BXRA-30E3500-F-00
BXRA-30E3500-F-00
    BRIDGELUX(普瑞)
    LED ARRAY 3150LM WARM WHT
BXRA-30E3500-F-00 数据手册
Bridgelux RS Array Series Product Data Sheet DS25 BXRA-27X-3500-F, BXRA-27X4000-H, BXRA-27x7000-J, BXRA-30X3500-F, BXRA-30X4000-H, BXRA-30X7000-J, BXRA-35X3500-F, BXRA-35X4000 -H, BXRA-35X7000-J, BXRA-40X4000-F, BXRA-40E4500-H, BXRA-40E7500-J, BXRA-5XC4500-F, BXRA-5XC5300-H, BXRA-5XC9000-J Introduction The Bridgelux family of LED Array products delivers high performance, compact and cost-effective solidstate lighting solutions to serve the general lighting market. These products combine the higher efficacy, lifetime, and reliability benefits of LEDs with the light output levels of many conventional lighting sources. The Bridgelux RS Array Series has been specified to enable lamp and luminaire designs with comparable performance to existing high wattage CFL and HID conventional light sources for retail, commercial, industrial and outdoor/street lighting applications. Bridgelux Arrays are ideal for all types of light-on-demand applications, where they can be instantaneously and smoothly dimmed up or down without any effect on lifetime, unlike traditional CFL and HID light sources. Bridgelux RS Array series are a high performance alternative to conventional solid state solutions, delivering between 3,000 and 10,000 lumens under application conditions in warm, neutral and cool white color temperatures. These compact high flux density light sources deliver uniform high quality illumination without pixilation or the multiple shadow effect caused by LED component based solutions, enabling excellent beam control for precision lighting. LED array solutions reduce system complexity and enable miniaturized cost-effective designs. Luminaire designs incorporating these LED Arrays deliver system level performance comparable to 42-55 Watt CFL, 35-90 Watt low pressure sodium, 70-150 Watt high pressure sodium or 70-200 Watt metal halide based luminaires and feature increased system level and service life. Typical applications include retail lighting, commercial down lights, high bay, outdoor and street lights, and entertainment lighting. Features Benefits • Compact high flux density light source • Enhanced optical control • Uniform high quality illumination • Clean white light without pixilation • Minimum 70, 80 and 90 CRI options • High quality true color reproduction • Streamlined thermal path • • Energy Star / ANSI compliant color binning structure with 3SDCM options Significantly reduced thermal resistance and increased operating temperatures • Uniform consistent white light • More energy efficient than incandescent, halogen and fluorescent lamps • Lower operating costs • Increased safety • Low voltage DC operation • • Instant light with unlimited dimming Easy to use with daylight and motion detectors to enable increased energy savings • 5-Year warranty • Reduced maintenance costs • RoHS compliant and Pb free • Environmentally friendly, no disposal issue 1 0 1 P o rt o l a A v e n u e , L i v e rm o re , C A 9 4 5 5 1 • T e l : (9 2 5 ) 5 8 3 -8 4 0 0 • Fa x: (9 2 5 ) 5 8 3 -8 4 0 1 • ww w. b ri d g e l u x. c o m Table of Contents Page Product Nomenclature 3 Average Lumen Maintenance Characteristics 3 IES LM-80 Test Data 3 Environmental Compliance 4 UL Recognition 4 Minor Product Change Policy 4 Cautionary Statements 4 Selection Guide 6 Color Control Options 7 Flux Characteristics 8 Optical Characteristics 9 Electrical Characteristics 10 Absolute Minimum and Maximum Ratings 11 Typical Performance at Alternative Drive Currents 12 Typical Performance at Alternative Drive Currents (continued) 13 Mechanical Dimensions 15 Typical Radiation Pattern 16 Wavelength Characteristics at Rated Test Current, Tj=25°C 17 Typical Relative Luminous Flux vs. Current, Tj=25°C 18 Typical Light Output Characteristics vs. Temperature 20 Forward Current Characteristics 22 Color Binning Information 24 Design Resources 27 Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 2 of 28 Product Nomenclature The part number designation for Bridgelux LED Arrays is explained as follows: BXRA – AB C DEFG – H – IJ - KLM Where: BXRA – Designates product family AB – Designates the nominal ANSI color temperature; 27 = 2700K; 30 = 3000K, etc. C - Designates minimum CRI; C = 70, E = 80, G = 90 DEFG - Designates Nominal Flux; 4000 = 4000lm, 7000 = 7000lm, 9000 = 9000lm, etc. H – Designates array configuration IJ – Designates CCT Bin options 3000K as an example: 00 = Full ANSI: Q3, Q4, R3, R4 03 = 3 SDCM KLM – Designates wire option if available Average Lumen Maintenance Characteristics Bridgelux projects that its family of LED Array products will deliver, on average, greater than 70% lumen maintenance after 50,000 hours of operation at the rated forward test current. This performance assumes constant current operation with case temperature maintained at or below 85°C. For use beyond these typical operating conditions please consult your Bridgelux sales representative for further assistance. These projections are based on a combination of package test data, semiconductor chip reliability data, a fundamental understanding of package related degradation mechanisms, and performance observed from products installed in the field using Bridgelux die technology. Bridgelux conducts lumen maintenance tests per LM80. Observation of design limits is required in order to achieve this projected lumen maintenance. IES LM-80 Test Data Bridgelux has carried out extensive testing on multiple LED arrays according to the IES LM-80 test protocols. LM80 data is available to support all BXRA LED array products. The IES LM-80 qualification test method is required for an LED light source. The LM-80 test method does not apply to an LED luminaire light fixture. LM-80 is a rigorous test procedure that has been designed to provide LED light source test data to support an ENERGY STAR rating for a luminaire light fixture. When a manufacturer requires an ENERGY STAR rating for a fixture, the manufacture must have the luminaire light fixture tested to LM-79 by an accredited test facility. This test ensures that the fixture meets the photometric performance required for the ENERGY STAR rating under the specified operating conditions of the fixture. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 3 of 28 The fixture manufacturer must provide an LM-80 report with the appropriate test data to support the operating conditions of the fixture that is to be submitted. Bridgelux can supply an LM-80 report for specific requests, contact your local Bridgelux sales representative. Environmental Compliance Bridgelux is committed to providing environmentally friendly products to the solid-state lighting market. Bridgelux LED Arrays comply with the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS directive. Bridgelux does not intentionally add the following restricted materials to LED Array products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE). UL Recognition Bridgelux secures UL Recognition for all the LED Array products. Please refer to the UL file E333389 for the latest list of UL Recognized Arrays. Bridgelux uses UL Recognized materials with suitable flammability ratings in the LED Array to streamline the process for customers to secure UL listing of the final luminaire product. Bridgelux recommends that luminaires are designed with a Class 2 Driver to facilitate the UL listing process. Minor Product Change Policy The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Cautionary Statements CAUTION: CONTACT WITH OPTICAL AREA Avoid any contact with the optical area. Do not touch the optical area of the LED Array or apply stress to the yellow phosphor resin area – it could damage to the LED Array. Optics and reflectors must not be mounted in contact with the white phosphor resin area or the white ring that surrounds the yellow phosphor area. Using the white ring to secure optics can result in damage to the LED Array as the ring is not designed to act as a mechanical locating feature. Optical devices may be mounted on the top surface of the LED Array substrate outside of the white ring maximum OD as specified in the product data sheet. Use the mechanical features of the LED Array substrate edges and/or mounting holes to locate and secure the optical device as needed. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux LED Arrays is in accordance with IEC specification EN62471; Photobiological Safety of Lamps and Lamp Systems. Bridgelux LED Arrays are classified as Risk Group 1 (Low Risk) when operated at or below their rated test current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION: RISK OF BURN Do not touch the LED Array or resin area during operation. Allow the LED Array to cool for a sufficient period of time before handling. The LED Array may reach elevated temperatures such that it can burn skin when touched. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 4 of 28 CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED Array. Please consult Application Note AN11 for additional information. Case Temperature Measurement Point A case temperature measurement point location is included on the top surface of the Bridgelux LED Arrays. The location of this measurement point is indicated in the mechanical dimensions section of this data sheet. The purpose of this measurement point is to allow the user access to a measurement point closely linked to the true case temperature on the back surface of the LED Array. Once the LED Array is installed, it is challenging to measure the back surface of the array, or true case temperature. Measuring the top surface of the product can lead to inaccurate results due to the poor thermal conductivity of the top layers of the array such as the solder mask and other materials. Bridgelux has provided the case temperature measurement location in a manner which closely ties it to the true case temperature of the LED Array under steady state operation. Deviations between thermal measurements taken at the point indicated and the back of the LED Array differ by less than 1°C, providing a robust method to testing thermal operation once the product is installed. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 5 of 28 Selection Guide The following configurations are available. (3-step (7SDCM) color control available on certain configurations): Table 1: Selection Guide for RS Arrays BXRA Part Number CCT CRI (Nominal) (min) Typical DC Flux Tcase= 70ºC (lm) Typical Pulsed Flux Tj = 25ºC Test Current Efficacy Vf Power (mA) (Typ) (V) (Typ) (W) (Typ at Tj 25ºC) (lm/W) (lm) BXRA-27E3500-F-00 BXRA-27G3500-F-00 BXRA-27E4000-H-00 2700 2700 2700 80 90 80 2690 2280 4090 3025 2570 4600 1750 1750 2100 18.2 18.2 23.5 31.8 31.8 49.4 95 81 93 BXRA-27G4000-H-00 2700 90 3550 3950 2100 23.5 49.4 80 BXRA-27E7000-J-00 2700 80 6425 7300 2800 30.5 85.4 85 BXRA-27G7000-J-00 2700 90 5520 6275 2800 30.5 85.4 73 BXRA-30E3500-F-00 3000 80 2800 3150 1750 18.2 31.8 99 BXRA-30G3500-F-00 3000 90 2450 2750 1750 18.2 31.8 86 BXRA-30E4000-H-00 3000 80 4375 4925 2100 23.5 49.4 100 BXRA-30G4000-H-00 3000 90 3730 4200 2100 23.5 49.4 85 BXRA-30E7000-J-00 3000 80 6900 7850 2800 30.5 85.4 92 BXRA-30G7000-J-00 3000 90 5900 6700 2800 30.5 85.4 78 BXRA-35E3500-F-00 3500 80 3025 3400 1750 18.2 31.8 107 BXRA-35E4000-H-00 3500 80 4710 5300 2100 23.5 49.4 107 BXRA-35E7000-J-00 3500 80 7390 8400 2800 30.5 85.4 98 BXRA-40E4000-F-00 4000 80 3130 3525 1750 18.2 31.8 111 BXRA-40E4500-H-00 4000 80 5025 5650 2100 23.5 49.4 114 BXRA-40E7500-J-00 4000 80 7830 8900 2800 30.5 85.4 104 BXRA-50C4500-F-00 5000 70 3575 4025 1750 18.2 31.8 127 BXRA-50C5300-H-00 5000 70 5585 6275 2100 23.5 49.4 127 BXRA-50C9000-J-00 5000 70 8800 10000 2800 30.5 85.4 117 BXRA-56C4500-F-00 5600 70 3580 4025 1750 18.2 31.8 127 BXRA-56C5300-H-00 5600 70 5575 6275 2100 23.5 49.4 127 BXRA-56C9000-J-00 5600 70 8800 10000 2800 30.5 85.4 117 Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 6 of 28 Color Control Options ES LED Series Arrays are available in the following color control options. Table 2: Color Control Options Product CCT CRI 7SDCM Part Number 3SDCM Part Number RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array RS LED Array 2700K 2700K 2700K 2700K 2700K 2700K 3000K 3000K 3000K 3000K 3000K 3000K 3500K 3500K 3500K 4000K 4000K 4000K 5000K 5000K 5000K 5600K 5600K 5600K 80 90 80 90 80 90 80 90 80 90 80 90 80 80 80 80 80 80 70 70 70 70 70 70 BXRA-27E3500-F-00 BXRA-27G3500-F-00 BXRA-27E4000-H-00 BXRA-27G4000-H-00 BXRA-27E7000-J-00 BXRA-27G7000-J-00 BXRA-30E3500-F-00 BXRA-30G3500-F-00 BXRA-30E4000-H-00 BXRA-30G4000-H-00 BXRA-30E7000-J-00 BXRA-30G7000-J-00 BXRA-35E3500-F-00 BXRA-35E4000-H-00 BXRA-35E7000-J-00 BXRA-40E4000-F-00 BXRA-40E4500-H-00 