SSR-90-WCLS-R11-L3450
    LUMINUS(朗明纳斯)
    Module
    BIG CHIP LED HB MODULE WHITE
SSR-90-WCLS-R11-L3450 数据手册
SST-90 Product Datasheet SST-90 LEDs Table of Contents Technology Overview. . . . . . 2 Features: • Extremely high optical output: Over 2,100 White Lumens Over 500 Red Lumens Over 950 Green Lumens Over 200 Blue Lumens Test Specifications . . . . . . . . . 2 White Binning Structure. . . . 3 White Chromaticity Bins. . . . 4 Monochromatic Binning structure. . . . . . . . . . . . . . . . . . . 8 Product Shipping & Labeling Information. . . . . . . 9 Electrical Characteristics. . 10 SST-90 W Lifetime & Lumen Maintenance. . . . . . . . . . . . . . 11 Spectral Characteristics. . . 11 SST-90- RGB Electrical Characteristics. . . . . . . . . . . . 12 • Extremely high efficiency: Over 100 lumens per watt at 3.15A for white • High thermal conductivity package - junction to case thermal resistance of only 0.64 °C/W • Large, monolithic chip with uniform emitting area of 9 mm2 • Lumen maintenance of greater than 70% after 60,000 hours • Environmentally friendly: RoHS compliant • Variable drive currents: less than 1 A through 9 A • High reliability • Electrically isolated thermal path Applications • Replacement Lamps • High Bay Lighting • Architectural Lighting • Wide Area Lighting • Retail Lighting • Street Lighting Thermal Resistance . . . . . . . 17 • Residential Lighting • Medical Lighting Mechanical Dimensions . . . 18 • Consumer Portable • Emergency Vehicle Lighting • Spot Lighting • Displays and Signage Radiation Patterns . . . . . . . . 17 Solder Profile . . . . . . . . . . . . . 20 Ordering Information . . . . . 21 1 PDS-001342Rev 09 © 2011 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 978.528.8000 • www.luminus.com 1100 Technology Park Drive • Billerica, MA 01821 SST-90 Product Datasheet Technology Overview Luminus Big Chip LEDs™ benefit from a suite of innovations in the fields of chip technology, packaging and thermal management. These breakthroughs allow illumination engineers and designers to achieve solutions that are high brightness and high efficiency. Photonic Lattice Technology and longer lifetimes. Luminus’ photonic lattice technology enables large area LED chips with uniform brightness over the entire LED chip surface. The optical power and brightness produced by these large monolithic chips enable solutions which replace arc and halogen lamps where arrays of traditional high power LEDs cannot. Reliability For red, green and blue LEDs, the photonic lattice structures extract more light and create radiation patterns that are more collimated than traditional LEDs. Having higher collimation from the source increases optical collection efficiencies and simplifies optical designs. Designed from the ground up, Luminus Big Chip LEDs are one of the most reliable light sources in the world today. Big Chip LEDs have passed a rigorous suite of environmental and mechanical stress tests, including mechanical shock, vibration, temperature cycling and humidity, and have been fully qualified for use in extreme high power and high current applications. With very low failure rates and median lifetimes that typically exceed 60,000 hours, Luminus Big Chip LEDs are ready for even the most demanding applications. Environmental Benefits Packaging Technology Thermal management is critical in high power LED applications. With a thermal resistance from junction to case of 0.64º C/W. Luminus SST-90 LEDs have the lowest thermal resistance of any LED on the market. This allows the LED to be driven at higher current densities while maintaining a low junction temperature, thereby resulting in brighter solutions Luminus LEDs help reduce power consumption and the amount of hazardous waste entering the environment. All Big Chip LED products manufactured by Luminus are RoHS compliant and free of hazardous materials, including lead and mercury. Understanding Big Chip LED Test Specifications Every Luminus LED is fully tested to ensure that it meets the high quality standards expected from Luminus’ products. Testing Temperature Multiple Operating Points (3.15, 6.3, 9.0 A) Luminus core board products are typically measured in such a way that the characteristics reported agree with how the devices will actually perform when incorporated into a system. This measurement is accomplished by mounting the devices on a 40ºC heat sink and allowing the device to reach thermal equilibrium while fully powered. Only after the device reaches equilibrium are the measurements taken. This method of measurement ensures that Luminus Big Chip LEDs perform in the field just as they are specified. The tables on the following pages provide typical optical and electrical characteristics. Since the LEDs can be operated over a wide range of drive conditions (currents from less than 1.0 A to 9.0 A, and duty cycle from
物料型号:Luminus SST-90系列大芯片LED
器件简介: - 该系列产品提供高亮度和高效率的照明解决方案,采用创新的芯片技术、封装技术和热管理技术。 - 拥有光子晶格技术和低热阻封装,提供高光学输出和高热导率。 - 产品符合RoHS标准,无铅和汞等有害物质。
引脚分配:文档中未明确提供引脚分配图,但提到了SST-90为表面贴装(SMD)封装。
参数特性: - 白光型号提供超过2100流明的光输出,红、绿、蓝型号分别提供500、950和200流明。 - 高效率,白光在3.15A电流下超过100流明/瓦。 - 热阻仅为0.64°C/W,有助于在高电流密度下维持低结温。
功能详解: - 产品经过严格的环境和机械应力测试,具有高可靠性。 - 可变驱动电流,从不到1A到9A。 - 电热隔离路径。
应用信息: - 适用于替换灯、高棚照明、建筑照明、大面积照明、零售照明、街道照明、住宅照明、医疗照明、便携式消费电子、紧急车辆照明、聚光灯和显示屏等。
封装信息: - 提供了详细的机械尺寸图,包括发光面积、发光区域尺寸、动态电阻、光度和辐射度的热系数、结电压的热系数等。 - 提供了热阻数据,包括从结到外壳的热阻。
订购信息: - 提供了详细的订购型号和描述,包括不同色温和CRI的白色LED,以及红、绿、蓝LED的订购型号。
注意事项: - 产品规格和信息如有变更,Luminus Devices不另行通知。 - 文档中提到的产品受美国专利保护,并在其他国家有待批专利。
SSR-90-WCLS-R11-L3450 价格&库存
很抱歉,暂时无法提供与“SSR-90-WCLS-R11-L3450”相匹配的价格&库存,您可以联系我们找货
