Notes for Tables 7 and 8: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Table 7 and 8, with a case temperature maintained at or below 85°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 12 of 24 Mechanical Dimensions Figure 1: Drawing for ES Star Arrays Notes for Figure 1: 1. Slots are for M2.5 or #4 screws. 2. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. 3. It is not necessary to provide electrical connections to both sets of solder pads. Either set my be used depending on application specific design requirements. 4. Drawings are not to scale. 5. Drawing dimensions are in millimeters. 6. Unless otherwise specified, tolerances are ± 0.20mm. 7. Refer to product Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. 8. The optical center of the LED Array is defined by the mechanical center of the array. 9. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 13 of 24 Typical Radiation Pattern Figure 2: Typical Spacial Radiation Pattern Figure 3: Typical Polar Radiation Pattern Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 14 of 24 Wavelength Characteristics at Rated Test Current, Tj=25°C 4: Typical FigureFigure 6: Typical Cool Color WhiteSpectrum Color Spectrum 1.2 Relative Intensity 1.0 Cool White Warm White Neutral White 0.8 0.6 0.4 0.2 0.0 400 450 500 550 600 650 Wavelength Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) 700 750 800 Page 15 of 24 Typical Relative Luminous Flux vs. Current, Tj=25°C Figure 5: Typical Flux vs. Current BXRA-xxx0540-A, BXRA-56C0700-A Nomalized Luminous Flux 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 0 100 200 300 400 500 600 700 Current (mA) Figure 6: Typical Flux vs. Current BXRA-xxx0740-A, BXRA-40E0810-A, BXRA-56C1000-A 2.2 Nomalized Luminous Flux 2.0 1.8 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 0 100 200 300 400 500 600 700 Current (mA) Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 16 of 24 Typical Light Output Characteristics vs. Temperature Figure 9:Figure Typical7:Flux vs. Junction Typical Flux vs. Temperature Junction Temperature 1.2 Normalized Luminous Flux Neutral White 1.0 0.8 Cool White Warm White 0.6 Warm White 0.4 Cool White Neutral White 0.2 0.0 -10 0 10 20 30 40 50 60 70 80 Junction Temperature, °C Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) 90 100 110 120 130 Page 17 of 24 Typical Chromaticity Characteristics vs. Temperature Figure 8: Typical ccy Shift vs. Junction Temperature 0.02 Neutral White 0.01 Warm White 0.00 ∆y -0.01 -0.02 Cool White -0.03 Warm White Cool White -0.04 Neutral White -0.05 -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C 70 80 90 100 110 Figure 9: Typical ccx Shift vs. Junction Temperature 0.02 Neutral White 0.01 Warm White 0.00 ∆x -0.01 Cool White -0.02 -0.03 Warm White -0.04 Cool White -0.05 Neutral White -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) 70 80 90 100 110 Page 18 of 24 Typical Forward Current Characteristics Figure 10: Typical Current vs. Voltage, BXRA-xxx0540-A, BXRA-56C0700-A 0.7 0.6 MIN Vf Tc=25°C MAX Vf Tc=25°C Current (A) 0.5 0.4 0.3 TYP Vf Tc=25°C MIN MAX MIN Vf Tc=70°C 0.2 TYP MIN Tc=70 0.1 0.0 13.0 15.5 18.0 20.5 23.0 Forward Voltage (V) Figure 11: Typical Current vs. Voltage BXRA-xxx0740-A, BXRA-40E0810-A, BXRA-56C1000-A 0.7 0.6 MIN Vf Tc=25°C Current (A) 0.5 0.4 MAX Vf Tc=25°C TYP Vf Tc=25°C MIN Vf Tc=70°C 0.3 MIN MAX 