BXRA-40E7500-J-00 BXRA-50C4500-F-00 BXRA-50C5300-H-00 BXRA-50C9000-J-00 BXRA-56C4500-F-00 BXRA-56C5300-H-00 BXRA-56C9000-J-00 BXRA-27E3500-F-03 BXRA-27G3500-F-03 BXRA-27E4000-H-03 BXRA-27G4000-H-03 BXRA-27E7000-J-03 BXRA-27G7000-J-03 BXRA-30E3500-F-03 BXRA-30G3500-F-03 BXRA-30E4000-H-03 BXRA-30G4000-H-03 BXRA-30E7000-J-03 BXRA-30G7000-J-03 BXRA-35E3500-F-03 BXRA-35E4000-H-03 BXRA-35E7000-J-03 BXRA-40E4000-F-03 BXRA-40E4500-H-03 BXRA-40E7500-J-03 Not Available Not Available Not Available Not Available Not Available Not Available Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 7 of 28 Flux Characteristics Table 3: Flux Characteristics Color ANSI CCT (K) 2700 Warm White 3000 3500 Neutral White 4000 5000 Cool White 5600 BXRA Part Number CRI (min)(4) Typical DC Flux Tcase= 70ºC (lm)(3) Minimum Pulsed Flux Tj 25ºC (lm) (1) Typical Pulsed Flux Tj = 25ºC (lm) (3) Test Current (mA) (2) BXRA-27E3500-F-00 80 2690 2720 3025 1750 BXRA-27G3500-F-00 90 2280 2310 2570 1750 BXRA-27E4000-H-00 80 4090 4140 4600 2100 BXRA-27G4000-H-00 90 3550 3550 3950 2100 BXRA-27E7000-J-00 80 6425 6570 7300 2800 BXRA-27G7000-J-00 90 5520 5640 6275 2800 BXRA-30E3500-F-00 80 2800 2835 3150 1750 BXRA-30G3500-F-00 90 2450 2475 2750 1750 BXRA-30E4000-H-00 80 4375 4420 4925 2100 BXRA-30G4000-H-00 90 3730 3775 4200 2100 BXRA-30E7000-J-00 80 6900 7050 7850 2800 BXRA-30G7000-J-00 90 5900 6030 6700 2800 BXRA-35E3500-F-00 80 3025 3060 3400 1750 BXRA-35E4000-H-00 80 4710 4750 5300 2100 BXRA-35E7000-J-00 80 7390 7550 8400 2800 BXRA-40E4000-F-00 80 3130 3170 3525 1750 BXRA-40E4500-H-00 80 5025 5075 5650 2100 BXRA-40E7500-J-00 80 7830 8010 8900 2800 BXRA-50C4500-F-00 70 3575 3620 4025 1750 BXRA-50C5300-H-00 70 5585 5640 6275 2100 BXRA-50C9000-J-00 70 8800 9000 10000 2800 BXRA-56C4500-F-00 70 3580 3620 4025 1750 BXRA-56C5300-H-00 70 5575 5640 6275 2100 BXRA-56C9000-J-00 70 8800 9000 10000 2800 Notes for Table 3: 1. Bridgelux maintains a ± 7% tolerance of flux measurements. 2. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 3. Typical performance when driven at DC (direct current) test current with LED Array case temperature maintained at 70°C, mounted to heat sink with thermal interface material. Please contact a Bridgelux sales representative for additional details. 4. Typical R9 value for 90 CRI product options is 50. 5. Reference Table 8 and 9 for typical performance at other driver currents (including those commonly available in the market). Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 8 of 28 Optical Characteristics Table 4: Optical Characteristics Color Temperature (CCT) Color ANSI CCT (K) 2700 Warm White 3000 3500 Neutral White 4000 5000 Cool White 5600 [1], [2], [3] BXRA Part Number Min BXRA-27E3500-F-00 BXRA-27G3500-F-00 BXRA-27E4000-H-00 BXRA-27G4000-H-00 BXRA-27E7000-J-00 BXRA-27G7000-J-00 BXRA-30E3500-F-00 BXRA-30G3500-F-00 BXRA-30E4000-H-00 BXRA-30G4000-H-00 BXRA-30E7000-J-00 BXRA-30G7000-J-00 BXRA-35E3500-F-00 BXRA-35E4000-H-00 BXRA-35E7000-J-00 BXRA-40E4000-F-00 BXRA-40E4500-H-00 BXRA-40E7500-J-00 BXRA-50C4500-F-00 BXRA-50C5300-H-00 BXRA-50C9000-J-00 BXRA-56C4500-F-00 BXRA-56C5300-H-00 BXRA-56C9000-J-00 2580 K 2580 K 2580 K 2580 K 2580 K 2580 K 2870 K 2870 K 2870 K 2870 K 2870 K 2870 K 3220 K 3220 K 3220 K 3700 K 3700 K 3700 K 5028 K 5028 K 5028 K 5310 K 5310 K 5310 K Typ 2725 K 2725 K 2725 K 2725 K 2725 K 2725 K 3045 K 3045 K 3045 K 3045 K 3045 K 3045 K 3465 K 3465 K 3465 K 4000 K 4000 K 4000 K 5100 K 5100 K 5100 K 5665 K 5665 K 5665 K Max 2870 K 2870 K 2870 K 2870 K 2870 K 2870 K 3220 K 3220 K 3220 K 3220 K 3220 K 3220 K 3710 K 3710 K 3710 K 4250 K 4250 K 4250 K 5665 K 5665 K 5665 K 6020 K 6020 K 6020 K Minimum Color Rendering [4] Index 80 90 80 90 80 90 80 90 80 90 80 90 80 80 80 80 80 80 70 70 70 70 70 70 Typical Viewing Angle (Degrees) 1/2 [5] 2θ 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 120 Typical Center Beam Candle Power (cd) [6] 960 810 1460 1250 2325 2000 1000 875 1560 1330 2500 2100 1080 1675 2675 1120 1800 2830 1280 2000 3180 1280 2000 3180 Notes for Table 4: 1. 2. 3. 4. 5. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. Refer to Flux Characteristic Table for test current data. Product is binned for color in x y coordinates. Viewing angle is the off axis angle from the centerline where Iv is ½ of the peak value. Center beam candle power is a calculated value based on lambertian radiation pattern at nominal test current. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 9 of 28 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Vf (V) Color Warm White Neutral White Cool White Test Current (mA) [1] Typical Coefficient of Forward Voltage (mV/ºC) ∆Vf/∆Tj Typical Thermal Resistance Junction to Case (ºC/W) Rθj-c [2] Base Part Number Min Typ Max BXRA-27E3500-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-27G3500-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-27E4000-H-00 21.2 23.5 25.9 2100 -8 to -24 0.31 BXRA-27G4000-H-00 21.2 23.5 25.9 2100 -8 to -24 0.31 BXRA-27E7000-J-00 27.5 30.5 33.6 2800 -10 to -30 0.26 BXRA-27G7000-J-00 27.5 30.5 33.6 2800 -10 to -30 0.26 BXRA-30E3500-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-30G3500-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-30E4000-H-00 21.2 23.5 25.9 2100 -8 to -24 0.31 BXRA-30G4000-H-00 21.2 23.5 25.9 2100 -8 to -24 0.31 BXRA-30E7000-J-00 27.5 30.5 33.6 2800 -10 to -30 0.26 BXRA-30G7000-J-00 27.5 30.5 33.6 2800 -10 to -30 0.26 BXRA-35E3500-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-35E4000-H-00 21.2 23.5 25.9 2100 -8 to -24 0.31 BXRA-35E7000-J-00 27.5 30.5 33.6 2800 -10 to -30 0.26 BXRA-40E4000-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-40E4500-H-00 21.2 23.5 25.9 2100 -8 to -24 0.31 BXRA-40E7500-J-00 27.5 30.5 33.6 2800 -10 to -30 0.26 BXRA-50C4500-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-50C5300-H-00 21.2 23.5 25.9 2100 -8 to -24 0.31 BXRA-50C9000-J-00 27.5 30.5 33.6 2800 -10 to -30 0.26 BXRA-56C4500-F-00 16.4 18.2 20.0 1750 -6 to -18 0.46 BXRA-56C5300-H-00 BXRA-56C9000-J-00 21.2 27.5 23.5 30.5 25.9 33.6 2100 2800 -8 to -24 -10 to -30 0.31 0.26 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tj = 25°C. Pulse width is 10 ms at rated test current. 2. Bridgelux maintains a tester tolerance of ± 0.10 V on forward voltage measurements. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 10 of 28 Absolute Minimum and Maximum Ratings Table 6: Maximum Current and Reverse Voltage Ratings Color Warm White Neutral White Cool White Base Part Number Maximum DC Forward Current (mA) Maximum Peak Pulsed Current [1] (mA) Maximum Reverse Voltage [2] (Vr) BXRA-XXX3500-F-00 BXRA-XXX4000-H-00 BXRA-XXX7000-J-00 BXRA-40X4000-F-00 BXRA-XXX4500-H-00 BXRA-XXX7500-J-00 BXRA-XXX54500-F-00 BXRA-XXX5300-H-00 BXRA-XXX9000-J-00 2250 3000 3750 2250 3000 3750 2250 3000 3750 2500 4000 5000 2500 4000 5000 2500 4000 5000 -30 -40 -50 -30 -40 -50 -30 -40 -50 Notes for Table 6: 1. Bridgelux recommends a maximum duty cycle of 10% when operating LED Arrays at the maximum peak pulsed current specified. 2. Light emitting diodes are not designed to be driven in reverse voltage. Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature 150°C Storage Temperature -40°C to +105°C Operating Case Temperature 105°C Soldering Temperature* 350°C or lower for a maximum of 3.5 seconds *See Bridgelux Application Note AN15: Reflow Soldering of Bridgelux LED Arrays for solder procedure (www.Bridgelux.com) Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 11 of 28 Typical Performance at Alternative Drive Currents Bridgelux LED Arrays may also be driven at alternative drive currents dependent on the specific application. Typical performance at any drive current can be derived from the flux vs. current characteristics (Figures 5 and 6) and current vs. voltage characteristics (Figures 10 and 11). The typical performance at common drive currents is also summarized in Tables 8 and 9. Table 8: Typical Product Performance at Alternative Drive Currents Color ANSI CCT (K) BXRA Part Number CRI BXRA-27E3500-F-00 80 BXRA-27G3500-F-00 90 BXRA-27E4000-H-00 80 BXRA-27G4000-H-00 90 BXRA-27E7000-J-00 80 BXRA-27G7000-J-00 90 BXRA-30E3500-F-00 80 BXRA-30G3500-F-00 90 BXRA-30E4000-H-00 80 BXRA-30G4000-H-00 90 BXRA-30E7000-J-00 80 BXRA-30G7000-J-00 90 Typ. Flux Tcase = 70ºC [3] (lm) Typ. Flux Tj = 25ºC (lm) Vf Forward Current [2] (mA) 2375 3130 3540 2010 2275 2710 2925 3510 4090 2520 3040 3550 4150 5000 6425 3550 4270 5520 2475 2800 3320 2150 2450 2900 3140 3780 4375 2700 3270 3730 4450 5350 6900 3825 