BXRA-35E0800-B-03
BXRA-35E0800-B-03
    BRIDGELUX(普瑞)
    LED ARRAY 1080LM WARM WHT
BXRA-35E0800-B-03 数据手册
Bridgelux ES Rectangle Array Series Product Data Sheet DS24 BXRA-xxx0800, BXRA-xxx1200, BXRA-xxx2000 BXRA-40E0950, BXRA-40E1350, BXRA-40E2200 BXRA-xxC1100, BXRA-xxC1600, BXRA-xxC2600 Introduction The Bridgelux family of LED Array products delivers high performance, compact and cost-effective solidstate lighting solutions to serve the general lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of many conventional lighting sources. The Bridgelux ES Array Series enables lamp and luminaire designs surpassing efficacy and quality of light requirements driven by regulatory standards with reasonable system design margins, enabling lighting product compliance to Energy Star, DLC, Title 24, Part L and other global standards. The Bridgelux ES Array products are a high performance alternative to conventional solid state solutions, delivering between 700 and 3000 lumens under application conditions in warm, neutral and cool white color temperatures. These compact high flux density light sources deliver uniform high quality illumination without pixilation or the multiple shadow effect caused by LED component based solutions. To simplify system design for appropriate light output, Bridgelux LED Arrays are specified to deliver performance under typical use conditions. These integrated plug and play solutions reduce system complexity and enable miniaturized costeffective lamp and luminaire designs. Lighting system designs incorporating these LED Arrays deliver comparable performance to that of 60-200 Watt incandescent and halogen, 7-42 Watt compact fluorescent, and 18-50 Watt HID based luminaires and feature increased system level efficacy and service life. Typical applications include replacement lamps, task, accent, spot, retail, track, down light, low bay, wide area, security, wall pack and street lighting. Features Benefits  Compact high flux density light source  Enhanced optical control  Uniform high quality illumination  Clean white light without pixilation  Minimum 70, 80 and 90 CRI options  High quality true color reproduction  Streamlined thermal path  Significantly reduced thermal resistance and increased  Energy Star / ANSI compliant color binning structure operating temperatures with 3SDCM options  Uniform consistent white light More energy efficient than incandescent, halogen  Lower operating costs and fluorescent lamps  UL Recognized  Low voltage DC operation  Easy to use with daylight and motion detectors to  Instant light with unlimited dimming  5-Year warranty  RoHS compliant and Pb free  enable increased energy savings  Reduced maintenance costs  Environmentally friendly, no disposal issue 1 0 1 P ort ol a A ven u e , L i ve r mo re , CA 9 45 51 • Te l: (9 25 ) 58 3 - 840 0 • Fa x: ( 92 5) 5 83 -8 40 1 • www. b r id ge lu x.c om Table of Contents Page Typical Product Features 3 Product Nomenclature 3 UL Recognition 4 CE Recognition 4 Selection Guide 6 Typical Performance at Alternative Drive Currents 7 Flux Characteristics 10 Electrical Characteristics 11 Absolute Maximum Ratings 12 Typical Relative Luminous Flux vs. Current 16 Typical Radiation Pattern 19 Typical Spectral Characteristics 20 Mechanical Dimensions 21 Color Binning Information 22 Color Control Options 26 Design Resources 27 About Bridgelux 28 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 2 of 28 Typical Product Features Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The ES Rectangle array is a general purpose chip-on-board device