0.2 TYP MIN Tc=70 0.1 0.0 20.0 22.5 25.0 27.5 30.0 32.5 35.0 Forward Voltage (V) Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 19 of 24 Color Binning Information Figure 12: Graph of Warm White Test Bins in xy Color Space 0.44 0.43 3000K 3SDCM 0.42 T3 S3 R3 Q3 Y 0.41 T4 0.40 R4 Q4 0.39 S4 2700K 3SDCM 0.38 0.37 0.41 0.42 0.43 0.44 0.45 0.46 0.47 0.48 0.49 X Table 9: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code Q3 Q4 R3 R4 X3 (3SDCM) X Y 0.4223 0.4299 0.4431 0.4345 0.4147 0.4223 0.4345 0.4260 0.4345 0.4431 0.4562 0.4468 0.4260 0.4345 0.4468 0.4373 0.4413 0.4325 0.4274 0.4350 0.3990 0.4165 0.4213 0.4033 0.3814 0.3990 0.4033 0.3854 0.4033 0.4213 0.4260 0.4077 0.3854 0.4033 0.4077 0.3893 0.4107 0.4075 0.3958 0.3984 ANSI CCT (K) 3000 3000 3000 3000 3000 Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Bin Code S3 S4 T4 T3 X3 (3SDCM) X Y 0.4468 0.4562 0.4688 0.4585 0.4373 0.4468 0.4585 0.4483 0.4585 0.4688 0.4813 0.4703 0.4483 0.4585 0.4703 0.4593 0.4656 0.4573 0.4510 0.4583 0.4077 0.4260 0.4290 0.4104 0.3893 0.4077 0.4104 0.3919 0.4104 0.4290 0.4319 0.4132 0.3919 0.4104 0.4132 0.3944 0.4174 0.4154 0.4032 0.4049 ANSI CCT (K) 2700 2700 2700 2700 2700 Page 20 of 24 Color Binning Information (continued) Figure 13: Graph of Neutral White Test Bins in xy Color Space 0.41 0.40 Y M3 4000K 3SDCM 0.39 L3 0.38 M4 0.37 L4 0.36 0.35 0.36 0.37 0.38 0.39 0.40 0.41 Z Table 10: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code L3 L4 M3 M4 X3 (3SDCM) X Y 0.3703 0.3736 0.3871 0.3828 0.3670 0.3703 0.3828 0.3784 0.3828 0.3871 0.4006 0.3952 0.3784 0.3828 0.3952 0.3898 0.3881 0.3791 0.3769 0.3845 0.3726 0.3874 0.3959 0.3803 0.3578 0.3726 0.3803 0.3647 0.3803 0.3959 0.4044 0.3880 0.3647 0.3803 0.3880 0.3716 0.3879 0.3823 0.3724 0.3770 Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) ANSI CCT (K) 4000 4000 4000 4000 4000 Page 21 of 24 Color Binning Information (continued) Figure 14: Graph of Cool White Test Bins in xy Color Space Table 11: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code E3 E4 F3 F4 X Y 0.3215 0.3293 0.3292 0.3207 0.3222 0.3294 0.3293 0.3215 0.3292 0.3293 0.3371 0.3376 0.3294 0.3366 0.3371 0.3293 0.3353 0.3423 0.3539 0.3462 0.3243 0.3306 0.3423 0.3353 0.3539 0.3423 0.3493 0.3616 0.3306 0.3369 0.3493 0.3423 Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) ANSI CCT (K) 5600 5600 5600 5600 Page 22 of 24 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes • • • • • • • AN10: Effective Thermal Management of Bridgelux LED Arrays AN11: Assembly Considerations for Bridgelux LED Arrays AN12: Electrical Drive Considerations for Bridgelux LED Arrays AN14: Reliability Data Sheet for Bridgelux LED Arrays AN15: Reflow Soldering of Bridgelux LED Arrays AN16: Optical Considerations for Bridgelux LED Arrays DS19: Bridgelux LED Array Data Sheet for Packing and Labeling Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance. • • • • • • • • • Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 23 of 24 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solidstate lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 550 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2011 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux ES Star Array Series Product Data Sheet DS23 (12/3/11) Page 24 of 24
BXRA-40E0600-A-00 价格&库存
很抱歉,暂时无法提供与“BXRA-40E0600-A-00”相匹配的价格&库存,您可以联系我们找货