4610 5980 2640 3525 3580 2240 2570 3050 3250 3900 4600 2800 3380 3950 4610 5620 7300 3950 4800 6270 2750 3150 3730 2400 2750 3260 3490 4200 4925 3000 3630 4200 4940 6025 7850 4250 5180 6800 18.2 18.5 18.7 18.2 18.5 18.7 22.8 23.2 23.5 22.8 23.2 23.5 29.0 29.5 30.5 29.0 29.5 30.5 18.2 18.5 18.7 18.2 18.5 18.7 22.8 23.2 23.5 22.8 23.2 23.5 29.0 29.5 30.5 29.0 29.5 30.5 1500 [1] 1750 2100 1500 [1] 1750 2100 1400 1750 [1] 2100 1400 1750 [1] 2100 1750 2100 [1] 2800 1750 2100 [1] 2800 1500 [1] 1750 2100 1500 [1] 1750 2100 1400 1750 [1] 2100 1400 1750 [1] 2100 1750 2100 [1] 2800 1750 2100 [1] 2800 2700 Warm White 3000 Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 12 of 28 Typical Performance at Alternative Drive Currents (continued) Table 9: Typical Product Performance at Alternative Drive Currents Color Warm White Neutral White ANSI CCT (K) 3500 4000 5000 BXRA Part Number CRI BXRA-35E3500-F-00 80 BXRA-35E4000-H-00 80 BXRA-35E7000-J-00 80 BXRA-40E4000-F-00 80 BXRA-40E4500-H-00 80 BXRA-40E7500-J-00 90 BXRA-50C4500-F-00 70 BXRA-50C5300-H-00 70 BXRA-50C9000-J-00 70 BXRA-56C4500-F-00 70 BXRA-56C5300-H-00 70 BXRA-56C9000-J-00 70 Typ. Flux Tcase = 70ºC [3] (lm) Typ. Flux Tj = 25ºC (lm) Vf Forward Current [2] (mA) 2650 3125 3600 3375 4100 4720 4750 5725 7390 2770 3130 3720 3600 4350 5025 5000 6100 7830 3150 3580 4240 4200 4840 5575 5600 6830 8800 3150 3580 4240 4190 4840 5575 5600 6830 8800 2950 3525 4050 3770 4550 5300 5275 6430 8400 3080 3525 4180 4010 4840 5650 5610 6840 8900 3500 4025 4770 4660 5380 6275 6300 7680 10000 3500 4025 4770 4660 5380 6275 6300 7680 10000 18.2 18.5 18.7 22.8 23.2 23.5 29.0 29.5 30.5 18.2 18.5 18.7 22.8 23.2 23.5 29.0 29.5 30.5 18.2 18.5 18.7 22.8 23.2 23.5 29.0 29.5 30.5 18.2 18.5 18.7 22.8 23.2 23.5 29.0 29.5 30.5 1500 [1] 1750 2100 1400 1750 [1] 2100 1750 2100 [1] 2800 1500 [1] 1750 2100 1400 1750 [1] 2100 1750 2100 [1] 2800 1500 [1] 1750 2100 1400 1750 [1] 2100 1750 2100 [1] 2800 1500 [1] 1750 2100 1400 1750 [1] 2100 1750 2100 [1] 2800 Cool White 5600 Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 13 of 28 Notes for Table 8 and 9: 1. Product is tested and binned at the specified drive current. 2. Operating these LED Arrays at or below the drive currents listed in Tables 7 and 8, with a case temperature maintained at or below 70°C, will enable the average lumen maintenance projection outlined earlier in this Product Data Sheet. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 14 of 28 Mechanical Dimensions Figure 1: Drawing for RS Arrays Notes for Figure 1: 1. Slots are for M2.5, M3 or #4 screws. 2. Solder pads are labeled “+” and “-“ to denote positive and negative, respectively. 3. It is not necessary to provide electrical connections to both sets of solder pads. Either set of solder pads (6.35 x 2.03 mm rectangular pads or 3.50 mm tapered square pads) may be used depending on application specific design requirements. 4. Drawings are not to scale. 5. Drawing dimensions are in millimeters. 6. Bridgelux recommends four tapped holes for mounting screws – refer to product Application Note AN11 for recommended spacing of holes. 7. Unless otherwise specified, tolerances are ± 0.10 mm. 8. Refer to product Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. 9. The optical center of the LED Array is defined by the mechanical center of the array. 10. Bridgelux maintains a flatness of 0.25 mm across the mounting surface of the array. Refer to Application Notes AN10 and AN11 for product handling, mounting and heat sink recommendations. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 15 of 28 Typical Radiation Pattern Figure 2: Typical Spatial Radiation Pattern Figure 3: Typical Polar Radiation Pattern Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 16 of 28 Wavelength Characteristics at Rated Test Current, Tj=25°C Figure 6: Typical Cool White Color Spectrum Figure 4: Typical Color Spectrum 1.2 1.0 Relative Intensity Cool White 0.8 Warm White Neutral White 0.6 0.4 0.2 0.0 400 450 500 550 600 650 700 750 800 Wavelength Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 17 of 28 Typical Relative Luminous Flux vs. Current, Tj=25°C Figure 5: Typical Flux vs. Current For 1750mA Products Normalized Luminous Flux 1.4 1.2 1.0 0.8 0.6 0.4 BXRA-xxx3500-F-00 