serving a wide range of applications. The arrays incorporate several features to simplify design integration and assembly. Figure 1: Array Features Manufacturer identification: genuine Bridgelux Mounting Holes Solder Pad Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Index features assist accurate orientation during assembly Polarity Indication simplifies assembly instructions Solder Pad Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRA – AB C DEFG – H – IJ Where: B X R A – Designates product family A B – Designates the nominal ANSI color temperature; 27 = 2700K; 30 = 3000K, etc. C - Designates minimum CRI; C = 70, E = 80, G = 90 D E F G - Designates Nominal Flux; 0800 = 800lm, 1200 = 1200lm, 2000 = 2000lm, etc. H – Designates array configuration I J – Designates CCT Bin options 03 = 3SDCM or 3-step 04 = 4SDCM or 4-step 00 = 7SDCM or 7-step Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 3 of 28 Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation at the nominal drive current with case temperature maintained at or below 85°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid state lighting market. Bridgelux LED Arrays comply with the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). UL Recognition Bridgelux secures UL recognition for all the LED Array products. Please refer to the UL file E350613 for the latest list of UL recognized Arrays. Bridgelux uses UL recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. CE Recognition In accordance with the relevant European Union directives, the family of LED Array products conform to the applicable requirements of the IEC/EN 62031:2008 (LED Modules for General Lighting Safety Specifications) and IEC 62471:2006 (Photobiological Safety of Lamps and Lamp Systems). Bridgelux maintains a CE Declaration of Conformity statement on its website and displays the CE mark on product packing labels. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Case Temperature Measurement Point A case temperature (Tc) measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 4 of 28 Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Avoid any contact with the optical area. Do not touch the optical area of the LED Array or apply mechanical stress to the yellow phosphor resin area – it could damage the LED Array. Optics and reflectors must not be mounted in contact with the yellow phosphor resin area (LES) or the white ring that surrounds the yellow phosphor area. Using the white ring to secure optics can result in damage to the LED Array as the ring is not designed to act as a mechanical locating feature. Optical devices may be mounted on the top surface of the LED Array substrate outside of the white ring maximum OD as specified in the product data sheet. Use the mechanical features of the LED Array substrate edges and/or mounting holes to locate and secure the optical device as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC specification EN62471; Photobiological Safety of Lamps and Lamp Systems. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below their rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED Array. Please consult Application Note AN11 for additional information. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 5 of 28 Selection Guide The following configurations are available: Table 1: Selection Guide for ES Rectangular Arrays [2] Part Number [1] BXRA-27E0800-B-03 BXRA-27E1200-B-03 BXRA-27E2000-B-03 BXRA-27G0800-B-03 BXRA-27G1200-B-03 BXRA-27G2000-B-03 BXRA-30E0800-B-03 BXRA-30E1200-B-03 BXRA-30E2000-B-03 BXRA-30G0800-B-03 BXRA-30G1200-B-03 BXRA-30G2000-B-03 BXRA-35E0800-B-03 BXRA-35E1200-B-03 BXRA-35E2000-B-03 BXRA-40E0950-B-03 BXRA-40E1350-B-03 BXRA-40E2200-B-03 BXRA-50C1100-B-xx BXRA-50C1600-B-xx BXRA-50C2600-B-xx BXRA-56C1100-B-xx BXRA-56C1600-B-xx BXRA-56C2600-B-xx CCT (Kelvin) 2700K 2700K 2700K 2700K 2700K 2700K 3000K 3000K 3000K 3000K 3000K 3000K 3500K 3500K 3500K 4000K 4000K 4000K 5000K 5000K 5000K 5600K 5600K 5600K CRI 80 80 80 90 90 90 80 80 80 90 90 90 80 80 80 80 80 80 70 70 70 70 70 70 [3] Test Current [5] (mA) Typical Voltage (V) 500 500 700 500 500 700 500 500 700 500 500 700 500 500 700 500 500 700 500 500 700 500 500 700 20.5 29.3 36.2 20.5 29.3 36.2 20.5 29.3 36.2 20.5 29.3 36.2 20.5 29.3 36.2 20.5 29.3 36.2 20.5 29.3 36.2 20.5 29.3 36.2 Typical Flux [6] (lm) Tj = 25ºC Tcase = 85ºC 980 1420 2300 830 1200 2020 1070 1540 2460 900 1310 2080 1130 1630 2610 1200 1720 2800 1340 1930 3150 1340 1930 3150 850 1230 2000 720 1040 1760 930 1340 2140 780 1140 1810 980 1420 2270 1040 1500 2430 1170 1680 2740 1170 1680 2740 Typical Power[6] (W) Typical [6] Efficacy (lm/W) 10.3 14.7 25.3 10.3 14.7 25.3 10.3 14.7 25.3 10.3 14.7 25.3 10.3 14.7 25.3 10.3 14.7 25.3 10.3 14.7 25.3 10.3 14.7 25.3 96 97 91 81 82 80 104 105 97 88 89 82 110 111 103 117 117 110 131 132 124 131 132 124 Note for Table 1 through 5 (additional specific notes following Table 2 through 5): 1. Part numbers with “-xx” suffix are available with multiple color control options (4 SDCM or 7 SDCM for example). 2. Nominal CCT as defined by ANSI C78.377-2011. 3. Values are mimimum. 4. Minimum R9 value for 90 CRI products is 50. 5. Products tested under pulsed condition (10ms pulse width) at rated test current where Tjunction = Tcase = 25°C. 6. Typical performance values are provided as a reference only and are not a guarantee of performance. 7. Bridgelux maintains a ±7% tolerance on flux measurements. 8. Operating these LED Arrays at or below the drive currents listed in Table 2 and 5, with a case temperature maintained at or below 85°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 6 of 28 Typical Performance at Alternative Drive Currents Customers may drive the LED Arrays at alternative drive currents dependent on the specific application. The typical performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 2 and 3 and from the flux versus current characteristics shown in Figure 8 and 9. The typical performance at common drive currents is summarized in Table 2. Table 2: Typical Product Performance at Alternative Drive Currents Part Number [1] BXRA-27E0800-B-03 BXRA-27E1200-B-03 BXRA-27E2000-B-03 BXRA-27G0800-B-03 BXRA-27G1200-B-03 BXRA-27G2000-B-03 BXRA-30E0800-B-03 BXRA-30E1200-B-03 CCT & CRI 2700K and 80 CRI 2700K and 80 CRI 2700K and 80 CRI 2700K and 90 CRI 2700K and 90 CRI 2700K and 90 CRI 3000K and 80 CRI 3000K and 80 CRI Typical Voltage [6] (V) Typical Power [6] (W) Tj = 25ºC Tj = 25ºC Tj = 25ºC Tcase = 85ºC Tj = 25ºC 250 19.4 4.8 510 440 105 350 19.8 6.9 700 600 101 500 20.5 10.3 980 850 96 700 21.3 14.9 1320 1150 89 250 27.7 6.9 730 630 105 350 28.3 9.9 1010 870 102 500 29.3 14.7 1420 1230 97 700 30.4 21.3 1920 1660 90 350 34.2 12.0 1190 1030 99 500 35.1 17.6 1700 1470 97 Current [9] (mA) Typical Flux [6] (lm) Typical Efficacy [6] (lm/W) 700 36.2 25.3 2300 2000 91 1000 37.7 37.7 3160 2750 84 250 19.4 4.8 430 370 89 350 19.8 6.9 590 510 85 500 20.5 10.3 830 720 81 700 21.3 14.9 1120 970 75 250 27.7 6.9 620 540 89 350 28.3 9.9 850 740 86 500 29.3 14.7 1200 1040 82 700 30.4 21.3 1620 1400 76 350 34.2 12.0 1040 910 87 500 35.1 17.6 1490 1300 85 700 36.2 25.3 