SST-90-W45S-F11-GL401 数据手册
SST-90 Product Datasheet
SST-90 LEDs
Table of Contents
Technology Overview. . . . . . 2
Features:
• Extremely high optical output:
Over 2,100 White Lumens
Over 500 Red Lumens
Over 950 Green Lumens
Over 200 Blue Lumens
Test Specifications . . . . . . . . . 2
White Binning Structure. . . . 3
White Chromaticity Bins. . . . 4
Monochromatic Binning
structure. . . . . . . . . . . . . . . . . . . 8
Product Shipping &
Labeling Information. . . . . . . 9
Electrical Characteristics. . 10
SST-90 W Lifetime & Lumen
Maintenance. . . . . . . . . . . . . . 11
Spectral Characteristics. . . 11
SST-90- RGB Electrical
Characteristics. . . . . . . . . . . . 12
• Extremely high efficiency: Over 100 lumens per watt at 3.15A for white
• High thermal conductivity package - junction to case thermal resistance of only
0.64 °C/W
• Large, monolithic chip with uniform emitting area of 9 mm2
• Lumen maintenance of greater than 70% after 60,000 hours
• Environmentally friendly: RoHS compliant
• Variable drive currents: less than 1 A through 9 A
• High reliability
• Electrically isolated thermal path
Applications
• Replacement Lamps
• High Bay Lighting
• Architectural Lighting
• Wide Area Lighting
• Retail Lighting
• Street Lighting
Thermal Resistance . . . . . . . 17
• Residential Lighting
• Medical Lighting
Mechanical Dimensions . . . 18
• Consumer Portable
• Emergency Vehicle Lighting
• Spot Lighting
• Displays and Signage
Radiation Patterns . . . . . . . . 17
Solder Profile . . . . . . . . . . . . . 20
Ordering Information . . . . . 21
1
PDS-001342Rev 09
© 2011 Luminus Devices, Inc. - All Rights Reserved
Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com
1100 Technology Park Drive • Billerica, MA 01821
Technology Overview
Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These
breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency.
Photonic Lattice Technology
and longer lifetimes.
Luminus’ photonic lattice technology enables large area LED
chips with uniform brightness over the entire LED chip surface.
The optical power and brightness produced by these large
monolithic chips enable solutions which replace arc and
halogen lamps where arrays of traditional high power LEDs
cannot.
Reliability
For red, green and blue LEDs, the photonic lattice structures
extract more light and create radiation patterns that are more
collimated than traditional LEDs. Having higher collimation
from the source increases optical collection efficiencies and
simplifies optical designs.
Designed from the ground up, Luminus Big Chip LEDs are one of
the most reliable light sources in the world today. Big Chip LEDs
have passed a rigorous suite of environmental and mechanical
stress tests, including mechanical shock, vibration, temperature
cycling and humidity, and have been fully qualified for use in
extreme high power and high current applications. With very
low failure rates and median lifetimes that typically exceed
60,000 hours, Luminus Big Chip LEDs are ready for even the
most demanding applications.
Environmental Benefits
Packaging Technology
Thermal management is critical in high power LED applications.
With a thermal resistance from junction to case of
0.64º C/W. Luminus SST-90 LEDs have the lowest thermal
resistance of any LED on the market. This allows the LED to be
driven at higher current densities while maintaining a low
junction temperature, thereby resulting in brighter solutions
Luminus LEDs help reduce power consumption and the amount
of hazardous waste entering the environment. All Big Chip LED
products manufactured by Luminus are RoHS compliant and
free of hazardous materials, including lead and mercury.
Understanding Big Chip LED Test Specifications
Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products.
Testing Temperature
Multiple Operating Points (3.15, 6.3, 9.0 A)
Luminus core board products are typically measured in such a
way that the characteristics reported agree with how the
devices will actually perform when incorporated into a system.
This measurement is accomplished by mounting the devices on
a 40ºC heat sink and allowing the device to reach thermal
equilibrium while fully powered. Only after the device reaches
equilibrium are the measurements taken. This method of
measurement ensures that Luminus Big Chip LEDs perform in
the field just as they are specified.
The tables on the following pages provide typical optical and
electrical characteristics. Since the LEDs can be operated over a
wide range of drive conditions (currents from less than 1.0 A to
9.0 A, and duty cycle from
SST-90-W45S-F11-GL401 价格&库存
很抱歉,暂时无法提供与“SST-90-W45S-F11-GL401”相匹配的价格&库存,您可以联系我们找货