BXRA-xxx4000-F-00 BXRA-xxx4500-F-00 0.2 0.0 0 200 400 600 800 1000 1200 1400 1600 1800 2000 2200 Current (mA) Figure 6: Typical Flux vs. Current 2100mA Products Figure For 7: Typical Flux vs. Current 2.00 1.80 Normalized Luminous Flux 1.60 1.40 1.20 1.00 0.80 BXRA-xxx4000-H-00 BXRA-W3000 BXRA-xxx4500-H-00 BXRA-N3500 BXRA-xxx5300-H-00 BXRA-C4500 0.60 0.40 0.20 0.00 0 500 1000 1500 2000 2500 3000 3500 4000 Current (mA) Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 18 of 28 Figure 7: Typical Flux vs. Current For 2800mA Products 1.8 1.6 Normalized Luminous Flux 1.4 1.2 1.0 0.8 BXRA-xxx7000-J-00 BXRA-xxx7500-J-00 BXRA-xxx9000-J-00 0.6 0.4 0.2 0.0 0 500 1000 1500 2000 2500 Current (mA) Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) 3000 3500 4000 4500 5000 5500 Page 19 of 28 Typical Light Output Characteristics vs. Temperature Figure 8: Typical FluxFlux vs. Junction Temperature Figure 9: Typical vs. Junction Temperature 1.2 Neutral White Normalized Luminous Flux 1.0 Warm White 0.8 Cool White 0.6 Warm White Neutral White 0.4 Cool White 0.2 0.0 -10 0 10 20 30 40 50 60 Junction Temperature, °C Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) 70 80 90 100 110 Page 20 of 28 Typical Chromaticity Characteristics vs. Temperature Figure9:10: Typical Shift vs. vs. Junction Junction Temperature Temperature Figure Typical ccyx Shift 0.02 Neutral White Warm White 0.01 0.00 -0.01 ∆y Cool White -0.02 -0.03 Warm White Cool White -0.04 Neutral White -0.05 -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C 70 80 90 100 110 Figure 11: Typical y Shift Junction Temperature Figure 10: Typical ccx Shift vs.vs. Junction Temperature 0.02 Neutral White 0.01 Warm White 0.00 ∆x -0.01 Cool White -0.02 -0.03 Warm White -0.04 Cool White -0.05 Neutral White -0.06 -10 0 10 20 30 40 50 60 Junction Temperature, °C Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) 70 80 90 100 110 Page 21 of 28 Forward Current Characteristics Figure 11: Current vs. Voltage BXRA-xxx3500-F-00, BXRA-xxx4000-F-00, BXRA-xxx4500-F-00 MIN Vf Tc=25°C MAX Vf Tc=25°C TYP Vf Tc=25°C MIN Vf Tc=70°C Figure 12: Current vs. Voltage BXRA-xxx4000-H-00, BXRA-xxx4500-H-00, BXRA-xxx5300-H-00 MIN Vf Tc=25°C MIN Vf Tc=70°C MAX Vf Tc=25°C TYP Vf Tc=25°C Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 22 of 28 Figure 13: Current vs. Voltage BXRA-xxx7000-J-00, BXRA-xxx7500-J-00, BXRA-xxx9000-J-00 MIN Vf Tc=25°C MIN Vf Tc=70°C Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) MAX Vf Tc=25°C TYP Vf Tc=25°C Page 23 of 28 Color Binning Information 37 10 K 0.42 0.41 32 20 K R3 Q3 P3 3500K 3SDCM N3 P4 2700K 3SDCM T4 S4 R4 0.39 0.38 T3 S3 Q4 27 25 K 0K N4 0.37 0.36 0.35 0.38 0.4 0.42 25 8 Y 0.4 34 65 K 0.43 30 45 K 3000K 3SDCM 0.44 28 70 K Figure 14: Graph of Warm White Test Bins in xy Color Space 0.44 0.46 0.48 X Table 10: Warm White xy Bin Coordinates and Associated Typical CCT Bin Code Q3 Q4 R3 R4 X3 (3SDCM) X Y 0.4223 0.4299 0.4431 0.4345 0.4147 0.4223 0.4345 0.4260 0.4345 0.4431 0.4562 0.4468 0.4260 0.4345 0.4468 0.4373 0.4413 0.4325 0.4274 0.4350 0.3990 0.4165 0.4213 0.4033 0.3814 0.3990 0.4033 0.3854 0.4033 0.4213 0.4260 0.4077 0.3854 0.4033 0.4077 0.3893 0.4107 0.4075 0.3958 0.3984 ANSI CCT (K) Bin Code 3000 S3 3000 S4 3000 T4 3000 T3 3000 X3 (3SDCM) X Y 0.4468 0.4562 0.4688 0.4585 0.4373 0.4468 0.4585 0.4483 0.4585 0.4688 0.4813 0.4703 0.4483 0.4585 0.4703 0.4593 0.4656 0.4573 0.4510 0.4583 0.4077 0.4260 0.4290 0.4104 0.3893 0.4077 0.4104 0.3919 0.4104 0.4290 0.4319 0.4132 0.3919 0.4104 0.4132 0.3944 0.4174 0.4154 0.4032 0.4049 Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) ANSI CCT (K) Bin Code 2700 N4 2700 N3 2700 P3 2700 P4 2700 X3 (3SDCM) X Y 0.3943 0.3996 0.4148 0.4083 0.3889 0.3943 0.4083 0.4018 0.4083 0.4148 0.4299 0.4223 0.4018 0.4083 0.4223 0.4147 0.4148 0.4047 0.4012 0.4098 0.3853 0.4015 0.4090 0.3921 0.3690 0.3853 0.3921 0.3752 0.3921 0.4090 0.4165 0.3990 0.3752 0.3921 0.3990 0.3814 0.4000 0.3950 0.3841 0.3883 Page 24 of 28 ANSI CCT (K) 3500 3500 3500 3500 3500 Color Binning Information (continued) Figure 15: Graph of Neutral White Test Bins in xy Color Space 0.41 0.40 Y M3 4000K 3SDCM 0.39 0.38 L3 M4 0.37 L4 0.36 0.35 0.36 0.37 0.38 0.39 0.40 0.41 Z Table 11: Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code