2020 1760 80 1000 37.7 37.7 2770 2420 73 250 19.4 4.8 550 480 113 350 19.8 6.9 760 660 109 500 20.5 10.3 1070 930 104 700 21.3 14.9 1440 1250 97 250 27.7 6.9 790 690 114 350 28.3 9.9 1090 950 110 500 29.3 14.7 1540 1340 105 700 30.4 21.3 2080 1810 98 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 7 of 28 Table 2 Continued Part Number [1] BXRA-30E2000-B-03 BXRA-30G0800-B-03 BXRA-30G1200-B-03 BXRA-30G2000-B-03 BXRA-35E0800-B-03 BXRA-35E1200-B-03 BXRA-35E2000-B-03 BXRA-40E0950-B-03 CCT & CRI 3000K and 80 CRI 3000K and 90 CRI 3000K and 90 CRI 3000K and 90 CRI 3500K and 80 CRI 3500K and 80 CRI 3500K and 80 CRI 4000K and 80 CRI Typical Voltage [6] (V) Typical Power [6] (W) Tj = 25ºC Tj = 25ºC Tj = 25ºC Tcase = 85ºC Tj = 25ºC 350 34.2 12.0 1270 1100 106 500 35.1 17.6 1810 1580 103 700 36.2 25.3 2460 2140 97 1000 37.7 37.7 3380 2940 90 250 19.4 4.8 460 400 95 350 19.8 6.9 640 550 92 500 20.5 10.3 900 780 88 700 21.3 14.9 1210 1050 81 250 27.7 6.9 680 590 98 350 28.3 9.9 930 810 94 500 29.3 14.7 1310 1140 89 700 30.4 21.3 1770 1540 83 350 34.2 12.0 1070 930 89 500 35.1 17.6 1530 1330 87 Current [9] (mA) Typical Flux [6] (lm) Typical Efficacy [6] (lm/W) 700 36.2 25.3 2080 1810 82 1000 37.7 37.7 2860 2490 76 250 19.4 4.8 580 510 120 350 19.8 6.9 800 700 115 500 20.5 10.3 1130 980 110 700 21.3 14.9 1520 1320 102 250 27.7 6.9 840 730 121 350 28.3 9.9 1160 1010 117 500 29.3 14.7 1630 1420 111 700 30.4 21.3 2200 1920 103 350 34.2 12.0 1350 1170 113 500 35.1 17.6 1920 1670 109 700 36.2 25.3 2610 2270 103 1000 37.7 37.7 3590 3120 95 250 19.4 4.8 620 540 128 350 19.8 6.9 850 740 122 500 20.5 10.3 1200 1040 117 700 21.3 14.9 1620 1400 109 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 8 of 28 Table 2 Continued Part Number [1] BXRA-40E1350-B-03 BXRA-40E2200-B-03 BXRA-50C1100-B-xx BXRA-50C1600-B-xx BXRA-50C2600-B-xx BXRA-56C1100-B-xx BXRA-56C1600-B-xx BXRA-56C2600-B-xx CCT & CRI 4000K and 80 CRI 4000K and 80 CRI 5000K and 70 CRI 5000K and 70 CRI 5000K and 70 CRI 5600K and 70 CRI 5600K and 70 CRI 5600K and 70 CRI Typical Voltage [6] (V) Typical Power [6] (W) Tj = 25ºC Tj = 25ºC 250 27.7 6.9 350 28.3 9.9 500 29.3 14.7 700 30.4 350 500 Current [9] (mA) Typical Flux [6] (lm) Tj = 25ºC Typical Efficacy [6] (lm/W) Tcase = 85ºC Tj = 25ºC 890 770 128 1220 1070 123 1720 1500 117 21.3 2320 2020 109 34.2 12.0 1440 1250 120 35.1 17.6 2060 1790 117 700 36.2 25.3 2800 2430 110 1000 37.7 37.7 3850 3340 102 250 19.4 4.8 690 600 142 350 19.8 6.9 950 830 137 500 20.5 10.3 1340 1170 131 700 21.3 14.9 1810 1580 121 250 27.7 6.9 1000 870 144 350 28.3 9.9 1370 1190 138 500 29.3 14.7 1930 1680 132 700 30.4 21.3 2600 2270 122 350 34.2 12.0 1620 1410 135 500 35.1 17.6 2320 2020 132 700 36.2 25.3 3150 2740 124 1000 37.7 37.7 4330 3760 115 250 19.4 4.8 690 600 142 350 19.8 6.9 950 830 137 500 20.5 10.3 1340 1170 131 700 21.3 14.9 1810 1580 121 250 27.7 6.9 1000 870 144 350 28.3 9.9 1370 1190 138 500 29.3 14.7 1930 1680 132 700 30.4 21.3 2600 2270 122 350 34.2 12.0 1620 1410 135 500 35.1 17.6 2320 2020 132 700 36.2 25.3 3150 2740 124 1000 37.7 37.7 4330 3760 115 Notes for Table 2: 9. Values in bold correspond to rated test currents from Table 1. Alternate values are provided for reference only and are not guaranteed. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 9 of 28 Flux Characteristics Table 3: Flux Characteristics [2] Part Number [1] CCT (Kelvin) CRI [3] Test Current [5] (mA) Minimum Flux [5] (lm) Minimum Flux [10] (lm) Typical Flux [6] (lm) Typical CBCP [11] (cd) Tj = 25ºC Tcase = 85ºC Tcase = 85ºC Tj = 25ºC BXRA-27E0800-B-03 2700K 80 500 870 750 850 310 BXRA-27E1200-B-03 2700K 80 500 1250 1080 1230 450 BXRA-27E2000-B-03 2700K 80 700 2030 1770 2000 730 BXRA-27G0800-B-03 2700K 90 500 740 640 720 260 BXRA-27G1200-B-03 2700K 90 500 1060 920 1040 380 BXRA-27G2000-B-03 2700K 90 700 1780 1550 1760 640 BXRA-30E0800-B-03 3000K 80 500 950 830 930 340 BXRA-30E1200-B-03 3000K 80 500 1360 1180 1340 490 BXRA-30E2000-B-03 3000K 80 700 2170 1890 2140 780 BXRA-30G0800-B-03 3000K 90 500 800 690 780 290 BXRA-30G1200-B-03 3000K 90 500 1160 1010 1140 420 BXRA-30G2000-B-03 3000K 90 700 1850 1610 1810 660 BXRA-35E0800-B-03 3500K 80 500 1000 870 980 360 BXRA-35E1200-B-03 3500K 80 500 1440 1250 1420 520 BXRA-35E2000-B-03 3500K 80 700 2300 2000 2270 830 BXRA-40E0950-B-03 4000K 80 500 1060 920 1040 380 BXRA-40E1350-B-03 4000K 80 500 1520 1330 1500 550 BXRA-40E2200-B-03 4000K 80 700 2470 2140 2430 890 BXRA-50C1100-B-xx 5000K 70 500 1180 1030 1170 430 BXRA-50C1600-B-xx 5000K 70 500 1700 1480 1680 610 BXRA-50C2600-B-xx 5000K 70 700 2780 2420 2740 1000 BXRA-56C1100-B-xx 5600K 70 500 1180 1030 1170 430 BXRA-56C1600-B-xx 5600K 70 500 1700 1480 1680 610 BXRA-56C2600-B-xx 5600K 70 700 2780 2420 2740 1000 Notes for Table 3: 10. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the environment in which the product is operated. 11. Center beam candle power is a calculated value based on a Lambertian radiation pattern at the rated test current. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 10 of 28 Electrical Characteristics Table 4: Electrical Characteristics Part Number [1] Minimum Typical Maximum Typical Coefficient of Forward Voltage [13] (mV/ºC) ∆Vf/∆Tj Operating Voltage Tj = 25°C [5, 12] (V) Test Current [5] (mA) Typical Thermal Resistance Junction to Case (ºC/W) Rθj-c BXRA-27E0800-B-03 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-27E1200-B-03 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-27E2000-B-03 700 32.6 36.2 39.8 -12 to -36 0.65 BXRA-27G0800-B-03 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-27G1200-B-03 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-27G2000-B-03 700 32.6 36.2 39.8 -12 to -36 0.65 BXRA-30E0800-B-03 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-30E1200-B-03 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-30E2000-B-03 700 32.6 36.2 39.8 -12 to -36 0.65 BXRA-30G0800-B-03 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-30G1200-B-03 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-30G2000-B-03 700 32.6 36.2 39.8 -12 to -36 0.65 BXRA-35E0800-B-03 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-35E1200-B-03 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-35E2000-B-03 700 32.6 36.2 39.8 -12 to -36 0.65 BXRA-40E0950-B-03 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-40E1350-B-03 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-40E2200-B-03 700 32.6 36.2 39.8 -12 to -36 0.65 BXRA-50C1100-B-xx 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-50C1600-B-xx 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-50C2600-B-xx 700 32.6 36.2 39.8 -12 to -36 0.65 BXRA-56C1100-B-xx 500 18.4 20.5 22.5 -7 to -21 0.95 BXRA-56C1600-B-xx 500 26.3 29.3 32.2 -10 to -30 0.80 BXRA-56C2600-B-xx 700 32.6 36.2 39.8 -12 to -36 0.65 Notes for Table 4: 12. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Voltage minimum and maximum values at the rated test current are guaranteed by 100% test. 13. Typical Coefficient of Forward Voltage maintains a tolerance of ±0.1 from nominal current. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 11 of 28 Absolute Maximum Ratings Table 5: Maximum Current and Reverse Voltage Ratings CCT [2] (Kelvin) 2700K 3000K 3500K 4000K 5000K 5600K DC Forward Current for LM-80 (mA) [4,5,6] Maximum Peak Pulsed Current (mA) [14, 16] Maximum Reverse Voltage (Vr) [15] BXRA-27E0800-B-03 700 1400 -35 BXRA-27G0800-B-03 700 1400 -35 BXRA-27E1200-B-03 700 1400 -50 BXRA-27G1200-B-03 700 1400 -50 BXRA-27E2000-B-03 700 1400 -60 BXRA-27G2000-B-03 700 1400 -60 BXRA-30E0800-B-03 700 1400 -35 BXRA-30G0800-B-03 700 1400 -35 BXRA-30E1200-B-03 700 1400 -50 BXRA-30G1200-B-03 700 1400 -50 BXRA-30E2000-B-03 700 1400 -60 BXRA-30G2000-B-03 700 1400 -60 BXRA-35E0800-B-03 700 1400 -35 BXRA-35E1200-B-03 700 1400 -50 BXRA-35E2000-B-03 700 1400 -60 BXRA-40E0950-B-03 700 1400 -35 BXRA-40E1350-B-03 700 1400 -50 BXRA-40E2200-B-03 700 1400 -60 BXRA-50C1100-B-xx 700 1400 -35 BXRA-50C1600-B-xx 700 1400 -50 BXRA-50C2600-B-xx 700 1400 -60 BXRA-56C1100-B-xx 700 1400 -35 BXRA-56C1600-B-xx 700 1400 -50 BXRA-56C2600-B-xx 700 1400 -60 Part Number [1] Notes for Table 5: 14. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. 15. Light emitting diodes are not designed to be driven in reverse voltage. 16. Maximum peak pulsed currents are values at which the LED Array can be driven without catastrophic failures. 17. DC Forward Current for LM-80 are the maximum drive currents for which LM-80 data is currently available 18. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these arrays. 19. Arrays can be driven at higher currents but lumen maintenance may be reduced Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 12 of 28 Table 6: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature Soldering Temperature [1] 105°C 350°C or lower for a maximum of 3.5 seconds Note for Table 6: 20. Refer to Bridgelux Application Note AN15: Reflow soldering of Bridgelux LED Arrays for solder procedure (www,Bridgelux.com) Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 13 of 28 Forward Current Characteristics Figure 2: Typical Current vs. Voltage BXRA-xxx0800-B-00, BXRA-xxx0950-B-00, BXRA-xxx1100-B-00 MIN Vf Tc=25°C MAX Vf Tc=25°C MIN Vf Tc=70°C TYP Vf Tc=25°C Figure 3: Typical Current vs. Voltage BXRA-xxx1200-B-00, BXRA-xxx1350-B-00, BXRA-xxx1600-B-00 MIN Vf Tc=25°C MAX Vf Tc=25°C TYP Vf Tc=25°C MIN Vf Tc=70°C Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 14 of 28 Forward Current Characteristics (continued) Figure 4: Typical Current vs. Voltage BXRA-xxx2000-B-00, BXRA-xxx2200-B-00, BXRA-xxx2600-B-00 MIN Vf Tc=70°C MAX Vf Tc=25°C MIN Vf Tc=25°C TYP Vf Tc=25°C Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 15 of 28 Typical Relative Luminous Flux vs. Current Typical performance at any drive current can be derived from the current versus voltage characteristics shown in Figures 2, 3, and 4 and the flux versus current characteristics shown in Figures 5 and 6. Figure 5 and 6 represent typical performance when pulsed at a junction temperature of 25 degrees Celsius. Normalized Flux Figure 5: Typical Flux vs. Current BXRA-xxx0800-B-00, BXRA-xxx0950-B-00, BXRA-xxx1100-B-00 BXRA-xxx1200-B-00, BXRA-xxx1350-B-00, BXRA-xxx1600-B-00 Normalized Flux Figure 6: Typical Flux vs. Current BXRA-xxx2000-B-00, BXRA-xxx2200-B-00, BXRA-xxx2600-B-00 Typical Chromaticity Characteristics (continued) Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 16 of 28 Figure 7: Typical Flux vs. Junction Temperature Figure 9: Typical Flux vs. Junction Temperature 1.2 Neutral White Normalized Luminous Flux 1.0 Warm White 0.8 Cool White 0.6 Warm White Neutral White 0.4 Cool White 0.2 0.0 -10 0 10 20 30 40 50 60 Junction Temperature, °C 70 80 90 100 110 Note for Figures 7, 8 and 9: 1. Characteristics shown for Warm White 3000K 80CRI 2. Characteristics shown for Neutral White 4000K 80CRI 3. Characteristics shown for Neutral White 5000K 70CRI Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 17 of 28 Typical Chromaticity Characteristics (continued) Figure 8: Typical Flux vs. Junction Temperature 0.02 Neutral White Warm White 0.01 0.00 Δy -0.01 Cool White -0.02 -0.03 Warm White Cool White -0.04 Neutral White -0.05 -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C 70 80 90 100 110 Figure 9: Typical Flux vs. Junction Temperature 0.02 Warm White Neutral White 0.01 0.00 -0.01 Δx Cool White -0.02 -0.03 Warm White -0.04 Cool White -0.05 Neutral White -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) 70 80 90 100 110 Page 18 of 28 Typical Radiation Pattern Figure 10: Typical Spatial Radiation Pattern 100% 90% Relative Intensity (%) 80% 70% 60% 50% 40% 30% 20% 10% 0% -90° -80° -70° -60° -50° -40° -30° -20° -10° 0° 10° 20° 30° 40° 50° 60° 70° 80° 90° Angular Displacement (°) Notes for figure 10: 1. Typical viewing angle is 120⁰ 2. Viewing angle is defined as the off axis angle from the centerline where vertical intensity is ½ of the peak intensity value. Figure 11: Typical Polar Radiation Pattern Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 19 of 28 Typical Spectral Characteristics Figure 12: Typical Color Spectrum Relative Intensity (%) 3000K 4000K 5000K 110% 100% 90% 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Notes for Figure 12: 1. 2. 3. 4. Color spectra measured at rated current and Tj = 25°C. Color spectrum shown for warm white is 3000K and 80 CRI. Color spectrum shown for neutral white is 4000K and 80 CRI. Color spectrum shown for cool white is 5000K and 70 CRI. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 20 of 28 Mechanical Dimensions Figure 13: Drawing for ES Rectangular Arrays Notes for Figure 13: 1. Mounting holes are for M2.5 or #4 screws. 2. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. 3. It is not necessary to provide electrical connections to both sets of solder pads. Either set may be used depending on application specific design requirements. 4. Drawings are not to scale. 5. Drawing dimensions are in millimeters. 6. Unless otherwise specified, tolerances are ± 0.10mm. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array. The light emitting surface (LES) is centered on the mechanical center of the array to a tolerance of ± 0.45 mm 8. Bridgelux maintains a flatness of 0.1 mm across the mounting surface of the array. Refer to Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 21 of 28 Color Binning Information Figure 14: Graph of Warm White Test Bins in xy Color Space Note: 3SDCM bins are shown inside standard ANSI bins for comparison purposes. Table 7: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code x y X3 (3SDCM) 0.4148 0.4047 0.4012 0.4098 0.4148 0.4000 0.3950 0.3841 0.3883 0.4000 CCT (K) 3500 Bin Code x y X3 (3SDCM) 0.4413 0.4325 0.4274 0.4350 0.4413 0.4107 0.4075 0.3958 0.3984 0.4107 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) CCT (K) 3000 Bin Code x y CCT (K) X3 (3SDCM) 0.4665 0.4557 0.4500 0.4595 0.4665 0.4175 0.4145 0.4026 0.4050 0.4175 2700 Page 22 of 28 Color Binning Information (continued) Figure 15: Graph of Neutral White Test Bins in xy Color Space Note: 3SDCM bins are shown inside standard ANSI bins for comparison purposes. Table 8: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code X Y CCT (K) X3 3SDCM 0.3881 0.3791 0.3769 0.3845 0.3879 0.3823 0.3724 0.377 4000 