L3 L4 M3 M4 X3 (3SDCM) X Y 0.3703 0.3736 0.3871 0.3828 0.3670 0.3703 0.3828 0.3784 0.3828 0.3871 0.4006 0.3952 0.3784 0.3828 0.3952 0.3898 0.3881 0.3791 0.3769 0.3845 0.3726 0.3874 0.3959 0.3803 0.3578 0.3726 0.3803 0.3647 0.3803 0.3959 0.4044 0.3880 0.3647 0.3803 0.3880 0.3716 0.3879 0.3823 0.3724 0.3770 Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) ANSI CCT (K) 4000 4000 4000 4000 4000 Page 25 of 28 Color Binning Information (continued) Figure 16: Graph of Cool White Test Bins in xy Color Space 5665K 0.38 K 60 20 0.37 0.36 H3 G3 H4 0.35 G4 K E3 0.34 F4 5310K 0.33 5 02 8 K E4 47 4 5 Y F3 0.32 0.31 0.32 0.33 0.34 0.35 0.36 X Table 12: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code G3 G4 H3 H4 X Y 0.3376 0.3464 0.3452 0.3371 0.3371 0.3452 0.3441 0.3366 0.3464 0.3551 0.3533 0.3452 0.3452 0.3533 0.3515 0.3441 0.3616 0.3688 0.3558 0.3493 0.3493 0.3558 0.3428 0.3369 0.3688 0.376 0.3624 0.3558 0.3558 0.3624 0.3487 0.3428 ANSI CCT (K) Bin Code 5000 E3 5000 E4 5000 F3 5000 F4 Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) X Y 0.3215 0.3293 0.3292 0.3207 0.3222 0.3294 0.3293 0.3215 0.3292 0.3293 0.3371 0.3376 0.3294 0.3366 0.3371 0.3293 0.3353 0.3423 0.3539 0.3462 0.3243 0.3306 0.3423 0.3353 0.3539 0.3423 0.3493 0.3616 0.3306 0.3369 0.3493 0.3423 ANSI CCT (K) 5600 5600 5600 5600 Page 26 of 28 Design Resources Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with Bridgelux LED Array products. Included below is a list of available resources which can be downloaded from the Bridgelux web site under the Design Resources section. These documents are updated regularly as new information becomes available, including complimentary infrastructure products such as commercially available secondary optics and electronic driver solutions. Application Notes • • • • • • AN10: AN11: AN12: AN14: AN15: AN16: Effective Thermal Management of Bridgelux LED Arrays Assembly Considerations for Bridgelux LED Arrays Electrical Drive Considerations for Bridgelux LED Arrays Reliability Data Sheet for Bridgelux LED Arrays Reflow Soldering of Bridgelux LED Arrays Optical Considerations for Bridgelux LED Arrays Optical Source Models Optical source models and ray set files are available for all Bridgelux LED Array products, and can be downloaded directly from the Bridgelux web site. The list below contains the formats currently available. If you require a specific format not included in this list, please contact your Bridgelux sales representative for assistance. • • • • • • • • • Zemax ASAP IESNA LightTools LucidShape OPTIS SPEOS PHOTOPIA TracePro Radiant Imaging Source Model 3D CAD Models Three dimensional CAD models depicting the product outline of all Bridgelux LED Arrays are available in both SAT and STEP formats. These CAD files can be downloaded directly from the Bridgelux web site. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 27 of 28 About Bridgelux Bridgelux is a leading developer and manufacturer of technologies and solutions transforming the $40 billion global lighting industry into a $100 billion market opportunity. Based in Livermore, California, Bridgelux is a pioneer in solid-state lighting (SSL), expanding the market for light-emitting diode (LED) technologies by driving down the cost of LED lighting systems. Bridgelux’s patented light source technology replaces traditional technologies (such as incandescent, halogen, fluorescent and high intensity discharge lighting) with integrated, solid-state lighting solutions that enable lamp and luminaire manufacturers to provide high performance and energy-efficient white light for the rapidly growing interior and exterior lighting markets, including street lights, commercial lighting and consumer applications. With more than 650 patent applications filed or granted worldwide, Bridgelux is the only vertically integrated LED manufacturer and developer of solid-state light sources that designs its solutions specifically for the lighting industry. For more information about the company, please visit www.bridgelux.com © 2012 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux RS Array Series Product Data Sheet DS25 (10/17/2012) Page 28 of 28
BXRA-30E3500-F-00 价格&库存
很抱歉,暂时无法提供与“BXRA-30E3500-F-00”相匹配的价格&库存,您可以联系我们找货