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 23 of 28 Color Binning Information (continued) Figure 16: Graph of Cool White Test Bins in xy Color Space Note: 4SDCM bins are shown inside standard ANSI bins for comparison purposes. Table 9: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code X Y 0.3376 0.3616 0.3464 0.3688 G3 ANSI CCT (K) 5000 Bin Code X Y 0.3215 0.3353 0.3293 0.3423 E3 5600 0.3452 0.3558 0.3292 0.3539 0.3371 0.3493 0.3207 0.3462 0.3371 0.3493 0.3222 0.3243 0.3452 0.3558 0.3294 0.3306 G4 5000 E4 5600 0.3441 0.3428 0.3293 0.3423 0.3366 0.3369 0.3215 0.3353 0.3464 0.3688 0.3292 0.3539 0.3551 0.376 0.3293 0.3423 H3 5000 F3 5600 0.3533 0.3624 0.3371 0.3493 0.3452 0.3558 0.3376 0.3616 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) ANSI CCT (K) Page 24 of 28 0.3452 0.3558 0.3533 0.3624 H4 X4 5000 0.3294 0.3306 0.3366 0.3369 F4 5600 0.3515 0.3487 0.3371 0.3493 0.3441 0.3428 0.3293 0.3423 0.3499 0.3657 0.3332 0.3517 0.3412 0.3585 X4 0.3247 0.3440 (4SDCM) 0.3255 0.3330 0.3327 0.3393 5000 (4SDCM) 0.3407 0.3461 0.3481 0.3520 5600 Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 25 of 28 Color Control Options ES LED Series Arrays are available in the following color control options. Table 10: Color Control Options Product CCT CRI 3SDCM Part Number 4SDCM Part Number 7SDCM Part Number ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array ES LED Array 2700K 2700K 2700K 2700K 2700K 2700K 3000K 3000K 3000K 3000K 3000K 3000K 3500K 3500K 3500K 4000K 4000K 4000K 5000K 5000K 5000K 5600K 5600K 5600K 80 90 80 90 80 90 80 90 80 90 80 90 80 80 80 80 80 80 70 70 70 70 70 70 BXRA-27E0800-B-03 BXRA-27G0800-B-03 BXRA-27E1200-B-03 BXRA-27G1200-B-03 BXRA-27E2000-B-03 BXRA-27G2000-B-03 BXRA-30E0800-B-03 BXRA-30G0800-B-03 BXRA-30E1200-B-03 BXRA-30G1200-B-03 BXRA-30E2000-B-03 BXRA-30G2000-B-03 BXRA-35E0800-B-03 BXRA-35E1200-B-03 BXRA-35E2000-B-03 BXRA-40E0950-B-03 BXRA-40E1350-B-03 BXRA-40E2200-B-03 Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available BXRA-50C1100-B-04 BXRA-50C1600-B-04 BXRA-50C2600-B-04 BXRA-56C1100-B-04 BXRA-56C1600-B-04 BXRA-56C2600-B-04 Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available Not Available BXRA-50C1100-B-00 BXRA-50C1600-B-00 BXRA-50C2600-B-00 BXRA-56C1100-B-00 BXRA-56C1600-B-00 BXRA-56C2600-B-00 Note: Color Control Marking Array part numbers are shown in the tables above. Arrays are tested, binned and marked with the appropriate sub-bin. Warm and Neutral White arrays are tested to 3SDCM (marked as X3). Cool white arrays are tested to 4SDCM (marked as X4). Cool white arrays are tested to 7SDCM (marked with sub-bin). Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 26 of 28 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes       AN10: AN11: AN12: AN14: AN15: AN16: Effective Thermal Management of Bridgelux LED Arrays Assembly Considerations for Bridgelux LED Arrays Electrical Drive Considerations for Bridgelux LED Arrays Reliability Data Sheet for Bridgelux LED Arrays Reflow Soldering of Bridgelux LED Arrays Optical Considerations for Bridgelux LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance.          Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 27 of 28 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid-state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 650 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2013 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux ES Rectangle Array Series Product Data Sheet DS24 (8/30/2013 rev3) Page 28 of 28
BXRA-35E0800-B-03 价格&库存
很抱歉,暂时无法提供与“BXRA-35E0800-B-03”相匹配的价格&库存,您可以联系我们找货
